PAD.700.A
PAD.700.A
    TAOGLASLIMITED
    EVAL FOR PA.700
PAD.700.A 数据手册
SPECIFICATION Patent Pending Part No. : PA.700. A Viking Product Name : Wide-Band LTE/Cellular/CDMA SMD Antenna For all in one 2G/3G/4G applications worldwide LTE/GSM / CDMA / DCS / PCS / WCDMA / UMTS /HSDPA / GPRS / EDGE 698MHz to 960MHz 1710MHz to 2170Mhz Feature : High efficiency wide-band antenna SMT for precision mounting and labor saving RoHS  SPE-11-8-005/G/RC Page 1 of 12 1. Introduction This revolutionary patent pending PA.700A Viking is a 2G/3G/4G High Efficiency SMD Ceramic antenna operating at 700MHz to 960MHz, 1710MHz to 2200MHz. It uses high grade ceramics to deliver the highest efficiencies on all bands on the shortest device ground-plane lengths possible. The exceptional wide-band response means it is the ideal antenna for LTE 700MHz applications that also need high efficiency 2G or 3G on lower and upper bands. The PA.700 is a unique solution which is delivered on tape and reel. For very detailed integration information additional to this specification please download our comprehensive PA-700 integration application note from our website. 1.1 Key Advantages 1. Highest efficiency in small size 40mm*6mm*5mm. A comparative metal, FR4, FPC, whip, rod, and helix antenna would have much more reduced efficiency in this configuration for the same size due to their different dielectric constants. Very high efficiency antennas are critical to 3G and 4G devices ability to deliver the stated data-speed rates of systems such as HSPA and LTE. 2. More resistant to detuning compared to other antenna integrations. If tuning is required it can be tuned for the device environment using a matching circuit or other techniques. There is no need for new tooling, thereby saving money if customization is required. 3. Highly reliable and robust– its predecessor the PA.25 antenna is used by the world’s leading auto makers in extremely challenging environments. The antenna meets all temperature and mechanical specs required (vibration, drop tests etc) 4. Rectangular shape - Easy to integrate. Other antenna designs come in irregular shapes and sizes making them hard to integrate. 5. SMD (On-Board) antenna saves on labor, cable and connector costs, leads to higher integration yield rates, and reduces losses in transmission. 6. It mounts directly on edge of device main-board. 7. Transmission losses are kept to absolute minimum resulting in much improved over the air (OTA) TRP(Total Radiated Power)/TIS(Total Isotropic Radiation) device performance compared to similar efficiency cable and connector antenna solutions, thus being an ideal antenna to be used for devices that need to pass network approvals from for example AT&T or Verizon. 8. Reductions in probability of radiated spurious emissions compared to other antenna technologies are observed when using the PA-700 and strictly following this application note layout 9. Achieves moderate to high gain in both vertical and horizontal polarization planes. This feature is very useful in certain wireless communications where the antenna orientation is not fixed and the reflections or multipath signals may be present from any plane. In those cases the important parameter to be considered is the total field strength, which is the vector sum of the signal from the horizontal and vertical polarization planes at any instant in time. SPE-11-8-005/G/RC Page 2 of 12 2. Specification ELECTRICAL 824 ~ 896 880 ~ 960 Frequency (MHz) 700~ 800 1710~ 1880 1850~1990 1710~2170 Peak Gain (dBi) 2.0 1.4 0.9 3.7 3.9 4.1 Average Gain (dBi) -2.3 -1.8 -2.5 -1.6 -1.4 -1.8 Efficiency 61% 66% 56% 69% 72% 67% VSWR < 3.0 : 1 Impedance 50Ω Polarization Linear Radiation Pattern Omni MECHANICAL Dimensions Termination 40 x 6 x 5 mm Ag (environmental-friendly Pb free) ENVIRONMENTAL Operation Temperature -40°C to 85°C Humidity Non-condensing 65°C 95% RH * All electrical properties are measured with PA.700 mounted on its EVB with 140x40mm ground. SPE-11-8-005/G/RC Page 3 of 12 3. Antenna Characteristics 3.1. Return Loss 0 -2 -4 (dBi) -6 -8 -10 -12 -14 -16 -18 600 3.2. 800 1000 1200 1400 1600 1800 2000 2200 2400 VSWR 8 7 6 5 4 3 2 1 600 800 1000 1200 1400 1600 1800 2000 SPE-11-8-005/G/RC 2200 2400 Page 4 of 12 3.3. Efficiency 100 90 80 70 (%) 60 50 40 30 20 10 0 600 3.4. 800 1000 1200 1400 1600 1800 2000 2200 2400 (MHz) 2000 2200 2400 (MHz) Peak Gain 5 4 3 (dBi) 2 1 0 -1 -2 -3 600 800 1000 1200 1400 1600 1800 SPE-11-8-005/G/RC Page 5 of 12 3.5. Average Gain 0 -1 (dBi) -2 -3 -4 -5 -6 600 3.6. 800 1000 1200 1400 1600 1800 2000 2200 2400 (MHz) Antenna Radiation Pattern y x z SPE-11-8-005/G/RC Page 6 of 12 X-Y Plane Radiation 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 -35 270 90 240 700MHz 800MHz 900MHz 1710MHz 120 210 1850MHz 1990MHz 2170MHz 150 180 (Unit : dBi) X-Z Plane Radiation 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 -35 270 90 240 120 210 150 700MHz 800MHz 900MHz 1710MHz 1850MHz 1990MHz 2170MHz 180 (Unit : dBi) SPE-11-8-005/G/RC Page 7 of 12 4. Mechanical Drawing SPE-11-8-005/G/RC Page 8 of 12 5. Layout Dimensions Note: Inductor Value 8.2nH for Taoglas Evaluation Board – different values may be required for different board designs Size Description 0402 8.2nH Inductor (MLK1005S8N2D) SPE-11-8-005/G/RC Page 9 of 12 6. EVB Dimensions SPE-11-8-005/G/RC Page 10 of 12 7. Packing Blister tape to IEC 286-3, Polyester Pieces / Tape = 450 SPE-11-8-005/G/RC Page 11 of 12 8. Recommended Reflow Profile PA.700 can be assembled following either Sn-Pb or Pb-Free assembly processes. The recommended soldering temperatures are as follows: Temperature profile – (green area) for the assembly process in reflow ovens SPE-11-8-005/G/RC Page 12 of 12
PAD.700.A 价格&库存
很抱歉,暂时无法提供与“PAD.700.A”相匹配的价格&库存,您可以联系我们找货
