江苏浩都频 率科技有限公司
JIANGSU HD-CRYSTAL TECHNOLOGY CO.,LTD
Specifications For Product
TYPE :
Quartz Crystal Oscillator
SPEC : CXO3225/27.120M/3.3V/±30PPM
83027120301
P/N :
VER
A/2
R&D APPR.SIGNATURED
ISSUE
CHECK
DEPT.
APPROVAL
Jiangsu HD-Crystal technology CO., Ltd
Add:NO 3,Dongxu Road,Lingang City,Jiangyin,Jiangsu Procince
Specification Revision Record Sheet
Rev.
Revise page
Revise Contents
Date
Ref. No.
Reviser
A/0
N/A
Initial released
2018/3/30
N/A
吴佳斌
A/1
N/A
P/N revision
2020/1/1
N/A
吴佳斌
A/2
4
package and pad layout change
2022/2/8
N/A
吴佳斌
www. hd- crystal.
com
1
Product Descipion
83027120301
1.
Scope:
1.1
This specification applies to the RoHS crystal
oscillator with a frequency of 27.120MHz which
will be used in electronic equipment.
2.
Construction:
2.1
Oscillators series: 83 series CXO3225
2.2
Package: SMD3.2×2.5
3.
Electrical Characteristics
3.1
Nominal Frequency:
27.120MHz
3.2
Frequency Stability:
±30ppm
(incl. 25°C tolerance, tolerance over
operating temperature range, input voltage
change, load change, 1 year aging)
±3ppm/year
3.3
3.4
Aging:
Operating Temperature Range:
-40 to + 85°C
3.5
Storage Temperature Range:
-55 to + 125°C
3.6
Input Voltage (VDD):
+3.3Vdc±10%
3.7
Input Current (IDD):
20mA max
3.8
Output Waveform:
CMOS
3.9
Output Symmetry:
50±10%
3.10 Rise/Fall Time:
8ns max
3.11 Output Voltage VOL:
10%VDD
VOH:
3.12 Output Load:
90%VDD
15pF
3.13 Output State Control:
Enable/disable
510ms max
3.14 Start-up Time:
3.15 Standby current:
10µA max
3.16 Phase Jitter (rms):
1ps rms max 12kHz to 20MHz max
3.17 Oscillation
mode:
Fundmental
3.18 Others:
Not recommended for safety applications
www. hd- crystal. com
2
Reliability Specification
Item
Condition
Free drop from 75cm height on a hard wooden
1.
Drop characteristics
board for 3 times. (Board is thickness more than
30 mm.)
2
Mechanical shock
Device are shocked to half sine wave (1000g)
three mutually perpendicular axes each 3 times
Shake frequency 10~55Hz, cyc1~2 minutes,
3.
Shake characteristics
swing 1.5mm, direction x/y/z, all 30 minutes, test
after 1 hours.
Humidity
4.
5.
6.
characteristics
Low temperature
characteristics
High temperature
characteristics
7.
Temperature cycling
8.
Refluence
examination
+40±2℃ & 90%~95% R.H. 250 hours
Standard
Frequency change:≤±5ppm
Rr as specification
Rr as specification
Rr as specification
Rr as specification
-40±2℃, 250 hours, put in room temperature,
test after 1 hours.
Rr as specification
+85±2℃, 250 hours, put in room temperature,
test after 1 hours.
Rr as specification
-40±2℃/30±3 min~+85±2℃/30±3min,
5 cycles
Rr as specification
Rr as specification
www. hd- crystal.
com
3
3DFNDJH2XWOLQH'LPHQVLRQV
Units:mm
6XJJHVWHG3DG/D\RXW
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1uF as close to the part
as possible between Vdd and GND pads.
www. hd- crystal.
com
4
Packing Specification
Qty:3000Pcs
www. hd- crystal.
com
5
很抱歉,暂时无法提供与“83027120301”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.88500
- 30+1.82000
- 100+1.69000
- 500+1.56000
- 1000+1.49500
- 国内价格
- 1+2.91006
- 10+2.28582
- 30+2.01960
- 100+1.68912
- 500+1.53306
- 1000+1.45044
