2019
PROFESSIONAL TECH TOOLS
COMPLETE
TECHNICIAN’S PROGRAM
Precision Screwdrivers • PicoFinish Drivers • TorqueControl
Micro Bits • Blade Sets • Electronic Pliers • ESD Tweezers • Mirrors
Toll Free: (800) 494-6104
2
Wiha Precision Screwdrivers
Description Page
Precision Slotted Drivers
Precision Phillips Drivers
4
Description Page
Magnetizer/Demagnetizer 11
4
Precision Pozidriv® Drivers
5
Precision Hex Drivers
5
Precision Ball End Drivers
6
Precision Nut Drivers
7
Precision Torx® Drivers
6
Precision Pentalobe Drivers
7
Precision Chip Lifters
4
Wiha Magnetizer/Demagnetizer
Wiha TorqueControl Tools
Wiha Precision Proturn Drivers
Description Page
Proturn Drivers & Blade Sets
12
Slotted, Phillips, Torx, Chip Lifter
Wiha ESD Safe Precision Handles/Blades
Description Page
Description Page
Torque Cable Keys
8
SYSTEM 4 Handles/Blades
TorqueControl Handle
8
13-15
Wiha Precision Screwdriver Accessories
Description Page
Precision Master Tech Sets
8
Precision Pocket Clip
4
Precision Stand
4
Precision Pouch
11
Wiha Precision PicoFinish Drivers
Description Page
PicoFinish Screwdrivers
9-12
Wiha ESD Safe Precision Handle & Blades
Description Page
SYSTEM 4 Drive-Loc
Handle & Blades
15
SYSTEM 4 Drive-Loc Set
15
ESD Safe Micro Bit Handles, Bits & Sets
Description Page
Micro Bit Handles/Bits/Sets
16-21
TorxPlus, Hex, MagicSpring,
Ball End Hex, Chip Lifter &
Micro Bit Storage Handle Sets 21
Nut Drivers
Tri-Wing Drivers
Insulated PicoFinish Drivers
12
ESD Safe Micro Bit Sets
18-21
www.wihatools.com
3
Precision Electronic Pliers/Cutters
Description Page
Electronic Diagonal Cutters
Wide Pointed Head
22
22
Wide Shape w/Wire Holding Spring
Narrow Shap
22
Full Flush Cutters w/Wire
Trapping Spring
22
22
48O Front Cutter/Long Nose Pliers
Oblique 30O Cutting Nippers
22
Short Nose Precision Pliers
22
Electronic Stripping Pliers
22
Wiha Professional Tweezers
Description Page
ESD Safe Tweezers
Inspection Mirrors
23-25
25
Wiha ESD Safe Tech Tools
ESD Safe Precision Drivers
Slotted/Phillips/Torx®/
TorxPlus®/Hex/Nut Drivers/
Chip Lifter
ESD Safe Ceramic Drivers
ESD Safe SYSTEM 4
Handles/Blades/Sets
ESD Safe Drive-Loc
Handles/Blades/Sets
ESD Safe Pliers & Cutters
Catalog 99945.wo
The Comfortable
Soft Grip Handle
CVM tool steel
blade, hardened,
hard chrome finish
Ergonomic multicomponent handle
with rotating cap for
maximum user comfort
and precise control
New & Improved
PicoFinish
Screwdrivers On
Pages 9-12
Sets In Roll-Up Pouch
4
Wiha Precision Slotted/Phillips Drivers
Rotating cap
for precise turning and
control with fingertip
Precision handle
high quality plastic,
cadmium free
Molded on
tapered handle
allows rapid rotation
High performance
blades
CVM steel,
Hard chrome finished
Tip
precision ground for exact fit,
hard chromed non-slip surface
Wiha Precision Chip Lifter
& Accessories
26810 Precision Chip Lifter
Blade CVM steel, hardened, chrome-plated.
Precision handle high quality plastic, impact
resistant. Standard handle
Item
No.
mm mm mm mm Inch lbs. Pkg.
26810 1
3.5 50 145 5.7 .07 1
*Metric dimensions actual - Inch dimensions approximate
26001 Pocket Clip for Precision
Screwdrivers Tool clips turn Precision
Screwdrivers into Pocket Screwdrivers.
Item No. Fits all
lbs. pkg.
26001
Precision handles .01
1
26000 Plastic Precision Tool Rack
Rack holds 6 precision screwdrivers, can be
set on workbench. Also has holes for hanging.
Made from high quality plastic.
Item No. Rack for 6
lbs.
Pkg.
26000
Precision screwdrivers .08
1
260 Slotted Screwdriver, With Precision
Handle Blade high alloy chrome-vanadiummolybdenum steel.
Pkg. 10
Item
No.
mm Inch mm Inch mm mm Inch lbs.
26008 .80 1/32 40 1.6 0.16 120 4.7 .02
26010 1.0 .039 40 1.6 0.18 120 4.7 .02
26012 1.2 3/64 40 1.6 0.20 120 4.7 .02
26015 1.5 1/16 40 1.6 0.25 120 4.7 .02
26018 1.8 .070 40 1.6 0.30 120 4.7 .02
26020 2.0 5/64 40 1.6 0.40 120 4.7 .02
26022 2.0 5/64 50 2.0 0.40 145 5.7 .02
26023 2.0 5/64 100 3.9 0.40 180 7.1 .03
26025 2.5 3/32 50 2.0 0.40 145 5.7 .03
26027 2.5 3/32 100 3.9 0.40 195 7.7 .03
26028 2.5 3/32 150 6.0 0.40 245 9.6 .04
26030 3.0 1/8 50 2.0 0.50 145 5.7 .03
26032 3.0 1/8 60 2.4 0.50 170 6.7 .04
26033 3.0 1/8 100 3.9 0.50 210 8.3 .04
26034 3.0 1/8 150 5.9 0.50 260 10.2 .05
26035 3.5 9/64 60 2.4 0.60 170 6.7 .05
26040 4.0 5/32 60 2.4 0.80 170 6.7 .05
26041 4.0 5/32 100 3.9 0.80 210 8.3 .06
26042 4.0 5/32 150 5.9 0.80 260 10.2 .07
26090 6pc Precision Slotted Set
Blade high alloy chrome-vanadiummolybdenum steel. Hard chrome finished.
Item No.
26090 Slotted:
lbs.
1.5, 2.0 x 40mm
.27
2.5, 3.0 x 50mm
3.5, 4.0 x 60mm
261 Phillips Screwdriver, With Precision
Pkg. 10
Item
No.
Size mm Inch mm Inch mm Inch lbs.
26102 000 40 1.6 2.0 .08 120 4.7 .02
26100 00 40 1.6 2.0 .08 120 4.7 .02
26101 00 75 3.0 2.0 .08 155 6.1 .02
26105 0 50 2.0 3.0 .12 145 5.7 .02
26108 0 75 3.0 3.0 .12 170 6.7 .03
26107 0 100 3.9 3.0 .12 195 7.6 .05
26109 0 150 5.9 3.0 .12 245 9.6 .06
26110 1 60 2.4 4.0 .16 170 6.7 .05
26113 1 80 3.1 4.0 .16 190 7.5 .05
26114 1 100 3.9 4.0 .16 210 8.2 .06
26115 1 150 5.9 4.0 .16 260 10.2 .07
8pc Precision Slotted & Phillips
26190
Screwdrivers and Industrial Long Nose
Pliers Set
Item No. Slotted: 1.5 x 40mm
26190 2.0, 2.5 x 50mm, 3.0 x 60mm
Phillips: 00 x 40mm
lbs. .72 0 x 50mm , 1 x 60mm
Industrial Long Nose Pliers
6.3”/160mm OAL
7pc Precision Slotted &
26197
Phillips Set Blade high alloy CVM steel.
26197 2.0, 2.5 x 50mm, 3.0 x 60mm
Phillips: 00 x 40mm
lbs. .31 0 x 50mm , 1 x 60mm
In canvas
storage
pouch
26099 8pc Precision Slotted Set
Blade high alloy CVM steel. Hard chrome
finished. In canvas storage pouch.
Item Slotted:
No.
1.0, 1.2, 1.5, 2.0 x 40mm lbs.
26099 2.5, 3.0 x 50mm, 3.5, 4.0 x 60mm .54
26199 8pc Precision Slotted/Phillips Set
Item No.
26199
Slotted: 1.0, 2.0 x 40mm, lbs.
3.0 x 50mm, 4.0 x 60mm .55
Phillips: 000, 00 x 40mm,
0 x 50mm, 1 x 60mm
www.wihatools.com
5
Phillips Drivers
26092 7pc Precision Slotted & Phillips
Set Blade high alloy chromevanadium-molybdenum steel.
Item No.
26092 Slotted:
lbs.
2.5 x 50mm,
.30
2.5, 3.0, 4.0 x 100mm
3.0, 4.0 x 150mm
Phillips:
0 x 75mm
Wiha Hex Inch & Metric Precision Series
263 Inch Inch Hex Driver, With Precision
Handle Inch sizes. Blade high alloy chromevanadium-molybdenum steel.
Pkg. 10
Item
No.
Inch mm mm Inch mm Inch lbs.
26307 0.028 0.7 40 1.6 120 4.7 .02
26309 0.035 0.9 40 1.6 120 4.7 .02
26313 0.05 1.3 40 1.6 120 4.7 .02
26316
1/16 -
50 2.0 145 5.7 .03
26320 5/64 2.0 50 2.0 145 5.7 .03
26323 3/32 - 60 2.4 170 6.7 .04
26327 7/64 - 60 2.4 170 6.7 .04
26331 1/8 - 60 2.4 170 6.7 .04
26333 9/64 60 2.4 170 6.7 .05
26336 5/32 60 2.4 170 6.7 .05
263 Metric Metric Hex Driver, With
Precision Handle Metric sizes. Blade high
alloy chrome-vanadium-molybdenum steel.
Item
No.
mm Inch mm Inch mm Inch lbs. pkg.
26307 .7 .028 40 1.6 120 4.7 .02 10
26309 .9 .035 40 1.6 120 4.7 .02 10
26313 1.3 .050 40 1.6 120 4.7 .02 10
26315 1.5 - 50 2.0 145 5.7 .03 10
26320 2.0 5/64 50 2.0 145 5.7 .03 10
26325 2.5 - 60 2.4 170 6.7 .04 10
26330 3.0 - 60 2.4 170 6.7 .04 10
26340 4.0 - 60 2.4 170 6.7 .05 10
26391 8pc Precision Hex Driver Set Inch Blade high alloy chrome-vanadiummolybdenum steel.
Item No.
26391 Hex Inch:
lbs.
.028, .035, .050 x 1.6”
.32
1/16, 5/64 x 2.0”
3/32, 7/64, 1/8 x 2.4”
26390 7pc Precision Hex Driver Set Metric Blade high alloy chrome-vanadiummolybdenum steel.
Item No.
26390 Hex Metric:
lbs.
.7, .9, 1.3 x 40mm
.28
1.5, 2.0 x 50mm
2.5, 3.0 x 60mm
26194 4pc Precision Phillips Set
Item Phillips:
No.
000, 00 x 40mm
lbs.
26194
0 x 50mm, 1 x 60mm
.18
26192 5pc Precision Slotted & Phillips
Item Slotted:
No.
2.5, 3.0, 4.0 x 150mm
lbs. .44
26192 Phillips:
0, 1 x 150mm
Wiha Pozidriv®
Precision Series
262 Pozidriv® Screwdriver, With
Precision Handle Blade high alloy chromevanadium-molybdenum steel.
Pkg. 10
Item
No.
26205 0 50 2.0 3.0 .12 145 5.7 .03
26210 1 60 2.4 4.0 .16 170 6.7 .05
Y-Type Precision Driver
26399 8pc Precision Hex Driver Set - Inch
Blade high alloy CVM steel. Hard chrome finished. In canvas storage pouch
Item No. Hex Inch:
26399
lbs. .55
1/16, 5/64 x 2.0”, 3/32, 7/64, 1/8 x 2.4”
Y-Type
(Used in iphone 7 or higher series)
Y-Type Precision Screwdriver
26601
Item
No.
26601 000 40 1.6 2.0 .08 120 4.75
6
Wiha Ball End Precision Series
30°
264 Inch Ball End Hex Inch Screwdriver
With Precision Handle Angle entry up to
30°. Blade high alloy chrome-vanadiummolybdenum steel. Hard chrome finish.
Item
No.
Inch mm Inch mm Inch lbs. Pkg.
26413 .050 40 1.6 120 4.7 .02 10
26416 1/16 50 2.0 145 5.7 .03 10
26419 5/64 50 2.0 145 5.7 .03 10
26423 3/32 50 2.0 145 5.7 .03 10
26427 7/64 60 2.4 170 6.7 .03 10
26431 1/8 60 2.4 170 6.7 .05 10
26436 9/64 60 2.4 170 6.7 .05 10
26439 5/32 60 2.4 170 6.7 .05 10
26490 8 Piece Ball End Hex Driver Set Inch Angle entry up to 30°.
Item
No.
Hex Inch: .050 x 1.6,
lbs.
26490 1/16, 5/64, 3/32 x 2.0,
.28
7/64, 1/8, 9/64,
5/32 x 2.4”
Wiha
Precision Series
267
Item
No.
Size mm Inch mm Inch lbs. pkg.
26701 T1 40 1.6 120 4.7 .01 10
26702 T2 40 1.6 120 4.7 .02 10
26703 T3 40 1.6 120 4.7 .02 10
26704 T4 40 1.6 120 4.7 .02 10
26705 T5 40 1.6 120 4.7 .02 10
26706 T6 40 1.6 120 4.7 .02 10
26707 T7 40 1.6 120 4.7 .02 10
26708 T8 40 1.6 120 4.7 .03 10
26709 T9 50 2.0 145 5.7 .03 10
26710 T10 50 2.0 145 5.7 .03 10
26715 T15 60 2.4 170 6.7 .05 10
26720 T20 60 2.4 170 6.7 .05 10
30°
264 Metric Ball End Hex Metric Screwdriver
With Precision Handle Angle entry up to 30°.
Item
No.
mm Inch mm Inch mm Inch lbs. Pkg.
26413 1.3 .050 40 1.6 120 4.7 .02 10
26415 1.5 - 50 2.0 145 5.7 .03 10
26420 2.0 - 50 2.0 145 5.7 .03 10
26425 2.5 - 60 2.4 170 6.7 .04 10
26430 3.0 - 60 2.4 170 6.7 .05 10
26440 4.0
26499 8pc Ball End Hex Driver Set - Inch
Blade high alloy chrome-vanadium-molybdenum
Item
Ball End Hex Inch:
lbs.
No.
.050 x 1.6”
.62
26499 1/16, 5/64, 3/32 x 2.0”
7/64, 1/8, 9/64, 5/32 x 2.4”
Wiha
26491
26790 6pc
Screwdriver Set
Item
No.
: lbs.
26790 T6, T7, T8 x 40mm .30
T9, T10 x 50mm
T15 x 60mm
Screwdriver Set
26791 8pc
Item No. T1, T2, T3, T4,
26791
T5, T6, T7, T8
Precision Series
5pc Ball End Hex Driver Set -
Metric Angle entry up to 30°.
Blade high alloy chrome-vanadiummolybdenum-steel.
Item
No.
Ball End Hex Metric: lbs.
26491 1.3 x 40mm
.25
1.5, 2.0 x 50mm
2.5, 3.0 x 60mm
Screwdriver Set
26792 7pc
Item
No.
lbs.
26792 T5, T6, T7, T8 x 40mm
.33
T9, T10 x 50mm
T15 x 60mm
Screwdriver Set
26799 8pc
Item
: T3, T4, T5,
No.
T6, T7, T8 x 40mm
lbs.
26799
T9 x T10 x 50mm
.50
www.wihatools.com
7
Wiha Pentalobe
Precision Series
Wiha Nut Driver Precision Series
Wiha Pentalobe drivers will fit fasteners
used in “Apple” brand products including
iPhone, Mac Book & Mac Air
Exact fit precision machined tips
High performance CRM72 tool steel
Hard chromed finish blades & tips
Tapered ergonomic handle
Easy spin finger tip control cap
267 Pentalobe Screwdrivers, With
Item
No.
26761 PL1 40 1.6 120 4.7 .01 1
26762 PL2 40 1.6 120 4.7 .02 1
26763 PL3 40 1.6 120 4.7 .02 1
26764 PL4 40 1.6 120 4.7 .02 1
26765 PL5 40 1.6 120 4.7 .02 1
26766 PL6 40 1.6 120 4.7 .02 1
26794 6pc Precision Pentalobe
Screwdriver Set Blade high alloy CVM steel.
Hard chrome finished. Super hardened best
wear resistance long life.
Item No. Pentalobe Drivers:
26794
PL1, PL2, PL3, PL4,
lbs.
PL5, PL6
.35
265 Metric Metric Nut Driver With Precision
Handle Metric sizes. Blade CVM steel. Hard
chrome finished.
Item
No.
mm mm Inch mm Inch mm mm lbs. Pkg.
26510 1.5 60 2.4 140 5.5 2.5 3.0 .03 10
26515 1.8 60 2.4 140 5.5 2.9 3.5 .03 10
26520 2.0 60 2.4 140 5.5 3.2 4.0 .04 10
26525 2.5 60 2.4 155 6.1 4.0 4.0 .04 10
26530 3.0 60 2.4 155 6.1 5.0 5.0 .05 10
26532 3.2 60 2.4 155 6.1 5.0 5.0 .05 10
26535 3.5 60 2.4 155 6.1 5.3 6.0 .05 10
26540 4.0 60 2.4 155 6.1 5.5 6.0 .05 10
26545 4.5 60 2.4 155 6.1 6.2 7.0 .05 10
26550 5.0 60 2.4 155 6.1 6.8 7.0 .05 10
26555 5.5 60 2.4 170 6.7 7.6 8.0 .06 10
26560 6.0 60 2.4 170 6.7 8.2 9.0 .06 10
26570 7.0 60 2.4 170 6.7 9.6 10.0 .06 10
26590 8pc Precision Nut Driver Set Metric Blade CVM steel.
Item No.
26590 Metric Nut Drivers:
lbs. .48
2.5, 3.0, 3.5, 4.0, 4.5,
5.0, 5.5, 6.0 x 60mm
7pc
Nut Driver Set - Metric
26592
Item No. 1.5, 1.8, 2.0, 2.5,
26592 3.0, 3.5, 4.0mm
265 Inch Inch Nut Driver With Precision
Handle Inch sizes. Blade CVM steel. Hard
chrome finished.
Item
No.
Inch mm Inch mm Inch mm mm lbs. Pkg.
26523 3/32 60 2.4 155 6.1 .16 .16 .04 10
26527 7/64 60 2.4 155 6.1 .20 .20 .05 10
26531 1/8 60 2.4 155 6.1 .20 .20 .05 10
26536 9/64 60 2.4 155 6.1 .21 .24 .05 10
26539 5/32 60 2.4 155 6.1 .22 .24 .05 10
26547 3/16 60 2.4 155 6.1 .25 .28 .05 10
26556 7/32 60 2.4 170 6.7 .30 .32 .06 10
26563 1/4 60 2.4 170 6.7 .34 .36 .06 10
26591 8pc Precision Nut Driver Set - Inch
Blade CVM steel.
Item No.
26591 Inch Nut Drivers:
lbs. 47
3/32, 7/64, 1/8, 9/64, 5/32,
3/16, 7/32, 1/4” x 2.4”
26599 8pc Precision Nut Driver Set - Inch
Item
Inch Nut Drivers: lbs.
No.
3/32, 7/64, 1/8, 9/64, 5/32, .72
26599 3/16, 7/32, 1/4” x 2.4”
26598 8pc Precision Nut Driver Set Metric Blade high alloy CVM steel. Hard
Item No.
lbs.
26598
Metric Nut Drivers:
.70
2.5, 3.0, 3.5, 4.0, 4.5, 5.0,
5.5, 6.0 x 60mm
8
Wiha Precision Screwdriver Set
92189 Master Technicians Bench Top Set
Metal frame. Equipped with 50 precision drivers.
92191 51pc Precision Tool Tray Set
Tool box tray. Equipped with 51 precision drivers.
Item No.
92189
lbs.
3.67
Slotted: 1.5, 2.0, 2.5, 3.0, 3.5, 4.0
Phillips: #000, #00, #0, #1
Pentalobe: PL1, PL2, PL3, PL4
: T1, T2, T3, T4, T5, T6,
T7, T8, T9, T10
Metric Hex: 1.27, 1.5, 2.0, 2.5, 3.0
Inch Hex: .028, .035, .050, 1/16,
Item No.
92191
lbs.
3.14
Slotted: .8, 1.0, 1.2, 1.5, 1.8, 2.0,
2.5, 3.0, 3.5, 4.0
Torx®: T1, T2, T3, T4, T5, T6,
T7, T8, T9, T10
Metric Hex: 1.27, 1.5, 2.0, 2.5, 3.0, 4.0
5/64, 3/32, 7/64, 1/8, 9/64, 5/32”
Metric Nut Drivers: 1.5, 1.8, 2.0,
2.5, 3.0, 3.5, 4.0, 4.5, 5.0, 5.5
26810 Chip Lifter
26810 Chip Lifter
Wiha Torque Cable Keys
286 Torque Cable Key For Threaded
Hex Connectors For torque controlled
fastening of cable plug connectors with
Hex heads. Used with Wiha-TorqueControl
Screwdrivers.
Item Max
No.
Size mm mm mm Nm lbs. Pkg.
28620 8mm 4.0 78 218 1.0 .06 1
28622 9mm 4.0 78 218 1.0 .06 1
28626 12mm 4.0 78 218 1.5 .06 1
28627 13mm 4.0 78 218 1.5 .06 1
28629 14mm 4.0 78 218 1.5 .06 1
28633 18mm 4.0 78 218 1.5 .06 1
28644 Torque Cable Key For Threaded
Hex Connectors - Inch
Item
Max
No.
28644 1/2” 4.0 78 218 1.5 .06 1
Wiha Magnetizer/
Demagnetizer
Magnetize or Demagnetize tools
and small parts instantly
92190 Master Technicians Bench Top Set
Item No.
92190
lbs.
3.67
2.5, 3.0, 3.5, 4.0
T7, T8, T9, T10
26810 Chip Lifter
+/-6% accuracy tolerance
Certificate of calibration
Shatterproof
Box is made
from high
quality plastic
Uses 2 C8
industrial
permanent
magnets
(+) to Magnetize
(-) to Demagnetize
40010 Magnetizer and Demagnetizer
To magnetize and demagnetize steel
screwdriver blades, tweezers and similar
tools. Box high quality plastic, shock-resistant,
green, cadmium free.
Application:
To magnetize, lead tool slowly through the
(+) opening, to demagnetize guide tool slowly
through the (-) opening.
Item
No. Dimensions lbs.
40010
2.1” x 2.0” x 1.1” .30
(Parts under 1” Length or 1/8” Diameter may not demagnetize)
28552 Adjustable TorqueVario-S Handle In Newton Meter Scale EN ISO 6798,
BS EN 26789, ASME B107.14M. Ergonomic
molded multi-component handle, light
and compact. Handle sizes proportioned
to optimize torque range. Audible and
perceptible click when the torque setting has
been attained, automatically resets for next
torque cycle.
Item
No.
28552
Newton
Meter Scale Increments mm
lbs. Pkg.
0.8 - 2.0Nm .10 Nm 126 - 131 .45 1
www.wihatools.com
9
Wiha Soft Grip PicoFinish Precision Screwdrivers
The Comfortable Precision Screwdriver
Soft Grip Handle
and precise control
CVM tool steel
blade, hardened,
hard chrome finish
and precise control
260 Slotted Precision Screwdriver,
With PicoFinish Handle Blade CVM steel,
hardened, hard chromed.
Item
No.
mm Inch mm Inch mm Inch Pkg.
26050 0.8 .03 40 1.6 134 5.3 10
26051 1.0 .04 40 1.6 134 5.3 10
26052 1.2 .05 40 1.6 134 5.3 10
26053 1.5 .06 40 1.6 134 5.3 10
26055 1.8 .07 40 1.6 134 5.3 10
26060 2.0 .08 40 1.6 140 5.5 10
26061 2.0 .08 60 2.4 160 6.3 10
26065 2.5 .09 50 2.0 150 5.9 10
26066 2.5 .09 75 3.0 175 6.9 10
26068 2.5 .09 100 3.9 200 7.9 10
26070 3.0 .13 50 2.0 150 5.9 10
26072 3.0 .13 100 3.9 200 7.9 10
26073 3.0 .13 150 5.9 250 9.8 10
26074 3.5 .14 60 2.4 160 6.3 10
26076 4.0 .16 60 2.4 160 6.3 10
26079 4.0 .16 100 3.9 200 7.9 10
26080 4.0 .16 150 5.9 250 9.8 10
26093 8pc Slotted Precision Screwdriver
Set, With Soft PicoFinish Handle
In storage pouch
Item
No. Slotted: .8, 1.2, 1.5, 2.0 x 40mm lbs.
26093 2.5, 3.0 x 50mm, 3.5, 4.0 x 60mm .54
261 Phillips Precision Screwdriver, With
Soft PicoFinish Precision Handle Blade high
Item
No.
Size mm Inch mm Inch mm Inch Pkg.
26130 000 40 1.6 2.0 .08 134 5.3 10
26132 00 40 1.6 2.0 .08 134 5.3 10
26135 0 50 2.0 3.0 .12 150 5.9 10
26136 0 75 3.0 3.0 .12 175 6.9 10
26140 1 60 2.4 4.0 .16 160 6.3 10
26142 1 80 3.1 4.0 .16 180 7.1 10
26145 1 150 5.9 4.0 .16 250 9.8 10
In Roll-Up
Pouch
26193 8pc Slotted & Phillips Precision
Driver Set, With Soft PicoFinish Handle
Blade high alloy CVM steel, hardened, hard
chromed. ChromTop finish on tip for a perfect
fit. In storage pouch
Item Slotted:
No.
1.0, 1.5, 2.0 x 40mm
lbs.
26193
2.5 x 50mm, 3.5 x 60mm .55
Phillips: 00 x 40mm
0 x 50mm, 1 x 60mm
26195 5pc Precision Screwdrivers With
Precision Soft PicoFinish Handle
Item Slotted:
No.
1.5, 2.5, 3.5mm
lbs.
26195
Phillips: #0, #1
.25
* No Pouch - In clamshell
26196 5pc Precision Screwdrivers With
Item Phillips: #0, #1
No.
Pentalobe: PL1
lbs.
26196
Tri-Wing: #000
.25
Tweezers: 2a SA ESD Flat Round Tip
26198 11pc Smartphone Precision
Screwdrivers With Precision Soft
PicoFinish Handle
Item
Slotted: 1.8mm
No. Phillips: #000, #00, #0
26198
: T3, T4, T5, T6
Pentalobe: PL1
lbs.
Tri-Wing: #000
.59
Tweezers: PSF SA ESD Long Flat Tip
10
Wiha Pico Soft Grip
267
Soft PicoFinish Handle Blade high alloy
CVM tool steel, hardened, hard chrome finish.
Item
No.
Size mm Inch mm Inch Pkg.
26732 T1 40 1.6 134 5.3
10
26733 T2 40 1.6 134 5.3
10
26735 T3 40 1.6 134 5.3
10
26736 T4 40 1.6 134 5.3
10
26737 T5 40 1.6 134 5.3
10
26739 T6 40 1.6 140 5.5
10
26741 T7 40 1.6 140 5.5
10
26743 T8 40 1.6 140 5.5
10
26745 T9 50 2.0 150 5.9
10
26747 T10 50 2.0 150 5.9
10
26749 T15 60 2.4 160 6.3
10
26751 T20 60 2.4 160 6.3
10
Pico Soft Grip Hex Inch & Metric
263 Hex Inch Screwdriver, With Precision
Item
No.
Inch
26341
0.028(0.7) 40 1.6 134 5.3
10
26343
0.035(0.9) 40 1.6 134 5.3
10
26345
0.05(1.3) 40 1.6 134 5.3
10
26349
5/64(2.0) 50 2.0 150 5.9
10
26363
1/16
50 2.0 144 5.7
10
26367
3/32
60 2.4 160 6.3
10
26369 7/64
60 2.4 160 6.3
10
26371
1/8
60 2.4 160 6.3
10
In
storage
pouch
Pico Soft Grip Ball End
Inch & Metric
264 Ball End Hex Inch Screwdriver, With
Precision Soft PicoFinish Handle Blade
high alloy CVM tool steel, hardened, hard
chrome finish.
Item
No.
Inch Inch mm Inch mm pkg.
26455 1/16 2.0 50 5.9 150 10
26457 5/64 2.0 50 5.9 150 10
26459 3/32 2.0 50 5.9 150 10
26461 7/64 2.4 60 6.3 160 10
26463 1/8 2.4 60 6.3 160 10
26465 9/64 2.4 60 6.3 160 10
26467 5/32 2.4 60 6.3 160 10
In storage pouch
26392 8pc Hex Inch Precision Driver
Set, Soft PicoFinish Handle Blade high alloy
CVM steel, hardened, hard chromed.
Item
Hex Inch:
lbs.
No.
.028, .035, .050 x 1.6” .24
26392 5/64, 1/16 x 2.0”, 3/32, 7/64, 1/8 x 2.4”
26793 8pc
Precision Driver Set,
With Soft PicoFinish Handle Blade high
alloy CVM steel, hardened, hard chromed.
ChromTop finish on tip for a perfect fit.
Item
No.
T1, T2, T3, T4,
lbs.
26793
T5, T6, T7, T8
.50
In storage pouch
26796 8pc
Soft PicoFinish Handle Blade high alloy CVM
steel, hardened, hard chromed. ChromTop
Item
No.
lbs. .57
26796
T9, T10 x 50mm, T15, T20 x 60mm
263 Hex Metric Driver, With Precision Soft
PicoFinish Handle
Item
No.
mm
26341 .7(.028) 40 1.6 134 5.3
10
26343 .9(.035) 40 1.6 134 5.3
10
26345 1.3(.050) 40 1.6 134 5.3
10
26347 1.5
50 2.0 144 5.7
10
26349 2.0(5/64) 50 2.0 150 5.9
10
26351 2.5
60 2.4 160 6.3
10
26353 3.0
60 2.4 160 6.3
10
In
storage
pouch
26393 7pc Hex Metric Precision Driver
Item No. Hex Metric:
lbs.
26393
.7, .9, 1.3 x 40mm
.22
1.5, 2.0 x 50mm, 2.5, 3.0 x 60mm
26493 7pc Inch Ball End Hex Precision
Item
lbs.
No.
Ball End Hex Inch: .27
26493 1/16, 5/64, 3/32 x 2.0”
264 Ball End Hex Metric Screwdriver, With
Precision Soft PicoFinish Handle. Blade
chrome finish.
Item
No.
mm mm Inch mm Inch pkg.
26441 1.3 40 1.6 134 5.3 10
26443 1.5 50 2.0 150 5.9 10
26445 2.0 50 2.0 150 5.9 10
26447 2.5 60 2.4 160 6.3 10
26449 3.0 60 2.4 160 6.3 10
www.wihatools.com
11
Pico Soft Grip Nut Drivers Inch & Metric
265 Inch Nut Drivers, With Precision Soft
chrome-vanadium-molybdenum tool steel,
Item
No.
26571
3/32 2.4 60 6.3 160 10
26572
26573
26574
26575
26576
3/16 2.4 60 6.3 160 10
26577
7/32 2.4 60 6.3 160 10
26578
1/4 2.4 60 6.3 160 10
26593 8pc Inch Nut Driver Set, With
chrome finish. Chrom-Top finish on tip for a
perfect fit. In storage pouch
Item
Inch Nut Drivers:
lbs. .72
No.
26593
5/32, 3/16, 7/32, 1/4” x 2.4”
265 Metric Nut Drivers, With Precision
PicoFinish Handle Blade high alloy CVM tool
Item
No.
26579 1.5 60 2.4 160 6.3 10
26581 2.0 60 2.4 160 6.3 10
26582 2.5 60 2.4 160 6.3 10
26583 3.0 60 2.4 160 6.3 10
26584 3.5 60 2.4 160 6.3 10
26585 4.0 60 2.4 160 6.3 10
26586 4.5 60 2.4 160 6.3 10
26587 5.0 60 2.4 160 6.3 10
26588 5.5 60 2.4 160 6.3 10
26589 6.0 60 2.4 160 6.3 10
26596 8pc Metric Nut Driver Set, With
Item
Metric Nut Drivers:
No.
2.0, 2.5, 3.0, 3.5, 4.0, lbs.
26596
4.5, 5.0, 5.5 x 60mm
.66
Pico Soft Grip Precision Chip Lifter
26815 Soft PicoFinish Precision Chip Lifter
Blade CVM steel, hardened, hard chromed.
Item
No.
26815
1 3.5 50 150 5.9 .03 1
Standard Soft PicoFinish handle
Pico Soft Grip
Y-Type
(Used in iphone 7
or higher series)
266 Y-Type Precision Screwdriver, With
Item
No.
26631 000 40 1.6 2.0 .08 140 5.5
Pico Soft Grip Pentalobe
267 Pentalobe Screwdriver, With
chrome finish.
Item
No.
Size Inch mm Inch mm pkg.
26771 PL1 1.6 40 5.5 140 10
26772 PL2 1.6 40 5.5 140 10
26773 PL3 1.6 40 5.5 140 10
26774 PL4 1.6 40 5.5 140 10
26775 PL5 1.6 40 5.5 140 10
26776 PL6 1.6 40 5.5 140 10
6pc Precision Pentalobe Driver
26795
26795
PL1, PL2, PL3, PL4,
lbs.
PL5, PL6
.40
75973 23pc Micro Bit Set, With Soft
PicoFinish Handle CVM steel Micro Bits,
hardened, on 4 mm hex stock. Ergonomic
multi-component handle with rotating cap for
maximum user comfort and precise control.
Item Slotted: 1.5, 2.0, 2.5, 3.0, 3.5mm
No.
Phillips: 000, 00, 0, 1, 2
75973
: T1, T2, T3, T4,
T5, T6, T7, T8, T9, T10
lbs. PicoFinish® Precision Handle
.82
Micro Bit Holder - 100mm
Micro Bit Socket Adapter 1/4”
12
PicoFinish MagicSpring
1000Volt
267 MagicSpring Screw Holding
Screwdriver, With Wiha-Precision Soft
steel, hardened, hard chromed. Molded on
ergonomic Wiha-PicoFinish precision handle,
molded on, soft grips.
Item
No.
Size mm Inch mm Inch lbs. Pkg.
26721 T6 40 1.6 140 5.5 .03 10
26723 T7 40 1.6 140 5.5 .03 10
26725 T8 40 1.6 140 5.5 .03 10
26727 T9 50 2.0 150 5.9 .04 10
26729 T10 50 2.0 150 5.9 .04 10
26731 T15 60 2.4 160 6.3 .04 10
320
Insulated Slotted PicoFinish
Screwdrivers. Individually Tested Protective
Insulation 1000Volt AC, VDE & GS Tested.
High quality CV steel, through hardened, black
finish. Rotating cap for precise turning and
control with fingertip.
Item
No.
1.5 .06 40 154 .05
1
32000
2.0 .08 40 154 .07
1
32001
2.5 .10 60 160 .07
1
32002
3.0 .12 60 160 .08
1
32003
3.5 .14 60 160 .08
1
32004
Wiha Proturn Precision
Screwdrivers
n
r
u
t
o
r
p
Molded on
ergonomic
handle
Tip
precision
ground for
exact fit
Rotating cap
for precise
turning and
Tapered
control with
handle
fingertip
allows rapid
Blade CVM steel, rotation
black finish blades
1000Volt
26798 6pc MagicSpring Screw Holding
Screwdriver Set, With WihaPrecision Soft PicoFinish Handle
hard chromed. Molded on ergonomic WihaPicoFinish precision handle, molded on,
soft grips. In storage pouch
Item
No. MagicSpring
lbs.
26798 T6, T7, T8 x 40mm
.45
T9, T10, T15 x 50mm
Insulated Phillips PicoFinish
321
Protective Insulation 1000Volt AC,
VDE & GS Tested.
Item
No.
Size mm mm lbs. Pkg.
00
40 154 .05 1
32106
0 60 160 .07 1
32107
1 60 160 .08 1
32108
1000Volt
32088
Item
No.
32088
Individually
Tested
Protective
Insulation
1000Volt AC,
VDE and
GS Tested
8pc Slotted/Phillips PicoFinish Set
Slotted: 1.5, 2.0,
2.5, 3.0, 3.5mm
lbs.
Phillips: #00, #0, #1
.35
1000Volt
91118 Rugged Polyester Canvas Storage
Pouch Holds 8 Precision Tools up to 170mm
in length. Folding pouch. Has security flaps
and velcro closer.
Item
No.
Size
lbs. pkg.
91118 14 1/2” W x 7 3/4” L .13 1
32085
Item
No.
32085
5pc Slotted/Phillips PicoFinish Set
Slotted: 1.5,
2.5, 3.5mm
lbs.
Phillips: #0, #1
.26
62994 14pc Inch/Metric Ball End Hex
Work Tech Pack Proturn precision
ball retainer handle & 13 Wiha
interchangeable blades.
62994 Set includes the following blades:
Hex Inch: .050, 1/16, 5/64, 3/32,
Hex Metric: 1.5, 2.0, 2.5, 3.0, 4.0mm
lbs. .66
Set in canvas storage pouch
96800 Proturn Precision Chip Lifter
Molded on precision handle. Blade CVM tool
steel, hardened, black finish.
Item
No.
Size mm mm Inch lbs. pkg.
96800 1.0 50 145 5.7 .07 1
www.wihatools.com
13
Wiha SYSTEM 4 Precision Handles and Blades
Rotating
Cap
for precise
turning &
control
Tapered Handle
allows rapid
rotation, requires
less clearance
Blades
chrome-vanadiummolybdenum steel,
hardened, hard
chromed. On 4mm
Hex shafts
Tips
Exact fit,
precision machined
Precision Handle
high quality
plastic, cadmium
free. ESD Safe
or Standard styles
26900 SYS 4 Standard Precision Handle,
with rotating control cap. Accepts all
SYSTEM 4 interchangeable blades. Wiha
Precision handle, tapered, impact resistant.
Ball retainer hold. 110mm/4.3” OAL
Item
No.
26900 4.0 .1574 14.0 .55 .04
28000 ESD Safe Dissipative Precision
Handle with rotating control cap. Surface
resistant 106-109 Ohms. 4 mm hex retainer
for all SYSTEM 4 interchangeable blades.
Tapered handle, high quality plastic, impact
resistant. Ball retainer hold. 110mm/4.3” OAL
Item
No. mm Inch mm Inch lbs.
28000 4.0 .1574 14.0 .55 .04
269 SYSTEM 4 Slotted Reversible Blade
High alloy CVM steel, hardened, hard
chromed. Wiha vapor Chrome-Top
finish on tips.
Item
No.
mm mm mm Inch lbs.
26903 1.5 + 3.0 120 4.7 .05
26904 2.0 + 3.5 120 4.7 .05
26905 2.5 + 4.0 120 4.7 .06
269 SYSTEM 4 Pozidriv® Reversible Blade
finish on tips.
Item
No.
Size Size mm Inch lbs.
26922 0 + 1
120 4.7 .03
15mm
Collet Lock Handle
adjustable blade
length from
15 to 95mm/
.6” to 3.75”
95mm
Notes:
269 SYSTEM 4 Phillips Reversible Blade
High alloy CVM steel, hardened, hard chromed.
Wiha vapor Chrome-Top finish on tips.
Item
No.
26911 000 + 00 120 4.7 .03
26912 0 + 1
120 4.7 .03
Reversible Blade
269 SYS 4
High alloy CVM steel, hardened, vapor chrome
protected, Wiha vapor Chrome-Top finish on
tips. 120mm/4.7” OAL.
Item
No.
Size Size lbs.
26951 T6 + T8 .03
26952 T7 + T9 .03
26953 T10 + T15 .03
26954 T15 + T20 .03
269 SYSTEM 4 Combined Slotted/Phillips
Reversible Blade High alloy CVM
Item
No.
mm Size mm Inch lbs.
26971
1.5 + 000 120 4.7 .05
26972
2.0 + 00
120 4.7 .05
26973
3.0 + 0
120 4.7 .05
26974
4.0 + 1
120 4.7 .06
Interchangeable
269 SYSTEM 4
Blade High alloy CVM steel, hardened,
120mm/4.7” OAL
Item
No.
Size lbs.
26955
T3 .03
26956
T4 .03
26957 T5 .03
14
Wiha SYSTEM 4 Precision Blades
For angle
entry
269 SYSTEM 4 Inch Hex Sizes,
Interchangeable Blade High alloy CVM steel,
hardened, corrosion protected.
Item
No.
Inch mm Inch lbs.
26921 .050 120 4.7 .06
26923 1/16 120 4.7 .06
26924 5/64 120 4.7 .06
26925 3/32 120 4.7 .06
26926 7/64 120 4.7 .06
26927 1/8 120 4.7 .06
26928 9/64 120 4.7 .06
26929 5/32 120 4.7 .06
269 SYSTEM 4 Metric Hex Sizes,
Item
No.
mm mm Inch lbs.
26913 0.7 120 4.7 .06
26914 0.9 120 4.7 .06
26916 1.5 120 4.7 .06
26917 2.0 120 4.7 .06
26918 2.5 120 4.7 .06
26919 3.0 120 4.7 .06
26920 4.0 120 4.7 .06
280 SYSTEM 4 Inch Ball End Hex
Interchangeable Blade High alloy tool steel,
hardened, corrosion protected. Ball end works
at 30° angle entry for easy access to fasteners.
Item
No.
Inch mm Inch lbs.
28021 .050 120 4.7 .06
28023 1/16 120 4.7 .06
28024 5/64 120 4.7 .06
28026 7/64 120 4.7 .06
28027 1/8 120 4.7 .06
28028 9/64 120 4.7 .06
28029 5/32 120 4.7 .06
For angle
entry
280 SYSTEM 4 Metric Ball End Hex
Item
No.
28033 1.5 120 4.7 .06 1
28034 2.0 120 4.7 .06 1
28035 2.5 120 4.7 .06 1
28036 3.0 120 4.7 .06 1
28037 4.0 120 4.7 .06 1
Notes:
269 SYSTEM 4 Nut Driver Inch,
Interchangeable Blade High alloy chromevanadium-molybdenum steel, hardened,
corrosion protected. 120mm/4.7” OAL
Item
No.
Inch Inch Inch lbs.
26962 3/32 .16 .16 .04
26963 7/64 .20 .20 .04
26964 1/8 .20 .20 .04
26965 9/64 .21 .24 .04
26966 5/32 .22 .24 .04
26968 7/32 .30 .32 .04
26969 1/4 1.34 .36 .04
269 SYSTEM 4 Nut Driver Metric,
Item
No.
mm mm Inch Inch lbs.
26940 1.5 + 1.8 .12 .12 .03
26941 2.0 + 2.5 .16 .16 .03
26938 1.5 -
.11 .11 .04
26939 1.8 -
.12 .12 .04
26949 2.0 -
.13 .13 .06
26950 2.5 -
.16 .16 .06
26942 3.0 -
.20 .20 .06
26943 3.2 -
.20 .20 .06
26944 3.5 -
.22 .24 .06
26945 4.0 -
.22 .24 .06
26946 4.5 -
.25 .28 .06
26947 5.0 -
.27 .28 .06
26948 5.5 -
.30 .32 .06
Notes:
For angle
entry
269 SYS 4 Metric Ball End & Standard
Hex, Reversible Blade CVM steel, hardened,
hard chromed. Wiha vapor Chrome-Top
finish on tips. One side hex, other
side ballpoint hex.
Item
No.
mm mm mm Inch lbs.
26932 1.3 + 1.3 120 4.7 .05
26934 2.0 + 2.0 120 4.7 .06
26935 2.5 + 2.5 120 4.7 .06
26936 3.0 + 3.0 120 4.7 .06
26937 4.0 + 4.0 120 4.7 .06
www.wihatools.com
15
Wiha SYSTEM 4 Drive-Loc Precision Locking Tools
D
26906 SoftFinish® Cushion Grip
Drive-Loc Handle 4 mm hex retainer for
all SYSTEM 4 interchangeable blades. Ball
retainer hold. 105mm/4.13” OAL
Item
No.
26906 4.0 .1574 23 .91 .08
280 SYSTEM 4 Pozidriv® Drive-Loc
Reversible Locking Blades
On 4mm Hex blades
Item
No.
Size
Size lbs.
28002
.02
D
26961 ESD Safe Dissipative Precision
Drive-Loc Handle Surface resistant 106-109
Ohms. 4 mm hex retainer for all SYSTEM 4
interchangeable blades. Ball retainer hold.
105mm/4.13” OAL
Item
No.
26961 4.0 .1574 23 .91 .08
26985 12pc Drive-Loc IV Precision
ESD Safe Set In storage pouch
Item No.
26985
ESD Safe Drive-Loc Handle
Slotted: 1.5x3.0, 2.0x3.5, 2.5x4.0
lbs. .44
Phillips: 000x00, 0x1
: T1xT2, T3xT4, T5xT6,
T6xT8, T7xT9, T10xT15
Drive-Loc
269 SYSTEM 4
On 4mm Hex blades
Item
No.
Size
Size lbs.
26977
T1
+ T2
.02
26978
T3
+ T4
.02
26979
T5
+ T6
.02
26980
T6
+ T8
.02
26981
T7
+ T9
.02
26982
T10 + T15
.02
26983
T15 + T20
.02
D
269 SYSTEM 4 Slotted Drive-Loc
On 4mm Hex blades
Item
No.
mm
mm lbs.
26958
1.5 + 3.0
.02
26959
2.0 + 3.5
.02
26960
2.5 + 4.0
.02
269 SYSTEM 4 Phillips Drive-Loc
On 4mm Hex blades
Item
No.
Size
Size lbs.
26975
000 + 00
.02
26976
.02
280 SYSTEM 4 Metric Hex Drive-Loc
On 4mm Hex blades
Item
No.
mm
mm lbs.
28003
1.3
+ 1.3
.02
28004
1.5
+ 1.5
.02
28005
2.0
+ 2.0
.02
28006
2.5
+ 2.5
.02
28007
3.0
+ 3.0
.02
28008
4.0
+ 4.0
.02
280 SYSTEM 4 Metric Nut Drivers DriveLoc Reversible Locking Blades
On 4mm Hex blades
Item
No.
mm mm lbs.
28012 3.2 + -
.02
Precision
26930 7pc Drive-Loc IV
Item No.
26930
: T3xT4, T5xT6,
lbs. .56
T6xT8, T7xT9, T10xT15, T15xT20
16
Micro Bits Made in Germany
Wiha SYSTEM 4 Micro Bits - 10 Bit Packs
on 4 mm hex stock.
Tips Exact fit,
precision machined
Bits High alloy
CVM steel,
hardened
Use bits directly in handle or
with 4” bit extension
10 Bit Pack
756 SYSTEM 4 Hex Metric Micro Bits
Item
No.
mm
mm Inch lbs.
75616
.7
28
1.1 .06
75617
.9
28
1.1 .06
75618
1.3 28
1.1 .06
75619
1.5 28
1.1 .07
75620
2.0 28
1.1 .07
75621
2.5 28
1.1 .07
75622
3.0 28
1.1 .08
75623
4.0 28
1.1 .08
10 Bit Pack
10 Bit Pack
756 SYSTEM 4 Slotted Micro Bits
Item
No.
mm mm Inch lbs.
75602 0.8 28 1.1 .06
75603 1.2 28 1.1 .06
75604 1.5 28 1.1 .06
75605 1.8 28 1.1 .06
75606 2.0 28 1.1 .07
75607 2.5 28 1.1 .07
75608 3.0 28 1.1 .07
75609 3.5 28 1.1 .07
75610 4.0 28 1.1 .08
10 Bit Pack
756 SYSTEM 4 Phillips Micro Bits
Item
No.
Size mm Inch lbs.
75611 000 28 1.1 .06
75612 00 28 1.1 .06
75613 0 28 1.1 .06
75614 1 28 1.1 .07
75615 2 28 1.1 .07
756 SYSTEM 4 Hex Inch Micro Bits
Item
No.
Inch mm Inch lbs.
75628 .028 28 1.1 .06
75629 .035 28 1.1 .06
75630 .050 28 1.1 .06
75631 1/16 28 1.1 .06
75632 5/64 28 1.1 .06
75633 3/32 28 1.1 .07
75634 7/64 28 1.1 .07
75635 1/8 28 1.1 .07
75636 9/64 28 1.1 .08
75637 5/32 28
1.1 .08
10 Bit Pack
756 SYS 4 Metric Security Hex Micro Bits
Item
No.
mm mm Inch lbs.
75624 2.0 28 1.1 .06
75626 3.0 28 1.1 .07
75627 4.0 28 1.1 .08
10 Bit Pack
Micro Bits
756 SYSTEM 4
Item
No.
Size mm Inch lbs.
75660
T1 28 1.1 .06
75661
T2 28 1.1 .06
75662 T3 28 1.1 .06
75663 T4 28 1.1 .06
75664 T5 28 1.1 .06
75665 T6 28 1.1 .06
75666 T7 28 1.1 .06
75667 T8 28 1.1 .07
75668 T9 28 1.1 .07
75669 T10 28 1.1 .07
75670 T15 28 1.1 .08
75671
T20 28 1.1 .08
10 Bit Pack
756 SYSTEM 4 Security
Micro Bits
Item
No.
Size mm Inch lbs.
75681 T10s 28 1.1 .07
75683 T20s 28 1.1 .08
10 Bit Pack
756 SYSTEM 4 Inch Nut Setters
Item No.
Inch Inch mm Inch lbs.
75644 5/64 30 1.2 .07
75645 3/32 30 1.2 .07
75646 7/64 30 1.2 .07
75647 1/8 30 1.2 .07
75648 9/64 30 1.2 .08
75649 5/32 30 1.2 .08
75650 3/16 30 1.2 .08
75651 7/32 30 1.2 .09
10 Bit Pack
10 Bit Pack
756 SYSTEM 4 Pentalobe Micro Bits
Item
No.
Size mm Inch lbs.
75672 PL1 28 1.1 .06
75673 PL2 28 1.1 .06
75674 PL3 28 1.1 .07
75675 PL4 28 1.1 .07
75676 PL5 28 1.1 .07
10 Bit Pack
756 SYS 4 Security Hex Inch Micro Bits
Item
No.
Inch mm Inch lbs.
75638 5/64 28 1.1 .06
75639 3/32 28 1.1 .06
75641 1/8 28 1.1 .07
756 SYSTEM 4 Metric Nut Setters
Item No.
Metric mm mm Inch lbs.
75652 2.0 30 1.2 .07
75653 2.5 30 1.2 .07
75654 3.0 30 1.2 .07
75655 3.5 30 1.2 .07
75656 4.0 30 1.2 .08
75657 4.5 30 1.2 .08
75658 5.0 30 1.2 .08
75659 5.5 30 1.2 .09
www.wihatools.com
17
SYSTEM 4
Handles & Micro Bits
Tips
Exact fit,
precision
machined
Rotating Cap
for precise
turning and
control
Tapered Handle
allows rapid
rotation, requires
less clearance
Bits High alloy
CVM steel, hardened
750 SYSTEM 4 Slotted Micro Bits
CVM steel, hardened, on 4 mm hex stock.
Item
No.
mm mm Inch
lbs.
75008 0.8 28 1.1 .01
75012 1.2 28 1.1 .01
75015 1.5 28 1.1 .01
75018 1.8 28 1.1 .01
75020 2.0 28 1.1 .01
75025 2.5 28 1.1 .01
75030 3.0 28 1.1 .01
75035 3.5 28 1.1 .01
75040 4.0 28 1.1 .01
Use bits directly in handle or with 4” bit extension
75800 SYSTEM 4 Standard Precision Bit
Handle Accepts all SYSTEM 4 Series bits.
110mm/4.3” OAL
Item
No.
75800 4.0 .1574 14.0 .55 .06
751 SYSTEM 4 Phillips Micro Bits
Item
No.
Size mm Inch lbs.
75105 000 28 1.1 .01
75110 00 28 1.1 .01
75115 0 28 1.1 .01
75120 1 28 1.1 .01
75125 2 28 1.1 .02
Micro Bits
757 SYSTEM 4
CVM steel, hardened, on 4 mm stock.
Item
No.
Size mm Inch lbs.
75701 T1 28 1.1 .01
75702 T2 28 1.1 .01
75703 T3 28 1.1 .01
75704 T4 28 1.1 .01
75705 T5 28 1.1 .01
75706 T6 28 1.1 .01
75707 T7 28 1.1 .01
75708 T8 28 1.1 .01
75709 T9 28 1.1 .01
75710 T10 28 1.1 .01
75715 T15 28 1.1 .01
75720 T20 28 1.1 .01
757 SYSTEM 4 Security
Micro Bits
Item
No.
Size mm Inch lbs.
75735 T10s 28 1.1 .01
75742 T20s 28 1.1 .01
D
Dissipative
75801 SYSTEM 4 ESD Safe
Precision Bit Handle 110mm/4.3” OAL
Advantages:
• For working in ESD sensitive applications
Surface resistant 106-109 Ohms
• Ball retainer holds bits securely in place
• Accepts all SYSTEM 4 Series bits
Item
No.
75801 4.0 .1574 14.0 .55 .06
SYSTEM 4 Micro Bit
Extension Blades
75900 Extension Blade For SYS 4 Micro Bits
Shaft CVM steel, hardened, corrosion protected.
Ball retainer bit extension for 4mm bits.
Item
No.
Size
mm mm lbs.
75900
4.0
100 4.0 .07
75901 Magnetic Bit Extension Blade For
SYS 4 Micro Bits Shaft CVM steel, hardened,
corrosion protected. Magnetic bit holder.
Item
No.
Size mm mm lbs.
75901
4.0
100 4.0
.04
753 SYSTEM 4 Hex Metric Micro Bits
Item
No.
mm
mm Inch lbs.
75307
.7
28
1.1 .01
75309
.9
28
1.1 .01
75313
1.3 28
1.1 .01
75315
1.5 28
1.1 .01
75320
2.0 28
1.1 .01
75325
2.5 28
1.1 .01
75330
3.0 28
1.1 .01
75340
4.0 28
1.1 .01
753 SYSTEM 4 Hex Inch Micro Bits
Item
No.
Inch mm Inch lbs.
75307 .028 28 1.1 .01
75309 .035 28 1.1 .01
75313 .050 28 1.1 .01
75350 1/16 28 1.1 .01
75352 5/64 28 1.1 .01
75354 3/32 28 1.1 .01
75356 7/64 28 1.1 .01
75358 1/8 28 1.1 .01
75360 9/64 28 1.1 .01
75340 5/32 28
1.1 .01
753 SYS 4 Metric Security Hex Micro Bits
Item
No.
mm mm Inch lbs.
75322 2.0 28 1.1 .01
75332 3.0 28 1.1 .01
75342 4.0 28 1.1 .01
753 SYS 4 Security Hex Inch Micro Bits
Item
No.
Inch mm Inch lbs.
75362 5/64 28 1.1 .01
75364 3/32 28 1.1 .01
75366 7/64 28 1.1 .01
75368 1/8 28 1.1 .01
75370 9/64 28 1.1 .01
75372 5/32 28 1.1 .01
Micro Bit 1/4” Drive Power
Tool Adapter For 4mm Bits
2.3” OAL
75902 Micro Bit 1/4” Drive Power Tool Adapter
Item
No.
Size
mm mm lbs.
75902
4.0
60
4.0 .07
18
757 SYSTEM 4 Pentalobe Micro Bits CVM
Item
No.
Size mm Inch lbs.
75743 PL1 28 1.1 .01
75744 PL2 28 1.1 .01
75745 PL3 28 1.1 .01
75746 PL4 28 1.1 .01
75747 PL5 28 1.1 .01
75748 PL6 28 1.1 .01
758 SYSTEM 4 Metric & Inch Nut Setters
Item No.
75820 2.0 30 1.2 .01
75821 2.5 30 1.2 .01
75822 3.0 30 1.2 .01
75823 3.5 30 1.2 .01
75824 4.0 30 1.2 .01
75825 4.5 30 1.2 .01
75826 5.0 30 1.2 .01
75827 5.5 30 1.2 .01
75810 5/64 30 1.2 .01
75811 3/32 30 1.2 .01
75812 7/64 30 1.2 .01
75813 1/8 30 1.2 .01
75814 9/64 30 1.2 .01
75815 5/32 30 1.2 .01
75816 3/16 30 1.2 .01
75817 7/32 30 1.2 .01
Micro Bit Replacement Packs On 4mm Hex Stock
75982 10pc SYSTEM 4 Hex Inch Micro Bit
Replacement Pack
Item No.
75982 SYSTEM 4 Micro Bit Set
Hex Inch: .028, .035, .050, 1/16, 5/64,
lbs. .06
75987 10pc SYSTEM 4 Slotted & Phillips
Item No.
75987 SYSTEM 4 Micro Bit Set
Phillips: #000, 00, 0, 1
lbs. .06
75984 10pc SYSTEM 4 Slotted Micro Bit
Replacement Pack
Item No.
75984 SYSTEM 4 Micro Bit Set
Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5,
3.0, 3.5, 4.0mm
lbs. .06
Micro Bit
75988 10pc SYSTEM 4
Replacement Pack
Item No.
75988 SYSTEM 4 Micro Bit Set
T7, T8, T9, T10
lbs. .06
75986 10pc SYSTEM 4 Phillips &
Pentalobe Micro Bit Replacement Pack
Item No.
75986 SYSTEM 4 Micro Bit Set
PL4, PL5, PL6
lbs. .06
1/4” Drive Micro Bit Tool Adapters
75802 Micro Bit To 1/4” Drive Insert Bit
Adapter magnets to hold 4mm Micro Bits
Item
No.
Size mm mm lbs.
75802
4.0 25 4.0 .01
75803 Long Micro Bit To 1/4” Drive Insert
Bit Adapter Uses spring clip non-magnetic to
hold 4mm Micro Bits
Item
No.
Size mm mm lbs.
75803
4.0 38
4.0 .02
Micro Bit 4mm To
1/4” Socket Adapter
75806 Micro Bit 4mm to 1/4” Socket
Adapter CVM steel, hardened.
Item
No.
mm Inch
lbs.
75806 28
1.125
.02
www.wihatools.com
19
Wiha SYS 4 Micro Bits & Compact Bit Sets
D
26 Pc
. Set
75999
26pc SYS 4 Slotted, Phillips, Hex
Inch & Metric Precision Interchangeable
Bit Set. In Compact Fold Out Box. Precision
handle, bit extension & 24 interchangeable bits.
Item No. Combination Bit Set
75999
Set with Standard Precision Handle
Set includes the following bits:
Slotted: 1.5, 2.0, 3.0, 4.0mm
Hex Metric: .7, .9, 1.3, 1.5,
100mm Bit Extension
lbs. .64
18 Pc.
Set
75395 18pc SYS 4 Hex Inch & Metric
Precision Interchangeable Bit Set. In
Compact Fold Out Box. Wiha precision
handle, bit extension and 16 Wiha
75395
Includes the following bits:
100mm Bit Extension
lbs. .58
D
27 Pc.
Set
26 Pc.
Set
75995 26pc SYSTEM 4 Precision
Interchangeable Bit Set. In Compact Fold
Out Box Sets includes Wiha precision handle,
bit extension & 24 Wiha interchangeable bits.
Item
No.
Set with ESD Safe Precision Handle
75995
and the following bits:
: T1, T2, T3, T4, T5, T6, T7,
T8, T9, T10
Pentalobe: PL1, PL2, PL3, PL4, PL5, PL6
Slotted: 1.5, 2.0, 2.5, 3.0mm
100mm Bit Extension
lbs. .54
27 Pc.
Set
759 sets 27pc SYSTEM 4 Slotted/Phillips/
Hex Inch/
Bit Set. In Compact Fold Out Box. Sets
include your choice of Wiha precision handle,
bit extension & 25 Wiha interchangeable bits.
Item
Handle Options for SYSTEM 4
No.
Combination Bit Sets
75991 Set with Standard Precision Handle
75992 Set with ESD Safe Precision Handle
Sets include the following bits:
: T3, T4, T5,
T6, T7, T8, T9, T10, T15
100mm Bit Extension
lbs. .64
75994 27pc SYSTEM 4 Slotted/
Phillips/Hex Metric/
Precision
Out Box. Set includes Wiha precision handle,
bit extension and 25 Wiha interchangeable bits.
Item
SYSTEM 4
No.
Combination Bit Set
75994
T3, T4, T5, T6, T7, T8, T9, T10, T15
100mm Bit Extension
lbs. .64
40 P
c. S
et
D
75996 40pc SYSTEM 4 Interchangeable
Bit Set. Includes Wiha precision handle, bit
extension & 38 interchangeable bits.
Item
SYSTEM 4
No.
Combination Bit Set
75996
1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm
: T3, T4, T5,
Hex Metric: 1.3, 1.5,
100mm Bit Extension
lbs. 1.04
SYSTEM 4
Interchangeable Bit Sets
Technicians MicroBit Sets
• Micro Precision Bits on 4mm Hex Drive
• Bits of Exclusive CRM-72 Tool Steel
• Handle uses non-magnetic ball retainer
• Use bits in extension only
• Standard extension adds 4” to length
• Non-magnetic bit extension
Surface resistance of
handles is 106 - 109 Ohms
D
Rotation cap
Light weight &
compact
Handle tapered for
precise control
75096 16pc SYSTEM 4 Hex Inch & Metric
Compact ESD Precision Interchangeable
Bit Set
75096
Hex Inch: 1/16, 5/64, 3/32, 7/64,
1/8, 9/64, 5/32”
Hex Metric: .9, 1.3, 1.5, 2.0, 2.5,
lbs.
3.0, 4.0mm
.17
100mm Bit Extension
Bits hardened for
extreme durability
D
D
16pc SYSTEM 4 Slotted, Phillips,
75093
Phillips: 00, 0, 1
lbs.
: T6, T7, T8, T9, T10, T15, T20
.17
100mm Bit Extension
75093
D
75094 16pc SYSTEM 4 Slotted, Phillips,
Hex Inch Compact ESD Precision
75094
Phillips: 00, 0, 1
Hex Inch: .035, .050, 1/16, 5/64,
lbs.
3/32, 7/64, 1/8”
.17
100mm Bit Extension
D
75095 16pc SYSTEM 4 Slotted, Phillips,
Hex Metric Compact ESD Precision
75095
Phillips: 00, 0, 1
lbs.
3.0, 4.0mm
.17
100mm Bit Extension
75097 16pc SYSTEM 4 Slotted, Phillips,
Pentalobe Compact ESD Precision
75097
Slotted: 1.2, 1.5, 2.0, 2.5, 3.0mm
lbs.
.17
100mm Bit Extension
91109 Black Cartridge Holder
Holds 14 Micro bits 4mm. 1” OAL
Item
No.
mm
mm lbs.
91109
4.0
25.4 .01
Includes
Dust Cover
D
75968 68pc SYSTEM 4 Micro Bit Set
Includes ESD handle, Micro bit storage handle,
micro bit extension & 65 micro bits.
Item No.
75968 Includes the following micro bits:
lbs.
3.0, 3.5, 4.0mm
.70
Hex Metric: .7, .9, 1.3, 1.5, 2.0, 2.5,
3.0, 4.0mm
Nut Drivers Metric: 2.0, 2.5, 3.0,
3.5, 4.0, 4.5, 5.0, 5.5mm
Nut Drivers Inch: 5/64, 3/32, 7/64,
1/8, 9/64, 5/32, 3/16, 7/32”
Magnetic 1/4” to 4mm Adapter
* Does not include storage box
D
D
75965 65pc SYSTEM 4 Master Tech ESD
& Ratchet With Micro Bits. In Storage Box.
Includes Wiha precision ESD Safe handle,
micro bit extension, 72 tooth ratchet & 62
interchangeable micro bits.
Item No.
lbs. 1.16
75965
Slotted: 0.8, 1.2, 1.5, 1.8, 2.0, 2.5, 3.0, 3.5, 4.0mm
: T3, T4, T5, T6, T7, T8, T9, T10, T15, T20
Hex Metric: .7, .9, 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm
Hex Inch: .050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32”
Nut Drivers Metric: 2.0 - 5.5mm
Nut Drivers Inch: 5/64 - 7/32”
75971 68pc SYSTEM 4 Micro Bit Set
Item No. Set In Zipper Case
75971 Includes the following micro bits:
lbs.
3.0, 3.5, 4.0mm
.96
3.0, 4.0mm
www.wihatools.com
21
SYSTEM 4
Micro Bit Handle Storage Sets
Micro precision
bits on 4mm
hex drive
Bits of exclusive
CRM-72 tool steel
Storage handle
Bits hardened for
extreme durability
D
75980 68pc SYSTEM 4 Master Tech Micro
Bit Set. Includes Wiha ESD Safe Precision
Handle, 1/4” to 4mm Adapter, 100mm Bit
Extension & 36 Micro Bits.
Item No. SYSTEM 4 Micro Bit Set
75980 Includes The Following Bits:
T6, T7, T8, T9, T10
Hex Metric: 1.3, 1.5, 2.0, 2.5, 3.0, 4.0mm
lbs. .38
75981 7pc Micro Bit Handle Storage
Slotted & Phillips Bit Set
Wiha precision storage handle & 6 Micro Bit
interchangeable 4mm bits.
Item
Set with Micro Bit Precision
No.
Storage Handle
75981 Slotted: 1.2, 1.5, 2.0mm
lbs. .08
D
75993 28pc SYSTEM 4 Premium
ESD Safe Micro Bit Set. Includes Wiha ESD
Safe Precision Handle, 1/4” to 4mm Adapter,
100mm Bit Extension, ESD Safe Tweezers &
21 Micro Bits.
75993 Micro Bits:
Slotted: 0.8, 1.5, 2.0, 2.5,
3.0, 3.5mm
T6, T7, T8, T9, T10
ESD Safe Tweezers:
5SA ESD, 7aSA ESD, 2ASA ESD,
AASA ESD, OOSA ESD
lbs. .95
75805 SYSTEM 4 Micro Bit Storage
108mm / 4.25” OAL
Item
No.
mm Inch lbs.
75805 4.0 .1574 .05
75985 7pc Micro Bit Handle Storage
Bit Set
Item
No.
Storage Handle
75985
lbs. .08
75983 7pc Micro Bit Handle Storage Hex
Inch Bit Set
Item
No.
Storage Handle
75983
3/32, 7/64, 1/8”
lbs. .08
22
Pliers & Cutters
Electronic Oblique 48O Cutter
Full Flush
Electronics pliers with cutting edges
are designed especially for cutting
soft to medium hard wires.
Precision ground
cutting edges for
smooth cuts
Lay-on, riveted
precision joint
Glare free
black finish
Light weight design for
in production work
C70 tool steel HR60 hardness
Full Flush
56812 Precision Electronic Diagonal
Cutters, Narrow Shape Extra narrow, short
head for working in particularly restricted
spaces. Cutting edge - full flush. With return
spring. For absolutely flush cutting of copper
wires in difficult to access locations.
lbs. .19
Pkg.
Item No. mm Inch Cut Capacity
56812 118 4.5 0.8mm/16AWG 1
Narrow Front Cutter/Long
Nose Pliers
Full Flush
Wire Holding
Spring
Full Flush
56818 Precision Electronic Diagonal
Cutters, Wide Pointed Head Cutting edge full flush. With return spring. C70 special tool
steel. For an absolutely flush cut of copper wire.
lbs. Pkg.
56818 138 5.5 1.3mm/16AWG .22 1
56813 Precision Electronic Diagonal Full
Flush Cutters With Wire Trapping Spring
Extra narrow, short head for working in
particularly restricted spaces. Cutting edge full flush. With return spring. C70 special tool
steel. For absolutely flush cutting of copper
Item No. mm Inch Cut Capacity lbs. Pkg.
56813 128 5.0 1.0mm/16AWG .19 1
Full Flush
Semi Flush
56815 Precision Electronic Diagonal
Cutters, Wide Pointed Head Cutting edge semi flush. With return spring. C70 special tool
steel. Universal small diagonal cutter for cutting
copper wires.
lbs. .23
Item
Cut
Medium
No.
mm Inch Capacity Hard Wire Pkg.
1
56815 138 5.5 2.0mm/16AWG 0.8
56833 Electronic Oblique 48O Cutter
Wide pointed head. Cutting edge - full flush.
With cutting edge at 48O for cutting obliquely
from above or from the side. C70 special
tool steel. For absolutely flush cutting of copper
56833 138 5.5 1.3mm/16AWG .22 1
Wire
Holding
Spring
Full Flush
56830 Electronic Narrow 30O Front
Cutter / Long Nose Pliers Extremely narrow,
short head for working in particularly restricted
spaces. Cutting edge - full flush. Edge at 30O
to face end of pliers for cutting obliquely from
above or form the side. C70 special tool
56830 118 4.5 0.6mm/16AWG .19 1
56825 Precision Electronic Diagonal
Cutters, Wide Shape With Wire Holding
Spring Wide, Pointed head. Cutting edge full flush. With return spring & fixture for
holding ends of wires that have been cut off.
lbs. Pkg.
56825 138 5.5 1.3mm/16AWG .23 1
Electronic Pointed Pliers
56801 Electronic Short Nose Precision
Pliers Narrow, short head. Smooth jaws.
Width at tip is only 1.2mm. C70 special tool
steel. For holding small components as well as
for holding and angling wires.
Item No. mm Inch Pkg. lbs.
56801 138 5.5 1 .23
56871 Electronic Stripping Pliers
Wide long head with ridged gripping surface,
shears blade and firm wire stripping stations.
With opening spring and locking mechanism.
Wire stripping stations 0.81 / 1.0 / 1.3 / 1.6 /
2.0 / 2.59mm, AWG 20 / 18 / 16 / 14 / 12 / 10.
#56871 mm Inch Ø
AWG lbs. Pkg.
180 7.0 0.81-2.59 20-10 .15 1
www.wihatools.com
23
D
Professional Quality ESD Tweezers
ESD SAFE • STATIC DISSIPATIVE • HYPO ALLERGENIC COATED • TEXTURED GRIPPING SURFACE
Universal Fine Point Tweezers
Very Fine Points/Tapered To Tip
Angled 3.5 to 7mm Diameter
Item No. Description
wt.
44501
AA SA ESD-130mm
.09
Static dissipative, ESD Safe hypo allergenic tweezers
made from Vommaloy. Special stainless steel,
anti-magnetic and acid resistant.
wt.
44508
4 SA ESD - 110mm
.08
wt.
44515
54 SA ESD - 120mm
.08
Long Narrow Body Low Force
Extra Fine Points/Tapered To Tip
Narrow Rounded Tip Serrated,
Guide Pin
wt.
44503
SS SA ESD - 135mm
.08
wt.
44509
5 SA ESD - 110mm
.08
made from Vommaloy. Special stainless steel, antimagnetic and acid resistant.
wt.
44518
22 SA ESD - 150mm
.10
Reduced Body To Medium Point
Curved Extra Fine Rounded Tips
Universal Blunt Tip Serrated
wt.
44504
2 SA ESD - 120mm
.08
wt.
44510
7a SA ESD - 120mm
.08
wt.
44520
40 SA ESD - 145mm
.11
Flat Round Tip Smooth Sides
Holds 0.8 to 2mm Diameter
MicroTip 45O Hook 1x1x2mm
wt.
44511
50 SA ESD - 120mm
.08
wt.
44521
12 SA-SMD ESD-120mm .09
wt.
44505
2a SA ESD - 120mm
.08
Fine Round Points For Assembly
wt.
44506
3 SA ESD - 120mm
.08
Holds 1.5 to 3mm Diameter
wt.
44512
51 SA ESD - 130mm
.08
10pc ESD Safe Tweezers Set
Fine Round Points Shorter
Holds 6.5 to 10mm Diameter
wt.
44507
3c SA ESD - 110mm
.08
wt.
44514
53 SA ESD - 120mm
.08
wt.
44593
10pc Set Includes:
1.05
AA SA Fine Point, 2a SA Flat Round Tip,
3 SA Round Point, 3c SA Fine Round Points Shorter,
4 SA Very Fine Points, 7a SA Curved Extra Fine,
PSF SA Flat-1.0mm Wide, 7abb SA Curved Extra Fine,
5bb SA Extra Fine Bent, 4b SA Very Fine Point 40°
24
Wiha Professional Quality ESD Safe Tweezers
MicroTip For Chips Angled
1.6 x 1 x 1mm
Flat Bent 35O 2mm Diameter Grip Radius
Narrow Body, Bent, Long Guide
Pin, Serrated
wt.
44522
13 SA ESD - 120mm
.08
wt.
44530
59 SA-SMD ESD-117mm .08
wt.
55532
22b SA ESD - 155mm
.10
S
Long Flat to 1.0mm Wide
No Serration
wt.
44523
PSF SA ESD-125mm
.09
ESD Safe General Purpose Fine Point
Blunt Tips - 1.0mm Wide Serrated
wt.
44531
1 SA ESD - 120mm
.08
wt.
55533
PSF SA ESD S -125mm .09
Curved Extra Fine, 3mm Long
Straight Tip
Heavy Duty Strong Tweezers
Tapered To Strong Point
wt.
44525
7abb SA ESD - 120mm .08
wt.
44532
00 SA ESD - 120mm
.09
Angled Extra Fine Points
Bent 30O - 3mm Long Tips
Angled & Slightly Bent
With Extra Fine Tips
wt.
44527
5abb SA ESD - 117mm .08
wt.
44533
7 SA ESD - 120mm
.08
Extra Fine Points Bent
30O - 3mm Long Tips
wt.
44528
5bb SA ESD-107mm
.08
MicroTip 30O Bend & 0.5mm Slot Milled
wt.
55531
11SA-SMD ESD-117mm
.08
Flat and Broad Tips 3mm Wide
wt.
55534
F SA ESD - 120mm
.08
MicroTip Straight & 0.5mm Slot Milled
wt.
55535
8ab SA-SMD ESD-120mm .08
MicroTip 30O Bent & Angled
With 0.5 Slot
wt.
55536
19 SA-SMD ESD-120mm
.08
www.wihatools.com
25
Wiha Professional
Quality ESD Safe
Tweezers
Chip Holding Curved Fine MicroTip
Inspection Mirrors All Stainless Detachable & Boilable
Inspection Mirrors - Detachable
All Stainless
For Visual Checks and Fault
Finding at Inaccessible
Locations
wt.
55537
R10 SA SMD ESD - 117mm .07
Light weight,
tubular
Stainless
Steel
Natural Finish,
Stainless Steel
Mirrors-Clean
Room Quality
40426 - #6
10mm
40410 - #0
26mm
Very Fine Points 40° Tapered To Tip
Inspection Mirror - Stainless 10mm
Inspection Mirror - Stainless 26mm
wt.
55539
4b SA ESD - 110mm
.08
40410
#0 IM - 216mm
40426
#6 IM - 229mm
wt.
.09
wt.
.10
40430 - #8
30mm
14mm
40414 - #0
Wafer Tweezer
wt.
55538
72a SA ESD -
.07
Inspection Mirror - Stainless 14mm
Inspection Mirror - Stainless 30mm
40414
#0 IM - 216mm
40430
#8 IM - 232mm
wt.
.09
wt.
.10
20mm
40420 - #3
Inspection Mirror - Stainless 20mm
9mm Wide With
Back Stop Pins - Wafer
wt.
55546
89 SA ESD - 125mm
.08
40420
#3 IM - 224mm
wt.
.09
22mm
40422 - #4
Inspection Mirror - Stainless 22mm
Short Stem
40422
#4 IM -224mm
Angled 12mm Wide Flat,
Back Stop - Wafer
wt.
55547
91 SA ESD - 125mm
.08
wt.
.10
7pc Inspection Mirror Set
Item No.
40490
Description
wt.
7pc Set Includes:
.67
10mm, 14mm, 20mm, 22mm
24mm, 26mm, 30mm
40424 - #5
24mm
24mm Short Stem
40424
#5 IM - 225mm
wt.
.10
Disposable Inspection Mirrors
wt.
40425
5 Pack - Plastic
.10
Set includes: White disposable inspection mirror #5
Inspection Mirrors - 24mm x 146mm
26
Item No. Page
26000 4
26001 4
26008 4
26010 4
26012 4
26015 4
26018 4
26020 4
26022 4
26023 4
26025 4
26027 4
26028 4
26030 4
26032 4
26033 4
26034 4
26035 4
26040 4
26041 4
26042 4
26050 9
26051 9
26052 9
26053 9
26055 9
26060 9
26061 9
26065 9
26066 9
26068 9
26070 9
26072 9
26073 9
26074 9
26076 9
26079 9
26080 9
26090 4
26092 5
26093 9
26099 4
26100 4
26101 4
26102 4
26105 4
26107 4
26108 4
26109 4
26110 4
26113 4
26114 4
26115 4
26130 9
26132 9
26135 9
26136 9
26140 9
26142 9
Item No. Page
26145 9
26190 4
26192 5
26193 9
26194 5
26195 9
26196 9
26197 4
26198 9
26199 4
26205 5
26210 5
26307 5
26309 5
26313 5
26315 5
26316 5
26320 5
26323 5
26325 5
26327 5
26330 5
26331 5
26333 5
26336 5
26340 5
26341 10
26343 10
26345 10
26347 10
26349 10
26351 10
26353 10
26363 10
26367 10
26369 10
26371 10
26390 5
26391 5
26392 10
26393 10
26399 5
26413 6
26415 6
26416 6
26419 6
26420 6
26423 6
26425 6
26427 6
26430 6
26431 6
26436 6
26439 6
26440 6
26441 10
26443 10
26445 10
26447 10
Item No. Page
Item No. Page
Item No. Page
Item No. Page
26449 10
26455 10
26457 10
26459 10
26461 10
26463 10
26465 10
26467 10
26490 6
26491 6
26493 10
26499 6
26510 7
26515 7
26520 7
26523 7
26525 7
26527 7
26530 7
26531 7
26532 7
26535 7
26536 7
26539 7
26540 7
26545 7
26547 7
26550 7
26555 7
26556 7
26560 7
26563 7
26570 7
26571 11
26572 11
26573 11
26574 11
26575 11
26576 11
26577 11
26578 11
26579 11
26581 11
26582 11
26583 11
26584 11
26585 11
26586 11
26587 11
26588 11
26589 11
26590 7
26591 7
26592 7
26593 11
26596 11
26598 7
26599 7
26601 5
26631 11
26701 6
26702 6
26703 6
26704 6
26705 6
26706 6
26707 6
26708 6
26709 6
26710 6
26715 6
26720 6
26721 12
26723 12
26725 12
26727 12
26729 12
26731 12
26732 10
26733 10
26735 10
26736 10
26737 10
26739 10
26741 10
26743 10
26745 10
26747 10
26749 10
26751 10
26761 7
26762 7
26763 7
26764 7
26765 7
26766 7
26771 11
26772 11
26773 11
26774 11
26775 11
26776 11
26790 6
26791 6
26792 6
26793 10
26794 7
26795 11
26796 10
26798 12
26799 6
26810 4
26815 11
26900 13
26903 13
26904 13
26905 13
26906 15
26911 13
26912 13
26913 14
26914 14
26916 14
26917 14
26918 14
26919 14
26920 14
26921 14
26922 13
26923 14
26924 14
26925 14
26926 14
26927 14
26928 14
26929 14
26930 15
26932 14
26934 14
26935 14
26936 14
26937 14
26938 14
26939 14
26940 14
26941 14
26942 14
26943 14
26944 14
26945 14
26946 14
26947 14
26948 14
26949 14
26950 14
26951 13
26952 13
26953 13
26954 13
26955 13
26956 13
26957 13
26958 15
26959 15
26960 15
26961 15
26962 14
26963 14
26964 14
26965 14
26966 14
26968 14
26969 14
26971 13
26972 13
26973 13
26974 13
26975 15
26976 15
26977 15
26978 15
26979 15
26980 15
26981 15
26982 15
26983 15
26985 15
28000 13
28002 15
28003 15
28004 15
28005 15
28006 15
28007 15
28008 15
28012 15
28021 14
28023 14
28024 14
28026 14
28027 14
28028 14
28029 14
28033 14
28034 14
28035 14
28036 14
28037 14
28552 8
28620 8
28622 8
28624 8
28626 8
28627 8
28629 8
28632 8
28633 8
28637 8
28644 8
32000 12
32001 12
32002 12
32003 12
32004 12
32085 12
32088 12
32106 12
32107 12
32108 12
40010 8
40410 25
40414 25
40420 25
40422 25
40424 25
40425 25
www.wihatools.com
27
Item No. Page
Item No. Page
Item No. Page
Item No. Page
Item No. Page
40426 25
40430 25
40490 25
44501 23
44503 23
44504 23
44505 23
44506 23
44507 23
44508 23
44509 23
44510 23
44511 23
44512 23
44514 23
44515 23
44518 23
44520 23
44521 23
44522 24
44523 24
44525 24
44527 24
44528 24
44530 24
44531 24
44532 24
44533 24
44593 23
55531 24
55532 24
55533 24
55534 24
55535 24
55536 24
55537 25
55538 25
55539 25
55546 25
55547 25
56801 22
56812 22
56813 22
56815 22
56818 22
56825 22
56830 22
56833 22
56871 22
62994 12
75008 17
75012 17
75015 17
75018 17
75020 17
75025 17
75030 17
75035 17
75040 17
75093 20
75094 20
75095 20
75096 20
75097 20
75105 17
75110 17
75115 17
75120 17
75125 17
75307 17
75309 17
75313 17
75315 17
75320 17
75322 17
75325 17
75330 17
75332 17
75340 17
75342 17
75350 17
75352 17
75354 17
75356 17
75358 17
75360 17
75362 17
75364 17
75366 17
75368 17
75370 17
75372 17
75395 19
75602 16
75603 16
75604 16
75605 16
75606 16
75607 16
75608 16
75609 16
75610 16
75611 16
75612 16
75613 16
75614 16
75615 16
75616 16
75617 16
75618 16
75619 16
75620 16
75621 16
75622 16
75623 16
75624 16
75626 16
75627 16
75628 16
75629 16
75630 16
75631 16
75632 16
75633 16
75634 16
75635 16
75636 16
75637 16
75638 16
75639 16
75641 16
75644 16
75645 16
75646 16
75647 16
75648 16
75649 16
75650 16
75651 16
75652 16
75653 16
75654 16
75655 16
75657 16
75658 16
75659 16
75660 16
75661 16
75662 16
75663 16
75664 16
75665 16
75666 16
75667 16
75668 16
75669 16
75670 16
75671 16
75672 16
75673 16
75674 16
75675 16
75676 16
75681 16
75683 16
75701 17
75702 17
75703 17
75704 17
75705 17
75706 17
75707 17
75708 17
75709 17
75710 17
75715 17
75720 17
75735 17
75742 17
75743 18
75744 18
75745 18
75746 18
75747 18
75748 18
75800 17
75801 17
75802 18
75803 18
75805 21
75806 18
75810 18
75811 18
75812 18
75813 18
75814 18
75815 18
75816 18
75817 18
75820 18
75821 18
75822 18
75823 18
75824 18
75825 18
75826 18
75827 18
75900 17
75901 17
75902 17
75965 20
75968 20
75971 20
75973 11
75980 21
75981 21
75982 18
75983 21
75993 21
75984 18
75985 21
75986 18
75987 18
75988 18
75991 19
75992 19
75994 19
75995 19
75996 19
75999 19
91109 20
91118
11
92189 8
92190 8
92191 8
96800 12
Item No. Page
Prop65 WARNING: This product could expose you
to chemicals including Vinyl Chloride, Ethylene Glycol, Ni
or CrVl, which are known to the state od California to cause
cancer or reproductive harm. For more information go to
www.P65warnings.ca.gov/
(800) 494-6104
fax: (800) 494-7456
cservice@wihatools.com
www.wihatools.com
Wiha Quality Tools
1348 Dundas Circle
Monticello, MN 55362
tel: 763.295.6591
fax: 763.295.6598
Wiha Tools Canada Ltd.
www.wihatools.ca
Brampton, ONT L6T 4X4
tel: 866.494.0096 or 763.295.6591
fax: 763.295.6598
To:
Catalog Item No. 99006 .wo
version - 9/1/19
Subject to change without notice
©2019 Willi Hahn Corporation
®Torx is a registered trademark of
Acument Intellectual Properties LLC.
2019
99934.wo - Hex Tools Catalog
2019
99914.wo - TORX Catalog
2019
99001.wo - TorqueControl Catalog
99951.wo - Bits Catalog
2019
99919.wo - Insulated Catalog
2019
PROFESSIONAL PLIERS & CUTTERS
Professional Quality Tools
COMPLETE
PLIERS AND
CUTTERS PROGRAM
MERCHANDISE PROGRAM
Insulated Chrome • Insulated Industrial • Industrial SoftGrip • Vinyl Soft Grip
Precision • ESD Safe • ESD Safe Proturn • Pipe Wrenches • Adjustable Wrenches
99002.wo - Screwdrivers Catalog
99004.wo - Shop Tools Catalog
99977.wo - Pliers/Crimpers Catalog
99945.wo - ESD Catalog
99007.wo - Merchandise Catalog
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Wiha:
26325 26330 75742 76131 76113 76129 75705 26982 75706 75715 76111 75720 76107 76121 76123
75708 76117 28552 75709 75710 75739 75707 26978 75704 26980 76106 76109 75703 76119 26935
26926 26913 26916 26927 26932 26914 26924 26937 26929 26917 26918 26971 28633 56825 28626
28632 26938 26949 56801 56813 56818 26956 26958 26976 28027 26957 26963 26968 26911 26940
26954 26941 26945 26947 28023 28029 26959 40425 56830 75395 26922 28644 26943 26708 28637
56815 26967 40422 28622 56871 26965 56812 56833 75999 26055 26960 75800 28629 28627 75902
40424 75360 75368 75735 75327 75340 28620 75320 75358 75309
