26105
    WIHA(威汉)
    OPTIVISOR 2-3/4X
26105 数据手册
2019 PROFESSIONAL TECH TOOLS COMPLETE TECHNICIAN’S PROGRAM Precision Screwdrivers • PicoFinish Drivers • TorqueControl Micro Bits • Blade Sets • Electronic Pliers • ESD Tweezers • Mirrors Toll Free: (800) 494-6104 2 Wiha Precision Screwdrivers Description Page Precision Slotted Drivers Precision Phillips Drivers 4 Description Page Magnetizer/Demagnetizer 11 4 Precision Pozidriv® Drivers 5 Precision Hex Drivers 5 Precision Ball End Drivers 6 Precision Nut Drivers 7 Precision Torx® Drivers 6 Precision Pentalobe Drivers 7 Precision Chip Lifters 4 Wiha Magnetizer/Demagnetizer Wiha TorqueControl Tools Wiha Precision Proturn Drivers Description Page Proturn Drivers & Blade Sets 12 Slotted, Phillips, Torx, Chip Lifter Wiha ESD Safe Precision Handles/Blades Description Page Description Page Torque Cable Keys 8 SYSTEM 4 Handles/Blades TorqueControl Handle 8 13-15 Wiha Precision Screwdriver Accessories Description Page Precision Master Tech Sets 8 Precision Pocket Clip 4 Precision Stand 4 Precision Pouch 11 Wiha Precision PicoFinish Drivers Description Page PicoFinish Screwdrivers 9-12 Slotted, Phillips, Torx, Wiha ESD Safe Precision Handle & Blades Description Page SYSTEM 4 Drive-Loc Handle & Blades 15 SYSTEM 4 Drive-Loc Set 15 ESD Safe Micro Bit Handles, Bits & Sets Description Page Micro Bit Handles/Bits/Sets 16-21 TorxPlus, Hex, MagicSpring, Ball End Hex, Chip Lifter & Micro Bit Storage Handle Sets 21 Nut Drivers Tri-Wing Drivers Insulated PicoFinish Drivers 12 ESD Safe Micro Bit Sets 18-21 www.wihatools.com 3 Precision Electronic Pliers/Cutters Description Page Electronic Diagonal Cutters Wide Pointed Head 22 Electronic Diagonal Cutters 22 Wide Shape w/Wire Holding Spring Electronic Diagonal Cutters Narrow Shap 22 Electronic Diagonal Cutters Full Flush Cutters w/Wire Trapping Spring 22 Electronic Diagonal Cutters 22 48O Front Cutter/Long Nose Pliers Electronic Diagonal Cutters Oblique 30O Cutting Nippers 22 Electronic Diagonal Cutters Short Nose Precision Pliers 22 Electronic Stripping Pliers 22 Wiha Professional Tweezers Description Page ESD Safe Tweezers Inspection Mirrors 23-25 25 Wiha ESD Safe Tech Tools ESD Safe Precision Drivers Slotted/Phillips/Torx®/ TorxPlus®/Hex/Nut Drivers/ Chip Lifter ESD Safe Ceramic Drivers ESD Safe SYSTEM 4 Handles/Blades/Sets ESD Safe Drive-Loc Handles/Blades/Sets ESD Safe Pliers & Cutters Catalog 99945.wo The Comfortable Precision Screwdriver Soft Grip Handle CVM tool steel blade, hardened, hard chrome finish Ergonomic multicomponent handle with rotating cap for maximum user comfort and precise control New & Improved PicoFinish Screwdrivers On Pages 9-12 Sets In Roll-Up Pouch Toll Free: (800) 494-6104 4 Wiha Precision Slotted/Phillips Drivers Rotating cap for precise turning and control with fingertip Precision handle high quality plastic, cadmium free Molded on tapered handle allows rapid rotation High performance blades CVM steel, Hard chrome finished Tip precision ground for exact fit, hard chromed non-slip surface Wiha Precision Chip Lifter & Accessories 26810 Precision Chip Lifter Blade CVM steel, hardened, chrome-plated. Precision handle high quality plastic, impact resistant. Standard handle Item No. mm mm mm mm Inch lbs. Pkg. 26810 1 3.5 50 145 5.7 .07 1 *Metric dimensions actual - Inch dimensions approximate 26001 Pocket Clip for Precision Screwdrivers Tool clips turn Precision Screwdrivers into Pocket Screwdrivers. Item No. Fits all lbs. pkg. 26001 Precision handles .01 1 26000 Plastic Precision Tool Rack Rack holds 6 precision screwdrivers, can be set on workbench. Also has holes for hanging. Made from high quality plastic. Item No. Rack for 6 lbs. Pkg. 26000 Precision screwdrivers .08 1 260 Slotted Screwdriver, With Precision Handle Blade high alloy chrome-vanadiummolybdenum steel. Pkg. 10 Item No. mm Inch mm Inch mm mm Inch lbs. 26008 .80 1/32 40 1.6 0.16 120 4.7 .02 26010 1.0 .039 40 1.6 0.18 120 4.7 .02 26012 1.2 3/64 40 1.6 0.20 120 4.7 .02 26015 1.5 1/16 40 1.6 0.25 120 4.7 .02 26018 1.8 .070 40 1.6 0.30 120 4.7 .02 26020 2.0 5/64 40 1.6 0.40 120 4.7 .02 26022 2.0 5/64 50 2.0 0.40 145 5.7 .02 26023 2.0 5/64 100 3.9 0.40 180 7.1 .03 26025 2.5 3/32 50 2.0 0.40 145 5.7 .03 26027 2.5 3/32 100 3.9 0.40 195 7.7 .03 26028 2.5 3/32 150 6.0 0.40 245 9.6 .04 26030 3.0 1/8 50 2.0 0.50 145 5.7 .03 26032 3.0 1/8 60 2.4 0.50 170 6.7 .04 26033 3.0 1/8 100 3.9 0.50 210 8.3 .04 26034 3.0 1/8 150 5.9 0.50 260 10.2 .05 26035 3.5 9/64 60 2.4 0.60 170 6.7 .05 26040 4.0 5/32 60 2.4 0.80 170 6.7 .05 26041 4.0 5/32 100 3.9 0.80 210 8.3 .06 26042 4.0 5/32 150 5.9 0.80 260 10.2 .07 *Metric dimensions actual - Inch dimensions approximate 26090 6pc Precision Slotted Set Blade high alloy chrome-vanadiummolybdenum steel. Hard chrome finished. Item No. 26090 Slotted: lbs. 1.5, 2.0 x 40mm .27 2.5, 3.0 x 50mm 3.5, 4.0 x 60mm 261 Phillips Screwdriver, With Precision Handle Blade high alloy chrome-vanadiummolybdenum steel. Pkg. 10 Item No. Size mm Inch mm Inch mm Inch lbs. 26102 000 40 1.6 2.0 .08 120 4.7 .02 26100 00 40 1.6 2.0 .08 120 4.7 .02 26101 00 75 3.0 2.0 .08 155 6.1 .02 26105 0 50 2.0 3.0 .12 145 5.7 .02 26108 0 75 3.0 3.0 .12 170 6.7 .03 26107 0 100 3.9 3.0 .12 195 7.6 .05 26109 0 150 5.9 3.0 .12 245 9.6 .06 26110 1 60 2.4 4.0 .16 170 6.7 .05 26113 1 80 3.1 4.0 .16 190 7.5 .05 26114 1 100 3.9 4.0 .16 210 8.2 .06 26115 1 150 5.9 4.0 .16 260 10.2 .07 *Metric dimensions actual - Inch dimensions approximate 8pc Precision Slotted & Phillips 26190 Screwdrivers and Industrial Long Nose Pliers Set Item No. Slotted: 1.5 x 40mm 26190 2.0, 2.5 x 50mm, 3.0 x 60mm Phillips: 00 x 40mm lbs. .72 0 x 50mm , 1 x 60mm Industrial Long Nose Pliers 6.3”/160mm OAL 7pc Precision Slotted & 26197 Phillips Set Blade high alloy CVM steel. Item No. Slotted: 1.5 x 40mm 26197 2.0, 2.5 x 50mm, 3.0 x 60mm Phillips: 00 x 40mm lbs. .31 0 x 50mm , 1 x 60mm In canvas storage pouch 26099 8pc Precision Slotted Set Blade high alloy CVM steel. Hard chrome finished. In canvas storage pouch. Item Slotted: No. 1.0, 1.2, 1.5, 2.0 x 40mm lbs. 26099 2.5, 3.0 x 50mm, 3.5, 4.0 x 60mm .54 26199 8pc Precision Slotted/Phillips Set Item No. 26199 Slotted: 1.0, 2.0 x 40mm, lbs. 3.0 x 50mm, 4.0 x 60mm .55 Phillips: 000, 00 x 40mm, 0 x 50mm, 1 x 60mm www.wihatools.com 5 Wiha Precision Slotted/ Phillips Drivers 26092 7pc Precision Slotted & Phillips Set Blade high alloy chromevanadium-molybdenum steel. Item No. 26092 Slotted: lbs. 2.5 x 50mm, .30 2.5, 3.0, 4.0 x 100mm 3.0, 4.0 x 150mm Phillips: 0 x 75mm Wiha Hex Inch & Metric Precision Series 263 Inch Inch Hex Driver, With Precision Handle Inch sizes. Blade high alloy chromevanadium-molybdenum steel. Pkg. 10 Item No. Inch mm mm Inch mm Inch lbs. 26307 0.028 0.7 40 1.6 120 4.7 .02 26309 0.035 0.9 40 1.6 120 4.7 .02 26313 0.05 1.3 40 1.6 120 4.7 .02 26316 1/16 - 50 2.0 145 5.7 .03 26320 5/64 2.0 50 2.0 145 5.7 .03 26323 3/32 - 60 2.4 170 6.7 .04 26327 7/64 - 60 2.4 170 6.7 .04 26331 1/8 - 60 2.4 170 6.7 .04 26333 9/64 60 2.4 170 6.7 .05 26336 5/32 60 2.4 170 6.7 .05 *Metric dimensions actual - Inch dimensions approximate 263 Metric Metric Hex Driver, With Precision Handle Metric sizes. Blade high alloy chrome-vanadium-molybdenum steel. Item No. mm Inch mm Inch mm Inch lbs. pkg. 26307 .7 .028 40 1.6 120 4.7 .02 10 26309 .9 .035 40 1.6 120 4.7 .02 10 26313 1.3 .050 40 1.6 120 4.7 .02 10 26315 1.5 - 50 2.0 145 5.7 .03 10 26320 2.0 5/64 50 2.0 145 5.7 .03 10 26325 2.5 - 60 2.4 170 6.7 .04 10 26330 3.0 - 60 2.4 170 6.7 .04 10 26340 4.0 - 60 2.4 170 6.7 .05 10 *Metric dimensions actual - Inch dimensions approximate 26391 8pc Precision Hex Driver Set Inch Blade high alloy chrome-vanadiummolybdenum steel. Item No. 26391 Hex Inch: lbs. .028, .035, .050 x 1.6” .32 1/16, 5/64 x 2.0” 3/32, 7/64, 1/8 x 2.4” 26390 7pc Precision Hex Driver Set Metric Blade high alloy chrome-vanadiummolybdenum steel. Item No. 26390 Hex Metric: lbs. .7, .9, 1.3 x 40mm .28 1.5, 2.0 x 50mm 2.5, 3.0 x 60mm 26194 4pc Precision Phillips Set Blade high alloy chrome-vanadiummolybdenum steel. Hard chrome finished. Item Phillips: No. 000, 00 x 40mm lbs. 26194 0 x 50mm, 1 x 60mm .18 26192 5pc Precision Slotted & Phillips Set Blade high alloy chromevanadium-molybdenum steel. Item Slotted: No. 2.5, 3.0, 4.0 x 150mm lbs. .44 26192 Phillips: 0, 1 x 150mm Wiha Pozidriv® Precision Series 262 Pozidriv® Screwdriver, With Precision Handle Blade high alloy chromevanadium-molybdenum steel. Pkg. 10 Item No. Size mm Inch mm Inch mm Inch lbs. 26205 0 50 2.0 3.0 .12 145 5.7 .03 26210 1 60 2.4 4.0 .16 170 6.7 .05 *Metric dimensions actual - Inch dimensions approximate Y-Type Precision Driver 26399 8pc Precision Hex Driver Set - Inch Blade high alloy CVM steel. Hard chrome finished. In canvas storage pouch Item No. Hex Inch: 26399 .028, .035, .050 x 1.6” lbs. .55 1/16, 5/64 x 2.0”, 3/32, 7/64, 1/8 x 2.4” Y-Type (Used in iphone 7 or higher series) Y-Type Precision Screwdriver 26601 Blade high alloy CVM steel. Hard chrome finished. Item No. Size mm Inch mm Inch mm Inch 26601 000 40 1.6 2.0 .08 120 4.75 Toll Free: (800) 494-6104 6 Wiha Ball End Precision Series 30° 264 Inch Ball End Hex Inch Screwdriver With Precision Handle Angle entry up to 30°. Blade high alloy chrome-vanadiummolybdenum steel. Hard chrome finish. Item No. Inch mm Inch mm Inch lbs. Pkg. 26413 .050 40 1.6 120 4.7 .02 10 26416 1/16 50 2.0 145 5.7 .03 10 26419 5/64 50 2.0 145 5.7 .03 10 26423 3/32 50 2.0 145 5.7 .03 10 26427 7/64 60 2.4 170 6.7 .03 10 26431 1/8 60 2.4 170 6.7 .05 10 26436 9/64 60 2.4 170 6.7 .05 10 26439 5/32 60 2.4 170 6.7 .05 10 *Metric dimensions actual - Inch dimensions approximate 26490 8 Piece Ball End Hex Driver Set Inch Angle entry up to 30°. Blade high alloy chrome-vanadiummolybdenum steel. Item No. Hex Inch: .050 x 1.6, lbs. 26490 1/16, 5/64, 3/32 x 2.0, .28 7/64, 1/8, 9/64, 5/32 x 2.4” Wiha Precision Series Screwdriver, With Precision 267 Handle Blade high alloy chrome-vanadiummolybdenum steel. Item No. Size mm Inch mm Inch lbs. pkg. 26701 T1 40 1.6 120 4.7 .01 10 26702 T2 40 1.6 120 4.7 .02 10 26703 T3 40 1.6 120 4.7 .02 10 26704 T4 40 1.6 120 4.7 .02 10 26705 T5 40 1.6 120 4.7 .02 10 26706 T6 40 1.6 120 4.7 .02 10 26707 T7 40 1.6 120 4.7 .02 10 26708 T8 40 1.6 120 4.7 .03 10 26709 T9 50 2.0 145 5.7 .03 10 26710 T10 50 2.0 145 5.7 .03 10 26715 T15 60 2.4 170 6.7 .05 10 26720 T20 60 2.4 170 6.7 .05 10 *Metric dimensions actual - Inch dimensions approximate 30° 264 Metric Ball End Hex Metric Screwdriver With Precision Handle Angle entry up to 30°. Blade high alloy CVM steel. Item No. mm Inch mm Inch mm Inch lbs. Pkg. 26413 1.3 .050 40 1.6 120 4.7 .02 10 26415 1.5 - 50 2.0 145 5.7 .03 10 26420 2.0 - 50 2.0 145 5.7 .03 10 26425 2.5 - 60 2.4 170 6.7 .04 10 26430 3.0 - 60 2.4 170 6.7 .05 10 26440 4.0 60 2.4 170 6.7 .05 10 *Metric dimensions actual - Inch dimensions approximate 26499 8pc Ball End Hex Driver Set - Inch Blade high alloy chrome-vanadium-molybdenum steel. Hard chrome finished. Item Ball End Hex Inch: lbs. No. .050 x 1.6” .62 26499 1/16, 5/64, 3/32 x 2.0” 7/64, 1/8, 9/64, 5/32 x 2.4” Wiha 26491 26790 6pc Screwdriver Set Blade high alloy chrome-vanadiummolybdenum steel. Item No. : lbs. 26790 T6, T7, T8 x 40mm .30 T9, T10 x 50mm T15 x 60mm Screwdriver Set 26791 8pc Item No. T1, T2, T3, T4, 26791 T5, T6, T7, T8 Precision Series 5pc Ball End Hex Driver Set - Metric Angle entry up to 30°. Blade high alloy chrome-vanadiummolybdenum-steel. Item No. Ball End Hex Metric: lbs. 26491 1.3 x 40mm .25 1.5, 2.0 x 50mm 2.5, 3.0 x 60mm Screwdriver Set 26792 7pc Blade high alloy chrome-vanadiummolybdenum steel. Item No. : lbs. 26792 T5, T6, T7, T8 x 40mm .33 T9, T10 x 50mm T15 x 60mm Screwdriver Set 26799 8pc Blade high alloy chrome-vanadiummolybdenum steel. Hard chrome finished. In canvas storage pouch Item : T3, T4, T5, No. T6, T7, T8 x 40mm lbs. 26799 T9 x T10 x 50mm .50 www.wihatools.com 7 Wiha Pentalobe Precision Series Wiha Nut Driver Precision Series Wiha Pentalobe drivers will fit fasteners used in “Apple” brand products including iPhone, Mac Book & Mac Air · · · · · Exact fit precision machined tips High performance CRM72 tool steel Hard chromed finish blades & tips Tapered ergonomic handle Easy spin finger tip control cap 267 Pentalobe Screwdrivers, With Precision Handle Blade high alloy chromevanadium-molybdenum steel. Item No. Size mm Inch mm Inch lbs. pkg. 26761 PL1 40 1.6 120 4.7 .01 1 26762 PL2 40 1.6 120 4.7 .02 1 26763 PL3 40 1.6 120 4.7 .02 1 26764 PL4 40 1.6 120 4.7 .02 1 26765 PL5 40 1.6 120 4.7 .02 1 26766 PL6 40 1.6 120 4.7 .02 1 *Metric dimensions actual - Inch dimensions approximate 26794 6pc Precision Pentalobe Screwdriver Set Blade high alloy CVM steel. Hard chrome finished. Super hardened best wear resistance long life. Item No. Pentalobe Drivers: 26794 PL1, PL2, PL3, PL4, lbs. PL5, PL6 .35 265 Metric Metric Nut Driver With Precision Handle Metric sizes. Blade CVM steel. Hard chrome finished. Item No. mm mm Inch mm Inch mm mm lbs. Pkg. 26510 1.5 60 2.4 140 5.5 2.5 3.0 .03 10 26515 1.8 60 2.4 140 5.5 2.9 3.5 .03 10 26520 2.0 60 2.4 140 5.5 3.2 4.0 .04 10 26525 2.5 60 2.4 155 6.1 4.0 4.0 .04 10 26530 3.0 60 2.4 155 6.1 5.0 5.0 .05 10 26532 3.2 60 2.4 155 6.1 5.0 5.0 .05 10 26535 3.5 60 2.4 155 6.1 5.3 6.0 .05 10 26540 4.0 60 2.4 155 6.1 5.5 6.0 .05 10 26545 4.5 60 2.4 155 6.1 6.2 7.0 .05 10 26550 5.0 60 2.4 155 6.1 6.8 7.0 .05 10 26555 5.5 60 2.4 170 6.7 7.6 8.0 .06 10 26560 6.0 60 2.4 170 6.7 8.2 9.0 .06 10 26570 7.0 60 2.4 170 6.7 9.6 10.0 .06 10 *Metric dimensions actual - Inch dimensions approximate 26590 8pc Precision Nut Driver Set Metric Blade CVM steel. Item No. 26590 Metric Nut Drivers: lbs. .48 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5, 6.0 x 60mm 7pc Nut Driver Set - Metric 26592 Item No. 1.5, 1.8, 2.0, 2.5, 26592 3.0, 3.5, 4.0mm 265 Inch Inch Nut Driver With Precision Handle Inch sizes. Blade CVM steel. Hard chrome finished. Item No. Inch mm Inch mm Inch mm mm lbs. Pkg. 26523 3/32 60 2.4 155 6.1 .16 .16 .04 10 26527 7/64 60 2.4 155 6.1 .20 .20 .05 10 26531 1/8 60 2.4 155 6.1 .20 .20 .05 10 26536 9/64 60 2.4 155 6.1 .21 .24 .05 10 26539 5/32 60 2.4 155 6.1 .22 .24 .05 10 26547 3/16 60 2.4 155 6.1 .25 .28 .05 10 26556 7/32 60 2.4 170 6.7 .30 .32 .06 10 26563 1/4 60 2.4 170 6.7 .34 .36 .06 10 *Metric dimensions actual - Inch dimensions approximate 26591 8pc Precision Nut Driver Set - Inch Blade CVM steel. Item No. 26591 Inch Nut Drivers: lbs. 47 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4” x 2.4” 26599 8pc Precision Nut Driver Set - Inch Blade high alloy CVM steel. Hard chrome finished. In canvas storage pouch Item Inch Nut Drivers: lbs. No. 3/32, 7/64, 1/8, 9/64, 5/32, .72 26599 3/16, 7/32, 1/4” x 2.4” 26598 8pc Precision Nut Driver Set Metric Blade high alloy CVM steel. Hard chrome finished. In canvas storage pouch Item No. lbs. 26598 Metric Nut Drivers: .70 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5, 6.0 x 60mm Toll Free: (800) 494-6104 8 Wiha Precision Screwdriver Set 92189 Master Technicians Bench Top Set Metal frame. Equipped with 50 precision drivers. 92191 51pc Precision Tool Tray Set Tool box tray. Equipped with 51 precision drivers. Item No. 92189 lbs. 3.67 Slotted: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0 Phillips: #000, #00, #0, #1 Pentalobe: PL1, PL2, PL3, PL4 : T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Metric Hex: 1.27, 1.5, 2.0, 2.5, 3.0 Inch Hex: .028, .035, .050, 1/16, Item No. 92191 lbs. 3.14 Slotted: .8, 1.0, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0 Phillips: #000, #00, #0, #1 Torx®: T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Metric Hex: 1.27, 1.5, 2.0, 2.5, 3.0, 4.0 Inch Hex: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Metric Nut Drivers: 1.5, 1.8, 2.0, Metric Nut Drivers: 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5 26810 Chip Lifter 26810 Chip Lifter Wiha Torque Cable Keys 286 Torque Cable Key For Threaded Hex Connectors For torque controlled fastening of cable plug connectors with Hex heads. Used with Wiha-TorqueControl Screwdrivers. Item Max No. Size mm mm mm Nm lbs. Pkg. 28620 8mm 4.0 78 218 1.0 .06 1 28622 9mm 4.0 78 218 1.0 .06 1 28626 12mm 4.0 78 218 1.5 .06 1 28627 13mm 4.0 78 218 1.5 .06 1 28629 14mm 4.0 78 218 1.5 .06 1 28633 18mm 4.0 78 218 1.5 .06 1 28644 Torque Cable Key For Threaded Hex Connectors - Inch Item Max No. Size mm mm mm Nm lbs. Pkg. 28644 1/2” 4.0 78 218 1.5 .06 1 Wiha Magnetizer/ Demagnetizer Magnetize or Demagnetize tools and small parts instantly 92190 Master Technicians Bench Top Set Metal frame. Equipped with 50 precision drivers. Item No. 92190 lbs. 3.67 Slotted: .8, 1.0, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0 Phillips: #000, #00, #0, #1 : T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Metric Hex: 1.27, 1.5, 2.0, 2.5, 3.0 Inch Hex: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Metric Nut Drivers: 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5 26810 Chip Lifter +/-6% accuracy tolerance Certificate of calibration Shatterproof Box is made from high quality plastic Uses 2 C8 industrial permanent magnets (+) to Magnetize (-) to Demagnetize 40010 Magnetizer and Demagnetizer To magnetize and demagnetize steel screwdriver blades, tweezers and similar tools. Box high quality plastic, shock-resistant, green, cadmium free. Application: To magnetize, lead tool slowly through the (+) opening, to demagnetize guide tool slowly through the (-) opening. Item No. Dimensions lbs. 40010 2.1” x 2.0” x 1.1” .30 (Parts under 1” Length or 1/8” Diameter may not demagnetize) 28552 Adjustable TorqueVario-S Handle In Newton Meter Scale EN ISO 6798, BS EN 26789, ASME B107.14M. Ergonomic molded multi-component handle, light and compact. Handle sizes proportioned to optimize torque range. Audible and perceptible click when the torque setting has been attained, automatically resets for next torque cycle. Item No. 28552 Newton Meter Scale Increments mm lbs. Pkg. 0.8 - 2.0Nm .10 Nm 126 - 131 .45 1 www.wihatools.com 9 Wiha Soft Grip PicoFinish Precision Screwdrivers The Comfortable Precision Screwdriver Soft Grip Handle Sets In Roll-Up Pouch Ergonomic multicomponent handle with rotating cap for maximum user comfort and precise control CVM tool steel blade, hardened, hard chrome finish Ergonomic multicomponent handle with rotating cap for maximum user comfort and precise control 260 Slotted Precision Screwdriver, With PicoFinish Handle Blade CVM steel, hardened, hard chromed. Item No. mm Inch mm Inch mm Inch Pkg. 26050 0.8 .03 40 1.6 134 5.3 10 26051 1.0 .04 40 1.6 134 5.3 10 26052 1.2 .05 40 1.6 134 5.3 10 26053 1.5 .06 40 1.6 134 5.3 10 26055 1.8 .07 40 1.6 134 5.3 10 26060 2.0 .08 40 1.6 140 5.5 10 26061 2.0 .08 60 2.4 160 6.3 10 26065 2.5 .09 50 2.0 150 5.9 10 26066 2.5 .09 75 3.0 175 6.9 10 26068 2.5 .09 100 3.9 200 7.9 10 26070 3.0 .13 50 2.0 150 5.9 10 26072 3.0 .13 100 3.9 200 7.9 10 26073 3.0 .13 150 5.9 250 9.8 10 26074 3.5 .14 60 2.4 160 6.3 10 26076 4.0 .16 60 2.4 160 6.3 10 26079 4.0 .16 100 3.9 200 7.9 10 26080 4.0 .16 150 5.9 250 9.8 10 *Metric dimensions actual - Inch dimensions approximate 26093 8pc Slotted Precision Screwdriver Set, With Soft PicoFinish Handle In storage pouch Item No. Slotted: .8, 1.2, 1.5, 2.0 x 40mm lbs. 26093 2.5, 3.0 x 50mm, 3.5, 4.0 x 60mm .54 261 Phillips Precision Screwdriver, With Soft PicoFinish Precision Handle Blade high alloy CVM steel. Hard chrome finished. Item No. Size mm Inch mm Inch mm Inch Pkg. 26130 000 40 1.6 2.0 .08 134 5.3 10 26132 00 40 1.6 2.0 .08 134 5.3 10 26135 0 50 2.0 3.0 .12 150 5.9 10 26136 0 75 3.0 3.0 .12 175 6.9 10 26140 1 60 2.4 4.0 .16 160 6.3 10 26142 1 80 3.1 4.0 .16 180 7.1 10 26145 1 150 5.9 4.0 .16 250 9.8 10 *Metric dimensions actual - Inch dimensions approximate In Roll-Up Pouch 26193 8pc Slotted & Phillips Precision Driver Set, With Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. ChromTop finish on tip for a perfect fit. In storage pouch Item Slotted: No. 1.0, 1.5, 2.0 x 40mm lbs. 26193 2.5 x 50mm, 3.5 x 60mm .55 Phillips: 00 x 40mm 0 x 50mm, 1 x 60mm 26195 5pc Precision Screwdrivers With Precision Soft PicoFinish Handle Item Slotted: No. 1.5, 2.5, 3.5mm lbs. 26195 Phillips: #0, #1 .25 * No Pouch - In clamshell 26196 5pc Precision Screwdrivers With Precision Soft PicoFinish Handle Item Phillips: #0, #1 No. Pentalobe: PL1 lbs. 26196 Tri-Wing: #000 .25 Tweezers: 2a SA ESD Flat Round Tip * No Pouch - In clamshell 26198 11pc Smartphone Precision Screwdrivers With Precision Soft PicoFinish Handle Item Slotted: 1.8mm No. Phillips: #000, #00, #0 26198 : T3, T4, T5, T6 Pentalobe: PL1 lbs. Tri-Wing: #000 .59 Tweezers: PSF SA ESD Long Flat Tip Toll Free: (800) 494-6104 10 Wiha Pico Soft Grip Screwdriver, With Precision 267 Soft PicoFinish Handle Blade high alloy CVM tool steel, hardened, hard chrome finish. Item No. Size mm Inch mm Inch Pkg. 26732 T1 40 1.6 134 5.3 10 26733 T2 40 1.6 134 5.3 10 26735 T3 40 1.6 134 5.3 10 26736 T4 40 1.6 134 5.3 10 26737 T5 40 1.6 134 5.3 10 26739 T6 40 1.6 140 5.5 10 26741 T7 40 1.6 140 5.5 10 26743 T8 40 1.6 140 5.5 10 26745 T9 50 2.0 150 5.9 10 26747 T10 50 2.0 150 5.9 10 26749 T15 60 2.4 160 6.3 10 26751 T20 60 2.4 160 6.3 10 *Metric dimensions actual - Inch dimensions approximate Pico Soft Grip Hex Inch & Metric 263 Hex Inch Screwdriver, With Precision Soft PicoFinish Handle Blade high alloy CVM tool steel, hardened, hard chrome finish. Item No. Inch mm Inch mm Inch Pkg. 26341 0.028(0.7) 40 1.6 134 5.3 10 26343 0.035(0.9) 40 1.6 134 5.3 10 26345 0.05(1.3) 40 1.6 134 5.3 10 26349 5/64(2.0) 50 2.0 150 5.9 10 26363 1/16 50 2.0 144 5.7 10 26367 3/32 60 2.4 160 6.3 10 26369 7/64 60 2.4 160 6.3 10 26371 1/8 60 2.4 160 6.3 10 *Metric dimensions actual - Inch dimensions approximate In storage pouch Pico Soft Grip Ball End Inch & Metric 264 Ball End Hex Inch Screwdriver, With Precision Soft PicoFinish Handle Blade high alloy CVM tool steel, hardened, hard chrome finish. Item No. Inch Inch mm Inch mm pkg. 26455 1/16 2.0 50 5.9 150 10 26457 5/64 2.0 50 5.9 150 10 26459 3/32 2.0 50 5.9 150 10 26461 7/64 2.4 60 6.3 160 10 26463 1/8 2.4 60 6.3 160 10 26465 9/64 2.4 60 6.3 160 10 26467 5/32 2.4 60 6.3 160 10 *Metric dimensions actual - Inch dimensions approximate In storage pouch 26392 8pc Hex Inch Precision Driver Set, Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. Item Hex Inch: lbs. No. .028, .035, .050 x 1.6” .24 26392 5/64, 1/16 x 2.0”, 3/32, 7/64, 1/8 x 2.4” 26793 8pc Precision Driver Set, With Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. ChromTop finish on tip for a perfect fit. Item : No. T1, T2, T3, T4, lbs. 26793 T5, T6, T7, T8 .50 In storage pouch 26796 8pc Precision Driver Set, Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. ChromTop finish on tip for a perfect fit. Item : No. T5, T6, T7, T8 x 40mm lbs. .57 26796 T9, T10 x 50mm, T15, T20 x 60mm 263 Hex Metric Driver, With Precision Soft PicoFinish Handle Item No. mm mm Inch mm Inch Pkg. 26341 .7(.028) 40 1.6 134 5.3 10 26343 .9(.035) 40 1.6 134 5.3 10 26345 1.3(.050) 40 1.6 134 5.3 10 26347 1.5 50 2.0 144 5.7 10 26349 2.0(5/64) 50 2.0 150 5.9 10 26351 2.5 60 2.4 160 6.3 10 26353 3.0 60 2.4 160 6.3 10 *Metric dimensions actual - Inch dimensions approximate In storage pouch 26393 7pc Hex Metric Precision Driver Set, Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. Item No. Hex Metric: lbs. 26393 .7, .9, 1.3 x 40mm .22 1.5, 2.0 x 50mm, 2.5, 3.0 x 60mm 26493 7pc Inch Ball End Hex Precision Driver Set, With Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. ChromTop finish on tip for a perfect fit. In storage pouch Item lbs. No. Ball End Hex Inch: .27 26493 1/16, 5/64, 3/32 x 2.0” 7/64, 1/8, 9/64, 5/32 x 2.4” 264 Ball End Hex Metric Screwdriver, With Precision Soft PicoFinish Handle. Blade high alloy CVM tool steel, hardened, hard chrome finish. Item No. mm mm Inch mm Inch pkg. 26441 1.3 40 1.6 134 5.3 10 26443 1.5 50 2.0 150 5.9 10 26445 2.0 50 2.0 150 5.9 10 26447 2.5 60 2.4 160 6.3 10 26449 3.0 60 2.4 160 6.3 10 *Metric dimensions actual - Inch dimensions approximate www.wihatools.com 11 Pico Soft Grip Nut Drivers Inch & Metric 265 Inch Nut Drivers, With Precision Soft PicoFinish Handle Blade high alloy chrome-vanadium-molybdenum tool steel, hardened, hard chrome finish. Item No. Inch Inch mm Inch mm pkg. 26571 3/32 2.4 60 6.3 160 10 26572 7/64 2.4 60 6.3 160 10 26573 1/8 2.4 60 6.3 160 10 26574 9/64 2.4 60 6.3 160 10 26575 5/32 2.4 60 6.3 160 10 26576 3/16 2.4 60 6.3 160 10 26577 7/32 2.4 60 6.3 160 10 26578 1/4 2.4 60 6.3 160 10 *Metric dimensions actual - Inch dimensions approximate 26593 8pc Inch Nut Driver Set, With Precision Soft PicoFinish Handle Blade high alloy CVM tool steel, hardened, hard chrome finish. Chrom-Top finish on tip for a perfect fit. In storage pouch Item Inch Nut Drivers: lbs. .72 No. 3/32, 7/64, 1/8, 9/64, 26593 5/32, 3/16, 7/32, 1/4” x 2.4” 265 Metric Nut Drivers, With Precision PicoFinish Handle Blade high alloy CVM tool steel, hardened, hard chrome finish. Item No. mm mm Inch mm Inch pkg. 26579 1.5 60 2.4 160 6.3 10 26581 2.0 60 2.4 160 6.3 10 26582 2.5 60 2.4 160 6.3 10 26583 3.0 60 2.4 160 6.3 10 26584 3.5 60 2.4 160 6.3 10 26585 4.0 60 2.4 160 6.3 10 26586 4.5 60 2.4 160 6.3 10 26587 5.0 60 2.4 160 6.3 10 26588 5.5 60 2.4 160 6.3 10 26589 6.0 60 2.4 160 6.3 10 *Metric dimensions actual - Inch dimensions approximate 26596 8pc Metric Nut Driver Set, With Precision Soft PicoFinish Handle Item Metric Nut Drivers: No. 2.0, 2.5, 3.0, 3.5, 4.0, lbs. 26596 4.5, 5.0, 5.5 x 60mm .66 Pico Soft Grip Precision Chip Lifter 26815 Soft PicoFinish Precision Chip Lifter Blade CVM steel, hardened, hard chromed. Item No. 26815 mm mm mm mm Inch lbs. Pkg. 1 3.5 50 150 5.9 .03 1 Standard Soft PicoFinish handle Pico Soft Grip Y-Type Precision Driver Y-Type (Used in iphone 7 or higher series) 266 Y-Type Precision Screwdriver, With Soft PicoFinish Precision Handle Blade high alloy CVM steel. Hard chrome finished. Item No. Size mm Inch mm Inch mm Inch 26631 000 40 1.6 2.0 .08 140 5.5 Pico Soft Grip Pentalobe 267 Pentalobe Screwdriver, With Precision Soft PicoFinish Handle Blade high alloy CVM tool steel, hardened, hard chrome finish. Item No. Size Inch mm Inch mm pkg. 26771 PL1 1.6 40 5.5 140 10 26772 PL2 1.6 40 5.5 140 10 26773 PL3 1.6 40 5.5 140 10 26774 PL4 1.6 40 5.5 140 10 26775 PL5 1.6 40 5.5 140 10 26776 PL6 1.6 40 5.5 140 10 *Metric dimensions actual - Inch dimensions approximate 6pc Precision Pentalobe Driver 26795 Set, Soft PicoFinish Handle Blade high alloy CVM steel. Hard chrome finished. Item No. Pentalobe Drivers: 26795 PL1, PL2, PL3, PL4, lbs. PL5, PL6 .40 75973 23pc Micro Bit Set, With Soft PicoFinish Handle CVM steel Micro Bits, hardened, on 4 mm hex stock. Ergonomic multi-component handle with rotating cap for maximum user comfort and precise control. Item Slotted: 1.5, 2.0, 2.5, 3.0, 3.5mm No. Phillips: 000, 00, 0, 1, 2 75973 : T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 lbs. PicoFinish® Precision Handle .82 Micro Bit Holder - 100mm Micro Bit Socket Adapter 1/4” Toll Free: (800) 494-6104 12 PicoFinish MagicSpring Precision Screwdrivers Insulated PicoFinish Precision Screwdrivers 1000Volt 267 MagicSpring Screw Holding Screwdriver, With Wiha-Precision Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. Molded on ergonomic Wiha-PicoFinish precision handle, molded on, soft grips. Item No. Size mm Inch mm Inch lbs. Pkg. 26721 T6 40 1.6 140 5.5 .03 10 26723 T7 40 1.6 140 5.5 .03 10 26725 T8 40 1.6 140 5.5 .03 10 26727 T9 50 2.0 150 5.9 .04 10 26729 T10 50 2.0 150 5.9 .04 10 26731 T15 60 2.4 160 6.3 .04 10 320 Insulated Slotted PicoFinish Screwdrivers. Individually Tested Protective Insulation 1000Volt AC, VDE & GS Tested. High quality CV steel, through hardened, black finish. Rotating cap for precise turning and control with fingertip. Item No. mm Inch mm mm lbs. Pkg. 1.5 .06 40 154 .05 1 32000 2.0 .08 40 154 .07 1 32001 2.5 .10 60 160 .07 1 32002 3.0 .12 60 160 .08 1 32003 3.5 .14 60 160 .08 1 32004 Wiha Proturn Precision Screwdrivers n r u t o r p Molded on ergonomic handle Tip precision ground for exact fit Rotating cap for precise turning and Tapered control with handle fingertip allows rapid Blade CVM steel, rotation black finish blades 1000Volt *Metric dimensions actual - Inch dimensions approximate 26798 6pc MagicSpring Screw Holding Screwdriver Set, With WihaPrecision Soft PicoFinish Handle Blade high alloy CVM steel, hardened, hard chromed. Molded on ergonomic WihaPicoFinish precision handle, molded on, soft grips. In storage pouch Item No. MagicSpring : lbs. 26798 T6, T7, T8 x 40mm .45 T9, T10, T15 x 50mm Insulated Phillips PicoFinish 321 Screwdrivers. Individually Tested Protective Insulation 1000Volt AC, VDE & GS Tested. Item No. Size mm mm lbs. Pkg. 00 40 154 .05 1 32106 0 60 160 .07 1 32107 1 60 160 .08 1 32108 1000Volt 32088 Item No. 32088 Individually Tested Protective Insulation 1000Volt AC, VDE and GS Tested 8pc Slotted/Phillips PicoFinish Set Slotted: 1.5, 2.0, 2.5, 3.0, 3.5mm lbs. Phillips: #00, #0, #1 .35 1000Volt 91118 Rugged Polyester Canvas Storage Pouch Holds 8 Precision Tools up to 170mm in length. Folding pouch. Has security flaps and velcro closer. Item No. Size lbs. pkg. 91118 14 1/2” W x 7 3/4” L .13 1 32085 Item No. 32085 5pc Slotted/Phillips PicoFinish Set Slotted: 1.5, 2.5, 3.5mm lbs. Phillips: #0, #1 .26 62994 14pc Inch/Metric Ball End Hex Work Tech Pack Proturn precision ball retainer handle & 13 Wiha interchangeable blades. 62994 Set includes the following blades: Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metric: 1.5, 2.0, 2.5, 3.0, 4.0mm lbs. .66 Set in canvas storage pouch 96800 Proturn Precision Chip Lifter Molded on precision handle. Blade CVM tool steel, hardened, black finish. Item No. Size mm mm Inch lbs. pkg. 96800 1.0 50 145 5.7 .07 1 www.wihatools.com 13 Wiha SYSTEM 4 Precision Handles and Blades Rotating Cap for precise turning & control Tapered Handle allows rapid rotation, requires less clearance Blades chrome-vanadiummolybdenum steel, hardened, hard chromed. On 4mm Hex shafts Tips Exact fit, precision machined Precision Handle high quality plastic, cadmium free. ESD Safe or Standard styles 26900 SYS 4 Standard Precision Handle, with rotating control cap. Accepts all SYSTEM 4 interchangeable blades. Wiha Precision handle, tapered, impact resistant. Ball retainer hold. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 26900 4.0 .1574 14.0 .55 .04 28000 ESD Safe Dissipative Precision Handle with rotating control cap. Surface resistant 106-109 Ohms. 4 mm hex retainer for all SYSTEM 4 interchangeable blades. Tapered handle, high quality plastic, impact resistant. Ball retainer hold. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 28000 4.0 .1574 14.0 .55 .04 269 SYSTEM 4 Slotted Reversible Blade High alloy CVM steel, hardened, hard chromed. Wiha vapor Chrome-Top finish on tips. Item No. mm mm mm Inch lbs. 26903 1.5 + 3.0 120 4.7 .05 26904 2.0 + 3.5 120 4.7 .05 26905 2.5 + 4.0 120 4.7 .06 269 SYSTEM 4 Pozidriv® Reversible Blade High alloy CVM steel, hardened, hard chromed. Wiha vapor Chrome-Top finish on tips. Item No. Size Size mm Inch lbs. 26922 0 + 1 120 4.7 .03 15mm Collet Lock Handle adjustable blade length from 15 to 95mm/ .6” to 3.75” 95mm Notes: 269 SYSTEM 4 Phillips Reversible Blade High alloy CVM steel, hardened, hard chromed. Wiha vapor Chrome-Top finish on tips. Item No. Size Size mm Inch lbs. 26911 000 + 00 120 4.7 .03 26912 0 + 1 120 4.7 .03 Reversible Blade 269 SYS 4 High alloy CVM steel, hardened, vapor chrome protected, Wiha vapor Chrome-Top finish on tips. 120mm/4.7” OAL. Item No. Size Size lbs. 26951 T6 + T8 .03 26952 T7 + T9 .03 26953 T10 + T15 .03 26954 T15 + T20 .03 269 SYSTEM 4 Combined Slotted/Phillips Reversible Blade High alloy CVM steel, hardened, hard chromed. Item No. mm Size mm Inch lbs. 26971 1.5 + 000 120 4.7 .05 26972 2.0 + 00 120 4.7 .05 26973 3.0 + 0 120 4.7 .05 26974 4.0 + 1 120 4.7 .06 Interchangeable 269 SYSTEM 4 Blade High alloy CVM steel, hardened, Wiha vapor Chrome-Top finish on tips. 120mm/4.7” OAL Item No. Size lbs. 26955 T3 .03 26956 T4 .03 26957 T5 .03 Toll Free: (800) 494-6104 14 Wiha SYSTEM 4 Precision Blades For angle entry 269 SYSTEM 4 Inch Hex Sizes, Interchangeable Blade High alloy CVM steel, hardened, corrosion protected. Item No. Inch mm Inch lbs. 26921 .050 120 4.7 .06 26923 1/16 120 4.7 .06 26924 5/64 120 4.7 .06 26925 3/32 120 4.7 .06 26926 7/64 120 4.7 .06 26927 1/8 120 4.7 .06 26928 9/64 120 4.7 .06 26929 5/32 120 4.7 .06 269 SYSTEM 4 Metric Hex Sizes, Interchangeable Blade High alloy CVM steel, hardened, corrosion protected. Item No. mm mm Inch lbs. 26913 0.7 120 4.7 .06 26914 0.9 120 4.7 .06 26916 1.5 120 4.7 .06 26917 2.0 120 4.7 .06 26918 2.5 120 4.7 .06 26919 3.0 120 4.7 .06 26920 4.0 120 4.7 .06 280 SYSTEM 4 Inch Ball End Hex Interchangeable Blade High alloy tool steel, hardened, corrosion protected. Ball end works at 30° angle entry for easy access to fasteners. Item No. Inch mm Inch lbs. 28021 .050 120 4.7 .06 28023 1/16 120 4.7 .06 28024 5/64 120 4.7 .06 28026 7/64 120 4.7 .06 28027 1/8 120 4.7 .06 28028 9/64 120 4.7 .06 28029 5/32 120 4.7 .06 For angle entry 280 SYSTEM 4 Metric Ball End Hex Interchangeable Blade High alloy tool steel, hardened, corrosion protected. Ball end works at 30° angle entry for easy access to fasteners. Item No. mm mm Inch lbs. pkg. 28033 1.5 120 4.7 .06 1 28034 2.0 120 4.7 .06 1 28035 2.5 120 4.7 .06 1 28036 3.0 120 4.7 .06 1 28037 4.0 120 4.7 .06 1 Notes: 269 SYSTEM 4 Nut Driver Inch, Interchangeable Blade High alloy chromevanadium-molybdenum steel, hardened, corrosion protected. 120mm/4.7” OAL Item No. Inch Inch Inch lbs. 26962 3/32 .16 .16 .04 26963 7/64 .20 .20 .04 26964 1/8 .20 .20 .04 26965 9/64 .21 .24 .04 26966 5/32 .22 .24 .04 26968 7/32 .30 .32 .04 26969 1/4 1.34 .36 .04 269 SYSTEM 4 Nut Driver Metric, Interchangeable Blade High alloy chromevanadium-molybdenum steel, hardened, corrosion protected. 120mm/4.7” OAL Item No. mm mm Inch Inch lbs. 26940 1.5 + 1.8 .12 .12 .03 26941 2.0 + 2.5 .16 .16 .03 26938 1.5 - .11 .11 .04 26939 1.8 - .12 .12 .04 26949 2.0 - .13 .13 .06 26950 2.5 - .16 .16 .06 26942 3.0 - .20 .20 .06 26943 3.2 - .20 .20 .06 26944 3.5 - .22 .24 .06 26945 4.0 - .22 .24 .06 26946 4.5 - .25 .28 .06 26947 5.0 - .27 .28 .06 26948 5.5 - .30 .32 .06 Notes: For angle entry 269 SYS 4 Metric Ball End & Standard Hex, Reversible Blade CVM steel, hardened, hard chromed. Wiha vapor Chrome-Top finish on tips. One side hex, other side ballpoint hex. Item No. mm mm mm Inch lbs. 26932 1.3 + 1.3 120 4.7 .05 26934 2.0 + 2.0 120 4.7 .06 26935 2.5 + 2.5 120 4.7 .06 26936 3.0 + 3.0 120 4.7 .06 26937 4.0 + 4.0 120 4.7 .06 www.wihatools.com 15 Wiha SYSTEM 4 Drive-Loc Precision Locking Tools D 26906 SoftFinish® Cushion Grip Drive-Loc Handle 4 mm hex retainer for all SYSTEM 4 interchangeable blades. Ball retainer hold. 105mm/4.13” OAL Item No. mm Inch mm Inch lbs. 26906 4.0 .1574 23 .91 .08 280 SYSTEM 4 Pozidriv® Drive-Loc Reversible Locking Blades On 4mm Hex blades Item No. Size Size lbs. 28002 0 + 1 .02 D 26961 ESD Safe Dissipative Precision Drive-Loc Handle Surface resistant 106-109 Ohms. 4 mm hex retainer for all SYSTEM 4 interchangeable blades. Ball retainer hold. 105mm/4.13” OAL Item No. mm Inch mm Inch lbs. 26961 4.0 .1574 23 .91 .08 26985 12pc Drive-Loc IV Precision ESD Safe Set In storage pouch Item No. 26985 ESD Safe Drive-Loc Handle Slotted: 1.5x3.0, 2.0x3.5, 2.5x4.0 lbs. .44 Phillips: 000x00, 0x1 : T1xT2, T3xT4, T5xT6, T6xT8, T7xT9, T10xT15 Drive-Loc 269 SYSTEM 4 Reversible Locking Blades On 4mm Hex blades Item No. Size Size lbs. 26977 T1 + T2 .02 26978 T3 + T4 .02 26979 T5 + T6 .02 26980 T6 + T8 .02 26981 T7 + T9 .02 26982 T10 + T15 .02 26983 T15 + T20 .02 D 269 SYSTEM 4 Slotted Drive-Loc Reversible Locking Blades On 4mm Hex blades Item No. mm mm lbs. 26958 1.5 + 3.0 .02 26959 2.0 + 3.5 .02 26960 2.5 + 4.0 .02 269 SYSTEM 4 Phillips Drive-Loc Reversible Locking Blades On 4mm Hex blades Item No. Size Size lbs. 26975 000 + 00 .02 26976 0 + 1 .02 280 SYSTEM 4 Metric Hex Drive-Loc Reversible Locking Blades On 4mm Hex blades Item No. mm mm lbs. 28003 1.3 + 1.3 .02 28004 1.5 + 1.5 .02 28005 2.0 + 2.0 .02 28006 2.5 + 2.5 .02 28007 3.0 + 3.0 .02 28008 4.0 + 4.0 .02 280 SYSTEM 4 Metric Nut Drivers DriveLoc Reversible Locking Blades On 4mm Hex blades Item No. mm mm lbs. 28012 3.2 + - .02 Precision 26930 7pc Drive-Loc IV ESD Safe Set In storage pouch Item No. 26930 ESD Safe Drive-Loc Handle : T3xT4, T5xT6, lbs. .56 T6xT8, T7xT9, T10xT15, T15xT20 Toll Free: (800) 494-6104 16 Micro Bits Made in Germany Wiha SYSTEM 4 Micro Bits - 10 Bit Packs CVM steel, hardened, on 4 mm hex stock. Tips Exact fit, precision machined Bits High alloy CVM steel, hardened Use bits directly in handle or with 4” bit extension 10 Bit Pack 756 SYSTEM 4 Hex Metric Micro Bits Item No. mm mm Inch lbs. 75616 .7 28 1.1 .06 75617 .9 28 1.1 .06 75618 1.3 28 1.1 .06 75619 1.5 28 1.1 .07 75620 2.0 28 1.1 .07 75621 2.5 28 1.1 .07 75622 3.0 28 1.1 .08 75623 4.0 28 1.1 .08 10 Bit Pack 10 Bit Pack 756 SYSTEM 4 Slotted Micro Bits Item No. mm mm Inch lbs. 75602 0.8 28 1.1 .06 75603 1.2 28 1.1 .06 75604 1.5 28 1.1 .06 75605 1.8 28 1.1 .06 75606 2.0 28 1.1 .07 75607 2.5 28 1.1 .07 75608 3.0 28 1.1 .07 75609 3.5 28 1.1 .07 75610 4.0 28 1.1 .08 10 Bit Pack 756 SYSTEM 4 Phillips Micro Bits Item No. Size mm Inch lbs. 75611 000 28 1.1 .06 75612 00 28 1.1 .06 75613 0 28 1.1 .06 75614 1 28 1.1 .07 75615 2 28 1.1 .07 756 SYSTEM 4 Hex Inch Micro Bits Item No. Inch mm Inch lbs. 75628 .028 28 1.1 .06 75629 .035 28 1.1 .06 75630 .050 28 1.1 .06 75631 1/16 28 1.1 .06 75632 5/64 28 1.1 .06 75633 3/32 28 1.1 .07 75634 7/64 28 1.1 .07 75635 1/8 28 1.1 .07 75636 9/64 28 1.1 .08 75637 5/32 28 1.1 .08 10 Bit Pack 756 SYS 4 Metric Security Hex Micro Bits Item No. mm mm Inch lbs. 75624 2.0 28 1.1 .06 75626 3.0 28 1.1 .07 75627 4.0 28 1.1 .08 10 Bit Pack Micro Bits 756 SYSTEM 4 Item No. Size mm Inch lbs. 75660 T1 28 1.1 .06 75661 T2 28 1.1 .06 75662 T3 28 1.1 .06 75663 T4 28 1.1 .06 75664 T5 28 1.1 .06 75665 T6 28 1.1 .06 75666 T7 28 1.1 .06 75667 T8 28 1.1 .07 75668 T9 28 1.1 .07 75669 T10 28 1.1 .07 75670 T15 28 1.1 .08 75671 T20 28 1.1 .08 10 Bit Pack 756 SYSTEM 4 Security Micro Bits Item No. Size mm Inch lbs. 75681 T10s 28 1.1 .07 75683 T20s 28 1.1 .08 10 Bit Pack 756 SYSTEM 4 Inch Nut Setters Item No. Inch Inch mm Inch lbs. 75644 5/64 30 1.2 .07 75645 3/32 30 1.2 .07 75646 7/64 30 1.2 .07 75647 1/8 30 1.2 .07 75648 9/64 30 1.2 .08 75649 5/32 30 1.2 .08 75650 3/16 30 1.2 .08 75651 7/32 30 1.2 .09 10 Bit Pack 10 Bit Pack 756 SYSTEM 4 Pentalobe Micro Bits Item No. Size mm Inch lbs. 75672 PL1 28 1.1 .06 75673 PL2 28 1.1 .06 75674 PL3 28 1.1 .07 75675 PL4 28 1.1 .07 75676 PL5 28 1.1 .07 10 Bit Pack 756 SYS 4 Security Hex Inch Micro Bits Item No. Inch mm Inch lbs. 75638 5/64 28 1.1 .06 75639 3/32 28 1.1 .06 75641 1/8 28 1.1 .07 756 SYSTEM 4 Metric Nut Setters Item No. Metric mm mm Inch lbs. 75652 2.0 30 1.2 .07 75653 2.5 30 1.2 .07 75654 3.0 30 1.2 .07 75655 3.5 30 1.2 .07 75656 4.0 30 1.2 .08 75657 4.5 30 1.2 .08 75658 5.0 30 1.2 .08 75659 5.5 30 1.2 .09 www.wihatools.com 17 Wiha SYSTEM 4 Micro Bits SYSTEM 4 Handles & Micro Bits Tips Exact fit, precision machined Rotating Cap for precise turning and control Tapered Handle allows rapid rotation, requires less clearance Bits High alloy CVM steel, hardened 750 SYSTEM 4 Slotted Micro Bits CVM steel, hardened, on 4 mm hex stock. Item No. mm mm Inch lbs. 75008 0.8 28 1.1 .01 75012 1.2 28 1.1 .01 75015 1.5 28 1.1 .01 75018 1.8 28 1.1 .01 75020 2.0 28 1.1 .01 75025 2.5 28 1.1 .01 75030 3.0 28 1.1 .01 75035 3.5 28 1.1 .01 75040 4.0 28 1.1 .01 Use bits directly in handle or with 4” bit extension 75800 SYSTEM 4 Standard Precision Bit Handle Accepts all SYSTEM 4 Series bits. 110mm/4.3” OAL Item No. mm Inch mm Inch lbs. 75800 4.0 .1574 14.0 .55 .06 751 SYSTEM 4 Phillips Micro Bits CVM steel, hardened, on 4 mm hex stock. Item No. Size mm Inch lbs. 75105 000 28 1.1 .01 75110 00 28 1.1 .01 75115 0 28 1.1 .01 75120 1 28 1.1 .01 75125 2 28 1.1 .02 Micro Bits 757 SYSTEM 4 CVM steel, hardened, on 4 mm stock. Item No. Size mm Inch lbs. 75701 T1 28 1.1 .01 75702 T2 28 1.1 .01 75703 T3 28 1.1 .01 75704 T4 28 1.1 .01 75705 T5 28 1.1 .01 75706 T6 28 1.1 .01 75707 T7 28 1.1 .01 75708 T8 28 1.1 .01 75709 T9 28 1.1 .01 75710 T10 28 1.1 .01 75715 T15 28 1.1 .01 75720 T20 28 1.1 .01 757 SYSTEM 4 Security Micro Bits Item No. Size mm Inch lbs. 75735 T10s 28 1.1 .01 75742 T20s 28 1.1 .01 D Dissipative 75801 SYSTEM 4 ESD Safe Precision Bit Handle 110mm/4.3” OAL Advantages: • For working in ESD sensitive applications Surface resistant 106-109 Ohms • Ball retainer holds bits securely in place • Accepts all SYSTEM 4 Series bits Item No. mm Inch mm Inch lbs. 75801 4.0 .1574 14.0 .55 .06 SYSTEM 4 Micro Bit Extension Blades 75900 Extension Blade For SYS 4 Micro Bits Shaft CVM steel, hardened, corrosion protected. Ball retainer bit extension for 4mm bits. Item No. Size mm mm lbs. 75900 4.0 100 4.0 .07 75901 Magnetic Bit Extension Blade For SYS 4 Micro Bits Shaft CVM steel, hardened, corrosion protected. Magnetic bit holder. Item No. Size mm mm lbs. 75901 4.0 100 4.0 .04 753 SYSTEM 4 Hex Metric Micro Bits CVM steel, hardened, on 4 mm hex stock. Item No. mm mm Inch lbs. 75307 .7 28 1.1 .01 75309 .9 28 1.1 .01 75313 1.3 28 1.1 .01 75315 1.5 28 1.1 .01 75320 2.0 28 1.1 .01 75325 2.5 28 1.1 .01 75330 3.0 28 1.1 .01 75340 4.0 28 1.1 .01 753 SYSTEM 4 Hex Inch Micro Bits CVM steel, hardened, on 4 mm hex stock. Item No. Inch mm Inch lbs. 75307 .028 28 1.1 .01 75309 .035 28 1.1 .01 75313 .050 28 1.1 .01 75350 1/16 28 1.1 .01 75352 5/64 28 1.1 .01 75354 3/32 28 1.1 .01 75356 7/64 28 1.1 .01 75358 1/8 28 1.1 .01 75360 9/64 28 1.1 .01 75340 5/32 28 1.1 .01 753 SYS 4 Metric Security Hex Micro Bits CVM steel, hardened, on 4 mm hex stock. Item No. mm mm Inch lbs. 75322 2.0 28 1.1 .01 75332 3.0 28 1.1 .01 75342 4.0 28 1.1 .01 753 SYS 4 Security Hex Inch Micro Bits Item No. Inch mm Inch lbs. 75362 5/64 28 1.1 .01 75364 3/32 28 1.1 .01 75366 7/64 28 1.1 .01 75368 1/8 28 1.1 .01 75370 9/64 28 1.1 .01 75372 5/32 28 1.1 .01 Micro Bit 1/4” Drive Power Tool Adapter For 4mm Bits 2.3” OAL 75902 Micro Bit 1/4” Drive Power Tool Adapter CVM steel, hardened, corrosion protected. Item No. Size mm mm lbs. 75902 4.0 60 4.0 .07 Toll Free: (800) 494-6104 18 Wiha SYSTEM 4 Micro Bits 757 SYSTEM 4 Pentalobe Micro Bits CVM steel, hardened, on 4 mm hex stock. Item No. Size mm Inch lbs. 75743 PL1 28 1.1 .01 75744 PL2 28 1.1 .01 75745 PL3 28 1.1 .01 75746 PL4 28 1.1 .01 75747 PL5 28 1.1 .01 75748 PL6 28 1.1 .01 758 SYSTEM 4 Metric & Inch Nut Setters CVM steel, hardened, on 4 mm hex stock. Item No. Metric mm mm Inch lbs. 75820 2.0 30 1.2 .01 75821 2.5 30 1.2 .01 75822 3.0 30 1.2 .01 75823 3.5 30 1.2 .01 75824 4.0 30 1.2 .01 75825 4.5 30 1.2 .01 75826 5.0 30 1.2 .01 75827 5.5 30 1.2 .01 Inch Inch mm Inch lbs. 75810 5/64 30 1.2 .01 75811 3/32 30 1.2 .01 75812 7/64 30 1.2 .01 75813 1/8 30 1.2 .01 75814 9/64 30 1.2 .01 75815 5/32 30 1.2 .01 75816 3/16 30 1.2 .01 75817 7/32 30 1.2 .01 Micro Bit Replacement Packs On 4mm Hex Stock 75982 10pc SYSTEM 4 Hex Inch Micro Bit Replacement Pack CVM steel, hardened, on 4 mm hex stock. Item No. 75982 SYSTEM 4 Micro Bit Set Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” lbs. .06 75987 10pc SYSTEM 4 Slotted & Phillips Micro Bit Replacement Pack CVM steel, hardened, on 4 mm hex stock. Item No. 75987 SYSTEM 4 Micro Bit Set Slotted: 1.5, 2.0, 2.5, 3.0, 3.5mm Phillips: #000, 00, 0, 1 lbs. .06 75984 10pc SYSTEM 4 Slotted Micro Bit Replacement Pack CVM steel, hardened, on 4 mm hex stock. Item No. 75984 SYSTEM 4 Micro Bit Set Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm lbs. .06 Micro Bit 75988 10pc SYSTEM 4 Replacement Pack CVM steel, hardened, on 4 mm hex stock. Item No. 75988 SYSTEM 4 Micro Bit Set : T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 lbs. .06 75986 10pc SYSTEM 4 Phillips & Pentalobe Micro Bit Replacement Pack CVM steel, hardened, on 4 mm hex stock. Item No. 75986 SYSTEM 4 Micro Bit Set Phillips: #000, 00, 0, 1 Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 lbs. .06 1/4” Drive Micro Bit Tool Adapters 75802 Micro Bit To 1/4” Drive Insert Bit Adapter magnets to hold 4mm Micro Bits Item No. Size mm mm lbs. 75802 4.0 25 4.0 .01 75803 Long Micro Bit To 1/4” Drive Insert Bit Adapter Uses spring clip non-magnetic to hold 4mm Micro Bits Item No. Size mm mm lbs. 75803 4.0 38 4.0 .02 Micro Bit 4mm To 1/4” Socket Adapter 75806 Micro Bit 4mm to 1/4” Socket Adapter CVM steel, hardened. Item No. mm Inch lbs. 75806 28 1.125 .02 www.wihatools.com 19 Wiha SYS 4 Micro Bits & Compact Bit Sets D 26 Pc . Set 75999 26pc SYS 4 Slotted, Phillips, Hex Inch & Metric Precision Interchangeable Bit Set. In Compact Fold Out Box. Precision handle, bit extension & 24 interchangeable bits. Item No. Combination Bit Set 75999 Set with Standard Precision Handle Set includes the following bits: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 Hex Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension lbs. .64 18 Pc. Set 75395 18pc SYS 4 Hex Inch & Metric Precision Interchangeable Bit Set. In Compact Fold Out Box. Wiha precision handle, bit extension and 16 Wiha interchangeable bits. Item No. Combination Bit Set 75395 Set with Standard Precision Handle Includes the following bits: Hex Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension lbs. .58 D 27 Pc. Set 26 Pc. Set 75995 26pc SYSTEM 4 Precision Interchangeable Bit Set. In Compact Fold Out Box Sets includes Wiha precision handle, bit extension & 24 Wiha interchangeable bits. Item SYSTEM 4 Micro Bit Set No. Set with ESD Safe Precision Handle 75995 and the following bits: : T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: #000, 00, 0, 1 100mm Bit Extension lbs. .54 27 Pc. Set 759 sets 27pc SYSTEM 4 Slotted/Phillips/ Hex Inch/ Precision Interchangeable Bit Set. In Compact Fold Out Box. Sets include your choice of Wiha precision handle, bit extension & 25 Wiha interchangeable bits. Item Handle Options for SYSTEM 4 No. Combination Bit Sets 75991 Set with Standard Precision Handle 75992 Set with ESD Safe Precision Handle Sets include the following bits: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension lbs. .64 75994 27pc SYSTEM 4 Slotted/ Phillips/Hex Metric/ Precision Interchangeable Bit Set. In Compact Fold Out Box. Set includes Wiha precision handle, bit extension and 25 Wiha interchangeable bits. Item SYSTEM 4 No. Combination Bit Set 75994 Set with ESD Safe Precision Handle Set includes the following bits: Slotted: 1.5, 2.0, 3.0, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm 100mm Bit Extension lbs. .64 40 P c. S et D 75996 40pc SYSTEM 4 Interchangeable Bit Set. Includes Wiha precision handle, bit extension & 38 interchangeable bits. Item SYSTEM 4 No. Combination Bit Set 75996 Set with ESD Safe Precision Handle Set includes the following bits: Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15 Hex Metric: 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .028, .035, .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” 100mm Bit Extension lbs. 1.04 Toll Free: (800) 494-6104 20 SYSTEM 4 Interchangeable Bit Sets Technicians MicroBit Sets • Micro Precision Bits on 4mm Hex Drive • Bits of Exclusive CRM-72 Tool Steel • Handle uses non-magnetic ball retainer • Use bits in extension only • Standard extension adds 4” to length • Non-magnetic bit extension Surface resistance of handles is 106 - 109 Ohms D Rotation cap Light weight & compact Handle tapered for precise control 75096 16pc SYSTEM 4 Hex Inch & Metric Compact ESD Precision Interchangeable Bit Set Item No. Combination Bit Set 75096 Set with ESD Safe Precision Handle Hex Inch: 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Hex Metric: .9, 1.3, 1.5, 2.0, 2.5, lbs. 3.0, 4.0mm .17 100mm Bit Extension Bits hardened for extreme durability D D 16pc SYSTEM  4 Slotted, Phillips, Compact ESD Precision Interchangeable Bit Set Item No. Combination Bit Set 75093 Set with ESD Safe Precision Handle Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: 00, 0, 1 lbs. : T6, T7, T8, T9, T10, T15, T20 .17 100mm Bit Extension 75093 D 75094 16pc SYSTEM 4 Slotted, Phillips, Hex Inch Compact ESD Precision Interchangeable Bit Set Item No. Combination Bit Set 75094 Set with ESD Safe Precision Handle Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: 00, 0, 1 Hex Inch: .035, .050, 1/16, 5/64, lbs. 3/32, 7/64, 1/8” .17 100mm Bit Extension D 75095 16pc SYSTEM 4 Slotted, Phillips, Hex Metric Compact ESD Precision Interchangeable Bit Set Item No. Combination Bit Set 75095 Set with ESD Safe Precision Handle Slotted: 1.5, 2.0, 2.5, 3.0mm Phillips: 00, 0, 1 Hex Metric: .9, 1.3, 1.5, 2.0, 2.5, lbs. 3.0, 4.0mm .17 100mm Bit Extension 75097 16pc SYSTEM 4 Slotted, Phillips, Pentalobe Compact ESD Precision Interchangeable Bit Set Item No. Combination Bit Set 75097 Set with ESD Safe Precision Handle Slotted: 1.2, 1.5, 2.0, 2.5, 3.0mm Phillips: 000, 00, 0, 1, 2 lbs. Pentalobe: PL1, PL2, PL3, PL4 .17 100mm Bit Extension 91109 Black Cartridge Holder Holds 14 Micro bits 4mm. 1” OAL Item No. mm mm lbs. 91109 4.0 25.4 .01 Includes Dust Cover D 75968 68pc SYSTEM 4 Micro Bit Set Includes ESD handle, Micro bit storage handle, micro bit extension & 65 micro bits. Item No. 75968 Includes the following micro bits: Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, lbs. 3.0, 3.5, 4.0mm .70 Phillips: 000, 00, 0, 1, 2 : T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T15, T20 Hex Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Nut Drivers Metric: 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm Nut Drivers Inch: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32” Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 Magnetic 1/4” to 4mm Adapter * Does not include storage box D D 75965 65pc SYSTEM 4 Master Tech ESD & Ratchet With Micro Bits. In Storage Box. Includes Wiha precision ESD Safe handle, micro bit extension, 72 tooth ratchet & 62 interchangeable micro bits. Item No. lbs. 1.16 75965 Includes the following micro bits: Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1 : T3, T4, T5, T6, T7, T8, T9, T10, T15, T20 Hex Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Nut Drivers Metric: 2.0 - 5.5mm Nut Drivers Inch: 5/64 - 7/32” Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 Magnetic 1/4” to 4mm Adapter 75971 68pc SYSTEM 4 Micro Bit Set Includes ESD handle, Micro bit storage handle, micro bit extension & 65 micro bits. Item No. Set In Zipper Case 75971 Includes the following micro bits: Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, lbs. 3.0, 3.5, 4.0mm .96 Phillips: 000, 00, 0, 1, 2 : T1, T2, T3, T4, T5, T6, T7, T8, T9, T10, T15, T20 Hex Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32” Nut Drivers Metric: 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5mm Nut Drivers Inch: 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32” Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 Magnetic 1/4” to 4mm Adapter www.wihatools.com 21 SYSTEM 4 Interchangeable Bit Sets Micro Bit Handle Storage Sets Micro precision bits on 4mm hex drive Bits of exclusive CRM-72 tool steel Storage handle Bits hardened for extreme durability D 75980 68pc SYSTEM 4 Master Tech Micro Bit Set. Includes Wiha ESD Safe Precision Handle, 1/4” to 4mm Adapter, 100mm Bit Extension & 36 Micro Bits. Item No. SYSTEM 4 Micro Bit Set 75980 Includes The Following Bits: Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm Phillips: 000, 00, 0, 1, 2 : T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 Hex Metric: 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6 lbs. .38 75981 7pc Micro Bit Handle Storage Slotted & Phillips Bit Set Wiha precision storage handle & 6 Micro Bit interchangeable 4mm bits. Item Set with Micro Bit Precision No. Storage Handle 75981 Slotted: 1.2, 1.5, 2.0mm Phillips: 000, 00, 0 lbs. .08 D 75993 28pc SYSTEM 4 Premium ESD Safe Micro Bit Set. Includes Wiha ESD Safe Precision Handle, 1/4” to 4mm Adapter, 100mm Bit Extension, ESD Safe Tweezers & 21 Micro Bits. Item No. SYSTEM 4 Micro Bit Set 75993 Micro Bits: Slotted: 0.8, 1.5, 2.0, 2.5, 3.0, 3.5mm Phillips: 000, 00, 0, 1, 2 : T1, T2, T3, T4, T5, T6, T7, T8, T9, T10 ESD Safe Tweezers: 5SA ESD, 7aSA ESD, 2ASA ESD, AASA ESD, OOSA ESD lbs. .95 75805 SYSTEM 4 Micro Bit Storage Handle Accepts all SYSTEM 4 Series bits. 108mm / 4.25” OAL Item No. mm Inch lbs. 75805 4.0 .1574 .05 75985 7pc Micro Bit Handle Storage Bit Set Wiha precision storage handle & 6 Micro Bit interchangeable 4mm bits. Item Set with Micro Bit Precision No. Storage Handle 75985 T3, T4, T5, T6, T7, T8 lbs. .08 75983 7pc Micro Bit Handle Storage Hex Inch Bit Set Wiha precision storage handle & 6 Micro Bit interchangeable 4mm bits. Item Set with Micro Bit Precision No. Storage Handle 75983 Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8” lbs. .08 Toll Free: (800) 494-6104 22 The Comfortable Precision Pliers & Cutters Electronic Diagonal Cutters Electronic Oblique 48O Cutter Full Flush Electronics pliers with cutting edges are designed especially for cutting soft to medium hard wires. Precision ground cutting edges for smooth cuts Lay-on, riveted precision joint Glare free black finish Light weight design for maximum user comfort in production work C70 tool steel HR60 hardness Electronic Diagonal Cutters Full Flush 56812 Precision Electronic Diagonal Cutters, Narrow Shape Extra narrow, short head for working in particularly restricted spaces. Cutting edge - full flush. With return spring. For absolutely flush cutting of copper wires in difficult to access locations. lbs. .19 Pkg. Item No. mm Inch Cut Capacity 56812 118 4.5 0.8mm/16AWG 1 Electronic Diagonal Cutters Narrow Front Cutter/Long Nose Pliers Full Flush Wire Holding Spring Full Flush 56818 Precision Electronic Diagonal Cutters, Wide Pointed Head Cutting edge full flush. With return spring. C70 special tool steel. For an absolutely flush cut of copper wire. Item No. mm Inch Cut Capacity lbs. Pkg. 56818 138 5.5 1.3mm/16AWG .22 1 Electronic Diagonal Cutters 56813 Precision Electronic Diagonal Full Flush Cutters With Wire Trapping Spring Extra narrow, short head for working in particularly restricted spaces. Cutting edge full flush. With return spring. C70 special tool steel. For absolutely flush cutting of copper wires in difficult to access locations. Item No. mm Inch Cut Capacity lbs. Pkg. 56813 128 5.0 1.0mm/16AWG .19 1 Electronic Diagonal Cutters Full Flush Semi Flush 56815 Precision Electronic Diagonal Cutters, Wide Pointed Head Cutting edge semi flush. With return spring. C70 special tool steel. Universal small diagonal cutter for cutting copper wires. lbs. .23 Item Cut Medium No. mm Inch Capacity Hard Wire Pkg. 1 56815 138 5.5 2.0mm/16AWG 0.8 56833 Electronic Oblique 48O Cutter Wide pointed head. Cutting edge - full flush. With cutting edge at 48O for cutting obliquely from above or from the side. C70 special tool steel. For absolutely flush cutting of copper wires in difficult to access locations. Item No. mm Inch Cut Capacity lbs. Pkg. 56833 138 5.5 1.3mm/16AWG .22 1 Wire Holding Spring Full Flush 56830 Electronic Narrow 30O Front Cutter / Long Nose Pliers Extremely narrow, short head for working in particularly restricted spaces. Cutting edge - full flush. Edge at 30O to face end of pliers for cutting obliquely from above or form the side. C70 special tool steel. For absolutely flush cutting of copper wires in difficult to access locations. Item No. mm Inch Cut Capacity lbs. Pkg. 56830 118 4.5 0.6mm/16AWG .19 1 Electronic Stripping Pliers 56825 Precision Electronic Diagonal Cutters, Wide Shape With Wire Holding Spring Wide, Pointed head. Cutting edge full flush. With return spring & fixture for holding ends of wires that have been cut off. For an absolutely flush cut of copper wire. lbs. Pkg. Item No. mm Inch Cut Capacity 56825 138 5.5 1.3mm/16AWG .23 1 Electronic Pointed Pliers 56801 Electronic Short Nose Precision Pliers Narrow, short head. Smooth jaws. Width at tip is only 1.2mm. C70 special tool steel. For holding small components as well as for holding and angling wires. Item No. mm Inch Pkg. lbs. 56801 138 5.5 1 .23 56871 Electronic Stripping Pliers Wide long head with ridged gripping surface, shears blade and firm wire stripping stations. With opening spring and locking mechanism. Wire stripping stations 0.81 / 1.0 / 1.3 / 1.6 / 2.0 / 2.59mm, AWG 20 / 18 / 16 / 14 / 12 / 10. #56871 mm Inch Ø AWG lbs. Pkg. 180 7.0 0.81-2.59 20-10 .15 1 www.wihatools.com 23 D Professional Quality ESD Tweezers ESD SAFE • STATIC DISSIPATIVE • HYPO ALLERGENIC COATED • TEXTURED GRIPPING SURFACE Universal Fine Point Tweezers Very Fine Points/Tapered To Tip Angled 3.5 to 7mm Diameter Item No. Description wt. 44501 AA SA ESD-130mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 44508 4 SA ESD - 110mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 44515 54 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Long Narrow Body Low Force Extra Fine Points/Tapered To Tip Narrow Rounded Tip Serrated, Guide Pin Item No. Description wt. 44503 SS SA ESD - 135mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 44509 5 SA ESD - 110mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, antimagnetic and acid resistant. Item No. Description wt. 44518 22 SA ESD - 150mm .10 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Reduced Body To Medium Point Curved Extra Fine Rounded Tips Universal Blunt Tip Serrated Item No. Description wt. 44504 2 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 44510 7a SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 44520 40 SA ESD - 145mm .11 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Flat Round Tip Smooth Sides Holds 0.8 to 2mm Diameter MicroTip 45O Hook 1x1x2mm Item No. Description wt. 44511 50 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 44521 12 SA-SMD ESD-120mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 44505 2a SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Fine Round Points For Assembly Item No. Description wt. 44506 3 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Holds 1.5 to 3mm Diameter Item No. Description wt. 44512 51 SA ESD - 130mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. 10pc ESD Safe Tweezers Set Fine Round Points Shorter Holds 6.5 to 10mm Diameter Item No. Description wt. 44507 3c SA ESD - 110mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 44514 53 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 44593 10pc Set Includes: 1.05 AA SA Fine Point, 2a SA Flat Round Tip, 3 SA Round Point, 3c SA Fine Round Points Shorter, 4 SA Very Fine Points, 7a SA Curved Extra Fine, PSF SA Flat-1.0mm Wide, 7abb SA Curved Extra Fine, 5bb SA Extra Fine Bent, 4b SA Very Fine Point 40° Toll Free: (800) 494-6104 24 Wiha Professional Quality ESD Safe Tweezers MicroTip For Chips Angled 1.6 x 1 x 1mm Flat Bent 35O 2mm Diameter Grip Radius Narrow Body, Bent, Long Guide Pin, Serrated Item No. Description wt. 44522 13 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 44530 59 SA-SMD ESD-117mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 55532 22b SA ESD - 155mm .10 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. S Long Flat to 1.0mm Wide No Serration Item No. Description wt. 44523 PSF SA ESD-125mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. ESD Safe General Purpose Fine Point Blunt Tips - 1.0mm Wide Serrated Item No. Description wt. 44531 1 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 55533 PSF SA ESD S -125mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Curved Extra Fine, 3mm Long Straight Tip Heavy Duty Strong Tweezers Tapered To Strong Point Item No. Description wt. 44525 7abb SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 44532 00 SA ESD - 120mm .09 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Angled Extra Fine Points Bent 30O - 3mm Long Tips Angled & Slightly Bent With Extra Fine Tips Item No. Description wt. 44527 5abb SA ESD - 117mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description wt. 44533 7 SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, antimagnetic and acid resistant. Extra Fine Points Bent 30O - 3mm Long Tips Item No. Description wt. 44528 5bb SA ESD-107mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. MicroTip 30O Bend & 0.5mm Slot Milled Item No. Description wt. 55531 11SA-SMD ESD-117mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Flat and Broad Tips 3mm Wide Item No. Description wt. 55534 F SA ESD - 120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. MicroTip Straight & 0.5mm Slot Milled Item No. Description wt. 55535 8ab SA-SMD ESD-120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. MicroTip 30O Bent & Angled With 0.5 Slot Item No. Description wt. 55536 19 SA-SMD ESD-120mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. www.wihatools.com 25 Wiha Professional Quality ESD Safe Tweezers Chip Holding Curved Fine MicroTip Inspection Mirrors All Stainless Detachable & Boilable Inspection Mirrors - Detachable All Stainless For Visual Checks and Fault Finding at Inaccessible Locations Item No. Description wt. 55537 R10 SA SMD ESD - 117mm .07 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Light weight, tubular Stainless Steel Natural Finish, Stainless Steel Mirrors-Clean Room Quality 40426 - #6 10mm 40410 - #0 26mm Very Fine Points 40° Tapered To Tip Inspection Mirror - Stainless 10mm Inspection Mirror - Stainless 26mm Item No. Description wt. 55539 4b SA ESD - 110mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description 40410 #0 IM - 216mm Item No. Description 40426 #6 IM - 229mm wt. .09 wt. .10 40430 - #8 30mm 14mm 40414 - #0 Wafer Tweezer Item No. Description wt. 55538 72a SA ESD - .07 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Inspection Mirror - Stainless 14mm Inspection Mirror - Stainless 30mm Item No. Description 40414 #0 IM - 216mm Item No. Description 40430 #8 IM - 232mm wt. .09 wt. .10 20mm 40420 - #3 Inspection Mirror - Stainless 20mm 9mm Wide With Back Stop Pins - Wafer Item No. Description wt. 55546 89 SA ESD - 125mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. Item No. Description 40420 #3 IM - 224mm wt. .09 22mm 40422 - #4 Inspection Mirror - Stainless 22mm Short Stem Item No. Description 40422 #4 IM -224mm Angled 12mm Wide Flat, Back Stop - Wafer Item No. Description wt. 55547 91 SA ESD - 125mm .08 Static dissipative, ESD Safe hypo allergenic tweezers made from Vommaloy. Special stainless steel, anti-magnetic and acid resistant. wt. .10 7pc Inspection Mirror Set Item No. 40490 Description wt. 7pc Set Includes: .67 10mm, 14mm, 20mm, 22mm 24mm, 26mm, 30mm 40424 - #5 24mm Inspection Mirror - Stainless 24mm Short Stem Item No. Description 40424 #5 IM - 225mm wt. .10 Disposable Inspection Mirrors Item No. Description wt. 40425 5 Pack - Plastic .10 Set includes: White disposable inspection mirror #5 Inspection Mirrors - 24mm x 146mm Toll Free: (800) 494-6104 26 Item No. Page 26000 4 26001 4 26008 4 26010 4 26012 4 26015 4 26018 4 26020 4 26022 4 26023 4 26025 4 26027 4 26028 4 26030 4 26032 4 26033 4 26034 4 26035 4 26040 4 26041 4 26042 4 26050 9 26051 9 26052 9 26053 9 26055 9 26060 9 26061 9 26065 9 26066 9 26068 9 26070 9 26072 9 26073 9 26074 9 26076 9 26079 9 26080 9 26090 4 26092 5 26093 9 26099 4 26100 4 26101 4 26102 4 26105 4 26107 4 26108 4 26109 4 26110 4 26113 4 26114 4 26115 4 26130 9 26132 9 26135 9 26136 9 26140 9 26142 9 Item No. Page 26145 9 26190 4 26192 5 26193 9 26194 5 26195 9 26196 9 26197 4 26198 9 26199 4 26205 5 26210 5 26307 5 26309 5 26313 5 26315 5 26316 5 26320 5 26323 5 26325 5 26327 5 26330 5 26331 5 26333 5 26336 5 26340 5 26341 10 26343 10 26345 10 26347 10 26349 10 26351 10 26353 10 26363 10 26367 10 26369 10 26371 10 26390 5 26391 5 26392 10 26393 10 26399 5 26413 6 26415 6 26416 6 26419 6 26420 6 26423 6 26425 6 26427 6 26430 6 26431 6 26436 6 26439 6 26440 6 26441 10 26443 10 26445 10 26447 10 Item No. Page Item No. Page Item No. Page Item No. Page 26449 10 26455 10 26457 10 26459 10 26461 10 26463 10 26465 10 26467 10 26490 6 26491 6 26493 10 26499 6 26510 7 26515 7 26520 7 26523 7 26525 7 26527 7 26530 7 26531 7 26532 7 26535 7 26536 7 26539 7 26540 7 26545 7 26547 7 26550 7 26555 7 26556 7 26560 7 26563 7 26570 7 26571 11 26572 11 26573 11 26574 11 26575 11 26576 11 26577 11 26578 11 26579 11 26581 11 26582 11 26583 11 26584 11 26585 11 26586 11 26587 11 26588 11 26589 11 26590 7 26591 7 26592 7 26593 11 26596 11 26598 7 26599 7 26601 5 26631 11 26701 6 26702 6 26703 6 26704 6 26705 6 26706 6 26707 6 26708 6 26709 6 26710 6 26715 6 26720 6 26721 12 26723 12 26725 12 26727 12 26729 12 26731 12 26732 10 26733 10 26735 10 26736 10 26737 10 26739 10 26741 10 26743 10 26745 10 26747 10 26749 10 26751 10 26761 7 26762 7 26763 7 26764 7 26765 7 26766 7 26771 11 26772 11 26773 11 26774 11 26775 11 26776 11 26790 6 26791 6 26792 6 26793 10 26794 7 26795 11 26796 10 26798 12 26799 6 26810 4 26815 11 26900 13 26903 13 26904 13 26905 13 26906 15 26911 13 26912 13 26913 14 26914 14 26916 14 26917 14 26918 14 26919 14 26920 14 26921 14 26922 13 26923 14 26924 14 26925 14 26926 14 26927 14 26928 14 26929 14 26930 15 26932 14 26934 14 26935 14 26936 14 26937 14 26938 14 26939 14 26940 14 26941 14 26942 14 26943 14 26944 14 26945 14 26946 14 26947 14 26948 14 26949 14 26950 14 26951 13 26952 13 26953 13 26954 13 26955 13 26956 13 26957 13 26958 15 26959 15 26960 15 26961 15 26962 14 26963 14 26964 14 26965 14 26966 14 26968 14 26969 14 26971 13 26972 13 26973 13 26974 13 26975 15 26976 15 26977 15 26978 15 26979 15 26980 15 26981 15 26982 15 26983 15 26985 15 28000 13 28002 15 28003 15 28004 15 28005 15 28006 15 28007 15 28008 15 28012 15 28021 14 28023 14 28024 14 28026 14 28027 14 28028 14 28029 14 28033 14 28034 14 28035 14 28036 14 28037 14 28552 8 28620 8 28622 8 28624 8 28626 8 28627 8 28629 8 28632 8 28633 8 28637 8 28644 8 32000 12 32001 12 32002 12 32003 12 32004 12 32085 12 32088 12 32106 12 32107 12 32108 12 40010 8 40410 25 40414 25 40420 25 40422 25 40424 25 40425 25 www.wihatools.com 27 Item No. Page Item No. Page Item No. Page Item No. Page Item No. Page 40426 25 40430 25 40490 25 44501 23 44503 23 44504 23 44505 23 44506 23 44507 23 44508 23 44509 23 44510 23 44511 23 44512 23 44514 23 44515 23 44518 23 44520 23 44521 23 44522 24 44523 24 44525 24 44527 24 44528 24 44530 24 44531 24 44532 24 44533 24 44593 23 55531 24 55532 24 55533 24 55534 24 55535 24 55536 24 55537 25 55538 25 55539 25 55546 25 55547 25 56801 22 56812 22 56813 22 56815 22 56818 22 56825 22 56830 22 56833 22 56871 22 62994 12 75008 17 75012 17 75015 17 75018 17 75020 17 75025 17 75030 17 75035 17 75040 17 75093 20 75094 20 75095 20 75096 20 75097 20 75105 17 75110 17 75115 17 75120 17 75125 17 75307 17 75309 17 75313 17 75315 17 75320 17 75322 17 75325 17 75330 17 75332 17 75340 17 75342 17 75350 17 75352 17 75354 17 75356 17 75358 17 75360 17 75362 17 75364 17 75366 17 75368 17 75370 17 75372 17 75395 19 75602 16 75603 16 75604 16 75605 16 75606 16 75607 16 75608 16 75609 16 75610 16 75611 16 75612 16 75613 16 75614 16 75615 16 75616 16 75617 16 75618 16 75619 16 75620 16 75621 16 75622 16 75623 16 75624 16 75626 16 75627 16 75628 16 75629 16 75630 16 75631 16 75632 16 75633 16 75634 16 75635 16 75636 16 75637 16 75638 16 75639 16 75641 16 75644 16 75645 16 75646 16 75647 16 75648 16 75649 16 75650 16 75651 16 75652 16 75653 16 75654 16 75655 16 75657 16 75658 16 75659 16 75660 16 75661 16 75662 16 75663 16 75664 16 75665 16 75666 16 75667 16 75668 16 75669 16 75670 16 75671 16 75672 16 75673 16 75674 16 75675 16 75676 16 75681 16 75683 16 75701 17 75702 17 75703 17 75704 17 75705 17 75706 17 75707 17 75708 17 75709 17 75710 17 75715 17 75720 17 75735 17 75742 17 75743 18 75744 18 75745 18 75746 18 75747 18 75748 18 75800 17 75801 17 75802 18 75803 18 75805 21 75806 18 75810 18 75811 18 75812 18 75813 18 75814 18 75815 18 75816 18 75817 18 75820 18 75821 18 75822 18 75823 18 75824 18 75825 18 75826 18 75827 18 75900 17 75901 17 75902 17 75965 20 75968 20 75971 20 75973 11 75980 21 75981 21 75982 18 75983 21 75993 21 75984 18 75985 21 75986 18 75987 18 75988 18 75991 19 75992 19 75994 19 75995 19 75996 19 75999 19 91109 20 91118 11 92189 8 92190 8 92191 8 96800 12 Item No. Page Prop65 WARNING: This product could expose you to chemicals including Vinyl Chloride, Ethylene Glycol, Ni or CrVl, which are known to the state od California to cause cancer or reproductive harm. For more information go to www.P65warnings.ca.gov/ PROFESSIONAL TECH TOOLS (800) 494-6104 fax: (800) 494-7456 cservice@wihatools.com www.wihatools.com Wiha Quality Tools 1348 Dundas Circle Monticello, MN 55362 tel: 763.295.6591 fax: 763.295.6598 Wiha Tools Canada Ltd. www.wihatools.ca Brampton, ONT L6T 4X4 tel: 866.494.0096 or 763.295.6591 fax: 763.295.6598 To: Catalog Item No. 99006 .wo version - 9/1/19 Subject to change without notice ©2019 Willi Hahn Corporation ®Torx is a registered trademark of Acument Intellectual Properties LLC. 2019 99934.wo - Hex Tools Catalog 2019 99914.wo - TORX Catalog 2019 99001.wo - TorqueControl Catalog 99951.wo - Bits Catalog 2019 99919.wo - Insulated Catalog 2019 PROFESSIONAL PLIERS & CUTTERS Professional Quality Tools COMPLETE PLIERS AND CUTTERS PROGRAM MERCHANDISE PROGRAM Insulated Chrome • Insulated Industrial • Industrial SoftGrip • Vinyl Soft Grip Precision • ESD Safe • ESD Safe Proturn • Pipe Wrenches • Adjustable Wrenches 99002.wo - Screwdrivers Catalog 99004.wo - Shop Tools Catalog 99977.wo - Pliers/Crimpers Catalog 99945.wo - ESD Catalog 99007.wo - Merchandise Catalog Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Wiha: 26325 26330 75742 76131 76113 76129 75705 26982 75706 75715 76111 75720 76107 76121 76123 75708 76117 28552 75709 75710 75739 75707 26978 75704 26980 76106 76109 75703 76119 26935 26926 26913 26916 26927 26932 26914 26924 26937 26929 26917 26918 26971 28633 56825 28626 28632 26938 26949 56801 56813 56818 26956 26958 26976 28027 26957 26963 26968 26911 26940 26954 26941 26945 26947 28023 28029 26959 40425 56830 75395 26922 28644 26943 26708 28637 56815 26967 40422 28622 56871 26965 56812 56833 75999 26055 26960 75800 28629 28627 75902 40424 75360 75368 75735 75327 75340 28620 75320 75358 75309
26105 价格&库存
很抱歉,暂时无法提供与“26105”相匹配的价格&库存,您可以联系我们找货
    • 1+37.778181+4.72075
    库存:742
