DK691
DK691
    C-TON
    PROCESS METER 4-20MA LED PNL MT
DK691 数据手册
LED DIGITAL PANEL METERS Low-cost 3 1/2 Digit LCD & LED Displays for process inputs DPMs shown actual size Features: • Space saving design only 0.67”(17mm) deep • Occupies less than 2.5 x 1.1 inches of front panel space • Choose a red or green LED • 3-1/2 digits with 0.56” LED • User Selectable Decimal Points • Process input (4 to 20mA) adder board with multi-turn SPAN (GAIN) and ZERO (OFFSET) adjustments • Loop controlled • Window mount with optional bezel Ordering Information: Specifications: Display: Digits: Type: Polarity: Decimal Points: Overload: 3 1/2 Digits (±1999 counts) 0.56” (14.2mm) Red or Green 7-Segment LED Automatic, “-” Displayed. 3 Position, User Selectable Three lower order digits blank for inputs >1999 & 30 db @ 60 Hz ±1V DC >86 dB Automatic 10 Minutes Typical ±100 ppm per °C Typical Operating Range: Storage Range: 0 to 50 °C -10 to 60 °C Voltage: Current: LEDs, +5V DC (±5%) LEDs, 200mA; LED: Process Board: Window Mount, or Bezel Mount with Optional Bezel Plugs onto DPM pins, adds approx. 0.6”(16mm) to depth 10 Pins, 0.025” Square on 0.1” centers Screw terminals on Process Board Inputs: DK691 ..............Green LED DPM, 4 to 20mA board ...................... DK694 ..............Red LED DPM, 4 to 20mA board .......................... LED-B ................Bezel Mounting Kit For LPI-2 .................................. PW2-5................Regulated 120V AC to 5V DC Adaptor .................. Performance: Environment: Power Supply: Mounting: Connection: C-TON Industries •PO Box 10129 •Bedford, NH, 03110 •USA 03110-0129 INCHES (mm) LED
DK691 价格&库存
很抱歉,暂时无法提供与“DK691”相匹配的价格&库存,您可以联系我们找货
