7E030000I01
7E030000I01
    HDFREQUENCY(浩都频率)
    SMD1612_4P
    无源晶振 30MHz ±10ppm 10pF -20℃~+70℃
7E030000I01 数据手册
JIANGSU HD-CRYSTAL TECHNOLOGY CO., LTD SMD1612-4 Crystal Resonator 7E030000I01 1. Scope: 1.1 This specification applies to the RoHS compliance quartz crystal unit with a frequency of 30.000MHz which will be used in crystal oscillator applications. 2. Construction: 2.1Type of Quartz Resonator: SMD1612-4pads 3.  Electrical Characteristics 3.1 Nominal Frequency(f): 30.000MHz 3.2 Load Capacitance(CL): 10pF 3.3 Frequency Tolerance(△f/f): ±10ppm 3.4 Frequency Temperature Stability: ±20ppm 3.5 Resonance Resistance(ohm): 80 ohms Max 3.6 Osc mode: Fundamental mode 3.7 Shunt Capacitance(C0): 2pF Max 3.8 Drive Level(DL): 100μW Max 3.9 Operating Temperature Range(TOPR): -20 to + 70°C 3.10 Storage Temperature Range(TSTG): -55 to + 125°C 3.11 Insulation Resistance(IR): >500M ohms 3.12 Aging(△fA): ±3ppm/Year Max  www. hd- crystal. com 1  Rev . 1. 1 Reliability Specification Item Condition Free drop from 75cm height on a hard wooden 1. Drop characteristics board for 3 times. (Board is thickness more than 30 mm.) 2 Mechanical shock Device are shocked to half sine wave (1000g) three mutually perpendicular axes each 3 times Shake frequency 10~55Hz, cyc1~2 minutes, 3. Shake characteristics swing 1.5mm, direction x/y/z, all 30 minutes, test after 1 hours. Humidity 4. 5. 6.  characteristics Low temperature characteristics High temperature characteristics 7. Temperature cycling 8. Refluence examination +40±2℃ & 90%~95% R.H. 250 hours Standard Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification -40±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification +85±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification -30±3℃/30±3 min~+85±2℃/30±3min, Frequency change:≤±5ppm 5 cycles Rr as specification Frequency change:≤±5ppm Rr as specification  www. hd- crystal. com 2  Rev . 1. 1 3DFNDJH2XWOLQH'LPHQVLRQV 1.65 ± 0.10 3 1 4 NC 2 3 1.25 ± 0.10 2 4 1 3 2 0.40 MAX 4 GND Internal View Connection 0.4 ± 0.10 0.5±0.10 0.3±0.10 0.5± 0.10 1 CRYSTAL NC CRYSTAL GND Units:mm Bottom View 6XJJHVWHG3DG/D\RXW 0.4 0.7 0.6 0.2 0.6 0.7 Units:mm   www. hd- crystal. com 3  Rev . 1. 1 Packing Specification Qty:3000Pcs   www. hd- crystal. com 4  Rev . 1. 1
7E030000I01 价格&库存
很抱歉,暂时无法提供与“7E030000I01”相匹配的价格&库存,您可以联系我们找货
7E030000I01
  • 1+0.84000
  • 30+0.81000
  • 100+0.78000
  • 500+0.72000
  • 1000+0.69000
  • 2000+0.67200
