7D052000F01
7D052000F01
    HDFREQUENCY(浩都频率)
    SMD2016_4P
    无源晶振 52MHz ±10ppm 8pF -20℃~+70℃
7D052000F01 数据手册
JIANGSU HD-CRYSTAL TECHNOLOGY CO., LTD SMD2016-4 Crystal Resonator 7D052000F01 1. Scope: 1.1 This specification applies to the RoHS compliance quartz crystal unit with a frequency of 52.000MHz which will be used in crystal oscillator applications. 2. Construction: 2.1 Type of Quartz Resonator: SMD2016-4pads 3.  Electrical Characteristics 3.1 Nominal Frequency(f): 52.000MHz 3.2 Load Capacitance(CL): 8pF 3.3 Frequency Tolerance(△f/f): ±10ppm 3.4 Frequency Temperature Stability: ±20ppm 3.5 Resonance Resistance(ohm): 35 ohms Max 3.6 Osc mode: Fundamental mode 3.7 Shunt Capacitance(C0): 2pF Max 3.8 Drive Level(DL): 100μW Max 3.9 Operating Temperature Range(TOPR): -20 to + 70°C 3.10 Storage Temperature Range(TSTG): -55 to + 125°C 3.11 Insulation Resistance(IR): >500M ohms 3.12 Aging(△fA): ±3ppm/Year Max  www. hd- crystal. com 1  Rev . 1. 1 Reliability Specification Item Condition Free drop from 75cm height on a hard wooden 1. Drop characteristics board for 3 times. (Board is thickness more than 30 mm.) 2 Mechanical shock Device are shocked to half sine wave (1000g) three mutually perpendicular axes each 3 times Shake frequency 10~55Hz, cyc1~2 minutes, 3. Shake characteristics swing 1.5mm, direction x/y/z, all 30 minutes, test after 1 hours. Humidity 4. 5. 6.  characteristics Low temperature characteristics High temperature characteristics 7. Temperature cycling 8. Refluence examination +40±2℃ & 90%~95% R.H. 250 hours Standard Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification -40±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification +85±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification -30±3℃/30±3 min~+85±2℃/30±3min, Frequency change:≤±5ppm 5 cycles Rr as specification Frequency change:≤±5ppm Rr as specification  www. hd- crystal. com 2  Rev . 1. 1 3DFNDJH2XWOLQH'LPHQVLRQV 2.00 ± 0.10 3 1 4 GND 2 3 1.60 ± 0.10 2 4 1 3 2 0.50 MAX 4 GND Internal View Connection 0.475 ± 0.10 0.7±0.10 0.5±0.10 0.575± 0.10 1 CRYSTAL GND CRYSTAL GND Units:mm Bottom View 6XJJHVWHG3DG/D\RXW Units:mm   www. hd- crystal. com 3  Rev . 1. 1 Packing Specification Qty:3000Pcs   www. hd- crystal. com 4  Rev . 1. 1
7D052000F01
物料型号:SMD2016-4C
器件简介:该文档描述的是一款用于晶体振荡器应用的RoHS合规石英晶体单元,具有52.000MHz的频率。
引脚分配: - #1:晶体 - #2:地 - #3:晶体 - #4:地
参数特性: - 标称频率:52.000MHz - 负载电容:8pF - 频率容差:±10ppm - 频率温度稳定性:±20ppm - 谐振电阻:最大35欧姆 - 并联电容:最大2pF - 驱动电平:最大100μW - 工作温度范围:-20至+70°C - 存储温度范围:-55至+125°C - 绝缘电阻:大于500M欧姆 - 老化:每年最大±3ppm
功能详解: - 该晶体振荡器在各种环境条件下(如跌落、机械冲击、振动、湿度、低温、高温、温度循环和回流)均能保持频率变化在±5ppm以内。
应用信息: - 适用于晶体振荡器应用。
封装信息: - 封装类型:SMD2016-4pads - 封装尺寸:2.00 ± 0.10 x 1.60 ± 0.10 x 0.50 MAX - 内部视图连接:引脚1和3为晶体,引脚2和4为地。
建议的焊盘布局: - 焊盘尺寸为0.9 x 0.5 x 0.9 mm。
包装规格: - 内包装纸箱:每箱3000个。
7D052000F01 价格&库存
很抱歉,暂时无法提供与“7D052000F01”相匹配的价格&库存,您可以联系我们找货
7D052000F01
  • 5+0.96218
  • 50+0.74445
  • 150+0.65114
  • 500+0.53471
  • 3000+0.49799
  • 6000+0.46689
库存:771
7D052000F01
  • 1+0.70000
  • 30+0.67500
  • 100+0.65000
  • 500+0.60000
  • 1000+0.57500
  • 2000+0.56000
