JIANGSU HD-CRYSTAL TECHNOLOGY CO., LTD
SMD2016-4 Crystal Resonator
7D019200C01
1.
Scope:
1.1 This specification applies to the RoHS
compliance quartz crystal unit with a frequency of 19.200MHz which will be used
in crystal oscillator applications.
2.
Construction:
2.1 Type of Quartz Resonator: SMD2016-4pads
3.
Electrical Characteristics
3.1 Nominal Frequency(f):
19.200MHz
3.2 Load Capacitance(CL):
7pF
3.3 Frequency Tolerance(△f/f):
±10ppm
3.4 Frequency Temperature Stability:
±20ppm
3.5 Resonance Resistance(ohm):
80 ohms Max
3.6 Osc mode:
Fundamental mode
3.7 Shunt Capacitance(C0):
2pF Max
3.8 Drive Level(DL):
100μW Max
3.9 Operating Temperature Range(TOPR):
-20 to + 70°C
3.10 Storage Temperature Range(TSTG):
-55 to + 125°C
3.11 Insulation Resistance(IR):
>500M ohms
3.12 Aging(△fA):
±3ppm/Year Max
www. hd- crystal.
com
1
Rev . 1. 1
Reliability Specification
Item
Condition
Free drop from 75cm height on a hard wooden
1.
Drop characteristics
board for 3 times. (Board is thickness more than
30 mm.)
2
Mechanical shock
Device are shocked to half sine wave (1000g)
three mutually perpendicular axes each 3 times
Shake frequency 10~55Hz, cyc1~2 minutes,
3.
Shake characteristics
swing 1.5mm, direction x/y/z, all 30 minutes, test
after 1 hours.
Humidity
4.
5.
6.
characteristics
Low temperature
characteristics
High temperature
characteristics
7.
Temperature cycling
8.
Refluence
examination
+40±2℃ & 90%~95% R.H. 250 hours
Standard
Frequency change:≤±5ppm
Rr as specification
Rr as specification
Rr as specification
Rr as specification
-40±2℃, 250 hours, put in room temperature,
test after 1 hours.
Rr as specification
+85±2℃, 250 hours, put in room temperature,
test after 1 hours.
Rr as specification
-30±3℃/30±3 min~+85±2℃/30±3min,
5 cycles
Rr as specification
Rr as specification
www. hd- crystal.
com
2
Rev . 1. 1
3DFNDJH2XWOLQH'LPHQVLRQV
2.00 ± 0.10
3
1
4
GND
2
3
1.60 ± 0.10
2
4
1
3
2
0.50 MAX
4
GND
Internal View Connection
0.475 ± 0.10
0.7±0.10
0.5±0.10
0.575± 0.10
1
CRYSTAL
GND
CRYSTAL
GND
Units:mm
Bottom View
6XJJHVWHG3DG/D\RXW
Units:mm
www. hd- crystal.
com
3
Rev . 1. 1
Packing Specification
Qty:3000Pcs
www. hd- crystal.
com
4
Rev . 1. 1
很抱歉,暂时无法提供与“7D019200C01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.52500
- 100+0.49000
- 300+0.45500
- 500+0.42000
- 2000+0.40250
- 5000+0.39200
- 国内价格
- 5+0.92880
- 50+0.73700
- 150+0.64109
