7D048000I01
7D048000I01
    HDFREQUENCY(浩都频率)
    SMD2016_4P
    无源晶振 48MHz ±10ppm 10pF -20℃~+70℃
7D048000I01 数据手册
JIANGSU HD-CRYSTAL TECHNOLOGY CO., LTD SMD2016-4 Crystal Resonator 7D048000I01 1. Scope: 1.1 This specification applies to the RoHS compliance quartz crystal unit with a frequency of 48.000MHz which will be used in crystal oscillator applications. 2. Construction: 2.1 Type of Quartz Resonator: SMD2016-4pads 3.  Electrical Characteristics 3.1 Nominal Frequency(f): 48.000MHz 3.2 Load Capacitance(CL): 10pF 3.3 Frequency Tolerance(△f/f): ±10ppm 3.4 Frequency Temperature Stability: ±20ppm 3.5 Resonance Resistance(ohm): 35 ohms Max 3.6 Osc mode: Fundamental mode 3.7 Shunt Capacitance(C0): 2pF Max 3.8 Drive Level(DL): 100μW Max 3.9 Operating Temperature Range(TOPR): -20 to + 70°C 3.10 Storage Temperature Range(TSTG): -55 to + 125°C 3.11 Insulation Resistance(IR): >500M ohms 3.12 Aging(△fA): ±3ppm/Year Max  www. hd- crystal. com 1  Rev . 1. 1 Reliability Specification Item Condition Free drop from 75cm height on a hard wooden 1. Drop characteristics board for 3 times. (Board is thickness more than 30 mm.) 2 Mechanical shock Device are shocked to half sine wave (1000g) three mutually perpendicular axes each 3 times Shake frequency 10~55Hz, cyc1~2 minutes, 3. Shake characteristics swing 1.5mm, direction x/y/z, all 30 minutes, test after 1 hours. Humidity 4. 5. 6.  characteristics Low temperature characteristics High temperature characteristics 7. Temperature cycling 8. Refluence examination +40±2℃ & 90%~95% R.H. 250 hours Standard Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification -40±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification +85±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification -30±3℃/30±3 min~+85±2℃/30±3min, Frequency change:≤±5ppm 5 cycles Rr as specification Frequency change:≤±5ppm Rr as specification  www. hd- crystal. com 2  Rev . 1. 1 3DFNDJH2XWOLQH'LPHQVLRQV 2.00 ± 0.10 3 1 4 GND 2 3 1.60 ± 0.10 2 4 1 3 2 0.50 MAX 4 GND Internal View Connection 0.475 ± 0.10 0.7±0.10 0.5±0.10 0.575± 0.10 1 CRYSTAL GND CRYSTAL GND Units:mm Bottom View 6XJJHVWHG3DG/D\RXW Units:mm   www. hd- crystal. com 3  Rev . 1. 1 Packing Specification Qty:3000Pcs   www. hd- crystal. com 4  Rev . 1. 1
7D048000I01
物料型号为7D048000I01,是一款48.000MHz的SMD2016-4 Crystal Resonator,由江苏海晶科技股份有限公司生产。
该器件采用SMD2016-4pads封装,具有以下参数特性: - 标称频率:48.000MHz - 负载电容:10pF - 频率容差:±10ppm - 频率温度稳定性:±20ppm - 谐振电阻:最大35欧姆 - 振荡模式:基础模式 - 并联电容:最大2pF - 驱动电平:最大100μW - 工作温度范围:-20至+70°C - 储存温度范围:-55至+125°C - 绝缘电阻:大于500M欧姆 - 老化:每年最大±3ppm
可靠性规格包括: - 跌落特性:从75cm高度自由跌落至硬木板3次,频率变化≤±5ppm - 机械冲击:在三个互相垂直的轴上各冲击3次,频率变化≤±5ppm - 振动特性:10-55Hz振动频率,每次1.5mm振幅,持续30分钟,测试后1小时,频率变化≤±5ppm - 湿度特性:在+40+2°C &90%-95% R.H.条件下250小时,频率变化≤±5ppm - 低温特性:在-40±2°C条件下250小时,频率变化≤±5ppm - 高温特性:在+85±2°C条件下250小时,频率变化≤±5ppm - 温度循环:-30至+85°C,5个循环,频率变化≤±5ppm - 回流焊检查:在不同温度下进行,频率变化≤±5ppm
封装信息包括: - 内部视图连接引脚功能: - #1:CRYSTAL - #2:GND - #3:CRYSTAL - #4:GND
建议的焊盘布局尺寸也已提供。
包装规格为内包装纸盒,交货包装纸盒,每盒3000件。
7D048000I01 价格&库存
很抱歉,暂时无法提供与“7D048000I01”相匹配的价格&库存,您可以联系我们找货
7D048000I01
  • 5+0.69612
  • 50+0.55668
  • 150+0.48691
  • 500+0.43468
  • 3000+0.34050
  • 6000+0.31957
库存:358
7D048000I01
  • 1+0.60000
  • 100+0.56000
  • 300+0.52000
  • 500+0.48000
  • 2000+0.46000
  • 5000+0.44800
