FT533DA
FT533DA
    FMD(辉芒微)
    SOT23-5
    快速启动、超低噪声、高PSRR、400mA LDO
FT533DA 数据手册
Fremont Micro Devices FT533xx Fast Start-up, Ultra Low Noise, High PSRR, 400mA LDO FEATURES DESCRIPTION ¾ Ultra-Low Noise for RF Application The FT533xx is designed for portable RF and ¾ Ultra-Fast Response in Line/Load Transient wireless applications with demanding performance ¾ Quick Start-Up (Typically 25μS) and space requirements. The FT533xx performance is ¾ Low Quiescent Current: 65μA optimized for battery powered systems to deliver ¾ Less than 0.1μA Standby Current When ultra low noise and low quiescent current. Regulator Shutdown ground current increases only slightly in dropout, Low Dropout Voltage: 100mV @ 100mA, further prolonging the battery life. ¾ 420mV @ 400mA (Vout=2.8V) ¾ Wide Operating Voltage Ranges : 2.5V to 6V The FT533xx also works with low-ESR ceramic ¾ TTL-Logic-Controlled Shutdown Input capacitors, reducing the amount of board space ¾ Low Temperature Coefficient necessary ¾ Current Limiting Protection hand-held wireless devices. The FT533xx consumes ¾ Only 1μF Output Capacitor Required less than 0.1μA in shutdown mode and has fast ¾ High Power Supply Rejection Ratio turn-on time less than 25μS. The other features ¾ ROHS Compliant and 100% Lead (Pb)-Free include low dropout voltage, high output accuracy, ¾ Custom Voltage Available current limiting protection, and high ripple rejection ¾ Custom Options for CE Logic and Build-in ratio. The FT533xx is available in the 5-lead of Pull-up/down Available SOT-23-5(L), SC-70 and the 3-lead of SOT-23-3(L), for power applications, critical in SOT-89-3(L), SOT-23 packages. APPLLICATIONS ¾ CDMA/GSM Cellular Handsets ¾ Battery-Powered Equipment ¾ Laptop, Palmtops, Notebook Computers ¾ Hand-Held Instruments ¾ PCMCIA Cards ¾ Portable Information Appliances www.fremontmicro.com Page 1 of 21 DS533-A2 Fremont Micro Devices FT533xx TYPICAL APPLICATION CIRCUIT Figure 1: Typical Application Circuit ABSOLUTE MAXIMUM RATINGS Š Supply Input Voltage ----------------------------------------------------------------------------------------------------- 6V Š Power Dissipation, PD@ TA=27 ୅ SOT-23-5(L) ---------------------------------------------------------------------------------------------------- 400mW SOT-23-3(L) ---------------------------------------------------------------------------------------------------- 400mW SOT-89-3(L) ---------------------------------------------------------------------------------------------------- 600mW SC-70 ------------------------------------------------------------------------------------------------------------ 300mW SOT-23 ----------------------------------------------------------------------------------------------------------- 250mW Š Package Thermal Resistance ć/W SOT-23-3(L) --------------------------------------------------------------------------------------------------- 250ć/W SOT-89-3(L) --------------------------------------------------------------------------------------------------- 170ć/W SC-70 ----------------------------------------------------------------------------------------------------------- 330ć/W SOT-23 --------------------------------------------------------------------------------------------------------- 380ć/W Lead Temperature (Soldering, 10sec.) ------------------------------------------------------------------------------ 260㠊 Storage Temperature Range -----------------------------------------------------------------------------ˉ60ć to 150ć SOT-23-5(L) --------------------------------------------------------------------------------------------------- 250 Š ESD Susceptibility HBM (Human Body Mode) -----------------------------------------------------------------------------------------4kV MM (Machine Mode) --------------------------------------------------------------------------------------------200V * Stresses exceed those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. Functional operation of the device at conditions beyond those listed in the specification is not guaranteed. Prolonged exposure to extreme conditions may affect device reliability or functionality. www.fremontmicro.com Page 2 of 21 DS533-A2 Fremont Micro Devices FT533xx PIN CONFIGURATION Figure 2: Pin Configuration www.fremontmicro.com Page 3 of 21 DS533-A2 Fremont Micro Devices FT533xx TERMINAL FUNCTION Function Pin Name Chip Enable (Active High). No Pull-Down Resistor Build-in For packages SOT-23-3(L) ,SOT-89-3(L) and SOT-23 EN internally connected to VIN ˈthe EN is Power Input Voltage VIN VOUT Output Voltage NC No Connection GND Ground Table 1 ORDERING INFORMATION FT533 ķĸ Designator Symbol ķ Output Voltage D 1.8V E 2.5V F 2.7V G 2.8V H 2.85V I 3.0V J 3.3V K 3.6V L 4.2V Table 2 Designator ĸ Symbol Pin Configuration Package Type a SOT-23-5A b SOT-23-5B c SOT-23-5C d SC-70A e SC-70B f SC-70C g SOT-23-3A SOT-23-3(L) h SOT-23A SOT-23 i SOT-89-3A SOT-89-3(L) SOT-23-5(L) SC-70 / SOT-353 Table 3 www.fremontmicro.com Page 4 of 21 DS533-A2 Fremont Micro Devices FT533xx MARKING RULE Figure 3: Top View c Represent Product Series Symbol Product Series 5 FT533xx d Represent Output Voltage and operating temperature range ୅ ~ 85୅. G represent the output voltage is 2.8V, operating temperature is –40 ĹĺĻ for internal reference. BLOCK DIAGRAM Figure 4: Block Diagram www.fremontmicro.com Page 5 of 21 DS533-A2 Fremont Micro Devices FT533xx ELECTRICAL CHARACTERISTICS Vout=1.8V; En=Vin=(Vout+1)V; Cout=1μF unless otherwise noted Parameter Output Voltage Symbol Conditions Min Typ Max Units -2 --- +2 % Vout Iout=1mA Imax Vin=Vout+1V 500 700 --- mA Ishort Vin=Vout+1V --- 80 --- mA Line Regulations ୞Vline (Vout+1.0V)~6V --- 0.01 0.3 %/V ୞Vload 1mA≤Iout≤100mA --- 10 --- Load Regulation 1mA≤Iout≤400mA --- 40 --- Iout=100mA --- 150 --- Iout=400mA --- 650 --- Accuracy Current Limiter Dropout Voltage Vdrop mV mV Supply Current Iq Vin=(Vout+1)V,Iout=0mA --- 65 --- μA Standby Current Istby Shut down --- 0.01 1 μA --- 100 --- ୞Vout/ (୞Temp* Iout=30mA Vout) -40°C≤Temp≤85°C eNO 10Hz~100kHz --- 30 --- Ripple PSRR@1k Vin=Vout+1VDC+1Vp-pAC --- 75 --- Rejection Rate PSRR@10k Iout=30mA --- 75 --- --- 0 100 nA Temperature Coefficient Output Noise Voltage EN Input Bias Current Ien ppm/ ୅ μVrms dB VL --- --- --- 0.3 V VH --- 1.2 --- 6 V EN Threshold * Dropout voltage is defined as the input to output differential at which the output voltage drops 2% below its nominal value measured at 1V differential. www.fremontmicro.com Page 6 of 21 DS533-A2 Fremont Micro Devices FT533xx Vout=2.5V; En=Vin=(Vout+1)V; Cout=1μF unless otherwise noted Parameter Output Voltage Symbol Conditions Min Typ Max Units -2 --- +2 % Vout Iout=1mA Imax Vin=Vout+1V 500 700 --- mA Ishort Vin=Vout+1V --- 80 --- mA Line Regulations ୞Vline (Vout+1.0V)~6V --- 0.01 0.3 %/V ୞Vload 1mA≤Iout≤100mA --- 10 --- Load Regulation 1mA≤Iout≤400mA --- 40 --- Iout=100mA --- 100 --- Iout=400mA --- 450 --- Accuracy Current Limiter Dropout Voltage Vdrop mV mV Supply Current Iq Vin=(Vout+1)V,Iout=0mA --- 65 --- μA Standby Current Istby Shut down --- 0.01 1 μA --- 100 --- ୞Vout/ (୞Temp* Iout=30mA Vout) -40°C≤Temp≤85°C eNO 10Hz~100kHz --- 30 --- Ripple PSRR@1k Vin=Vout+1VDC+1Vp-pAC --- 75 --- Rejection Rate PSRR@10k Iout=30mA --- 75 --- --- 0 100 nA Temperature Coefficient Output Noise Voltage EN Input Bias Current Ien ppm/ ୅ μVrms dB VL --- --- --- 0.3 V VH --- 1.2 --- 6 V EN Threshold * Dropout voltage is defined as the input to output differential at which the output voltage drops 2% below its nominal value measured at 1V differential. www.fremontmicro.com Page 7 of 21 DS533-A2 Fremont Micro Devices FT533xx Vout=2.7V; En=Vin=(Vout+1)V; Cout=1μF unless otherwise noted Parameter Output Voltage Symbol Conditions Min Typ Max Units -2 --- +2 % Vout Iout=1mA Imax Vin=Vout+1V 500 700 --- mA Ishort Vin=Vout+1V --- 80 --- mA Line Regulations ୞Vline (Vout+1.0V)~6V --- 0.01 0.3 %/V ୞Vload 1mA≤Iout≤100mA --- 10 --- Load Regulation 1mA≤Iout≤400mA --- 40 --- Iout=100mA --- 100 --- Iout=400mA --- 420 --- Accuracy Current Limiter Dropout Voltage Vdrop mV mV Supply Current Iq Vin=(Vout+1)V,Iout=0mA --- 65 --- μA Standby Current Istby Shut down --- 0.01 1 μA --- 100 --- ୞Vout/ (୞Temp* Iout=30mA Vout) -40°C≤Temp≤85°C eNO 10Hz~100kHz --- 30 --- Ripple PSRR@1k Vin=Vout+1VDC+1Vp-pAC --- 75 --- Rejection Rate PSRR@10k Iout=30mA --- 75 --- --- 0 100 nA Temperature Coefficient Output Noise Voltage EN Input Bias Current Ien ppm/ ୅ μVrms dB VL --- --- --- 0.3 V VH --- 1.2 --- 6 V EN Threshold * Dropout voltage is defined as the input to output differential at which the output voltage drops 2% below its nominal value measured at 1V differential. www.fremontmicro.com Page 8 of 21 DS533-A2 Fremont Micro Devices FT533xx Vout=2.8V; En=Vin=(Vout+1)V; Cout=1μF unless otherwise noted Parameter Output Voltage Symbol Conditions Min Typ Max Units -2 --- +2 % Vout Iout=1mA Imax Vin=Vout+1V 500 700 --- mA Ishort Vin=Vout+1V --- 80 --- mA Line Regulations ୞Vline (Vout+1.0V)~6V --- 0.01 0.3 %/V ୞Vload 1mA≤Iout≤100mA --- 10 --- Load Regulation 1mA≤Iout≤400mA --- 40 --- Iout=100mA --- 100 --- Iout=400mA --- 420 --- Accuracy Current Limiter Dropout Voltage Vdrop mV mV Supply Current Iq Vin=(Vout+1)V,Iout=0mA --- 65 --- μA Standby Current Istby Shut down --- 0.01 1 μA --- 100 --- ୞Vout/ (୞Temp* Iout=30mA Vout) -40°C≤Temp≤85°C eNO 10Hz~100kHz --- 30 --- Ripple PSRR@1k Vin=Vout+1VDC+1Vp-pAC --- 75 --- Rejection Rate PSRR@10k Iout=30mA --- 75 --- --- 0 100 nA Temperature Coefficient Output Noise Voltage EN Input Bias Current Ien ppm/ ୅ μVrms dB VL --- --- --- 0.3 V VH --- 1.2 --- 6 V EN Threshold * Dropout voltage is defined as the input to output differential at which the output voltage drops 2% below its nominal value measured at 1V differential. www.fremontmicro.com Page 9 of 21 DS533-A2 Fremont Micro Devices FT533xx Vout=2.85V; En=Vin=(Vout+1)V; Cout=1μF unless otherwise noted Parameter Output Voltage Symbol Conditions Min Typ Max Units -2 --- +2 % Vout Iout=1mA Imax Vin=Vout+1V 500 700 --- mA Ishort Vin=Vout+1V --- 80 --- mA Line Regulations ୞Vline (Vout+1.0V)~6V --- 0.01 0.3 %/V ୞Vload 1mA≤Iout≤100mA --- 10 --- Load Regulation 1mA≤Iout≤400mA --- 40 --- Iout=100mA --- 100 --- Iout=400mA --- 420 --- Accuracy Current Limiter Dropout Voltage Vdrop mV mV Supply Current Iq Vin=(Vout+1)V,Iout=0mA --- 65 --- μA Standby Current Istby Shut down --- 0.01 1 μA --- 100 --- ୞Vout/ (୞Temp* Iout=30mA Vout) -40°C≤Temp≤85°C eNO 10Hz~100kHz --- 30 --- Ripple PSRR@1k Vin=Vout+1VDC+1Vp-pAC --- 75 --- Rejection Rate PSRR@10k Iout=30mA --- 75 --- --- 0 100 nA Temperature Coefficient Output Noise Voltage EN Input Bias Current Ien ppm/ ୅ μVrms dB VL --- --- --- 0.3 V VH --- 1.2 --- 6 V EN Threshold * Dropout voltage is defined as the input to output differential at which the output voltage drops 2% below its nominal value measured at 1V differential. www.fremontmicro.com Page 10 of 21 DS533-A2 Fremont Micro Devices FT533xx Vout=3.0V; En=Vin=(Vout+1)V; Cout=1μF unless otherwise noted Parameter Output Voltage Symbol Conditions Min Typ Max Units -2 --- +2 % Vout Iout=1mA Imax Vin=Vout+1V 500 700 --- mA Ishort Vin=Vout+1V --- 80 --- mA Line Regulations ୞Vline (Vout+1.0V)~6V --- 0.01 0.3 %/V ୞Vload 1mA≤Iout≤100mA --- 10 --- Load Regulation 1mA≤Iout≤400mA --- 40 --- Iout=100mA --- 100 --- Iout=400mA --- 420 --- Accuracy Current Limiter Dropout Voltage Vdrop mV mV Supply Current Iq Vin=(Vout+1)V,Iout=0mA --- 65 --- μA Standby Current Istby Shut down --- 0.01 1 μA --- 100 --- ୞Vout/ (୞Temp* Iout=30mA Vout) -40°C≤Temp≤85°C eNO 10Hz~100kHz --- 30 --- Ripple PSRR@1k Vin=Vout+1VDC+1Vp-pAC --- 75 --- Rejection Rate PSRR@10k Iout=30mA --- 75 --- --- 0 100 nA Temperature Coefficient Output Noise Voltage EN Input Bias Current Ien ppm/ ୅ μVrms dB VL --- --- --- 0.3 V VH --- 1.2 --- 6 V EN Threshold * Dropout voltage is defined as the input to output differential at which the output voltage drops 2% below its nominal value measured at 1V differential. www.fremontmicro.com Page 11 of 21 DS533-A2 Fremont Micro Devices FT533xx Vout=3.3V; En=Vin=(Vout+1)V; Cout=1μF unless otherwise noted Parameter Output Voltage Symbol Conditions Min Typ Max Units -2 --- +2 % Vout Iout=1mA Imax Vin=Vout+1V 500 700 --- mA Ishort Vin=Vout+1V --- 80 --- mA Line Regulations ୞Vline (Vout+1.0V)~6V --- 0.01 0.3 %/V ୞Vload 1mA≤Iout≤100mA --- 10 --- Load Regulation 1mA≤Iout≤400mA --- 40 --- Iout=100mA --- 100 --- Iout=400mA --- 420 --- Accuracy Current Limiter Dropout Voltage Vdrop mV mV Supply Current Iq Vin=(Vout+1)V,Iout=0mA --- 65 --- μA Standby Current Istby Shut down --- 0.01 1 μA --- 100 --- ୞Vout/ (୞Temp* Iout=30mA Vout) -40°C≤Temp≤85°C eNO 10Hz~100kHz --- 30 --- Ripple PSRR@1k Vin=Vout+1VDC+1Vp-pAC --- 75 --- Rejection Rate PSRR@10k Iout=30mA --- 75 --- --- 0 100 nA Temperature Coefficient Output Noise Voltage EN Input Bias Current Ien ppm/ ୅ μVrms dB VL --- --- --- 0.3 V VH --- 1.2 --- 6 V EN Threshold * Dropout voltage is defined as the input to output differential at which the output voltage drops 2% below its nominal value measured at 1V differential. www.fremontmicro.com Page 12 of 21 DS533-A2 Fremont Micro Devices FT533xx Vout=3.6V; En=Vin=(Vout+1)V; Cout=1μF unless otherwise noted Parameter Output Voltage Symbol Conditions Min Typ Max Units -2 --- +2 % Vout Iout=1mA Imax Vin=Vout+1V 500 700 --- mA Ishort Vin=Vout+1V --- 80 --- mA Line Regulations ୞Vline (Vout+1.0V)~6V --- 0.01 0.3 %/V ୞Vload 1mA≤Iout≤100mA --- 10 --- Load Regulation 1mA≤Iout≤400mA --- 40 --- Iout=100mA --- 100 --- Iout=400mA --- 420 --- Accuracy Current Limiter Dropout Voltage Vdrop mV mV Supply Current Iq Vin=(Vout+1)V,Iout=0mA --- 65 --- μA Standby Current Istby Shut down --- 0.01 1 μA --- 100 --- ୞Vout/ (୞Temp* Iout=30mA Vout) -40°C≤Temp≤85°C eNO 10Hz~100kHz --- 30 --- Ripple PSRR@1k Vin=Vout+1VDC+1Vp-pAC --- 75 --- Rejection Rate PSRR@10k Iout=30mA --- 75 --- --- 0 100 nA Temperature Coefficient Output Noise Voltage EN Input Bias Current Ien ppm/ ୅ μVrms dB VL --- --- --- 0.3 V VH --- 1.2 --- 6 V EN Threshold * Dropout voltage is defined as the input to output differential at which the output voltage drops 2% below its nominal value measured at 1V differential. www.fremontmicro.com Page 13 of 21 DS533-A2 Fremont Micro Devices FT533xx TYPICAL PERFORMANCE CHARACTERISTICS FT533I Vin=4.0V, Vout=3.0V, Co=1μF, temp=27 ୅ unless otherwise noted Vout VS. Temp Quiescent Current VS. Temp 3.2 Quiescent Current (uA) 80 Vout (V) 3.1 3 2.9 70 60 50 40 2.8 -40 -20 0 20 40 60 80 100 Temp(C) -40 -20 0 20 40 60 80 100 Temp(C) PSRR -30 PSRR(dB20) -40 30mA -50 -60 -70 -80 -90 10 100 1000 10000 100000 Frequency (Hz) www.fremontmicro.com Page 14 of 21 DS533-A2 Fremont Micro Devices www.fremontmicro.com FT533xx Page 15 of 21 DS533-A2 Fremont Micro Devices FT533xx PAKAGING INFORMATION SOT-23-5L Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 0.889 1.295 0.035 0.051 A1 0.000 0.152 0.000 0.006 B 1.397 1.803 0.055 0.071 b 0.356 0.559 0.014 0.022 C 2.591 2.997 0.102 0.118 D 2.692 3.099 0.106 0.122 e 0.838 1.041 0.033 0.041 H 0.080 0.254 0.003 0.010 L 0.300 0.610 0.012 0.024 Symbol www.fremontmicro.com Page 16 of 21 DS533-A2 Fremont Micro Devices FT533xx SOT-23-3L Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950 (BSC) 0.037 ˄BSC˅ e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ e e e e www.fremontmicro.com Page 17 of 21 DS533-A2 Fremont Micro Devices FT533xx SOT-89-3L Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.400 1.600 0.055 0.063 b 0.320 0.520 0.013 0.020 b1 0.400 0.580 0.016 0.023 c 0.350 0.440 0.014 0.017 D 4.400 4.600 0.173 0.181 D1 1.550 REF. 0.061 REF. E 2.300 2.600 0.091 0.102 E1 3.940 4.250 0.155 0.167 e 1.500 TYP. 0.060 TYP. e1 3.000 TYP. 0.118 TYP. L www.fremontmicro.com 0.900 1.200 Page 18 of 21 0.035 0.047 DS533-A2 Fremont Micro Devices FT533xx SC-70 Note: 1. All dimensions are in inches/ (millimeters) 2. Dimensions are inclusive of plating 3. Dimensions are exclusive of mold flash & metal burr 4. All specifications comply to EIAJ SC70 Symbol Min e Max 0.026BSC/ (0.65 BSC) D 0.071/(1.80) 0.067/(2.20) b 0.006/(0.15) 0.012/(0.30) E 0.045/(1.15) 0.053/(1.35) HE 0.071(1.80) 0.094(2.40) Q1 0.004/(0.10) 0.016/(0.40) A2 0.031/(0.80) 0.039/(1.00) A1 0.000/(0.00) 0.004/(0.10) A 0.031/(0.80) 0.043/(1.10) c 0.004/(0.10) 0.007/(0.18) L 0.004/(0.10) 0.012/(0.30) www.fremontmicro.com Page 19 of 21 DS533-A2 Fremont Micro Devices FT533xx SOT-23 Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 0.900 1.100 0.035 0.043 A1 0.000 0.100 0.000 0.004 A2 0.900 1.000 0.035 0.039 b 0.300 0.500 0.012 0.020 c 0.080 0.150 0.003 0.006 D 2.800 3.000 0.110 0.118 E 1.200 1.400 0.047 0.055 E1 2.250 2.550 0.089 0.100 e e1 0.950 TYP. 1.800 L 0.037 TYP. 2.000 0.071 0.550 REF. 0.079 0.022 REF. L1 0.300 0.500 0.012 0.020 θ 0° 8° 0° 8° www.fremontmicro.com Page 20 of 21 DS533-A2 Fremont Micro Devices FT533xx APPENDIX A˖REVISION HISTORY RevisionA1: Added Typical Performance Characteristics of FT533I; Revised some Electrical Characteristics. Version A0: Original data sheet for the FT53xx. * Information furnished is believed to be accurate and reliable. However, Fremont Micro Devices, Incorporated (BVI) assumes no responsibility for the consequences of use of such information or for any infringement of patents of other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent rights of Fremont Micro Devices, Incorporated (BVI). Specifications mentioned in this publication are subject to change without notice. This publication supersedes and replaces all information previously supplied. Fremont Micro Devices, Incorporated (BVI) products are not authorized for use as critical components in life support devices or systems without express written approval of Fremont Micro Devices, Incorporated (BVI). The FMD logo is a registered trademark of Fremont Micro Devices, Incorporated (BVI). All other names are the property of their respective owners. www.fremontmicro.com Page 21 of 21 DS533-A2
FT533DA 价格&库存
很抱歉,暂时无法提供与“FT533DA”相匹配的价格&库存,您可以联系我们找货
