RN6752V1GQW
RN6752V1GQW
    RICHNEX(台湾立敏)
    WQFN32_5X5MM
    带MIPI CSI2输出的1通道HD视频解码器
RN6752V1GQW 数据手册
RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output RN6752V1 O n ly Data Sheet p c ry st a l 1-Channel HD Video Decoder With MIPI CSI2 Output o r T o (Rev. 1.6) F RICHNEX CONFIDENTIAL AND PROPRIETARY RICHNEX MICROELECTRONICS CORP. 4F, No.95, Minchiuan Road, Hsintien District, New Taipei City, Taiwan 23145 T 886-2-86676161 F 886-2-86673131 www.richnex.com Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 1 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Revision History Date Notes 1.1 2019-08-13 Initial draft. 1.2 2019-08-22 Modified application diagram and some register description. 1.3 2019-09-16 Modified ordering information 1.4 2019-11-05 Modified ground description 1.5 2019-12-13 Modified product ID 1.6 2020-08-06 Added Digital I/O AC characteristic ly Revision n Copyright © 2010-2019 by Richnex Microelectronics Corp. F o r T o p c ry st a l O NOTE: Richnex reserves the right to change the circuitry and/or specifications without notice at any time. Customers should obtain the latest relevant information and data sheets before placing orders and should verify that such information is current and complete. Richnex cannot assume responsibility for use of any circuitry other than circuitry entirely embodied in a Richnex product. Information furnished by Richnex is believed to be accurate and reliable. However, no responsibility is assumed by Richnex or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Richnex or its subsidiaries. Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 2 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Table of Contents TABLE OF CONTENTS ............................................................................................................. 3 GENERAL DESCRIPTION ................................................................................................. 5 2 ORDERING INFORMATION............................................................................................. 6 3 CONTACT INFORMATION .............................................................................................. 7 4 FEATURES ...................................................................................................................... 8 5 BLOCK DIAGRAM ........................................................................................................... 9 6 PIN DIAGRAM .............................................................................................................. 10 7 PIN DESCRIPTIONS ....................................................................................................... 11 8 I2C ADDRESS SETTING .................................................................................................. 13 9 REGISTER MAP............................................................................................................. 14 O n ly 1 F o r T o p c ry st a l 9.1 CHIP CONTROL REGISTERS ........................................................................................... 16 9.1.1 Central Control Register ....................................................................................... 16 9.1.1.1. Reset / Sleep Control Register ................................................................... 16 9.1.1.2. Analog Macro Control Register ................................................................. 16 9.1.2 Video Clock Configuration Register ...................................................................... 16 9.1.2.1. Video Clock Configuration A ...................................................................... 16 9.1.2.2. Video Clock Configuration B ...................................................................... 16 9.1.3 Video Data Port Configuration Register ............................................................... 17 9.1.3.1. Video Data Port Configuration A ............................................................... 17 9.1.3.2. Video Data Port Configuration B ............................................................... 17 9.1.3.3. Video Data Port Configuration C .............................................................. 18 9.1.4 GPIO Pin Configuration Register .......................................................................... 18 9.1.4.1. Video Timing Pin Enable Register .............................................................. 18 9.1.4.2. Video Timing Pin Direction Control Register .............................................. 19 9.1.4.3. Video Timing Pin GPIO Register ................................................................. 20 9.1.5 Video ADC MUX Configuration ............................................................................. 20 9.1.6 Video Format Selection Register .......................................................................... 20 9.1.7 Product ID, Low Byte............................................................................................ 21 9.1.8 Product ID, High Byte ........................................................................................... 21 9.1.9 Register Set Selection .......................................................................................... 21 9.2 VIDEO DECODER CONTROL REGISTERS ............................................................................ 21 9.2.1 Mode Control Register ......................................................................................... 21 9.2.2 Brightness Control Register .................................................................................. 22 9.2.3 Contrast Control Register ..................................................................................... 22 9.2.4 Saturation Control Register.................................................................................. 22 9.2.5 Hue Control Register ............................................................................................ 22 Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 3 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output O n ly 9.2.6 Enhancement Control Register............................................................................. 22 9.2.7 Input Control Register .......................................................................................... 23 9.2.8 Output & Decoder Control Register ...................................................................... 23 9.2.9 Video Detection Control Register ......................................................................... 23 9.2.10 Blue Screen Control Register .............................................................................. 23 9.2.11 Cropping Control Register .................................................................................. 24 9.2.12 ID Insertion Control Register .............................................................................. 24 9.2.13 BT.656/BT656-like Bus Control Register ............................................................. 28 9.2.14 HD Mode Control Registers ................................................................................ 29 9.2.15 Black/White Stretch Control .............................................................................. 30 9.2.16 Coaxitron Control Registers ............................................................................... 30 9.3 MIPI CONTROL REGISTERS .......................................................................................... 31 9.3.1 MIPI CSI-2 Control Registers ................................................................................ 33 9.3.2 MIPI TX Control Registers .................................................................................... 34 10 ELECTRICAL SPECIFICATIONS ....................................................................................... 36 ry st a l ABSOLUTE MAXIMUM RATINGS .................................................................................... 36 RECOMMENDED OPERATING CONDITIONS ....................................................................... 36 DC CHARACTERISTICS ................................................................................................. 36 AC CHARACTERISTICS ................................................................................................. 37 POWER CONSUMPTION .............................................................................................. 38 TWO-WIRE INTERFACE TIMING ..................................................................................... 38 ANALOG VIDEO PARAMETERS....................................................................................... 39 OSCILLATOR INPUT .................................................................................................... 39 p c 10.1 10.2 10.3 10.4 10.5 10.6 10.7 10.8 11 APPLICATION DIAGRAM .............................................................................................. 40 F o r T o 12 PACKAGE OUTLINES..................................................................................................... 41 Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 4 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 1 General Description The RN6752V1 is an analog high definition (Analog HD) video decoder IC designed for automotive applications. It integrates all necessary functional blocks: AFE, PLL, Decoding Logic, MIPI and I2C interface, etc., in a small 5mm x 5mm footprint, 32-pin QFN package. The decoder converts composite analog video input of up to full HD (FHD, 1080p) resolution to digital component video format (YCbCr) and sends the data via the MIPI interface to the host controller IC for further processing. F o r T o p c ry st a l O n ly The RN6752V1 supports multiple video formats including most popular formats from products of major camera suppliers. In addition, key format parameters such as resolution, frame rate, aspect ratio, etc. can be customized to meet specific requirements in automotive video. Due to its configurable, feature-rich design, challenges in e-mirror, driver monitoring, surround viewing and many other situations in demanding automotive applications can be effectively addressed. This single-channel decoder IC meets the highest quality and reliability criteria and can operate over temperature range from -40°C to 85°C. Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 5 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 2 Ordering Information RN6752V1 Package Type QW : WQFN-32 5x5 n ly Lead Plating System G : Green (Halogen Free and Pb Free) F o r T o p c ry st a l O Note: Richnex products are :  RoHS compliant and compatible with the current requirements of IPC/JEDEC J-STD-020.  Suitable for use in SnPb or Pb-free soldering processes. Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 6 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 3 Contact Information F o r T o p c ry st a l O n ly Richnex Microelectronics Corporation 4F., No.95, Minchiuan Rd., Hsintien District, New Taipei City 23145, Taiwan (R.O.C.) Tel 886-2-8667-6161 Fax 886-2-8667-3131 Email: insidesales@richnex.com Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 7 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 4 Features F o r T o p c ry st a l O n ly Video Decoder  MIPI CSI2 interface supporting 4 data lanes  Multi-format video decoder, covering FHD (1080p), HD (720p) and D1 (480i) analog video resolution  Automatic format detection  I2C interface for control and status registers access  Video input pins meeting 8KV (HBM) ESD compliance  Operation temperature range from -40°C to 85°C  3.3V and 1.2V power supplies  Flexible 1.8V to 3.3V I/O interface voltage  32pin QFN package (5mm x 5mm) Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 8 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 5 Block Diagram VP [7:0] VINA SCLK ADC MUX VINB (Y/C Separation ) Luminance & Chrominance Processing Output Processing Video Data Port AVID AGC & Clamping SDA FID HSYNC Two wires interface SCL VSYNC TCN TCP XIN ly Register Set PLL XOUT INTREQ /VBLK MIPI n VA33 VA12 O Power Management VD12 VDDIO TDN[3:0] TDP[3:0] RESETB PDN AGND DGND F o r T o p c ry st a l Figure 1: RN6752V1 Functional Block Diagram Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 9 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output O n ly HSYNC/Coax1 AVID/Coax0 VBLK/INTREQ/I2CSEL PDN TEST RESERVED AGND VA33 6 Pin Diagram VSYNC/Coax2/TDP0 VINA VINB st a l FID/Coax3/TDN0 AGND SDA VA12 SCL ry DGND XIN DGND p c XOUT VD12 VP0/TDP1 T o DGND VP2/TDP2 VP1/TDN1 VP3/TDN2 VP4/TCP VP5/TCN VP6/TDP3 VDDIO r SCLK o F VP7/TDN3/I2CSEL (Top View) RESETB Figure 2: RN6752V1 Pin Diagram Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 10 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 7 Pin Descriptions Table 1: RN6752V1 Pin Definition Analog Video Interface Name Pin Number VINA 1 VINB 2 Type Reset State A A Description Analog video input A Analog video input B 11 23 I O Video data port HiZ I2C select (shared with VP[7]) Timing signal and status indicator IO O O 24 IO 25 O O HiZ HiZ IO r 26 F o Coax1 AVID Coax0 VBLK /INTREQ 27 I2CSEL O O HiZ IO O O Coaxitron control Timing signal and status indicator VSYNC also can be programmed as a GPIO pin. T o Coax2 HSYNC FID also can be programmed as a GPIO pin. p c Coax3 VSYNC n I2CSEL FID HiZ O O st a l [11,12,13 ,14,15,16, 17,18] ry VP[7:0] ly Digital Video Interface ( shared with MIPI Video Interface ) Name Pin Type Reset Description Number State SCLK 9 O HiZ Video clock Coaxitron control Timing signal and status indicator HSYNC also can be programmed as a GPIO pin. Coaxitron control Timing signal and status indicator AVID also can be programmed as a GPIO pin. HiZ Coaxitron control Interrupt/Timing signal and status indicator IO VBLK also can be programmed as a GPIO pin. I I2C select (shared with VBLK pin) MIPI Video Interface ( shared with Digital Video Interface ) Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 11 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Type TDN[3:0] TCN Pin Number 11,13,15, 17,23 O Reset State HiZ TDP[3:0] TCP 12,14,16, 18,24 O HiZ Type Reset State HiZ HiZ HiZ HiZ HiZ HiZ HiZ Description Reset State Description 4 32 P P P P P P ly n O Internal 1.8V or external 3.3V IO post-driver 1.2V digital power Analog ground Digital ground (EP = exposed pad) 1.2V analog power. 3.3V analog power. F o r VA12 VA33 Type I2C serial clock (pull-up SCL with 4.7K Ohm resistor) I2C serial data (pull-up SDA with 4.7K Ohm resistor) Global chip reset (active low) Power down signal (active low) External reference clock input or crystal input External crystal output Recommend floating Reserved pin (Must be floating) ry VDDIO VD12 AGND DGND Pin Number 10 20 3,31 7,19, 33 (EP) T o Power Name I IO I I I O I MIPI negative data/clock lane output These pins also can be programmed as a MIPI negative clock/data lane output MIPI positive data/clock lane output These pins also can be programmed as a MIPI positive clock/dat lane output st a l System Control Name Pin Number SCL 21 SDA 22 RESETB 8 PDN 28 XIN 5 XOUT 6 TEST 29 RESERVED 30 Description p c Name Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 12 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 8 I2C address setting RN6752V1 provides an I2C slave interface for programming internal control registers. After power-on or the external reset has transitioned from low to high, RN6752V1 will capture I2CSEL pin state to determine its I2C device address. User can set their desired device address through weak pull-up/down on this pin. The I2C address can be either 0x2C or 0x2D. Pulled up/down Pulled down or floating: I2CSEL RN6752V1’s I2C device address 0x2C 1 Pulled up: I2CSEL 0x2D F o r T o p c ry st a l O n ly I2CSEL 0 Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 13 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 9 Register Map RN6752V1 integrates 1 video decoders and one MIPI CSI-2 links interface in one I2C slave device. The register set is outlined in the following index map. There are 3 sets of indexes, 0x00 to 0x7F, which are used for each individual video decoder control and MIPI interface control. Access to these 3 sets of registers is selectable via RegFF. Index 0x80 to 0xFE registers are used for chip-level control operations. 00h MIPI TX1 MIPI CSI1 Video Decoder and MIPI Interface Control Registers 7Fh 7Fh 80h O 00h st a l Chip Control Registers FEh Set Selection Register ry FFh n ly Video CH Figure 3: RN6752V1 Register Index Map WR (0) I2C Device Address ACK S F o S r T o p c The I2C interface supports single or multiple write/read accesses whose register addresses are in sequential order as illustrated in the following two figures. The first figure illustrates the write format for a one-byte write and a multiple-byte write. The second figure describes the transfer format for a single-byte read and a multiple-byte read. In the first byte, after start symbol, the I2C Device Address [6:0] is located at bit 7~1, and bit 0 is for the identification of write (bit0 = 0) or read (bit0 = 1) operation. So the 1st byte after start symbol is 0x58 if users perform the write transfer to the I2C Device Address 0x2C. ACK Write Data (A) ACK ACK Write Data (A) ACK Write Data (A + 1) ACK Write Data (A + 2) ACK Write Data (A + n -1) ACK Write Data (A + n ) P One-Byte Write WR (0) I2C Device Address Register Index Address (A) ACK Register Index Address (A) ACK P Multiple-Bytes Write Figure 4: I2C One and Multi-byte Write Operation Sequence Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 14 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output S I2C Device Address WR (0) ACK S I2C Device Address RD (1) ACK S I2C Device Address WR (0) ACK S I2C Device Address RD (1) ACK Register Index Address (A) Read Data (A) ACK P No ACK P ACK P One-Byte Read Register Index Address (A) Read Data (A ) Read Data (A + n - 1) ACK Read Data (A + 1) ACK Read Data (A + n ) ACK No ACK P ly Multiple-Bytes Read F o r T o p c ry st a l O n Figure 5: I2C One and Multiple-byte Read Operation Sequence Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 15 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 9.1 Chip Control Registers 9.1.1 Central Control Register 9.1.1.1. Reset / Sleep Control Register ly Address: 80h (R/W). Default: 30h. Bits Field Name Description 0 Soft_GRST Software Global Reset 1 Reserved Must be 0h. 2 Soft_PWRD Software Power Down 7:3 Reserved Must be 6h. O st a l Address: 81h (R/W). Default: 01h. Bits Field Name Description 0 CH_ON Channel Enable 7:1 Reserved Not used. n 9.1.1.2. Analog Macro Control Register 9.1.2 Video Clock Configuration Register p c ry RN6752V1 supports one independent clock pins, SCLK, which is synchronous with all video data ports. After the power-on/reset sequence has been completed, the SCLK will output 27MHz clock, and the video data port VP[7:0] will be in tri-state. o r Address: 88h (R/W). Default: 01h. Field Name Description EN_SCK Clock Enable INV_SCK Clock Invert DL_SCK Clock Output Delay Selection DS_SCK Clock Output Drive Strength F SCLK1: Bits 0 1 5:2 7:6 T o 9.1.2.1. Video Clock Configuration A 9.1.2.2. Video Clock Configuration B SCLK1: Bits 2:0 3 6:4 7 Address: 89h (R/W). Default: 00h. Field Name Description FSEL_SCK Clock Output Frequency Selection EN960M_SCK Clock Frequency Base Selection PHSEL_SCK Clock Phase Delay Selection Reserved N/A Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 16 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 9.1.3 Video Data Port Configuration Register In ITU-R BT.656 format, there is one timing reference codes: one at the beginning of each video data block (start of active video, SAV) and one at the end of each video data block (end of active video, EAV). Each timing reference code consists of a four-word sequence in the following format: (FFh, 00h, 00h, XYh). The first three words are a fixed preamble. The fourth word contains information defining field identification, the state of field blanking, and the state of line blanking. The data between EAV and SAV is the horizontal blanking code. The data between SAV and EAV is the valid Y/Cb/Cr color component value. DE_CLK 00 00 XY 80 10 80 10 80 10 FF 00 00 XY CB Y SAV Y CB Y CR Y O EAV CR ly FF n DE_DATA [7:0] Figure 6: Standard ITU-R BT.656 Format st a l Like standard ITU-R BT.656 format, RN6752V1 provides a modified ITU-R BT.656 format which inserts decoder information such as channel identification or indicator’s status. DE_DATA(CHx) Cb Y Cr Y Cb Y Cr Y Cb Y Cr Y Cb Y Cr Y Cb Y Cr Cb Y Cr Y Cb Y Cr Y Cb Y Cr Y Cb Y Cr Y Cb Y Cr p c VPn ry fSCLKn = 1X fDE_CLK T o Figure 7: Single Channel Output Format 9.1.3.1. Video Data Port Configuration A o r Address: 8Dh (R/W). Default: 00h. Field Name Description EN_VP Video Port Enable VP_PRATE The value of these parameters must be set to 0h. VP_SRC This bit must be set to 0. DS_VP VP[7:0] : Drive Strength Selection VP_DEVSEL Device Source Selection F VP[7:0]: Bits 0 2:1 3 5:4 7:6 9.1.3.2. Video Data Port Configuration B VP[7:0]: Address: 8Eh (R/W). Default: 04h. Bits Field Name Description 1:0 VP_MODE VP[7:0] : Output Mode Selection 3:2 VP_CHANSEL Data Stream Output Selection (only for VP_MODE = 0) Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 17 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Bits 7:4 Field Name VP_DDR_PAIR Description Reserved 9.1.3.3. Video Data Port Configuration C VP[7:0]: Address: 8Fh (R/W). Default: 00h. Bits Field Name Description 3:0 DL_VP VP[7:0] : Output Delay 6:4 VP_PHSEL VP[7:0] : Output Phase Delay (only for VP_MODE = 0) 7:4 Reserved Must be 0h. 9.1.4 GPIO Pin Configuration Register n Address: A3h (R/W). Default: 00h. Name Description Reserved Must be 0h. EN_HD_OUT Enable HD Output. VP_ORDER Pin Order selection ly Output Data Source Format Selection O VP[7:0]: Bits 1:0 2 3 VP_EN960M st a l 7 p c ry RN6752V1 provides 5 programmable outputs: VBLK, AVID, FID, VSYNC, and HSYNC. Each of the outputs can be programmed to provide video timing information such as: video blanking, active video, field, vertical sync, or horizontal sync. They can also be used to provide various status information that include: no video detect, PAL/NTSC indicator, VHS detect, color-kill, progressive video detect. Finally, any one of the five outputs can be programmed to transmit Coaxitron protocol data. T o In addition to the above functions, users can set *_ENGP as 1 to enable the GPIO function of the video timing pins. When *_GPIO_DIR is 0, the video timing pin is an output pin and the output value is depended on *_GPO. When *_GPIO_DIR is 1, the video timing pin is an input pin, and the input value can be read from Reg98 and Reg9C. r 9.1.4.1. Video Timing Pin Enable Register F o Address: 96h (R/W). Default: 40h. Bits Field Name Description 0 AVID_ENGP Video Status and GPIO Function Select 1 VBLK_ENGP Video Status and GPIO Function Select 2 FID_ENGP Video Status and GPIO Function Select 3 VSYNC_ENGP Video Status and GPIO Function Select 5:4 AVID_CHANSEL Select Indicator Source For AVID Pin (only for AVID_ENGP = 0) 7:6 VBLK_CHANSEL Select Indicator Source For VBLK Pin (only for VBLK_ENGP = 0) Address: 9Ah (R/W). Default: 40h. Bits Field Name Description 0 HSYNC_ENGP Video Status and GPIO Function Select Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 18 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Bits 3:1 5:4 Field Name Reserved HSYNC_CHANSEL 7:6 Reserved Description Not used. Select Indicator Source For HSYNC Pin (only for HSYNC_ENGP = 0) Not used. 9.1.4.2. Video Timing Pin Direction Control Register ly Address: 97h (R/W). Default: E0h. Bits Field Name Description 0 AVID_GPIO_DIR When AVID_ENGP is 0, AVID_GPIO_DIR’s usage is as follows: 1: Enable status indicator output on AVID pin. 0: AVID pin input and output are disabled. VBLK_GPIO_DIR st a l 1 O n When AVID_ENGP is 1, AVID_GPIO_DIR becomes GPIO Direction Control. 1: Set AVID pin to GPIO input. 0: Set AVID pin to GPIO output. When VBLK_ENGP is 0, VBLK_GPIO_DIR’s usage is as follows: 1: Enable status indicator output on VBLK pin. 0: VBLK pin input and output are disabled. ry FID_GPIO_DIR p c 2 When VBLK_ENGP is 1, VBLK_GPIO_DIR becomes GPIO Direction Control. 1: Set VBLK pin to GPIO input. 0: Set VBLK pin to GPIO output. When FID_ENGP is 0, FID_GPIO_DIR’s usage is as follows: 1: Enable status indicator output on FID pin. 0: FID pin input and output are disabled. T o VSYNC_GPIO_DIR F o r 3 5:4 7:6 When FID_ENGP is 1, FID_GPIO_DIR becomes GPIO Direction Control. 1: Set FID pin to GPIO input. 0: Set FID pin to GPIO output. When VSYNC_ENGP is 0, VSYNC_GPIO_DIR’s usage is as follows: 1: Enable status indicator output on VSYNC pin. 0: VSYNC pin input and output are disabled. FID_CHANSEL VSYNC_CHANSEL When VSYNC_ENGP is 1, VSYNC_GPIO_DIR becomes GPIO Direction Control. 1: Set VSYNC pin to GPIO input. 0: Set VSYNC pin to GPIO output. Select Indicator Source For FID Pin (only for FID_ENGP = 0) Select Indicator Source For VSYNC Pin (only for VSYNC_ENGP = 0) Address: 9Bh (R/W). Default: E0h. Bits Field Name Description 0 HSYNC_GPIO_DIR When HSYNC_ENGP is 0, HSYNC_GPIO_DIR’s usage is as follows: Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 19 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Bits 7:1 Field Name Description 1: Enable status indicator output on HSYNC pin. 0: HSYNC pin input and output are disabled. When HSYNC_ENGP is 1, HSYNC_GPIO_DIR becomes GPIO Direction Control. 1: Set HSYNC pin to GPIO input. 0: Set HSYNC pin to GPIO output. Not used. Reserved 9.1.4.3. Video Timing Pin GPIO Register st a l O n ly Address: 98h (R/W). Default: 00h. Bits Field Name Description 0 AVID_GPO Set the AVID GPO value or shows the AVID input value. 1 VBLK_GPO Set the VBLK GPO value or shows the VBLK input value. 2 FID_GPO Set the FID GPO value or shows the FID input value. 3 VSYNC_GPO Set the VSYNC GPO value or shows the VSYNC input value. 4 AVID_SRC Video Timing or Interrupt Output Select 5 VBLK_SRC Video Timing or Interrupt Output Select 6 FID_SRC Video Timing or Video Timing or Interrupt Output Select 7 VSYNC_SRC Video Timing or Interrupt Output Select T o p c ry Address: 9Ch (R/W). Default: 00h. Bits Field Name Description 0 HSYNC_GPO Set the HSYNC GPO value or shows the HSYNC input value. 3:1 Reserved Not used. 4 HSYNC_SRC Video Timing or Interrupt Output Select 7:5 Reserved Not used. 9.1.5 Video ADC MUX Configuration F o r Address: D3h (R/W). Default: 00h. Bits Field Name Description 1:0 SELV Video ADC Input Selection 7:2 Reserved N/A 9.1.6 Video Format Selection Register Address: DFh (R/W). Default: F0h. Bits Field Name Description 0 VIDEO_CHAN_SEL FHD/HD/SD Selection 7:1 Reserved N/A. Address: F0h (R/W). Default: 1Fh. Bits Field Name Description 5:0 Reserved. N/A Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 20 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Bits 6 Field Name POP144 Description Enable Top FIFO Output 7 EN_BT144 Enable 144 MHz Decoder Output 9.1.7 Product ID, Low Byte ly Address: FDh (RO). Default: 01h. Bits Field Name Description 3:0 Chip Package Product package information 7:4 Reserved N/A O st a l Address: FEh (RO). Default: 26h. Bits Field Name Description 4:0 Chip PID The product ID code 7:5 Chip Version The product revision code n 9.1.8 Product ID, High Byte 9.1.9 Register Set Selection p c ry Address: FFh (R/W). Default: 00h. Bits Field Name Description 7:0 REG_SET_SEL Register Set Select 9.2 Video Decoder Control Registers F o r Address: 00h (WO). Bits Field Name 3:0 Reserved 5:4 OPM 7:6 TESTPAT T o 9.2.1 Mode Control Register Address: 00h (RO). Bits Field Name 0 F30 2:1 Reserved 3 CKill 4 NoVid 7:5 VDet Description Reserved Decoder Operation Mode Select Test Output Select Description System Input Indicator Reserved Color Kill Indicator No Video Input Indicator Video Format Detect Address: 4Bh (RO).Default: 00h. Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 21 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Bits 0 Field Name 720P_Format 7:1 Reserved Description 0: Analog HD 1: other public analog HD 720P_Format is valid only when VDet = 1. Must be 0h. 9.2.2 Brightness Control Register n ly Address: 01h (R/W).Default: 00h. Bits Field Name Description 7:0 Brit Brightness Control 2’s complement form, increases brightness (0~+127) if these bits are positive value. Decrease brightness (-1~ -128) if these bits are negative value. O 9.2.3 Contrast Control Register ry 9.2.4 Saturation Control Register st a l Address: 02h (R/W).Default: 80h. Bits Field Name Description 7:0 Cont Contrast Control Unsigned form. This 8-bit un-signed value defines the setting for the contrast adjustment. The nominal value is 80h. T o p c Address: 03h (R/W).Default: 80h. Bits Field Name Description 7:0 Satu Saturation Control Unsigned form. This 8-bit un-signed value defines the setting for the saturation adjustment. The nominal value is 80h. 9.2.5 Hue Control Register F o r Address: 04h (R/W).Default: 80h. Bits Field Name Description 7:0 Hue Hue Control Unsigned form. This 8-bit un-signed value defines the setting for the hue adjustment. The nominal value is 80h. 9.2.6 Enhancement Control Register Address: 05h (R/W).Default: 08h. Bits Field Name Description 6:0 EnhL Peaking Control for Luma Enhancement. (2’s complement form) This value is used to increase the amplitude of high frequency components of luma. A value of zero disables luma enhancement. 7 Reserved Reserved Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 22 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 9.2.7 Input Control Register Address: 07h (R/W).Default: 23h. Bits Field Name 1:0 LOP 2 Reserved 3 Reserved 6:4 Reserved 7 Reserved Description NTSC/PAL Operation Control Must be 0h. Must be 0h. Must be 2h. Reserved Description Swap Color Outputs Must be 1h. Reserved Reserved Disable Color Kill detection. Enable EQ Feature n Address: 09h (R/W).Default: 08h. Bits Field Name 2:0 SwpUV 3 Reserved 4 Reserved 5 Reserved 6 XCKill 7 AutoEnhL O Description Must be 2h. Invert internal HSync signal. Invert internal VSync signal. Invert internal Field signal. N/A p c ry st a l Address: 08h (R/W).Default: 02h. Bits Field Name 3:0 Reserved 4 InvHS 5 InvVS 6 InvF 7 Reserved ly 9.2.8 Output & Decoder Control Register T o 9.2.9 Video Detection Control Register F o r Address: 19h (R/W).Default: 00h. Bits Field Name Description 3:0 VDHystS Video Format Detection Hysteresis Control 7:4 Reserved Must be 0h. 9.2.10 Blue Screen Control Register Address: 1Ah (R/W).Default: 03h. Bits Field Name Description 6:0 Reserved Must be 3h. 7 NoBlue Blue Screen Insertion Disable. If this bit is set, the insertion of blue screen will be disabled when no video is detected at the input. Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 23 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 9.2.11 Cropping Control Register 00h 42h 00h 6 7 HSelCrop Reserved 0 HStart[10] 4 HEnd[10] The MSB of HEnd, used for HD output. 1:0 V0Start[10:9] The MSB of V0Start, used for HD output. 5:4 V0End[10:9] The MSB of V0End, used for HD output. T o 41h Field Name HStart[9:8] HEnd[9:8] V0Start[8] V0End[8] V1Start[8] V1End[8] HStart[7:0] HEnd[7:0] V0Start[7:0] V0End[7:0] V1Start[7:0] V1End[7:0] Reserved VSelCrop Description Image Cropping setting: {V0Start, V0End} defines field 0 active line range. {V1Start, V1End} defines field 1 active line range. {HStart, HEnd} defines active pixel range. n ly {V0Start, V0End} and {V1Start, V1End} are valid only when VSelCrop = 2 or 3. {HStart, HEnd} is valid only when HSelCrop = 1. O Must be 2h. 0: Reserved 1:  NTSC  PAL  720p  1080p/1080N 2, 3: Cropping range from register setting. {HStart, HEnd} is valid only when HSelCrop = 1. Reserved st a l 43h ACh 16h 05h 16h 05h 92h Bits 1:0 3:2 4 5 6 7 7:0 7:0 7:0 7:0 7:0 7:0 3:0 5:4 ry 21h 22h 23h 24h 25h 26h 28h Default A4h p c Address 20h The MSB of HStart, used for HD output. 9.2.12 ID Insertion Control Register F o r RN6752V1 supports the channel information insertion option. User can program INST_OBJ_SEL to select the inserted code which can include (1) invalid video indicator and a dark indicator (2) specific channel ID code. Table 2 shows the case in which Channel Information is inserted in SAV/EAV code. Table 2: Channel Information Insertion in SAV/EAV Code CONDITION Rev. 1.6 – August.2020 FVH VALUE SAV/EAV CODE Richnex Confidential and Proprietary Page 24 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output V Time H Time F V H 1st 2nd 3rd 4th 1 1 1 1 2 2 2 2 Active Active Blank Blank Active Active Blank Blank SAV EAV SAV EAV SAV EAV SAV EAV 0 0 0 0 1 1 1 1 0 0 1 1 0 0 1 1 0 1 0 1 0 1 0 1 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 {0x8, INST_OBJ[3:0]} {0x9, INST_OBJ[3:0]} {0xA, INST_OBJ[3:0]} {0xB, INST_OBJ[3:0]} {0xC, INST_OBJ[3:0]} {0xD, INST_OBJ[3:0]} {0xE, INST_OBJ[3:0]} {0xF, INST_OBJ[3:0]} ly Field Bits 7:0 7:0 7:0 Field Name MaskValue_Y MaskValue_U MaskValue_V p c Default 10h 10h 10h Description Replace Y/Cb/Cr with (MaskValue_Y+ 0x10)/MaskValue_U/MaskValue_V when EN_MASK_YUV = 1. T o Address 3Bh 3Ch 3Dh ry st a l O n Address: 3Ah (R/W).Default: 00h. Bits Field Name Description 0 EN_MASK_YUV EN_MASK_YUV = 1, replace Y/Cb/Cr with MaskValue_Y/MaskValue_U/MaskValue_V. 1 INV_AVID 1: Invert the AVID pin output. 2 INV_VBLK 1: Invert the VBLK pin output. 3 EN_NoVid_MASK EN_NoVid_MASK=1 will enable EN_MASK_YUV when NoVid = 1. 6:4 INST_POS_SEL Select the Channel Information format 7 Reserved Must be 0h. F o r Address: 3Eh (R/W).Default: 32h. Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 25 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Field Name AVID_SEL Description AVID_SEL is used to select the desired internal status signals for multiplexing onto the AVID pin output. The following is the mapping table: 0h: VSYNC 1h: HSYNC 2h: AVID 3h: VBLK 4h: Field 0=even, 1=odd. 5h: NoVid 6h: Coaxitron Output 7h: Reserved 8h: Reserved 9h: Reserved Ah: CKill Bh: Progressive mode Ch~Eh: Reserved Fh: Constant 0 VBLK_SEL is used to select the desired internal status signals for multiplexing onto the VBLK pin output. VBLK_SEL st a l 7:4 O n ly Bits 3:0 o r T o p c ry The following is the mapping table: 0h: VSYNC 1h: HSYNC 2h: AVID 3h: VBLK 4h: Field 0=even, 1=odd. 5h: NoVid 6h: Coaxitron Output 7h: Reserved 8h: Reserved 9h: Reserved Ah: CKill Bh: Progressive mode Ch~Eh: Reserved Fh: Constant 0 F Address: 3Fh (R/W).Default: 0001_00XXb. Bits Field Name Description 1:0 CHAN_ID For Video Decoder N, the default value of this field is N. This field is read/write-able to reassign the channel number. 3:2 Reserved Must be 0h. 5:4 INST_OBJ_SEL Select the inserted object format 7:6 Reserved Reserved Address: 40h (R/W).Default: 40h. Bits Field Name Description 0 Reserved Not used. Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 26 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Description 1: Invert the FID output. 1: Invert the VSYNC output. 1: Invert the HSYNC output. FID_SEL is used to select the desired internal status signals for multiplexing onto the FID pin output. st a l O The following is the mapping table: 0h: VSYNC 1h: HSYNC 2h: AVID 3h: VBLK 4h: Field 0=even, 1=odd. 5h: NoVid 6h: Coaxitron Output 7h: Reserved 8h: Reserved 9h: Reserved Ah: CKill Bh: Progressive mode Ch~Eh: Reserved Fh: Constant 0 ly Field Name INV_FID INV_VSYNC INV_HSYNC FID_SEL n Bits 1 2 3 7:4 p c ry Address: 46h (R/W).Default: 10h. Bits Field Name Description 3:0 VSYNC_SEL VSYNC_SEL is used to select the desired internal status signals for multiplexing onto the VSYNC pin output. F o r T o The following is the mapping table: 0h: VSYNC 1h: HSYNC 2h: AVID 3h: VBLK 4h: Field 0=even, 1=odd. 5h: NoVid 6h: Coaxitron Output 7h: Reserved 8h: Reserved 9h: Reserved Ah: CKill Bh: Progressive mode Ch~Eh: Reserved Fh: Constant 0 Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 27 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Description HSYNC_SEL is used to select the desired internal status signals for multiplexing onto the HSYNC pin output. Description Delay the AVID pin output for AVID_DLY pixel clocks. Delay the VBLK pin output for VBLK_DLY pixel clocks. Delay the VSYNC pin output for VSYNC_DLY pixel clocks. Delay the HSYNC pin output for HSYNC_DLY pixel clocks. ry Address: 47h (R/W).Default: 00h. Bits Field Name 1:0 AVID_DLY 3:2 VBLK_DLY 5:4 VSYNC_DLY 7:6 HSYNC_DLY st a l O The following is the mapping table: 0h: VSYNC 1h: HSYNC 2h: AVID 3h: VBLK 4h: Field 0=even, 1=odd. 5h: NoVid 6h: Coaxitron Output 7h: Reserved 8h: Reserved 9h: Reserved Ah: CKill Bh: Progressive mode Ch~Eh: Reserved Fh: Constant 0 ly Field Name HSYNC_SEL n Bits 7:4 T o p c Address: 48h (R/W).Default: 03h. Bits Field Name Description 5:0 Reserved Must be 13h. 7:6 FID_DLY Delay the FID pin output for FID_DLY pixel clocks. r 9.2.13 BT.656/BT656-like Bus Control Register Description Video Resolution Format Select. N/A. Horizontal Resolution Half. Must be 0h. Address: 56h (R/W).Default:01h. Bits Field Name 1:0 BtClk 2 Bt601 7:3 Reserved Description Selects 54MHz output clock for D1/720p/1080p output format. BT.656/BT.656-like output. Must be 0h. F o Address: 50h (R/W).Default: 02h. Bits Field Name 2:0 VRFmt 3 Reserved 4 HRHalf 7:3 Reserved Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 28 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 9.2.14 HD Mode Control Registers The selection of supported HD decoding format is stored in extended register address 0h, and it is accessed through a set of extended control registers. The supported HD decoding formats and the control registers are shown in the following tables. n ly ExtReg0 8’h42 8’h44 8’h43 8’h47 8’h4A 8’h4B 8’h45 8’h46 8’h48 8’h49 O HD Selection 720p, 25fps (Analog HD) 720p, 30fps(Analog HD) 720p, 25fps (other public analog HD) 720p, 30fps (other public analog HD) 720p, 25fps (other public analog HD) 720p, 30fps (other public analog HD) 1080N, 25fps(Analog HD) 1080N, 30fps(Analog HD) 1080p, 25fps (Analog HD) 1080p, 30fps (Analog HD) ry st a l ExtendedControlRegister – controls the access of extended register where HD mode selections are stored. Address: 58h (R/W).Default: 00h. Bits Field Name Description 0 ExRegWrEn This bit enables the write (1) or read access (0) to the extended registers. p c When set to 1, it enables the data in the ExtendedDataRegister to be written into the register defined by ExtendedAddressRegister. This bit is self-clearing, i.e. it resets to 0 in the following cycle. T o 7:1 When set to 0, it enables the register data defined by ExtendedAddressRegister to be updated in ExtendedDataRegister. Must be 0h. Reserved F o r ExtendedAddressRegister – provides the address to select the extended register to be accessed. Address: 59h (R/W).Default: 00h. Bits Field Name Description 7:0 ExRegAddr This 8-bit value provides the address of the extended register (ExtReg) to be accessed. ExtendedDataRegister – provides the data for read and write access to the extended register. Address: 5Ah (R/W).Default: 00h. Bits Field Name Description 7:0 ExRegData This 8-bit value provides the data to be written, when ExRegWrEn is 1, or the read data, when ExRegWrEn is 0, of the register selected by ExRegAddr. Example of writing data 0x42 to extended register address 0x00 (ExtReg0) to select 720p 25fps mode: 1. Write to ExtendedAddressRegister = 00h; Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 29 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 2. 3. Write to ExtendedDataRegister = 42h; Write to ExtendedControlRegister = 01h; Example of reading data from extended register address 00h (ExtReg0): 1. Write to ExtendedAddressRegister = 00h; 2. Read from ExtendedDataRegister; 9.2.15 Black/White Stretch Control ly In RN6752V1, the Black/White Stretch function is implemented as a post-decoding process on the luma signal. This non-linear process changes the available resolution that is allotted to the lighter and darker portion of the luma signal. The Black Stretch process assigns more resolution to the darker portion while the White Stretch process assigns more resolution to the lighter portion. ry st a l O n Address: 57h (R/W).Default: 20h. Bits Field Name Description 5:0 Stretch Black/White Stretch Control This 6-bit control signal is used to control the white stretch function (Stretch > 6’h20), which assigns more resolution to the lighter portion of an input video signal, and black stretch function (Stretch < 6’h20), which assigns more resolution to the darker portion. A value of 6’h20 disables black/white stretch. 7:6 Reserved Must be 0. 9.2.16 Coaxitron Control Registers F o r T o p c Address: 73h (R/W).Default: 00h. Bits Field Name Description 2:0 Coax_MSel Coaxitron mode select 3 EnCoaxRx Enable Coaxitron Receive 0: Coaxitron TX mode. 1: Coaxitron RX mode. 4 CoaxEmpty (RO) FIFO empty flag 5 CoaxFull (RO) FIFO full flag 6 CoaxTxWrDone/Coax Coaxitron TX FIFO write done (EnCoaxRx = 0) RxERR_CLR (WO) Write 1 to indicate the completion of writing data into FIFO, and the data in the FIFO will be transmitted based on the mode selected by Coax_MSel. This bit is write-only. 7 CoaxRxERR (RO) CoaxFIFO_INIT (WO) Coaxitron RX error clear (EnCoaxRx = 1) Write 1 to clear CoaxRxERR status. Coaxitron RX error indication. Set 1 to reset FIFO read/write address pointer. Address: 74h (R/W).Default: 00h. Bits Field Name Description 7:0 CoaxFIFO_DATA Coaxitron TX data FIFO (EnCoaxRX = 0) Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 30 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Bits Field Name Description The data written to this register will be written to the Coaxitron TX data FIFO for transmission. Coaxitron RX data FIFO (EnCoaxRX = 1) Coaxitron RX data in the FIFO can be read from this register whenever CoaxEmpty is 0. O n ly Address: 75h (WO).Default: 0Ah. Bits Field Name Description 3:0 CoaxLine Select Coaxitron TX line number. Defaults to 4’hA, which is line 18. Using CoaxLine, the TX line number can be selected from a range of 8 to 23. 4 Coax8Bit Coax8Bit mode enable Instead of using standard Coaxitron 15 or extended 15-bit protocol, setting Coax8Bit will enable 8-bit protocol. 7:5 Reserved N/A st a l 9.3 MIPI Control Registers RN6752V1 supports 1 links of MIPI CSI-2 unidirectional output. The low level protocol of MIPI CSI-2 consists of two packets: long packets and short packets. Figure 8 shows an example of the protocol. Long Packet SP EoT LPS SoT PH Data PF EoT LPS p c SoT ry Short Packet KEY: LPS – Low Power State SoT – Start of Transmission SoT Short Packet Long Packet PH Data PF EoT LPS SoT SP EoT EoT – End of Transmission T o Figure 8: Low Level Protocol of MIPI CSI-2 F o r The data stream is output at a fixed data rate of 648 Mbps per lane. The data stream for each decoder is a virtual channel. These data streams from virtual channels are interleaved. RN6752V1 supports 2-bit programmable virtual channel identifier. The virtual channel identifier is transferred in Data ID for both long packet and short packet. Figure 9, Figure 10 and Figure 11 shows long packet structure, short package structure and data identifier, respectively. Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 31 of 41 st a l O n ly RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output T o p c ry Figure 9: Long Packet Structure F o r Figure 10: Short Packet Structure Figure 11: Data Identifier The following figure shows an example of multi-channel output of RN6752V1. Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 32 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output VC 1 FS 1-line video data LPS SoT LPS SoT LPS PH SoT PH EoT LPS FS SoT EoT LPS SoT PH PF VC 0 VC 1 VC 2 1-line video data PH 1-line video data PH 1-line video data PF EoT SoT PH PF EoT LPS SoT PH 1-line video data VC 3 FE PF VC 3 1-line video data SoT PF VC 0 EoT LPS KEY: LPS – Low Power State SoT – Start of Transmission EoT – End of Transmission EoT LPS SoT VC 1 LPS PH – Packet Header PF – Packet Footer SoT FE EoT PF EoT VC 2 EoT LPS FS – Frame Start Packet FE – Frame End Packet PF EoT 9.3.1 MIPI CSI-2 Control Registers st a l O Figure 12: Multi-channel Data Transmission 1-line video data ly EoT VC 2 n SoT VC 0 Description CSI-2 Controller Software Reset MIPI TX Software Reset Must be 0h. Address: 06h (R/W).Default: 40h. Bits Field Name 1:0 Reserved 5:2 LANE_NUM 7:6 Reserved Description Not used. Lane Number Must be 1h. T o p c ry Address: 04h (R/W).Default: 00h. Bits Field Name 0 CSI_RESET 1 DPHY_RESET 7:2 Reserved F o r Address: 07h (R/W).Default: 04h. Bits Field Name Description 0 HSTX_CKLP_EN Enable non-continuous clock lane. 7:1 Reserved Must be 2h. Address: 21h (R/W).Default: 00h. Bits Field Name Description 0 LC_HSTX_EN Enable clock lane high speed mode. 7:1 Reserved Must be 0h. Address: 6Ch (R/W).Default: 0Fh. Bits Field Name 3:0 CSI_CH_EN 4 CSI_CH_RST 7:5 Reserved Rev. 1.6 – August.2020 Description CSI-2 Channel Enable CSI-2 Controller Reset Not used. Richnex Confidential and Proprietary Page 33 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Address: 6Dh (R/W).Default: 00h. Bits Field Name Description 1:0 CSI_CH0_FRM_MODE CSI-2 Frame Mode for Decoder 0 7:6 Reserved Reserved Description Bits 7-0 of CSI-2 max. frame number for decoder 0. Address: 71h (R/W).Default: 00h. Bits Field Name 7:0 CSI_CH0_FRM_NUM[15:8] Description Bits 15-8 of CSI-2 max. frame number for decoder 0. ly Address: 70h (R/W).Default: 01h. Bits Field Name 7:0 CSI_CH0_FRM_NUM[7:0] O n Address: 78h (R/W).Default: 80h. Bits Field Name Description 7:0 CSI_CH0_YC_CNT[7:0] Bits 7-0 of {Cb, Y0, Cr, Y1} counts per line for decoder 0. p c Description MIPI TX Bias Enable Must be 1b. Invert MIPI TX PHY clock. Must be 0h. T o Address: 00h (R/W).Default: 02h. Bits Field Name 0 CSI_BIAS_EN 1 Reserved 2 CSI_PHYCK_INV 7:3 Reserved ry 9.3.2 MIPI TX Control Registers st a l Address: 79h (R/W).Default: 02h. Bits Field Name Description 1:0 CSI_CH0_YC_CNT[9:8] Bits 9-8 of {Cb, Y0, Cr, Y1} counts per line for decoder 0. 7:2 Reserved Not used. F o r Address: 02h (R/W).Default: 10h. Bits Field Name 0 CSI_LNT0_CKLANE_EN 1 CSI_LNT1_CKLANE_EN 2 CSI_LNT2_CKLANE_EN 3 CSI_LNT3_CKLANE_EN 4 CSI_LNTC_CKLANE_EN 7:5 Reserved Address: 04h (R/W).Default: 10h. Bits Field Name 2:0 MIPI_TX_PHY0_SEL 3 Reserved 6:4 MIPI_TX_PHY1_SEL 7 Reserved Rev. 1.6 – August.2020 Description MIPI TX PHY Lane 0 Clock Mode Enable MIPI TX PHY Lane 1 Clock Mode Enable MIPI TX PHY Lane 2 Clock Mode Enable MIPI TX PHY Lane 3 Clock Mode Enable MIPI TX PHY Lane CK Clock Mode Enable Not used. Description MIPI TX PHY Lane 0 Selection Not used. MIPI TX PHY Lane 1 Selection Not used. Richnex Confidential and Proprietary Page 34 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Address: 05h (R/W).Default: 32h. Bits Field Name 2:0 MIPI_TX_PHY2_SEL 3 Reserved 6:4 MIPI_TX_PHY3_SEL 7 Reserved Description MIPI TX PHY Lane 2 Selection Not used. MIPI TX PHY Lane 3 Selection Not used. F o r T o p c ry st a l O n ly Address: 06h (R/W).Default: 04h. Bits Field Name Description 2:0 MIPI_TX_PHYC_SEL MIPI TX PHY Lane CK Selection 7:3 Reserved Not used. Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 35 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 10 Electrical Specifications 10.1 Absolute Maximum Ratings O n ly Description Symbol Min Typ Max Units VA33, 3.3V Analog Power -0.5 4.5 V VDDIO Digital Power -0.5 4.5 V VD12, 1.2V Digital Power * -0.5 1.45 V VA12, 1.2V Analog Power * -0.5 1.45 V Voltage on Any Digital Data Pin VI -0.5 4.5 V Analog Input Voltage for ADC VINM -0.5 4.5 V oC Storage Temperature TS -65 150 oC Junction Temperature TJ -40 125 NOTE: Stresses beyond those listed “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions may affect device reliability. st a l 10.2 Recommended Operating Conditions T o p c ry Description Symbol Min Typ VA33, 3.3V analog power 3.3 VD12, 1.2V digital power * 1.2 VA12, 1.2V analog power * 1.2 VDDIO 1.8/3.3 IO Ambient Operating Temperature TA -40 NOTE: The device is not guaranteed to function outside its operating conditions. Max VDDIO 85 Units V V V V V oC Max Units 0.2VDDIO ±10u V V A F 0.1VDDIO V V mA 10.3 DC Characteristics F o r Parameter Digital Inputs Input high Voltage Input Low Voltage Input Leakage Current Input Capacitance Digital Outputs Output High Voltage Output Low Voltage High Level Output Current (@VOH =2.4V) Low Level Output Current (@VOL =0.4V) Tri-state Output Leakage Current Output Capacitance Rev. 1.6 – August.2020 Symbol Min VIH VIL IL CIN 0.8VDDIO VOH VOL IOH 0.9VDDIO IOL Typ 3.5p 8 12 8 12 IOZ CO Richnex Confidential and Proprietary mA ±10u 3.5p A F Page 36 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 10.4 AC Characteristics BT656/BT601 I/O Propagation Delay over recommended ambient operating temperature range, load capacitance = 10pF VDDIO = 1.8V +/- 0.2V Symbol TPLH TPHL TPLH TPHL Min 2 2 2.2 2.2 Typ Symbol TPLH TPHL TPLH TPHL Min 1.3 1.2 1.4 1.3 Typ O Units ns ns ns ns ry 4 p c 3.5 3 3.3V, high drive 3.3V, low drive T o 2.5 1.8V, high drive 1.8V, low drive r 1 o TPLH- Propagation Delay - ns 4.5 1.5 Max 2.9 2.9 3.2 3.1 Units ns ns ns ns st a l 5 2 n VDDIO = 3.3V +/- 0.3V Parameter Propagation Delay TPLH (High drive) Propagation Delay TPHL (High drive) Propagation Delay TPLH (Low drive) Propagation Delay TPHL (Low drive) Max 5.9 6.1 6.4 6.5 ly Parameter Propagation Delay TPLH (High drive) Propagation Delay TPHL (High drive) Propagation Delay TPLH (Low drive) Propagation Delay TPHL (Low drive) F 0.5 0 5 10 15 20 CL - Load Capacitance - pF Figure 13: Typical Propagation Delay TPLH vs Load Capacitance (Ta=25°C) Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 37 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 5 4 3.5 3 3.3V, high drive 2.5 3.3V, low drive 1.8V, high drive 1.5 1.8V, low drive ly 2 1 n TPHL- Propagation Delay - ns 4.5 O 0.5 0 10 15 20 st a l 5 CL - Load Capacitance - pF ry Figure 14: Typical Propagation Delay TPHL vs Load Capacitance (Ta=25°C) 10.5 Power Consumption Min Typ TBD TBD TBD Max Units mA mA mA Min 1.3 100 0 0.6 0.6 0.6 Typ Max Units us ns us us us us ns ns us us pF T o p c Parameter Symbol Analog 3.3V Supply Current 2 IVA33 2 Analog 1.2V Supply Current IVA12 Digital 1.2V Supply Current 2 IVD12 Measured with normal IO driving strength, 1080p mode. r 10.6 Two-wire Interface Timing F o Parameter Bus Free Time Between STOP and START SDA setup time SDA hold time Setup time for START condition Setup time for STOP condition Hold time for START condition Rise time for SCL and SDA Fall time for SCL and SDA LOW period of SCL HIGH period of SCL Capacitive load for each bus line Rev. 1.6 – August.2020 Symbol TBF TSSDAT THSDAT TSSTA TSSTP THSTA TR TF TLOW THIGH CBUS 0.9 270 2.1 0.5 0.5 Richnex Confidential and Proprietary 25 Page 38 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output Parameter SCL clock frequency Symbol fSCLK Min Typ Max 400 Units KHz Note: external pull up resistor 4.7K Ohm, rise time, fall time and capacitive load for each bus line are specified by design stop star star SDA stop data TSSDAT THSDAT TR TF ly TLOW TBF n SCL TSSTA THSTA TSSTP O THIGH st a l Figure 15: Two-wire Interface Timing 10.7 Analog Video Parameters Min Typ Max 500 10 1 p c RINVAD CINVAD VINVAD Test conditions ry Symbol Units KOhm pF Vpp T o Parameter Analog Front End and ADC Input impedance Input capacitance Full scale input voltage 10.8 Oscillator Input F o r Parameter nominal frequency deviation duty cycle Rev. 1.6 – August.2020 Symbol Min 45 Richnex Confidential and Proprietary Typ 27 Max ±50 55 Units MHz ppm % Page 39 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output 11 Application Diagram T o p c ry st a l O n ly Please contact agents for further RN6752V1 applications in detail. F o r Figure 16: Application schematic Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 40 of 41 RN6752V1 1-Channel HD Video Decoder with MIPI CSI2 Output F o r T o p c ry st a l O n ly 12 Package Outlines Figure 17: RN6752V1 32-pin QFN Package Information Rev. 1.6 – August.2020 Richnex Confidential and Proprietary Page 41 of 41
RN6752V1GQW 价格&库存
很抱歉,暂时无法提供与“RN6752V1GQW”相匹配的价格&库存,您可以联系我们找货
