1916.000.01
1916.000.01
    FEIGELECTRONIC
1916.000.01 数据手册
 Multi-tag Reader Modules ID CPR (13.56 MHz) FEATURES  Also available as USB variant  Data rates up to 847 kBit/s  Low power consumption  Command Queue for explicit reduction of communication cycles between host and reader module  Supports NFC applications  Order description: ID CPR40.0x / ID CPR.M02.VP/AB-x Special advices: • The higher operation speed is caused by the so-called „Command Queue“. With this Command Queue a sequence of commmands can be sent to the reader module within one poll. The result is an explicit reduction of communication cycles between host and reader. • Beside the six reader modules ID CPR40.0x, the ISO 15693 / ISO14443-reader modules ID CPR.M02.VP/AB-B and -BA resp. ID CPR.M02.VP/AB-C and -CA are available. Reader modules with integrated antenna Dimensions RS232-TTL interface Data/Clock interface Wiegand interface RS232 interface USB interface Supply voltage ISO 14443-A/-B ISO 14443 Part 4 Support Mifare classic read / write ISO 15693 I-CODE1 Data rate NFC compatibility Current consumption Read 64 Byte mifare classic RF transmitting power Command Queue ID CPR40.00-A 50 x 50 x 14 mm ID CPR40.00-CDUSB 50 x 50 x 14 mm x x x ID CPR.M02.VP/AB-B 50 x 50 x 14 mm x x x ID CPR.M02.VP/AB-C 50 x 50 x 14 mm x x x 5V x TCL Firmware x x x 106 kBit/s x 300 mA 5V x TCL Firmware x x 4,1 ms 250 mW 4,1 ms 250 mW x 5V x x x x 5V x x x 106-847 kBit/s x 130 mA 106-847 kBit/s x 130 mA 2,6 ms 100 mW x 2,6 ms 100 mW x 106 kBit/s x 300 mA Accessories: - ID ISC.ANT40/30 External antenna 40 mm x 30 mm - ID ISC.ANT100/100 External antenna 100 mm x 100 mm - ID NET.5V 5V power supply - ID CO.RS232/LVTTL-A Converter LVTTL to RS232 - ID CO.RS232/TTL-A Converter TTL to RS232 - ID CAB.RS-A Cable for RS232/485 and power supply - ID CAB.A-A Adapter cable, 10 cm Note: Errors and technical alterations reserved. The information is given in April 2017. Not recommended for new design.  Order description: ID CPR40.0x / ID CPR.M02.VP/AB-x Reader modules for operation with external antennas Dimensions RS232-TTL interface Data/Clock interface Wiegand interface RS232 interface USB interface Supply voltage ISO 14443-A/-B ISO 14443 Part 4 Support Mifare classic read / write ISO 15693 I-CODE1 Data rate NFC compatibility Current consumption Read 64 Byte mifare classic RF transmitting power Command Queue ID CPR40.01-A 50 x 50 x 14 mm ID CPR40.01-CDUSB 50 x 50 x 14 mm x x x ID CPR.M02.VP/AB-BA 50 x 50 x 14 mm x x x ID CPR.M02.VP/AB-CA 50 x 50 x 14 mm x x x 5V x TCL Firmware x x x 106 kBit/s x 300 mA 5V x TCL Firmware x x 4,1 ms 250 mW 4,1 ms 250 mW x 5V x x x x 5V x x x 106-847 kBit/s x 130 mA 106-847 kBit/s x 130 mA 2,6 ms 100 mW x 2,6 ms 100 mW x 106 kBit/s x 300 mA Standard conformity Radio approval Europe USA EN 300 330 FCC 47 CFR Part 15* EMC EN 301 489 Safety Health EN 60950 EN 50364 *only for ID CPR.M02.VP/AB-BA and -CA Note: Errors and technical alterations reserved. The information is given in April 2017 As external antennas, two 50Ω antennas ID ISC.ANT40/30 and ID ISC.ANT100/100 are available. Not recommended for new design.
1916.000.01 价格&库存
很抱歉,暂时无法提供与“1916.000.01”相匹配的价格&库存,您可以联系我们找货
