K30C/M
K30C/M
    VECTOR
    PIN INBOARD .042" HOLE PKG/1000
K30C/M 数据手册
70 Accessories Pins, Terminals and Solder Washers K36, K24 T42-1 Inbord Pins for holes- .025”(.6mm) & .042”dia. Push-In Terminals for .042” diameter holes K36 K24 • Press-in pins provide excellent solder points • Installation tools available separately • Available in several sizes • Plating note: Tin plated. Gold plating available on K24 & K31 styles. Add “A” suffix to numeric portion of part number. Swage • Wiring terminals for mounting leads or wires horizontally or vertically (through board hole) • Connectors require no staking for most applications • Horizontal slot holds up to seven wires, depending upon thickness of wire Diamond knurl (K24 only) “P” Pattern Vectorbord® Use P133A Insertion Tool Part No. Pkg Hole A Qty Size K24A/M* K24A/C K24C/M* K24C/C K30C/M K30C/C K31C/M K31C/C K36C/M K36C/C 1000 100 1000 100 1000 100 1000 100 1000 100 .042” .042” .042” .042” .042” .042” .042” .042” .025” .025” .650” .650” .650” .650” .550” .550” .375” .375” .705” .705” B C D E F .255” .255” .255” .255” .255” .255” .160” .160” .293” .293” .375” .375” .375” .375” .305” .305” .195” .195” .400” .400” .073” .073” .073” .073” .085” .085” .075” .075” .040” .040” .080” .080” .080” .080” .060” .060” .060” .060” .050” .050” .039” .039” .039” .039” .040” .040” .040” .040” .023” .023” T42-1 Micro-Klip Use P149A (handle type) or P149 (shank type) Insertion tool T28 *Use in G-10 epoxy glass board only as knurled shoulder may split CEM-1 composite material R32 Socket Pins for .042” diameter holes • Low profile wire-wrap socket pins • Pressfit mounting • Four-finger contacts, tapered sockets for easy insertion • Accepts .015-.025 diameter leads • Gold-plated contact surfaces Use P158 Insertion Tool D9 Die Point Part No. Pkg A Qty R32/C R32/M B C D E Male Pin Depth 100 .745” .500” .072” .155” .075” 1000 .745” .500” .072” .155” .075” .13” .13” Push-In Terminals for .062” diameter holes • Wiring terminals for mounting leads or wires horizontally or vertically (through board hole) • Vertical (longitudinal) slot holes .025” diameter leads or .22 gauge wires • Includes .018” diameter tab hole which accepts transistor wires, can be used to hold an anchoring wire Use P91A Insertion tool Part No. Pkg Qty T28/C T28/M 100 1000 R30, R31, R53 Socket Pins for .055” diameter holes R30 • Low profile,pressfit pins, for hand or dip solder applications • Solder post is 0.110” long, extends 0.19” below and 0.030” above board surface • Gold-plated contact surfaces R31 • Low profile wire wrap • Four-finger contacts, tapered socket for easy insertion • Gold-plated contact surfaces R52 • Two level wire wrap • Tin-plated contact surfaces R53 • 3-level wire-wrap pins, .025” sq. posts • Six-finger contacts, low insertion force sockets • Gold-plated contact surfaces Part No. Pkg Qty A R30/C R30/M R31/C R52/C R52/M R53/C R53/M A Fine Technology Group 100 1000 100 100 1000 100 1000 .110” .110” .500” .370” .370” .500” .500” B C .286” .286” .703” .570” .570” .700” .700” .072” .072” .072” .072” .072” .062” .062” D Male Pin Depth .030” .030” .031” .031” - .15” .15” .17 .15-.22” .15-.22” - Specifications subject to change without notice. A B .437” .237” .437” .237” T124 Solder Washers - 3 Sizes in Package Multi-functional solder washer kits, with three sizes of washers. Different sizes provided to fit over sockets and tails of most Vector socket pins and wiring terminals. Ideal tools for committing pins to voltage and ground planes in Vectorbord® patterns, such as Voltage/Ground Plane and Vectorbord plus TM , that have clearance area isolating holes from planes. T124/M (Includes 3 sizes) Qty I.D. O.D. Application 500 500 1000 .078” .058” .040” .110” Vcc Side .103” GND Side .106” Connector T124-040/500 Qty I.D. O.D. Application 500 .040” .106” Connector
K30C/M
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-40至85度,隔离电压可达2500Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有抗干扰能力强,响应速度快等特点。
6. 应用信息:广泛应用于工业控制、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装方式。
K30C/M 价格&库存
很抱歉,暂时无法提供与“K30C/M”相匹配的价格&库存,您可以联系我们找货
K30C/M
  • 1+977.705271+126.48111
  • 10+831.1108710+107.51688
  • 25+779.1228225+100.79143
  • 50+741.9800750+95.98645
  • 100+706.61864100+91.41191
库存:1
