1451.009.02
1451.009.02
    FEIGELECTRONIC
    ID ISC.ANT.U250/250-FCC CIRC UHF
1451.009.02 数据手册
O B ID ® R UHF antenna ID ISC.ANT.U250/250-EU ID ISC.ANT.U250/250-FCC The UHF antennas ID ISC.ANT.U250/250-EU/-FCC are circular polarized antennas for operating frequencies in the UHF ranges 865-870 MHz (EU antenna) and 902-928 MHz (FCC antenna). So the antenna can be used for UHF applications within both released UHF ranges in Europe (865-870 MHz) as well as in North America (902-928 MHz). Features: Best performances in each frequency range by specifically optimized EU- and FCC antenna Two antenna cables available (2 m and 6 m) Mounting set for easy installation available UHF antenna ID ISC.ANT.U250/250-EU/-FCC Short description and technical information Short description Technische Daten The UHF antennas ID ISC.ANT.U250/250-EU/-FCC are Housing Plastic circular polarized antennas for operating frequencies in Dimensions (WxHxD) 260 x 260 x 56 mm the UHF ranges 865-870 MHz (EU antenna) and Weight approx. 1050 g 902-928 MHz (FCC antenna). Color white (similar RAL9018) So the antennas can be used for applications within Protection class IP 54 both released UHF ranges in Europe (865-870 MHz) as Operating frequency EU antenna FCC antenna 865 - 870 MHz 902 - 928 MHz Gain EU antenna FCC antenna 8,3 dBic @ 866 MHz 8,7 dBic @ 915 MHz 3 dB beam width - E plain - H plain 65° 65° Polarization circular VSWR < 1,5 : 1 Antenna connection SMA socket (50 Ohm) Temperature range - operation - storage -25°C up to 55°C -25°C up to 85°C well as in North America (902-928 MHz). Due to an integrated multiplexer, the long range readers R of the OBID i-scan UHF family can be connected with up to four UHF antennas. Due to the antennas´ circular polarization, transponders can be identified in two different orientations (E plane / H plane). Installation Information about the monting set ID ISC.MS.ANT.U250/250: FEIG ELECTRONIC reserves the right to change specification without notice at any time Maximum clamping range 30 - 60 mm Material Aluminium, steel-galvanizedt Weight 380 g Orientation changeable in three directions FEIG ELECTRONIC GmbH Lange Straße 4, D-35781 Weilburg Tel.: +49 (0) 6471 / 3109-0, Fax: -99 Internet: http://www.feig.de e-mail: OBID@feig.de
1451.009.02 价格&库存
很抱歉,暂时无法提供与“1451.009.02”相匹配的价格&库存,您可以联系我们找货
