JK250 Series
Polyer Positive Temperature Coefficient
Features
Radial leaded Devices
Cured,flame retardant epoxy polymer insulating material meets UL94V-0 requirements
Bulk packaging,or tape and reel available on most models
Agency Approval:UL,ROHS
Applications
Almost anywhere there is a low voltage power supply, up to DC60V and a load to be protested, including:
Security and fire alarm systems
Analog and digital line cards
Modems and DSL
Dimensions
Fig. 2
Fig.1
Fig .4
Fig .3
Uni t : mm
Model
Dimensions(mm)
A(max)
7.4
B(max)
12.7
C(max)
7.4
JK250-040U
Lead material
Shape
4.5
D(typ)
5.1
Tinned metal(mm)
22AWG/Φ 0.6
Fig
1
12.7
4.5
5.1
22AWG/Φ0.6
1
7.4
12.7
4.5
5.1
22AWG/Φ0.6
1/2
JK250-050U
JK250-060U
7.4
7.4
12.7
12.7
4.5
4.5
5.1
5.1
22AWG/Φ0.6
22AWG/Φ0.6
1/2
1/2
JK250-080U
7.4
12.7
4.5
5.1
22AWG/Φ0.6
2
JK250-090U
JK250-100U
7.4
7.8
12.7
12.6
4.5
4.5
5.1
5.1
22AWG/Φ0.6
22AWG/Φ0.6
2
1
JK250-020U
JK250-030U
1/4
JK250 Series
JK250-110U
7.0
12.6
4.5
5.1
22AWG/Φ0.6
4
JK250-120U
7.0
12.6
4.5
5.1
22AWG/Φ0.6
4
JK250-145U
7.0
12.6
4.5
5.1
22AWG/Φ0.6
4
JK250-180T
10.2
14.5
3.8
5.1
22AWG/Φ0.6
2
JK250-180U
9.0
11.0
4.5
5.1
22AWG/Φ0.6
4
JK250-200U
12.0
17.0
4.5
5.1
22AWG/Φ0.6
3
JK250-400U
12.0
17.0
4.5
5.1
22AWG/Φ0.6
3
JK250-600U
16.0
18.0
4.5
5.1
22AWG/Φ0.6
3
JK250-800U
20.0
22.5
4.5
5.1
20 AWG/Φ0.8
3
JK250-1000U
4.5
5.1
20 AWG/Φ0.8
3
JK250-1200U
22
28
4.5
5.1
20 AWG/Φ0.8
3
JK250-1500U
25
30
4.5
5.1
20 AWG/Φ0.8
3
JK250-2000U
26
32
4.5
10.2
20 AWG/Φ0.8
3
Note:
Dimensions in the A, B, C are the maximum sizes, all typical values of D is at the tolerance of ± 0.75mm.
Thermal Derating Chart-IH(A)
Model
JK250 series
Maximum ambient operating temperature(℃)
-40℃
-20℃
0℃
25℃
30℃
40℃
50℃
60℃
70℃
85℃
148%
132%
117%
100%
91%
85%
77%
68%
61%
45%
Electrical Characteristic
Model
IH(A)
IT(A)
VMAX(V)
IMAX
(A)
Pd
(W)
Maximum
Time-to-trip
Current
(A)
Resistance(Ω)
Time(S) RMIN- RMAX
JK250-020U
250
3
1.0
0.5
0.5
50-160
JK250-030U
30
65
250
3
1.0
0.5
0.5
40-120
JK250-040U
40
80
250
3
1.0
0.5
1.5
30-60
JK250-050U
50
100
250
3
1.0
0.5
2
25-50
JK250-060U
60
120
250
3
1.0
0.5
2
20-60
JK250-080U
80
160
250
3
1.0
1
0.5
12-22
JK250-090U
90
180
250
3
1.0
1
0.8
10-20
JK250-100U
100
200
250
3
1.0
1
1
10-20
JK250-110U
110
220
250
3
1.0
1
2.0
6-12
JK250-120U
120
240
250
3
1.0
1
2.0
6-11
JK250-145U
145
290
250
3
1.0
1
5.0
3.5-6.5
2/4
JK250 Series
JK250-180T
180
650
250
3
1.8
3
3.0
1.0-2.2
JK250-180U
180
650
250
3
1.8
3
1.5
2.0-4.0
JK250-200U
200
400
250
5
2.4
3
5
3-6
JK250-400U
400
800
250
5
2.8
3
8
1-3
JK250-600U
600
1200
250
5
3.2
3
12
0.6-2.0
JK250-800U
800
1600
250
5
3.6
4
18
0.4-1.0
JK250-1000U
1000
2000
250
7
3.6
5
JK250-1200U
1200
2400
250
7
3.6
6
JK250-1500U
1500
3000
250
7
4.8
7.5
JK250-2000U
2000
4000
250
10
4.8
10
IH=Hold current:Maximum current at which the device will not interrupt in 25℃ still air.
IT=Trip current:Minimum current at which the device from low resistance to high resistance in 25℃ still air.
VMAX=Maximum continuous voltage device can withstand without damage at rated current.
IMAX=Maximum fault current device can withstand without damage at rated voltage.
Maximum Time-to-trip:Maximum time to trip at assigned current.
Pd=Typical power dissipation:Typical amount of power dissipated from the device when in 25℃ still air environment.
RMIN=Minimum resistance of device at 25℃ prior to tripping.
RMAX=Maximum resistance of device at 25℃ prior to tripping.
Environmental Specifications
Test
Conditions
Resistance change
Passive Aging
+85℃,1000 hours
±8% typical
Humidity Aging
+85℃,85%R.H.1000 hours
+125℃ to -55℃,10 Times
± 8% typical
Thermal Shock
Solvent Resistance
MIL-STD-202,Method 215F
±12% typical
No change
Vibration
MIL-STD-202,Method 201
No change
3/4
JK250 Series
Soldering method
Wave Soldering
Soldering Temperature:260℃~270℃
Soldering Time:≤3sec.
Soldering Pos itio n: R esettab le fuse lead and the di stance fr om th e bottom ≥ 6 mm
Manual soldering
Soldering Temperature:250℃~280℃
Soldering Tim e: ≤3sec.
Soldering Position: Resettable fuse lead and the distance from the bottom ≥ 6mm
Packaging and Storage
Packaging quantity
JK250~020U~JK250-1 80U
JK250-200U~JK250-600U
1000Pcs/Bag
500 Pcs/Bag
JK250-800U~JK250-2000U
200 Pcs/Bag
4/4
很抱歉,暂时无法提供与“JK250-1500U”相匹配的价格&库存,您可以联系我们找货
