YX-X3-PHY6222
YX-X3-PHY6222
    PORRAY(普泰睿)
    MODULE_19.1X18.3MM
    蓝牙MESH模块 32-bit ARMCortex-M0 2412~2484MHz
YX-X3-PHY6222 数据手册
深圳市普泰睿科技有限公司 YX-X3-PHY6222 蓝牙 MESH 模块产品规格书 深圳市普泰睿科技有限公司 目录 1. 产品概述 ........................................................................................................................................................................ 1 1.1 性能优势........................................................................................................................................................2 1.2 芯片特性........................................................................................................................................................3 1.3 储存配置........................................................................................................................................................3 1.4 GPIO................................................................................................................................................................3 1.5 接收发射模式................................................................................................................................................4 1.6 蓝牙通信协议................................................................................................................................................4 1.7 功耗参数........................................................................................................................................................4 1.8 工作温度........................................................................................................................................................5 1.9 封装尺寸.........................................................................................................................................................5 2. 接口定义 ........................................................................................................................................................................ 6 3. 外形尺寸 ........................................................................................................................................................................ 8 1 深圳市普泰睿科技有限公司 1. 产品概述 PHY6222 是一款支持 BLE 5.2 功能和 IEEE 802.15.4 通信协议的系统级芯片(SoC) ,集成了超低功耗的高性 能多模射频收发机,搭载 32-bit ARM®Cortex™-M0 处理器,提供 64K retention SRAM、可选 128K-8M Flash、 96KB ROM 以及 256bit efuse,支持基于 BLE 和 IEEE 802.15.4 的安全架构、应用和 OTA 在线升级。此外, 芯片串行外设 IO 和集成的应用程序 IP 还能够以最小的 BOM 成本开发产品。 PHY6222 采用高效率片上电源管理、低功耗射频前端、低功耗时钟产生架构、振荡器快速启动技术等电 路技术,实现最低的峰值、平均和休眠功耗,保证常规 200mAH 的纽扣电池供电状态下能够持续工作五 年以上。 PHY6222 通过硬件模块的充分复用以最低代价实现多模数字收发机。发射机最大发射功率达到 10dBm; BLE 1Mbps 速率下接收机灵敏度达到-99dBm,链路射频预算 109dB@1Mbps;IEEE 802.15.4 250Kbps 速率 下接收灵敏度-103dBm;0dBm 时收发功耗 4.6/4mA(TX/RX) 。此外创新了无需调制系数估计的相干解调 (Coherent Demodulation) ,提供 3dB 的解调增益,将通信距离和抗干扰能力提高了数倍。 ———————————————— 1 深圳市普泰睿科技有限公司 1.1 性能优势 自主知识产权协议栈 2Mbps 高速率 Coded PHY 长距离 BLE 多连接和主从切换 AoA/AoD 无线定位 扩展广播/周期广播 私有 2.4G 协议栈 IEEE802.15.4 Zigbee 全功能 BLE+Zigbee 多协议 BLE Mesh 全模式全节点* SIG-Mesh BQB 认证 Friend Node/Low Power Node/Proxy Node/Relay Node 射频性能 99dBm@BLE 1Mbps 105dBm@BLE 125Kbps 103dBm@IEEE 802.15.4 250Kbps 20~10dBm 发射功率 107dBm@1Mbps 链路射频预算 超低功耗 发射峰值电流 4.6mA@3.3V 2 深圳市普泰睿科技有限公司 接收峰值电流 4mA@3.3V 多应用场景平均功耗<10uA 1.2 芯片特性 ARM Cortex-M0 32 位处理器 1.3 存储配置 • 128KB-8MB Flash • 64KB SRAM • 4-way Instruction Cache • 8KB Cache RAM • 96KB ROM • 256bit eFuse 1.4 GPIO • 22 个通用 I/O 管脚 • 关闭/休眠模式 GPIO 状态保留 • 可配置串行接口 • 支持 IO MUX 功能映射编程 • 所有管脚可配置唤醒 • 所有管脚可触发中断 • 3 个正交解码器(QDEC) 3 深圳市普泰睿科技有限公司 • 6 通道 PWM • 2 通道 PDM/I2C/SPI/UART • 4 通道 DMA 1.5 接收发射模式 • 关闭模式 0.3UA (仅限 10 唤醒) • 32KHz RTC 休眠模式 1uA • 32KHz RTC 且 SRAM 保留的休 眠模式 4uA • 接收模式 4mA@3.3V • 发射模式 4.7mA@3.3V (输出 功率 OdBm) • MCU:
YX-X3-PHY6222 价格&库存
很抱歉,暂时无法提供与“YX-X3-PHY6222”相匹配的价格&库存,您可以联系我们找货
