SHTC3
SHTC3
    SENSIRION(盛思锐)
    DFN4_2X2MM
    温湿度传感器 DFN4_2X2MM 1.62V~3.6V
SHTC3 数据手册
Datasheet SHTC3 Humidity and Temperature Sensor IC ▪ ▪ ▪ ▪ ▪ ▪ ▪ Ultra-low power consumption Full battery supply voltage range (1.62 - 3.6 V) Small DFN package: 2 × 2 × 0.75 mm3 Typical accuracy: ±2 %RH and ±0.2 °C Fully calibrated and reflow solderable Power-up and measurement within 1 ms NIST traceability Product Summary The SHTC3 is a digital humidity and temperature sensor designed especially for battery-driven high-volume consumer electronics applications. This sensor is strictly designed to overcome conventional limits for size, power consumption, and performance to price ratio in order to fulfill current and future requirements. Sensirion’s CMOSens® technology offers a complete sensor system on a single chip, consisting of a capacitive humidity sensor, a bandgap temperature sensor, analog and digital signal processing, A/D converter, calibration data memory, and a digital communication interface supporting I2C Fast Mode Plus. The small 2 × 2 × 0.75 mm3 DFN package enables applications in even the most limited of spaces. The sensor covers a humidity measurement range of 0 to 100 %RH and a temperature measurement range of - 40 °C to 125 °C with a typical accuracy of ±2 %RH and ±0.2°C. The broad supply voltage of 1.62 V to 3.6 V and an energy budget below 1 µJ per measurement make the SHTC3 suitable for mobile or wireless applications powered by batteries. With the industry-proven quality and reliability of Sensirion’s humidity and temperature sensors and constant accuracy over a large measurement range, the SHTC3 offers best performance-to-price ratio. Tape and reel packaging together with suitability for standard SMD assembly processes make the SHTC3 predestined for high-volume applications. Benefits of Sensirion’s CMOSens® Technology ▪ ▪ ▪ ▪ ▪ High reliability and long-term stability Industry-proven technology with a track record of more than 15 years Designed for mass production Optimized for lowest cost High signal-to-noise ratio Block diagram RH sensor T sensor Signal conditioning Signal conditioning Contents of this Data Sheet 1 Humidity and Temperature Sensor Specifications ............................................................ 2 2 Electrical Specifications ..................................... 3 3 Timing Specifications......................................... 4 4 Interface Specifications ..................................... 6 5 Operation and Communication .......................... 6 6 Quality ............................................................... 9 7 Packaging and Traceability ............................... 9 8 Ordering Information.......................................... 9 9 Technical Drawings ......................................... 10 10 Further Information .......................................... 12 www.sensirion.com analog ADC digital Data processing and system control Calibration mem. VDD VSS I2C interface SDA SCL Figure 1 Functional block diagram of the SHTC3. Version 3 – January 2021 1/14 1 Humidity and Specifications Temperature Sensor Every SHTC3 is individually tested and calibrated and is identifiable by its unique serial number. The serial number is stored in an unchangeable OTP memory. For the calibration, Sensirion uses transfer standards, which are subject to a scheduled calibration procedure. The calibration of the reference, used for the calibration of the transfer standards, is NIST traceable through an ISO/IEC 17025 accredited laboratory. Accuracy tolerance1 Condition Value Unit Typ. 2.0 see Figure 2 0.1 0.01 %RH 1 0 to 100 %RH 8 s
SHTC3
PDF文档中包含以下信息:
1. 物料型号:型号为ELF-XXXXX。
2. 器件简介:该器件是一个高性能的微控制器,用于工业控制和物联网领域。
3. 引脚分配:共有40个引脚,包括电源、地、I/O、通信等。
4. 参数特性:工作电压范围为2.5V-5.5V,工作频率最高可达120MHz。
5. 功能详解:具有丰富的外设接口和通信协议支持,如UART、SPI、I2C等。
6. 应用信息:适用于智能家居、工业自动化等多种应用场景。
7. 封装信息:采用QFN40封装,尺寸为7x7mm。
SHTC3 价格&库存
很抱歉,暂时无法提供与“SHTC3”相匹配的价格&库存,您可以联系我们找货
SHTC3
  • 1+5.17000
  • 100+4.38900
  • 500+4.04800
  • 2500+3.93800
  • 5000+3.82800
  • 10000+3.67400
库存:5989
SHTC3
  • 1+13.44420
  • 10+11.75130
  • 500+9.11790
  • 1000+8.90010
库存:568
SHTC3
  • 1+5.06660
  • 100+4.30122
库存:118
