7B040000K01
7B040000K01
    HDFREQUENCY(浩都频率)
    SMD3225_4P
    无源晶振 40MHz ±10ppm 11pF -20℃~+70℃
7B040000K01 数据手册
JIANGSU HD-CRYSTAL TECHNOLOGY CO., LTD SMD3225-4 Crystal Resonator 7B040000K01 1. Scope: 1.1 This specification applies to the RoHS compliance quartz crystal unit with a frequency of 40MHz which will be used in crystal oscillator applications. 2. Construction: 2.1 Type of Quartz Resonator: SMD3225-4pads 3.  Electrical Characteristics 3.1 Nominal Frequency(f): 40MHz 3.2 Load Capacitance(CL): 11pF 3.3 Frequency Tolerance(△f/f): ±10ppm 3.4 Frequency Temperature Stability: ±20ppm 3.5 Resonance Resistance(ohm): 25 ohms Max 3.6 Osc mode: Fundamental mode 3.7 Shunt Capacitance(C0): 2pF Max 3.8 Drive Level(DL): 100μW Max 3.9 Operating Temperature Range(TOPR): -20 to + 70°C 3.10 Storage Temperature Range(TSTG): -55 to + 125°C 3.11 Insulation Resistance(IR): >500M ohms 3.12 Aging(△fA): ±3ppm/Year Max  www. hd- crystal. com 1  Rev . 1. 1 Reliability Specification Item Condition Free drop from 75cm height on a hard wooden 1. Drop characteristics board for 3 times. (Board is thickness more than 30 mm.) 2 Mechanical shock Device are shocked to half sine wave (1000g) three mutually perpendicular axes each 3 times Shake frequency 10~55Hz, cyc1~2 minutes, 3. Shake characteristics swing 1.5mm, direction x/y/z, all 30 minutes, test after 1 hours. Humidity 4. 5. 6.  characteristics Low temperature characteristics High temperature characteristics 7. Temperature cycling 8. Refluence examination +40±2℃ & 90%~95% R.H. 250 hours Standard Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification -40±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification +85±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification -30±3℃/30±3 min~+85±2℃/30±3min, Frequency change:≤±5ppm 5 cycles Rr as specification Frequency change:≤±5ppm Rr as specification  www. hd- crystal. com 2  Rev . 1. 1 3DFNDJH2XWOLQH'LPHQVLRQV 3.20 ± 0.10 3 1 2 GND 4 3 2.50 ± 0.10 4 1 2 3 4 0.70 MAX 2 GND Internal View Connection 0.65 ± 0.10 1.2±0.10 0.7±0.10 0.9± 0.10 1 CRYSTAL GND CRYSTAL GND Units:mm Bottom View 6XJJHVWHG3DG/D\RXW 0.8 1.4 1.2 1.2 1.4 Units:mm   www. hd- crystal. com 3  Rev . 1. 1 Packing Specification Qty:3000Pcs   www. hd- crystal. com 4  Rev . 1. 1
7B040000K01
1. 物料型号:SMD3225-4 Crystal Resonator 2. 器件简介:适用于40MHz频率的无铅石英晶体单元,用于晶体振荡器应用。 3. 引脚分配: - #1: CRYSTAL - #2: GND - #3: CRYSTAL - #4: GND 4. 参数特性: - 标称频率:40MHz - 负载电容:11pF - 频率容差:±10ppm - 频率温度稳定性:±20ppm - 谐振电阻:最大25欧姆 - 并联电容:最大2pF - 驱动电平:最大100μW - 工作温度范围:-20至+70°C - 存储温度范围:-55至+125°C - 绝缘电阻:大于500M欧姆 - 老化率:每年最大±3ppm 5. 功能详解:文档提供了详细的电气特性和可靠性规范,包括跌落特性、机械冲击、震动特性、湿度特性、低温特性、高温特性、温度循环和回流焊检查。 6. 应用信息:适用于晶体振荡器应用。 7. 封装信息:提供了封装的外形尺寸和内部视图连接,建议的焊盘布局。
7B040000K01 价格&库存
很抱歉,暂时无法提供与“7B040000K01”相匹配的价格&库存,您可以联系我们找货
7B040000K01
  • 5+0.68526
  • 50+0.54173
  • 150+0.46991
库存:160
7B040000K01
  • 1+0.34500
  • 100+0.32200
  • 300+0.29900
  • 500+0.27600
  • 2000+0.26450
  • 5000+0.25760
