SMD1206P020TF
SMD1206P020TF
    YENJI(台湾元基)
    PTC自恢复保险丝 200mA 24V 1206
SMD1206P020TF 数据手册
SMD1206 Series Surface Mountable PTC Resettable Fuse Features:  RoHS Compliant & Halogen Free faster tripping, 1206 Dimen sion, Su rface mountable, Solid state Operation Current: 0.05A~2.00A   Maximum Voltage: 6V~60Vdc Operating Temperature:-40℃   TO 85℃ Product Dimensions Terminal pad materials :Tin-Plated Nickle-copper Terminal pad solderability : Meets EIA specification RS 186-9E and ANSI/J-STD-002 Category 3. Pig.1 Unit :mm Model Marking A B C D E Min Max Min Max Min Max Min Min SMD1206P005TF JZ 3.00 3.50 1.50 1.80 0.60 1.10 0.15 0.10 SMD1206P010TF JN 3.00 3.50 1.50 1.80 0.60 1.10 0.15 0.10 SMD1206P010TF/33 JN 3.00 3.50 1.50 1.80 0.50 1.10 0.15 0.10 SMD1206P012TF JN 3.00 3.50 1.50 1.80 0.60 1.10 0.15 0.10 SMD1206P016TF JF 3.00 3.50 1.50 1.80 0.40 0.90 0.15 0.10 SMD1206P020TF JF 3.00 3.50 1.50 1.80 0.40 0.90 0.15 0.10 SMD1206P025TF JF 3.00 3.50 1.50 1.80 0.40 0.90 0.15 0.10 SMD1206P030TF JB 3.00 3.50 1.50 1.80 0.40 0.90 0.15 0.10 SMD1206P035TF JB 3.00 3.50 1.50 1.80 0.40 0.90 0.15 0.10 SMD1206P050TF JG 3.00 3.50 1.50 1.80 0.35 0.85 0.15 0.10 1/7 SMD1206 Series Surface Mountable PTC Resettable Fuse Model Marking SMD1206P050TF/13.2 A B C D E Min Max Min Max Min Max Min Min JG 3.00 3.50 1.50 1.80 0.35 0.85 0.15 0.10 SMD1206P050TF/16 JG 3.00 3.50 1.50 1.80 0.35 0.85 0.15 0.10 SMD1206P050TF/24 JG 3.00 3.50 1.50 1.80 0.35 0.85 0.15 0.10 SMD1206P075TF JA 3.00 3.50 1.50 1.80 0.35 0.85 0.15 0.10 SMD1206P075TF/13.2 JA 3.00 3.50 1.50 1.80 0.35 0.85 0.15 0.10 SMD1206P075TF/16 JA 3.00 3.50 1.50 1.80 0.60 1.30 0.15 0.10 SMD1206P100TF SMD1206P100TF/16 JH 3.00 3.50 1.50 1.80 0.40 0.80 0.15 0.10 JH 3.00 3.50 1.50 1.80 0.40 1.30 0.15 0.10 SMD1206P110TF JH 3.00 3.50 1.50 1.80 0.40 1.30 0.15 0.10 SMD1206P110TF/13.2 JH 3.00 3.50 1.50 1.80 0.40 0.80 0.15 0.10 SMD1206P150TF JI 3.00 3.50 1.50 1.80 0.60 1.50 0.15 0.10 SMD1206P200TF JK 3.00 3.50 1.50 1.80 0.70 1.70 0.15 0.10 Thermal Derating Chart-IH(A) Model Maximum ambient operating temperatures(℃) -40 -20 0 25 40 50 60 70 85 SMD1206P005TF 0.09 0.08 0.06 0.05 0.04 0.036 0.033 0.029 0.02 SMD1206P010TF 0.18 0.16 0.12 0.1 0.08 0.072 0.066 0.058 0.04 SMD1206P010TF/33 0.18 0.16 0.12 0.1 0.08 0.072 0.066 0.058 0.04 SMD1206P012TF 0.216 0.192 0.144 0.12 0.096 0.086 0.079 0.070 0.048 SMD1206P016TF 0.288 0.256 0.192 0.16 0.128 0.115 0.106 0.093 0.064 SMD1206P020TF 0.31 0.26 0.22 0.20 0.18 0.16 0.15 0.13 0.07 SMD1206P025TF 0.37 0.33 0.29 0.25 0.22 0.20 0.17 0.15 0.12 SMD1206P030TF SMD1206P035TF 0.444 0.396 0.348 0.30 0.264 0.24 0.204 0.18 0.144 0.50 0.45 0.40 0.35 0.30 0.27 0.24 0.21 0.15 SMD1206P050TF SMD1206P050TF/13.2 0.71 0.64 0.57 0.50 0.42 0.39 0.35 0.31 0.25 0.71 0.64 0.57 0.50 0.42 0.39 0.35 0.31 0.25 SMD1206P050TF/16 0.71 0.64 0.57 0.50 0.42 0.39 0.35 0.31 0.25 SMD1206P050TF/24 0.639 0.576 0.513 0.50 0.378 0.351 0.315 0.279 0.225 SMD1206P075TF 1.14 1.01 0.88 0.75 0.65 0.59 0.54 0.49 0.41 SMD1206P100TF 1.45 1.31 1.15 1.00 0.84 0.77 0.69 0.61 0.48 SMD1206P100TF/16 1.305 1.179 1.035 1.00 0.756 0.693 0.621 0.549 0.432 SMD1206P110TF 1.305 1.179 1.035 1.00 0.756 0.693 0.621 0.549 0.432 SMD1206P110TF/13.2 1.595 1.441 1.265 1.10 0.924 0.847 0.759 0.671 0.528 SMD1206P150TF 2.18 1.94 1.72 1.50 1.28 1.17 1.06 0.96 0.77 SMD1206P200TF 2.60 2.44 2.35 2.00 1.78 1.67 1.50 1.45 1.10 2/7 SMD1206 Series Surface Mountable PTC Resettable Fuse Electrical Characteristic Ihold Itrip @25°C @25°C Current Time Rimin R1max (A) (A) (A) (A) (Sec) () () 60.0 100 0.05 0.15 0.25 1.50 3.600 50.000 SMD1206P010TF 60.0 100 0.10 0.25 0.5 1.00 1.600 15.000 SMD1206P010TF/33 33.0 100 0.10 0.25 0.5 1.00 1.600 15.000 SMD1206P012TF 30 100 0.12 0.29 1.00 0.20 1.350 10.00 SMD1206P016TF 30 100 0.16 0.37 1.00 0.30 1.000 4.50 SMD1206P020TF 24.0 100 0.20 0.46 8.0 0.08 0.350 3.500 SMD1206P025TF 16.0 100 0.25 0.50 8.0 0.08 0.350 2.500 SMD1206P030TF 16.0 100 0.30 0.65 8.0 0.10 0.250 2.00 SMD1206P035TF 6.0 100 0.35 0.75 8.0 0.10 0.250 1.300 SMD1206P050TF SMD1206P050TF/13.2 6.0 100 0.50 1.00 8.0 0.10 0.150 0.700 13.2 100 0.50 1.00 8.0 0.10 0.150 0.700 SMD1206P050TF/16 16 100 0.50 1.00 8.0 0.10 0.150 0.750 SMD1206P050TF/24 24 100 0.50 1.00 8.0 0.10 0.150 0.750 SMD1206P075TF 8.0 100 0.75 1.50 8.0 0.20 0.090 0.500 SMD1206P075TF/13.2 13.2 100 0.75 1.50 8.0 0.20 0.090 0.500 SMD1206P075TF/16 16 13.2 100 0.75 1.50 8.0 0.20 0.090 0.500 100 1.00 1.80 8.0 0.30 0.055 0.270 16 100 1.00 1.80 8.0 0.30 0.055 0.330 SMD1206P110TF 8.0 100 1.10 1.80 8.0 0.30 0.050 0.230 SMD1206P110TF/13.2 13.2 100 1.10 1.80 8.0 0.30 0.055 0.270 SMD1206P150TF 8.0 100 1.50 3.00 8.0 1.00 0.040 0.130 SMD1206P200TF 6.0 100 2.00 3.50 8.0 1.0 0.018 0.080 Vmax Imax (Vdc) SMD1206P005TF Model SMD1206P100TF SMD1206P100TF/16 3/7 Time to trip R25 SMD1206 Series Surface Mountable PTC Resettable Fuse Test Procedures And Requirements Test Test Conditions Accept/Reject Criteria Resistance In still air @ 25℃ Rmin≤R≤Rmax Time to Trip Specified current,Vmax,25℃ Tmaximum Time to Trip Hold Current 30min,at IH No trip Trip Cycle Life Vmax,Imax,100cycles No arcing or burning Trip Endurance Vmax,1 hours No arcing or burning Physical Characteristics and Environmental Specifications Physical Characteristics Terminal materials : Tin-Plated Nickle-copper Soldering Meets EIA specification RS 186-9E and ANSI/J-STD-002 Category 3. zone Environmental Specifications Test Conditions Resistance Change Passive aging 85℃,1000hours ±10% Humidity aging 85℃/85%RH.1000 hours ±5% Thermal shock MIL-STD-202,Method 107G Solvent Resistance MIL-STD-202,Method 215 no change Vibration ML-STD-883C,Test Condition A No chage +85℃/-40℃,20times -30% typical resistance change Electrical Specifications: Ihold = Hold Current. Maximum current device will not trip in 25°C still air. Itrip = Trip Current. Minimum current at which the device will always trip in 25°C still air. Vmax = Maximum operating voltage device can withstand without damage at rated current (Imax). Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax). Pd=Maximum power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Rimin/max = Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. 4/7 SMD1206 Series Surface Mountable PTC Resettable Fuse Recommended pad layout (mm) Solder reflow conditions ● Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free. ● Devices are not designed to be wave soldered to the bottom side of the board. ● Recommended maximum paste thickness is 0.25mm (0.010inch). ● Devices can be cleaned using standard industry methods and solvents. ● Soldering temprature profile meets RoHs leadfree process. Notes: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements 5/7 SMD1206 Series Surface Mountable PTC Resettable Fuse Tape Specification And Reel Dimensions Coverning Specifications EIA 481-1(Unit:mm) W 8.15 +0.15/-0.3 P0 4.0 ± 0.10 P1 4.0± 0.10 P2 2.0 ± 0.05 A0 1.95 ± 0.10 B0 3.65 ± 0.10 D0 1.55± 0.05 F 3.50± 0.05 E1 1.75 ± 0.10 T 0.20± 0.10 Leader min. 390 Trailer min. 160 Reel Dimensions A 178±1.0 N 59±1 W1 8.5+1.0/-0.2 W2 12.0±1 Packaging Quantity Model Quantity Model Quantity SMD1206P005TF 3500 SMD1206P050TF/24 3500 SMD1206P010TF 3500 SMD1206P075TF 5000 SMD1206P010TF/33 3500 SMD1206P075TF/13.2 5000 SMD1206P012TF 3500 SMD1206P075TF/16 3500 SMD1206P016TF 5000 3500 SMD1206P020TF 5000 SMD1206P100TF SMD1206P100TF/16 SMD1206P025TF 5000 SMD1206P110TF 5000 SMD1206P030TF 5000 SMD1206P110TF/13.2 3500 SMD1206P035TF 5000 SMD1206P150TF 3500 SMD1206P050TF SMD1206P050TF/13.2 5000 SMD1206P200TF 3500 SMD1206P050TF/16 5000 5000 6/7 3500 SMD1206 Series Surface Mountable PTC Resettable Fuse Storage The maximum ambient temperature shall not exceed 38℃. Storage temperatures higher than 38℃ could result in the deformation of packaging materials. The maximum relative humidity recommended for storage is 60%. High humidity with high temperature can accelerate the oxidation of the solder plating on the termination and reduce the solderability of the components. Sealed plastic bags with desiccant shall be used to reduce the oxidation of the termination and shall only be opened prior to use. The products shall not be stored in areas where harmful gases containing sulfur or chlorine are present WARNING • Use PPTC beyond the maximum ratings or improper use may result in device damage and possible electrical arcing and flame. • PPTC are intended for protection against occasional over current or over temperature fault conditions and should not be used when repeated fault conditions or prolonged trip events are anticipated. • Device performance can be impacted negatively if devices are handled in a manner inconsistent with recommended electronic, thermal, and mechanical procedures for electronic components. • Use PPTC with a large inductance in circuit will generate a circuit voltage (L di/dt) above the rated voltage of the PPTC. • Avoid impact PPTC device its thermal expansion like placed under pressure or installed in limited space. • Contamination of the PPTC material with certain silicon based oils or some aggressive solvents can adversely impact the performance of the devices.PPTC SMD can be cleaned by standard methods. • Requests that customers comply with our recommended solder pad layouts and recommended reflow profile. Improper board layouts or reflow profilecould negatively impact solderability performance of our devices. 7/7
SMD1206P020TF 价格&库存
很抱歉,暂时无法提供与“SMD1206P020TF”相匹配的价格&库存,您可以联系我们找货
SMD1206P020TF
  • 1+0.29998
  • 100+0.27998
  • 300+0.25998
  • 500+0.23998
  • 2000+0.22998
  • 5000+0.22398
库存:1773
SMD1206P020TF
  • 20+0.41150
  • 200+0.33880
  • 500+0.28330
  • 3000+0.24000
  • 6000+0.21950
  • 15000+0.20910
库存:4359
