SP45Y000000
SP45Y000000
    APEM(埃斐)
    SWITCH PUSH DPDT 0.1A 30V
SP45Y000000 数据手册
PANEL SWITCHES - SW 01 18 SP SP series Washable snap-action pushbutton switches DISTINCTIVE FEATURES Process sealed Front and rear sealing Process compatible (plain bushing models) Wave solderable Washable ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - gold plated brass contacts : 100 mA 30 VDC - silver or gold plated silver contacts : 1 A 30 VDC • Initial contact resistance : 50 mΩ max. • Insulation resistance : 1,000 MΩ min. • Dielectric strength : 1,000 Vrms 50 Hz min. • Electrical life : 60,000 cycles ENVIRONMENTAL SPECIFICATIONS • Operating temperature : -20 °C to +85 °C (-4 °F to +185 °F) • Storage temperature : -40 °C to +85 °C (-40 °F to +185 °F) • Moisture : The insulating materials employed and the complete seal permit the switches to withstand a 56 days moisture test (IEC 68-2-3). • Solderability : The switches are tested at 235°C according to IEC 68-2-20 after accelerated aging. GENERAL SPECIFICATIONS • Torque : 0.25 Nm (.18 Ft.lb) applied to nut (threaded bushing) • Total travel : 0.50 mm (.019) • Mechanical strength : Terminals are strengthened by a bracket or a ground plate ensuring the rigidity of the switch on the board. Actuator strength is 10 N max. • Soldering - thermal shock (plain bushing models only) : The switches are especially designed for flow soldering at 260 °C (500 °F) during 5 seconds owing to high temperature polymer parts. • Iron soldering (threaded bushing models) : 300 °C (572 °F) max., 5 seconds max. The company reserves the right to change specifications without notice. 1 Washable snap-action pushbutton switches MATERIALS TERMINALS • Case and cover : UL94-V0, polyamide, glass filled or PES 1.10 (.043) 1.90 (.070) 1.90 (.074) • Contacts 0 : brass, gold plated 1 : silver 2 : silver, gold plated 4.25 (.167) • Actuator : polyamide, glass filled 2.45 (.096) PANEL SWITCHES SP series 0.60 (.023) • Terminal seal : epoxy APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. ELECTRICAL FUNCTIONS AGENCY APPROVAL 1 A 120 VAC Availability : all models with silver or gold plated silver contacts. Marking : to order switches marked UL , complete appropriate box of ordering format. 1 2 3 PANEL CUT-OUT 2 Washable snap-action pushbutton switches BUILD YOUR PART NUMBER BASIC PART NUMBER SP SERIES ELECTRICAL FUNCTION NUMBER OF POLES 5 3 Single pole 4 Double pole ON - MOM TERMINALS P0 Straight PC Y0 Straight PC and bracket mounting W0 Right angle, horizontal mounting WW Right angle, vertical mounting S0 Solder lug terminals, (threaded bushing) OPTIONS PLUNGERS CONTACT AND TERMINAL MATERIALS 0 Brass, gold plated 1 Silver 2 Silver, gold plated OPTIONS/APPROVAL CAPS (MOUNTED) 00 Standard 00 Standard model 10 Ø 5 (.196) 02 Short 01 UL marking on standard model 20 Ø 8 (.314) 30 Ø 9,4 (.370) 02 UL marking on threaded bushing model (SP only) 40 Ø 10 (.393) 76 Short bushing for plunger 02 (SP only) 80 Ø 15 (.590) 77 Threaded bushing 70 Square Height 4 (.157) 50 Square Height 6 (.236) ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories : Standard hardware supplied with all models with Ø 6.35 (1/4) threaded bushing : 2 hex nuts 8 mm (.314) across flats, 1 locking ring and 1 lockwasher. Standard and special hardware available is presented in the "Accessories" section of website. 3 PANEL SWITCHES SP series Washable snap-action pushbutton switches Shown with standard plunger 5.30 (.208) 7.16 (.281) ¯6.20 (.244 DIA) 6.30 (.248) ¯3.10 (.122 DIA) ON MOM Double pole SP45P0... 00 ON MOM 11.35 (.446) 12.70 (.500) 1 2 3 EPOXY 0.60 (.023) 0.60 (.023) 4.75 (.187) 4.75 (.187) 4.70 (.185) 5.30 (.208) 3.18 (.125) SP45Y0... 00 ON MOM 0.90 (.035) 15.75 (.620) 4.75 (.187) 5.08 (.200) ¯3.10 (.122 DIA) ¯6.20 (.244 DIA) 5.30 (.208) SP35W0... 00 ON MOM Double pole SP45W0... 00 EPOXY 3.90 (.153) 6.90 (.271) 0.40 (.015) 3 2 1 5.08 (.200) 0.60 (.023) 4.70 (.185) ¯1.60 (.062 DIA) 12.70 (.500) MOM 3.81 (.150) ON Single pole 4.70 (.185) 0.60 (.023) 1-2 9.50 (.374) 12.70 (.500) 1-3 11.65 (.468) 3.90 (.153) 4.70 (.185) PLAIN BUSHING - RIGHT ANGLE TERMINALS VERTICAL 1-3 1-2 ON MOM ON MOM Single pole SP35WW... 00 Double pole SP45WW... 00 4 15.75 (.620) 4.70 (.185) 8.20 (.322) 6.10 (.240) PLAIN BUSHING -RIGHT ANGLE TERMINALS HORIZONTAL 0.40 (.015) 3.18 (.125) 12.70 (.500) Double pole EPOXY 3.18 (.125) 12.70 (.500) MOM 3 3.81 (.150) ON 2 4.70 (.185) SP35Y0... 00 1 7.16 (.281) Single pole Ø1.60 (.062 DIA) 11.35 (.446) 11.70 (.460) 1-2 4.40 (.173) 1-3 5.90 (.232) 15.75 (.620) 7.16 Ø6.20 (.244 DIA) (.281) Ø3.10 (.122 DIA) 4.70 (.185) PLAIN BUSHING - BRACKET MOUNTING 4.70 (.185) SP35P0... 00 6.60 (.259) 10.80 (.425) 1-2 4.25 (.167) 1-3 Single pole ¯1.60 (.062 DIA) 4.70 (.185) PLAIN BUSHING -STRAIGHT PC TERMINALS 12.70 (.500) PANEL SWITCHES SP series Washable snap-action pushbutton switches 1-2 ON MOM 1 EPOXY 1.80 (.070) 2 3 0.60 (.023) 4.70 (.185) THREADED BUSHING - STRAIGHT PC TERMINALS ON MOM 1 3 EPOXY Single pole SP35P0... 77 2 10.80 (.425) 12.70 (.500) 6.60 (.259) 1-2 8.90 (.350) Ø3.10 (.122 DIA) Ø6.35-40UNS (1/4 40UNS) 1-3 4.56 (.179) KEYWAY 0.60 (.023) 0.60 (.023) 4.70 (.185) 4.25 (.167) SP35S0... 77 12.70 (.500) 6.60 (.259) 10.80 (.425) 1-3 Single pole 8.90 (.350) Ø3.10 (.122 DIA) Ø6.35-40UNS (1/4 40UNS) 2.45 (.096) THREADED BUSHING - SOLDER LUG TERMINALS 4.56 (.179) Shown with standard plunger KEYWAY Ø1.60 (.062 DIA) 4.70 (.185) CONTACT & TERMINAL MATERIALS BASIC P/N 0 1 2 Brass, gold plated (standard) Silver Silver, gold plated PLUNGERS ¯3.10 (.122 DIA) ¯3.10 (.122 DIA) 7.16 (.281) 4.20 (.165) 5.10 (.200) 6.30 (.248) ¯3.10 (.122 DIA) 8.90 (.350) 00 Standard plunger 02 Short (for models with plain bushing, single pole only) Order with option 76 below. 4.56 (.179) BASIC P/N 00 02 5 PANEL SWITCHES SP series Washable snap-action pushbutton switches OPTIONS / AGENCY APPROVAL BASIC P/N 00 Standard model 01 UL marking for standard model 02 UL marking for threaded bushing model (single pole models only) 76 Short plain bushing for 02 plunger (single pole models only) 77 Threaded bushing (included in basic part numbers on previous page) CAPS BASIC P/N Blank 10 20 30 40 50 70 80 Without cap P/N U2400 P/N U2510 P/N U2130 Standard - P/N U2900 Square - P/N U2340. Not available with plunger 02 Square - P/N U910 P/N U3400. Not available with plunger 02 For cap colors, replace «0» with number : 1 Blue 1/4 Dark blue 2 Black 3 Green 4 Grey 5 Yellow 6 Red 7 Ivory 7/1 White 9 Orange To order caps separately, use their P/N (U...) (for threaded bushing order only separately). ¯8.00 (.314 DIA) ¯10.00 (.393 DIA) ¯9.40 (.370 DIA) 10 20 11.50x11.50 (.452 SQ) 3.00 (.118) 6.35 (.250) 3.30 (.129) 3.00 (.118) 4.00 (.157) 3.30 (.129) 6.35 (.250) 7.50 (.295) ¯5.00 (.196 DIA) 30 40 ¯15.00 (.590 DIA) 50 6 70 3.50 (.137) 4.00 (.157) 2.70 (.106) 10.00 (.393) 11.50x11.50 (.452 SQ) 6.00 (.236) 5.00 (.196) PANEL SWITCHES SP series 80 Washable snap-action pushbutton switches DRESS NUT For threaded bushing models only Dress nuts are to be ordered separately. 8.20 (.322) 8.00 (.314) ¯6.35-40UNS (1/4-40UNS) ¯6.35-40UNS (1/4-40UNS) U1636 For cap U2510 ¯10.50 (.413 DIA) 5.80 (.228) ¯15.50 (.610 DIA) 8.00 (.314) ¯8.20 (.322 DIA) ¯13.50 (.531 DIA) 5.80 (.228) ¯18.50 (.728 DIA) 6.20 (.244) ¯12.70 (.500 DIA) U825 For cap U3400 ¯6.35-40UNS (1/4-40UNS) U840 For cap U2900 7 PANEL SWITCHES SP series Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: SP45W000000 SP35W000000 SP35P000077 SP35W00000026 SP35WW0000026 SP45W020000 SP35P000000 SP35S000077 SP35W010000 SP35WW00000 SP35WW10000 SP35WW20000 SP35Y000000 SP45P000000 SP45Y000000 SP00043BR SP03102D SP09268A SP09273B SP10286B SP09275A SP09271A SP09272A SP35S01000282 SP45W02000142 SP35WW00276 SP35WW0000110 SP35WW1000110 SP35W02000112
SP45Y000000 价格&库存
很抱歉,暂时无法提供与“SP45Y000000”相匹配的价格&库存,您可以联系我们找货
