7B032000I01
7B032000I01
    HDFREQUENCY(浩都频率)
    SMD3225_4P
    无源晶振 32MHz ±10ppm 10pF -20℃~+70℃
7B032000I01 数据手册
JIANGSU HD-CRYSTAL TECHNOLOGY CO., LTD SMD3225-4 Crystal Resonator 7B032000I01 1. Scope: 1.1 This specification applies to the RoHS compliance quartz crystal unit with a frequency of 32MHz which will be used in crystal oscillator applications. 2. Construction: 2.1 Type of Quartz Resonator: SMD3225-4pads 3.  Electrical Characteristics 3.1 Nominal Frequency(f): 32MHz 3.2 Load Capacitance(CL): 10pF 3.3 Frequency Tolerance(△f/f): ±10ppm 3.4 Frequency Temperature Stability: ±20ppm 3.5 Resonance Resistance(ohm): 25 ohms Max 3.6 Osc mode: Fundamental mode 3.7 Shunt Capacitance(C0): 2pF Max 3.8 Drive Level(DL): 100μW Max 3.9 Operating Temperature Range(TOPR): -20 to + 70°C 3.10 Storage Temperature Range(TSTG): -55 to + 125°C 3.11 Insulation Resistance(IR): >500M ohms 3.12 Aging(△fA): ±3ppm/Year Max  www. hd- crystal. com 1  Rev . 1. 1 Reliability Specification Item Condition Free drop from 75cm height on a hard wooden 1. Drop characteristics board for 3 times. (Board is thickness more than 30 mm.) 2 Mechanical shock Device are shocked to half sine wave (1000g) three mutually perpendicular axes each 3 times Shake frequency 10~55Hz, cyc1~2 minutes, 3. Shake characteristics swing 1.5mm, direction x/y/z, all 30 minutes, test after 1 hours. Humidity 4. 5. 6.  characteristics Low temperature characteristics High temperature characteristics 7. Temperature cycling 8. Refluence examination +40±2℃ & 90%~95% R.H. 250 hours Standard Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification -40±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification +85±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification -30±3℃/30±3 min~+85±2℃/30±3min, Frequency change:≤±5ppm 5 cycles Rr as specification Frequency change:≤±5ppm Rr as specification  www. hd- crystal. com 2  Rev . 1. 1 3DFNDJH2XWOLQH'LPHQVLRQV 3.20 ± 0.10 3 1 2 GND 4 3 2.50 ± 0.10 4 1 2 3 4 0.70 MAX 2 GND Internal View Connection 0.65 ± 0.10 1.2±0.10 0.7±0.10 0.9± 0.10 1 CRYSTAL GND CRYSTAL GND Units:mm Bottom View 6XJJHVWHG3DG/D\RXW 0.8 1.4 1.2 1.2 1.4 Units:mm   www. hd- crystal. com 3  Rev . 1. 1 Packing Specification Qty:3000Pcs   www. hd- crystal. com 4  Rev . 1. 1
7B032000I01
物料型号:SMD3225-4 Crystal Resonator
器件简介:这是一份由江苏海晶科技有限公司发布的关于32MHz频率的SMD3225-4引脚的石英晶体谐振器的规格说明。该器件适用于符合RoHS标准的晶体振荡器应用。
引脚分配: - 引脚 #1:晶体 - 引脚 #2:地(GND) - 引脚 #3:晶体 - 引脚 #4:地(GND)
参数特性: - 标称频率:32MHz - 负载电容:10pF - 频率容差:±10ppm - 频率温度稳定性:±20ppm - 谐振电阻:最大25欧姆 - 工作模式:基频模式 - 并联电容:最大2pF - 驱动电平:最大100μW - 工作温度范围:-20°C 至 +70°C - 存储温度范围:-55°C 至 +125°C - 绝缘电阻:大于500M欧姆 - 老化率:每年最大±3ppm
功能详解:文档中详细列出了可靠性规范,包括跌落特性、机械冲击、振动特性、湿度特性、低温特性、高温特性、温度循环和回流焊检查等测试标准。
应用信息:该晶体谐振器适用于晶体振荡器应用。
封装信息:封装尺寸和内部视图提供了详细的尺寸和引脚布局,建议的焊盘布局也包含在文档中。
7B032000I01 价格&库存
很抱歉,暂时无法提供与“7B032000I01”相匹配的价格&库存,您可以联系我们找货
7B032000I01
  • 1+0.34500
  • 100+0.32200
  • 300+0.29900
  • 500+0.27600
  • 2000+0.26450
  • 5000+0.25760
7B032000I01
  • 10+0.47704
  • 100+0.37336
  • 300+0.32152
  • 3000+0.30057
库存:2915
