4N35S-TA1
4N35S-TA1
    LITE-ON(光宝)
    OC-6P_7.3X6.5MM_SM
    单向光耦 Viso=3550Vrms VF(typ)=1.2V IF=60mA Vo=30V CTR=100%
4N35S-TA1 数据手册
Photocoupler Product Data Sheet 4N35/ 4N37 (M, S, S-TA1) Spec No.: DS-70-99-0012 Effective Date: 12/13/2011 Revision: C LITE-ON DCC RELEASE BNS-OD-FC001/A4 LITE-ON Technology Corp. / Optoelectronics No.90,Chien 1 Road, Chung Ho, New Taipei City 23585, Taiwan, R.O.C. Tel: 886-2-2222-6181 Fax: 886-2-2221-1948 / 886-2-2221-0660 http://www.liteon.com/opto LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only FEATURES * High crrent transfer ratio ( CTR : MIN. 100% at IF = 10mA, VCE = 10V ) * Response time ( ton : TYP. 3s at VCC = 10V, IC = 2mA, RL = 100 ) * Input-output isolation voltage 4N35 series : Viso = 3,550Vrms 4N37 series : Viso = 1,500Vrms * Dual-in-line package : 4N35, 4N37 * Wide lead spacing package : 4N35M, 4N37M * Surface mounting package : 4N35S, 4N37S * Tape and reel packaging : 4N35S-TA1, 4N37S-TA1 * Safety approval UL& cUL, VDE, FIMKO, CQC approved * RoHS compliant Part No. : 4N35 / 4N37 ( M, S, S-TA1 ) (Rev.- October 17 2011) BNS-OD-C131/A4 Page : 1 of 11 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS 4N35 : 4N37 : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked (Y : Thailand, X : China-TJ, W : China-CZ) Part No. : 4N35 / 4N37 ( M, S, S-TA1 ) (Rev.- October 17 2011) BNS-OD-C131/A4 Page : 2 of 11 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS 4N35M : 4N37M : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked (Y : Thailand, X : China-TJ, W : China-CZ) Part No. : 4N35 / 4N37 ( M, S, S-TA1 ) (Rev.- October 17 2011) BNS-OD-C131/A4 Page : 3 of 11 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS 4N35S : 4N37S : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked (Y : Thailand, X : China-TJ, W : China-CZ) Part No. : 4N35 / 4N37 ( M, S, S-TA1 ) (Rev.- October 17 2011) BNS-OD-C131/A4 Page : 4 of 11 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only TAPING DIMENSIONS 4N35S-TA1 , 4N37S-TA1 : Description Tape wide Pitch of sprocket holes Distance of compartment Distance of compartment to compartment Symbol W P0 F P2 P1 Part No. : 4N35 / 4N37 ( M, S, S-TA1 ) (Rev.- October 17 2011) BNS-OD-C131/A4 Dimensions in mm ( inches ) 16  0.3 ( .63 ) 4  0.1 ( .15 ) 7.5  0.1 ( .295 ) 2  0.1 ( .079 ) 12  0.1 ( .472 ) Page : 5 of 11 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only ABSOLUTE MAXIMUM RATING ( Ta = 25C ) PARAMETER INPUT OUTPUT SYMBOL RATING UNIT Forward Current IF 60 mA Reverse Voltage VR 6 V Power Dissipation P 100 mW Collector - Emitter Voltage VCEO 30 V Emitter - Collector Voltage VECO 7 V Collector - Base Voltage VCBO 70 V Collector Current IC 100 mA Collector Power Dissipation PC 300 mW Ptot 350 mW Total Power Dissipation 4N35 series *1 Isolation Voltage 3550 Viso 4N37 series Vrms 1500 Operating Temperature Topr -55 ~ +100 C Storage Temperature Tstg -55 ~ +150 C Tsol 260 C *2 Soldering Temperature *1. AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector, emitter and base on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2. For 10 Seconds Part No. : 4N35 / 4N37 ( M, S, S-TA1 ) (Rev.- October 17 2011) BNS-OD-C131/A4 Page : 6 of 11 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only ELECTRICAL - OPTICAL CHARACTERISTICS ( Ta = 25C ) PARAMETER INPUT SYMBOL MIN. TYP. MAX. UNIT CONDITIONS Forward Voltage VF — 1.2 1.5 V IF=10mA Reverse Current IR — — 10 A VR=4V Terminal Capacitance Ct — 50 — pF V=0, f=1KHz — — 50 nA VCE=10V, IF=0 — — 500 A VCE=30V, IF=0 Collector Dark Current Ta=25C ICEO Ta=100C Collector-Emitter Breakdown Voltage BVCEO 30 — — V IC=0.1mA IF=0 Emitter-Collector Breakdown Voltage BVECO 7 — — V IE=10A IF=0 Collector-Base Breakdown Voltage BVCBO 70 — — V IC=0.1mA IF=0 IC 10 — — mA CTR 100 — — % Collector-Emitter Saturation Voltage VCE(sat) — — 0.3 V IF=50mA IC=2mA Isolation Resistance Riso —  DC500V 40 ~ 60% R.H. Floating Capacitance Cf — 1 2.5 pF V=0, f=1MHz Response Time (Turn-on) ton — 3 10 s Response Time (Turn-off) toff — 3 10 s OUTPUT Collector Current * Current Transfer Ratio TRANSFER 51010 11011 CHARACTERISTICS * CTR  IC IF=10mA VCE=10V VCC=10V, IC=2mA RL=100  100% IF Part No. : 4N35 / 4N37 ( M, S, S-TA1 ) (Rev.- October 17 2011) BNS-OD-C131/A4 Page : 7 of 11 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only CHARACTERISTICS CURVES F ig .1 F o rw a rd C u rre n t vs. A m b ie n t F ig .2 C o lle cto r P o w e r D issip a tio n vs. T e m p e ra tu re A m b ie n t T e m p e ra tu re C o llec to r Po w er d issip atio n Pc (m W) Fo rw ard c urrent I F (m A) 100 80 60 40 20 0 -55 -25 0 25 50 75 400 300 200 100 0 -55 100 125 -25 0 25 50 75 100 125 o o Am b ient tem p erature Ta ( C ) Am b ient tem p erature Ta ( C ) F ig .3 F o rw a rd C u rre n t vs. F o rw a rd F ig .4 C u rre n t T ra n sfe r R a tio vs. V o lta g e F o rw a rd C u rre n t 500 C urrent transfer ratio C TR (%) Fo rw ard c urrent I F(m A) o Ta= 75 C o 50 C 200 o 25 C o 0 C o -25 C 100 50 20 10 5 2 160 0.5 1.0 1.5 2.0 2.5 o Ta= 25 C 140 120 100 R = 80 60 40 20 100k 0 0.1 0.2 0.5 1 1 0 V = 10V 3.0 Fo rw ard vo ltag e V F (V) 100k 2 5 10 20 50 100 Fo rw ard c urrent I F (m A) F ig .5 C o lle cto r C u rre n t vs. F ig .6 R e la tive C u rre n t T ra n sfe r R a tio C o lle cto r-e m itte r V o lta g e vs. A m b ie n t T e m p e ra tu re o Ta= 25 C 30 C o llec to r c urrent Ic (m A) 10m A 20 5m A 10 2m A Relative c urrent transfer ratio (%) 150 Pc (M AX.) I F= 15m A I F = 10m A VC E = 10V 100 50 0 0 0 5 10 15 -55 -25 0 25 50 75 100 o C o llec to r-em itter vo ltag e V (V) Part No. : 4N35 / 4N37 ( M, S, S-TA1 ) (Rev.- October 17 2011) BNS-OD-C131/A4 Am b ient tem p erature Ta ( C ) Page : 8 of 11 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only CHARACTERISTICS CURVES Fig .7 C o llec to r-em itter Saturatio n Vo ltag e Fig .8 C o llec to r D ark C urrent vs. vs. Am b ient Tem p erature Am b ient Tem p erature -6 10 I F = 50m A 5 C o llec to r d ark c urrent I C EO (A) C o llec to r-em itter saturatio n vo ltag e V (sat) (V) 0.12 Ic = 2m A 0.10 0.08 0.06 0.04 0.02 V = 10V -7 10 5 -8 10 5 -9 10 5 -10 10 5 -11 10 5 -12 10 5 -13 0 -55 10 -25 0 25 50 75 100 -55 -25 20 40 60 100 100 125 o o Am b ient tem p erature Ta ( C ) Am b ient tem p erature Ta ( C ) Fig .9 Resp o nse Tim e vs. Lo ad Fig .10 Freq uenc y Resp o nse Resistanc e 200 5 V = 10V Ic = 2m A o Ta= 25 C V = 5V Ic = 2m A o Ta= 25 C tf tr Vo ltag e g ain Av (d B ) Resp o nse tim e ( s) 100 50 td 20 10 5 2 ts 1 0 -5 R L = 10k 100 -10 1k -15 0.5 0.2 0.05 -20 0.1 0.2 0.5 1 2 5 10 20 Lo ad resistanc e R L (k 50 0.5 1 2 5 ) 10 20 50 100 200 500 Freq uenc y f (kH z) Fig .11 C o llec to r-em itter Saturatio n Test C irc uit fo r Resp o nse Tim e Vo ltag e vs. Fo rw ard C urrent C o llec to r-em itter saturatio n vo ltag e VC E (sat) 7 Ic = 0.5m A 1m A 6 Vc c Inp ut O utp ut o Ta= 25 C Inp ut RD RL 10% O utp ut 2m A 90% 5 3m A 5m A 4 ts td 7m A tr 3 tf Test C irc uit fo r Freq uenc y Resp o nse 2 Vc c 1 RD RL O utp ut 0 0 5 10 15 Fo rw ard c urrent I F (m A) Part No. : 4N35 / 4N37 ( M, S, S-TA1 ) (Rev.- October 17 2011) BNS-OD-C131/A4 Page : 9 of 11 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only RECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD) Unit : mm Part No. : 4N35 / 4N37 ( M, S, S-TA1 ) (Rev.- October 17 2011) BNS-OD-C131/A4 Page : 10 of 11 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only Notes: - Lite-On is continually improving the quality, reliability, function or design and Lite-On reserves the right to make changes without further notices. - The products shown in this publication are designed for the general use in electronic applications such as office automation equipment, communications devices, audio/visual equipment, electrical application and instrumentation. - For equipment/devices where high reliability or safety is required, such as space applications, nuclear power control equipment, medical equipment, etc, please contact our sales representatives. - When requiring a device for any ”specific” application, please contact our sales in advice. - If there are any questions about the contents of this publication, please contact us at your convenience. - The contents described herein are subject to change without prior notice. - Immerse the unit’s body into solder paste is not recommended. Part No. : 4N35 / 4N37 ( M, S, S-TA1 ) (Rev.- October 17 2011) Page : 11 of 11 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Lite-On: 4N35S-TA1 4N37S-TA 4N35S-TA 4N37S-TA1 4N37M 4N35M 4N35 4N37 4N37S 4N35S
4N35S-TA1 价格&库存
很抱歉,暂时无法提供与“4N35S-TA1”相匹配的价格&库存,您可以联系我们找货
4N35S-TA1
  • 5+0.46816
  • 20+0.45980
  • 100+0.44308
