2SC3356
2SC3356
    MDD(辰达半导体)
    SOT-23
    NPN VCEO=12V IC=100mA hFE=50~250
2SC3356 数据手册
2SC3356 SOT-23 Plastic-Encapsulate Transistors 2SC3356 TRANSISTOR (NPN) SOT-23 FEATURES z Low Noise and High Gain z High Power Gain 1. BASE 2. EMITTER 3. COLLECTOR MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol Parameter Value Unit BVCBO Collector to Base Voltage 20 V BVCEO Collector to Emitter Voltage 12 V BVEBO Emitter to Base Voltage 3 V IC Collector Current 100 mA PC Power Dissipation 200 mW Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55~+150 ℃ ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Typ Symbol ol Test conditions Collector-base breakdown voltage V(BR)CBO IC=10μA, IE=0 20 V Collector-emitter breakdown voltage V(BR)CEO IC=1mA, IB=0 12 V Emitter-base breakdown voltage V(BR)EBO IE=10μA, IC=0 3 V Collector cut-off current ICBO VCB=10V, IE=0 1 μA Emitter cut-off current IEBO VEB=1V, IC=0 1 μA DC current gain hFE VCE=10V, IC=20mA Transition frequency fT VCE=10V, IC=20mA Noise figure NF VCE=10V, IC= 7mA, f = 1GHz Parameter Min Max 50 Unit 250 GHz 7 2 dB CLASSIFICATION OF hFE Marking Rank Range R23 R24 R25 Q R S 50 -100 80 -160 125-250 250-300 DN:T20413A0 http://www.microdiode.com Rev:2020A0 Page :1 2SC3356 Typical Characteristics Ptot—TA http://www.microdiode.com Cre—VCB HFE—Ic S21—freq NF—IC NF—VCE Rev:2020A0 Page :2 2SC3356 Outlitne Drawing SOT-23 Package Outline Dimensions e Suggested Pad Layout 0.037 0.95 0.037 0.95 L L1 E E1 Symbol A A1 b c D E E1 e L L1 θ Dimensions In Millimeters Min Typ Max 1.00 1.40 0.10 0.35 0.50 0.20 0.10 2.70 2.90 3.10 1.40 1.60 2.4 2.80 1.90 0.10 0.30 0.4 0° 10° Note: 1. Controlling dimension:in/millimeters. 2. General tolerance: ±0.05mm. 3. The pad layout is for reference purposes only. 0.079 2.0 0.035 0.9 0.031 0.8 inches mm Important Notice and Disclaimer Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Jiangsu). Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Jiangsu). http://www.microdiode.com Rev:2020A0 Page :3 2SC3356 SOT-23 Tape and Reel Packaging Description: SOT-23 parts are shipped in tape. The carrier tape is made from a dissipative (carbon filled) polycarbonate resin. The cover tape is a multilayer film (Heat Activated Adhesive in nature) primarily composed of polyester film,adhesive laye,sealant, and anti-static sprayed agent.These reeled parts In standard option are shipped with 3,000 units per 7" or 17.8cm diameter reel. The reels are clear in color and is made of polystyrene plastic (anti-static coated). 3000 pcs http://www.microdiode.com 7 Inch 45,000 pcs 203×203×195 180,000 pcs 438×438×220 Rev:2020A0 Page :4
2SC3356 价格&库存
很抱歉,暂时无法提供与“2SC3356”相匹配的价格&库存,您可以联系我们找货
