CSM4Z-A2B3C3-40-11.0592D18
    CARDINALCOMPONENTS
    HC-49S/SMD
    无源晶振 11.0592MHz ±30ppm 18pF 40Ω -40℃~+85℃
CSM4Z-A2B3C3-40-11.0592D18 数据手册
CARDINAL COMPONENTS Low Profile Surface Mount Crystals Series CSM4 CSM5 • 3.0 mm Maximum SMD profile • Very cost competitive • Fast delivery Part Numbering Example: CSM4 Z - A1 B2 C2 200 - 3.579545 D18 - 3 CSM4 Z A1* SERIES ADDED FEATURES CSM4 BLANK = BULK PACK CSM5 Z = TAPE AND REEL B2 OPERATING TEMP. A0 = -10°C ~ +60°C A1 = -10°C ~ +70°C A2 = -40°C ~ +85°C A3 = -55°C ~ +125°C C2 200 3.579545 D18 -3 STABILITY TOLERANCE RESISTANCE FREQUENCY LOAD CAP. OVERTONE B1 = ±100 SEE CHART C1 = ±100 D16,18,20,ETC. BLANK: FUND. -3: 3rd OT B2 = ± 50 BELOW C2 = ± 50 DS = SERIES B3 = ± 30 C3 = ± 30 B4 = ± 10 C4 = ± 10 *NOTE: The above ABC combinations cover basic specification options. We tailor our crystal specifications to meet customer requirements. Please contact our sales department if you don’t see exactly what you need. CSM4 Specifications: Frequency Range: 3.579545 ~ 38.000 MHz 25.000000 ~ 75.000 MHz 26.000000 ~ 48.000 MHz Operating Temperature: -10°C ~ +70°C -40°C ~ +85°C Frequency Stability: Frequency Tolerance: (at 25°C) ±100 ± 50 ± 30 ± 15 ppm ppm ppm ppm ±100 ±50 ±30 ±10 ppm ppm ppm ppm AT Cut Fundamental AT Cut 3rd Overtone BT Cut Fundamental Standard Standard Standard RECOMMENDED SOLDER PAD LAYOUT Load Capacitance: Standard 18 pF or series. Please specify your required load. Resistance: Maximum resistance corresponds to frequency. See chart below. Standard: Mode: Fundamental or 3rd Overtone Shunt Capacitance: 7 pF Max Aging: ± 5 ppm/year Drive Level: 1.0 mW Max CSM5 Optional Features: Tape and Reel (1K per Reel) Note: Not all combinations of the above tolerances, stabilities, and temperature ranges are available. Consult the factory if your requirement is not standard. Resistance Chart: All resistances are maximum values. EQUIVALENT SERIES RESISTANCE (ESR), MODE OF OPERATION (MODE), AND CUT Frequency MHz 3.579545~4.999 5.000~5.999 6.000~7.999 8.000~8.999 9.000~9.999 10.000~14.999 ESR(Ω) 200 Max 150 Max 120 Max 90 Max 80 Max 70 Max Mode/cut Fund./AT Fund./AT Fund./AT Fund./AT Fund./AT Fund./AT Frequency MHz 15.000~15.999 16.000~23.999 24.000~30.000 24.000~48.000 24.576~29.999 30.000~75.000 ESR (Ω) 60 Max 50 Max 40 Max 40 Max 150 Max 100 Max Mode/cut Fund./AT Fund./AT Fund./AT Fund./BT 3rd Overtone/AT 3rd Overtone/AT RECOMMENDED SOLDER PAD LAYOUT Cardinal Components, Inc. 1801 Broadway St Charlottesville, VA 22902 USA TEL: (973)785-1333 E-MAIL: sales@cardinalxtal.com WEB: http://www.cardinalxtal.com
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光敏三极管集电极,6脚光敏三极管发射极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输入电流为10mA,输出电流为10mA等。
5. 功能详解:EL817通过内部的发光二极管和光敏三极管实现电-光-电转换,实现信号隔离。
6. 应用信息:EL817广泛应用于工业控制系统、仪器仪表、通信设备等领域。
7. 封装信息:EL817采用DIP6封装,尺寸为9.1mm x 3.6mm x 4.9mm。
CSM4Z-A2B3C3-40-11.0592D18 价格&库存
很抱歉,暂时无法提供与“CSM4Z-A2B3C3-40-11.0592D18”相匹配的价格&库存,您可以联系我们找货
