7S032768NW2
7S032768NW2
    HDFREQUENCY(浩都频率)
    DT-26
    无源晶振 32.768kHz ±20ppm 12.5pF -40℃~+85℃
7S032768NW2 数据手册
JIANGSU HD-CRYSTAL TECHNOLOGY CO., LTD HD206 Quartz Crystal 7S032768NW2 1. Scope: 1.1 This specification applies to the RoHS compliance quartz crystal unit with a frequency of 32.768KHz which will be used in crystal oscillator applications. 2. Construction: 2.1 Type of Quartz Resonator: HD206 3.  Electrical Characteristics 3.1 Mode of Vibration: +2°X-cut , Fundamental 3.2 Nominal frequency(F): 32.768KHz 3.3 Load Capacitance(CL): 12.5pF 3.4 Frequency Tolerance at 25℃ ±20ppm 3.5 Frequency Temperature Stability: -0.04* 10-6/℃2 Max 3.6 Series Resistance(Rr): 50 KΩ Max 3.7 Quality Factor(Q): 60K TYP 3.8 Turnover Temperature(To): 25 ℃± 5℃ 3.9 Operation Temperature: -40 ℃~ + 85℃ 3.10 Preservation Temperature: -55 ℃~ +125℃ 3.11 Shunt Capacitance(C0 ): 0.8PF Typical 3.12 Capacitance Ratio(C0/C1): 500 Typical 3.13 Insulation Resistance: 500MΩ at DC 100V±10V 3.14 Drive Level: 1μ W  www. hd- crystal. com 1  Rev . 1. 1 Reliability Specification Item Condition Free drop from 75cm height on a hard wooden 1. Drop characteristics board for 3 times. (Board is thickness more than 30 mm.) 2 Mechanical shock Device are shocked to half sine wave (1000g) three mutually perpendicular axes each 3 times Shake frequency 10~55Hz, cyc1~2 minutes, 3. Shake characteristics swing 1.5mm, direction x/y/z, all 30 minutes, test after 1 hours. Humidity 4. 5. 6.  characteristics Low temperature characteristics High temperature characteristics 7. Temperature cycling 8. Refluence examination +40±2℃ & 90%~95% R.H. 250 hours Standard Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification -40±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification +85±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification -30±3℃/30±3 min~+85±2℃/30±3min, Frequency change:≤±5ppm 5 cycles Rr as specification Frequency change:≤±5ppm Rr as specification  www. hd- crystal. com 2  Rev . 1. 1 3DFNDJH2XWOLQH'LPHQVLRQV   www. hd- crystal. com 3  Rev . 1. 1 Packing Specificatio 1000 20 5   www. hd- crystal. com 4  Rev . 1. 1
7S032768NW2
物料型号:HD206 器件简介:这是江苏海晶科技有限公司生产的32.768KHz频率的无铅石英晶体单元,适用于晶体振荡器应用。
引脚分配:文档中未提供引脚分配信息。
参数特性: - 振动模式:+2°X切,基本模式 - 标称频率:32.768KHz - 负载电容:12.5pF - 25℃频率容差:±20ppm - 频率温度稳定性:最大-0.04 10^-6/℃^2 - 串联电阻:最大50 KΩ - 品质因数:典型值60K - 转折温度:25 ℃± 5℃ - 工作温度:-40℃~ + 85℃ - 储存温度:-55℃~ +125℃ - 并联电容:典型值0.8PF - 电容比:典型值500 - 绝缘电阻:直流100V±10V下500MΩ - 驱动水平:1 μW
功能详解:文档中未提供详细的功能详解
应用信息:适用于晶体振荡器应用。
封装信息:封装尺寸为2.5 1.0 0.7mm,具体封装轮廓尺寸图在文档中有详细描述。
7S032768NW2 价格&库存
很抱歉,暂时无法提供与“7S032768NW2”相匹配的价格&库存,您可以联系我们找货
7S032768NW2
  • 10+0.47337
  • 100+0.36969
  • 300+0.31785
  • 1000+0.30057
  • 5000+0.26946
  • 10000+0.25380
库存:215
7S032768NW2
  • 1+0.30000
  • 100+0.28000
  • 300+0.26000
  • 500+0.24000
  • 2000+0.23000
  • 5000+0.22400
