SPECIFICATION
Patent Pending
Part No.
PA.700. A Viking
Product Name
Wide-Band LTE/Cellular/CDMA SMD Antenna
For all in one 2G/3G/4G applications worldwide
LTE/GSM / CDMA / DCS / PCS / WCDMA / UMTS
/HSDPA / GPRS / EDGE
698MHz to 960MHz
1710MHz to 2170Mhz
Feature
High efficiency wide-band antenna
SMT for precision mounting and labor saving
RoHS
SPE-11-8-005/G/RC
Page 1 of 12
1. Introduction
This revolutionary patent pending PA.700A Viking is a 2G/3G/4G High Efficiency SMD Ceramic antenna
operating at 700MHz to 960MHz, 1710MHz to 2200MHz. It uses high grade ceramics to deliver the highest
efficiencies on all bands on the shortest device ground-plane lengths possible. The exceptional wide-band
response means it is the ideal antenna for LTE 700MHz applications that also need high efficiency 2G or 3G
on lower and upper bands.
The PA.700 is a unique solution which is delivered on tape and reel. For very detailed integration information
additional to this specification please download our comprehensive PA-700 integration application note from
our website.
1.1 Key Advantages
1. Highest efficiency in small size 40mm*6mm*5mm. A comparative metal, FR4, FPC, whip, rod, and helix
antenna would have much more reduced efficiency in this configuration for the same size due to their
different dielectric constants. Very high efficiency antennas are critical to 3G and 4G devices ability to deliver
the stated data-speed rates of systems such as HSPA and LTE.
2. More resistant to detuning compared to other antenna integrations. If tuning is required it can be tuned
for the device environment using a matching circuit or other techniques. There is no need for new tooling,
thereby saving money if customization is required.
3. Highly reliable and robust– its predecessor the PA.25 antenna is used by the world’s leading auto makers
in extremely challenging environments. The antenna meets all temperature and mechanical specs required
(vibration, drop tests etc)
4. Rectangular shape - Easy to integrate. Other antenna designs come in irregular shapes and sizes making
them hard to integrate.
5. SMD (On-Board) antenna saves on labor, cable and connector costs, leads to higher integration yield
rates, and reduces losses in transmission.
6. It mounts directly on edge of device main-board.
7. Transmission losses are kept to absolute minimum resulting in much improved over the air (OTA)
TRP(Total Radiated Power)/TIS(Total Isotropic Radiation) device performance compared to similar efficiency
cable and connector antenna solutions, thus being an ideal antenna to be used for devices that need to pass
network approvals from for example AT&T or Verizon.
8. Reductions in probability of radiated spurious emissions compared to other antenna technologies are
observed when using the PA-700 and strictly following this application note layout
9. Achieves moderate to high gain in both vertical and horizontal polarization planes. This feature is very
useful in certain wireless communications where the antenna orientation is not fixed and the reflections or
multipath signals may be present from any plane. In those cases the important parameter to be considered
is the total field strength, which is the vector sum of the signal from the horizontal and vertical polarization
planes at any instant in time.
SPE-11-8-005/G/RC
Page 2 of 12
2. Specification
ELECTRICAL
824 ~ 896 880 ~ 960
Frequency (MHz)
700~ 800
1710~ 1880
1850~1990
1710~2170
Peak Gain (dBi)
2.0
1.4
0.9
3.7
3.9
4.1
Average Gain (dBi)
-2.3
-1.8
-2.5
-1.6
-1.4
-1.8
Efficiency
61%
66%
56%
69%
72%
67%
VSWR
< 3.0 : 1
Impedance
50Ω
Polarization
Linear
Radiation Pattern
Omni
MECHANICAL
Dimensions
Termination
40 x 6 x 5 mm
Ag (environmental-friendly Pb free)
ENVIRONMENTAL
Operation Temperature
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
* All electrical properties are measured with PA.700 mounted on its EVB with 140x40mm ground.
SPE-11-8-005/G/RC
Page 3 of 12
3.
Antenna Characteristics
3.1.
Return Loss
-4
(dBi)
-6
-8
-10
-12
-14
-16
-18
600
3.2.
800
1000
1200
1400
1600
1800
2000
2200
2400
VSWR
8
7
6
5
4
3
2
1
600
800
1000
1200
1400
1600
1800
2000
SPE-11-8-005/G/RC
2200
2400
Page 4 of 12
3.3.
Efficiency
100
90
80
70
60
50
40
30
3.4.
800
1000
1200
1400
1600
1800
2000
2200
2400 (MHz)
2000
2200
2400 (MHz)
Peak Gain
5
4
3
(dBi)
2
1
-2
-3
600
800
1000
1200
1400
1600
1800
SPE-11-8-005/G/RC
Page 5 of 12
3.5.
Average Gain
(dBi)
-2
-3
-4
-5
-6
600
3.6.
800
1000
1200
1400
1600
1800
2000
2200
2400 (MHz)
Antenna Radiation Pattern
y
x
z
SPE-11-8-005/G/RC
Page 6 of 12
X-Y Plane Radiation
330
30
-10
300
60
-15
-20
-25
-30
-35
270
90
240
700MHz
800MHz
900MHz
1710MHz
120
210
1850MHz
1990MHz
2170MHz
150
180
(Unit : dBi)
X-Z Plane Radiation
330
30
-10
300
60
-15
-20
-25
-30
-35
270
90
240
120
210
150
700MHz
800MHz
900MHz
1710MHz
1850MHz
1990MHz
2170MHz
180
(Unit : dBi)
SPE-11-8-005/G/RC
Page 7 of 12
4. Mechanical Drawing
SPE-11-8-005/G/RC
Page 8 of 12
5. Layout Dimensions
Note: Inductor Value 8.2nH for Taoglas
Evaluation Board – different values may be
required for different board designs
Size
Description
0402
8.2nH Inductor (MLK1005S8N2D)
SPE-11-8-005/G/RC
Page 9 of 12
6. EVB Dimensions
SPE-11-8-005/G/RC
Page 10 of 12
7. Packing
Blister tape to IEC 286-3, Polyester
Pieces / Tape = 450
SPE-11-8-005/G/RC
Page 11 of 12
8. Recommended Reflow Profile
PA.700 can be assembled following either Sn-Pb or Pb-Free assembly processes. The
recommended soldering temperatures are as follows:
Temperature profile – (green area) for the assembly process in reflow ovens
SPE-11-8-005/G/RC
Page 12 of 12
很抱歉,暂时无法提供与“PA.700.A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 450+71.82660450+9.32991
- 900+70.19724900+9.11827
- 国内价格 香港价格
- 1+117.823251+15.30465
- 10+92.7267110+12.04473
- 25+86.4517825+11.22965
- 100+79.55328100+10.33357
