TPI-3002
TPI-3002
    TPI(TPI 公司)
    CONN ADAPTER MALE BNC
TPI-3002 数据手册
Molded BNC to BNC Cable Assemblies RG58/U, BNC Male to Male Instrumentation & Data RG59/U, BNC Male to MaleVideo & General 50 Ohm 75 Ohm Part No. 58-012-1M 58-024-1M 58-036-1M 58-048-1M 58-060-1M 58-072-1M 58-120-1M 58-180-1M 58-300-1M 58-600-1M 58-900-1M 58-1200-1M Length 12 inch 24 inch 36 inch 48 inch 60 inch 72 inch 10 feet 15 feet 25 feet 50 feet 75 feet 100 feet RG62/U, BNC Male to MaleComputer & Lab 93 Ohm Part No. 62-024-1M 62-036-1M 62-048-1M 62-060-1M Length 24 inch 36 inch 48 inch 60 inch F Series Cables Part No. 59-012-1M 59-024-1M 59-036-1M 59-048-1M 59-060-1M 59-072-1M 59-120-1M 59-180-1M 59-300-1M 59-600-1M 59-900-1M 59-1200-1M Length 12 inch 24 inch 36 inch 48 inch 60 inch 72 inch 10 feet 15 feet 25 feet 50 feet 75 feet 100 feet Assembled BNC to BNC Cable Assemblies RG58/U, BNC Male to Male Instrumentation & Data White F6-3W F6-6W F6-10W F6-12W F6-15W F6-25W F6-50W F6-75W F6-100W L BNC-0805 Conductor Insulation Braided Shielding Jacket General RG58 Material BC No./mm 1/0.813 Material LDPE Color Natural Diameter (mm) 2.95 Material BC No./mm 16/7/0.12 Material PVC Thickness (mm) 0.72 Color Black Outer Diameter (mm) 4.95 ±0.15 Tensile Strength 1,500 psi Nominal Impedance (Ohm) 53.5 Nominal Capacitance (pF/m) 93.5 Attenuation 100MHz (db/km) 138 Voltage Rating 5.0kv UL Standard 1354 Part No. 58-024-1A 58-036-1A 58-048-1A 58-060-1A Length 24 inch 36 inch 48 inch 60 inch RG59 CCS 1/0.643 LDPE Natural 3.71 BC 16/7/0.12 PVC 0.9 Black 6.0 ±0.15 1,500 psi 73 68.9 125 7.0kv 1354 F Series Cable Technical Specifications RG-6 Conductor Insulation Material CCS No./mm 1/1.02 Material FPE Color Braided Shielding Jacket White Diameter (mm) 4.7 Material OFC No./mm 16/4/0.12 Material PVC Thickness (mm) Length 3’ 6’ 10’ 12’ 15’ 25’ 50’ 75’ 100’ 3’ 6’ 10’ 12’ 15’ 25’ 50’ 75’ 100’ Copyright © 2005 Test Products International, Inc. RG62 CCS 1/0.643 LDPE Natural 3.71 BC 16/7/0.12 PVC 1 Black 6.15 ±0.15 1,500 psi 93 44.3 102 3.0kv 1354 BC = Bare Copper CCS = Copper Clad Steel LDPE = Low Density PE 50 Ohm RG-6 Video & General Part No. Black F6-3B F6-6B F6-10B F6-12B F6-15B F6-25B F6-50B F6-75B F6-100B BNC to BNC Coax Cable Technical Specifications Color General 1 Black or White Outer Diameter (mm) 7.2 ±0.2 Tensile Strength 1,500 psi Nominal Impedance (Ohm) 73 Nominal Capacitance (pF/m) 59 Attenuation 100MHz (db/km) 89 Voltage Rating 3.0kv UL Standard 1354 CCS = Copper Clad Steel FPE = Foam Polyethylene OFC = Oxygen Free Copper Test Products International, Inc. 9615 SW Allen Blvd., Ste. 104 • Beaverton, OR 97005 503-520-9197 • Fax: 503-520-1225 www.testproductsintl.com
TPI-3002 价格&库存
很抱歉,暂时无法提供与“TPI-3002”相匹配的价格&库存,您可以联系我们找货
