83008000301
83008000301
    HDFREQUENCY(浩都频率)
    SMD3225_4P
    有源晶振 8.000000MHz ±30ppm 3.3V -40℃~+85℃ CMOS
83008000301 数据手册
江苏浩都频 率科技有限公司 JIANGSU HD-CRYSTAL TECHNOLOGY CO.,LTD Specifications For Product TYPE : Quartz Crystal Oscillator SPEC : CXO3225/8.000M/3.3V/±30PPM 83008000301 P/N : VER A/2 : R&D APPR.SIGNATURED ISSUE CHECK DEPT. APPROVAL Jiangsu HD-Crystal technology CO., Ltd Add:NO 3,Dongxu Road,Lingang City,Jiangyin,Jiangsu Procince Specification Revision Record Sheet  Rev. Revise page Revise Contents Date Ref. No. Reviser A/0 N/A Initial released 2018/3/30 N/A 吴佳斌 A/1 N/A P/N revision 2020/1/1 N/A 吴佳斌 A/2 4 package and pad layout change 2022/2/8 N/A 吴佳斌  www. hd- crystal. com 1  Product Descipion 83008000301 1. Scope: 1.1 This specification applies to the RoHS crystal oscillator with a frequency of 8.000 MHz which will be used in electronic equipment. 2. Construction: 2.1 Oscillators series: 83 series CXO3225 2.2 Package: SMD3.2×2.5 3. Electrical Characteristics 3.1 Nominal Frequency: 8.000MHz 3.2 Frequency Stability: ±30ppm (incl. 25°C tolerance, tolerance over operating temperature range, input voltage change, load change, 1 year aging) ±3ppm/year 3.3 3.4 Aging: Operating Temperature Range: -40 to + 85°C 3.5 Storage Temperature Range: -55 to + 125°C 3.6 Input Voltage (VDD): +3.3Vdc±10% 3.7 Input Current (IDD): 20mA max 3.8 Output Waveform: CMOS 3.9 Output Symmetry: 50±10% 3.10 Rise/Fall Time: 8ns max 3.11 Output Voltage VOL: 10%VDD VOH: 3.12 Output Load: 90%VDD 15pF 3.13 Output State Control: Enable/disable 510ms max 3.14 Start-up Time: 3.15 Standby current: 10µA max 3.16 Phase Jitter (rms): 1ps rms max 12kHz to 20MHz max  3.17 Oscillation mode: Fundmental   3.18 Others: Not recommended for safety applications  www. hd- crystal. com 2 Reliability Specification Item Condition Free drop from 75cm height on a hard wooden 1. Drop characteristics board for 3 times. (Board is thickness more than 30 mm.) 2 Mechanical shock Device are shocked to half sine wave (1000g) three mutually perpendicular axes each 3 times Shake frequency 10~55Hz, cyc1~2 minutes, 3. Shake characteristics swing 1.5mm, direction x/y/z, all 30 minutes, test after 1 hours. Humidity 4. 5. 6.  characteristics Low temperature characteristics High temperature characteristics 7. Temperature cycling 8. Refluence examination +40±2℃ & 90%~95% R.H. 250 hours Standard Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification Frequency change:≤±5ppm Rr as specification -40±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification +85±2℃, 250 hours, put in room temperature, Frequency change:≤±5ppm test after 1 hours. Rr as specification -40±2℃/30±3 min~+85±2℃/30±3min, Frequency change:≤±5ppm 5 cycles Rr as specification Frequency change:≤±5ppm Rr as specification  www. hd- crystal. com 3  3DFNDJH2XWOLQH'LPHQVLRQV Units:mm 6XJJHVWHG3DG/D\RXW To ensure optimal oscillator performance, place a by-pass capacitor of 0.1uF as close to the part as possible between Vdd and GND pads.   www. hd- crystal. com 4  Packing Specification Qty:3000Pcs   www. hd- crystal. com 5
83008000301 价格&库存
很抱歉,暂时无法提供与“83008000301”相匹配的价格&库存,您可以联系我们找货
库存:18
83008000301
  • 1+1.88500
  • 30+1.82000
  • 100+1.69000
  • 500+1.56000
  • 1000+1.49500
