江苏浩都频 率科技有限公司
JIANGSU HD CRYSTAL TECHNOLOGY CO.,LTD
Specifications For Product
TYPE :
Quartz Crystal Oscillator
SPEC :
LVPECL/LVDS/HCSL
P/N
8X Series
VER
A/0
R&D APPR.SIGNATURED
ISSUE
CHECK
DEPT.
APPROVAL
Jiangsu HD-Crystal technology CO., Ltd
Add:NO 3,Dongxu Road,Lingang City,Jiangyin,Jiangsu Procince
Specification Revision Record Sheet
Rev.
Revise page
Revise Contents
Date
Ref. No.
Reviser
A/0
N/A
Initial released
2022/8/1
N/A
吴佳斌
www. hd- crystal.
com
1
Product Descipion
1.
Scope:
1.1
This specification applies to the RoHS crystal
oscillator with a frequency which will be used
in electronic equipment.
2.
Construction:
2.1
Oscillators series: LVPECL/LVDS/HCSL Crystal Oscillator
2.2
Package: SMD3.2×2.5
3.
Electrical Characteristics
LVPECL
Parameter
3.3V
Min
Max
Supply Voltage Variation(VDD)
Frequencu Range
LVDS
2.5V
Min
Max
3.3V
Min
Max
2.5V
Min
Max
VDD -5% VDD +5% VDD -5% VDD +5% VDD -5% VDD +5% VDD -5% VDD +5%
unit
V
10
250
10
250
10
250
10
250
MHz
70
70
50
50
mA
2.275
1.475
1.6
1.6
0.88
0.9
0.9
Transition Time: Rise/Fall Time +
1.68
1.0
1.0
1.0
1.0
nSec
Start Time
10
10
10
10
mSec
Tri-Start(Input to Pin 2 or Pin 1)
Enable (High voltage or floating)
Disable (Low voltage or GND)
2.31
1.75
2.31
1.75
0.99
0.75
0.99
0.75
RMS Phase Jitter
(Integrated 12KHz-20MHz)
Fo 80MHz
80MHz Fo 125MHz
1
1
1
1
0.5
0.5
0.5
0.5
0.3
0.3
0.3
0.3
Supply Current
10MHz
Fo
160MHz
Output Level Output High
Output Low
125MHz
Fo 160MHz
Phase Noise@ 156.25MHz
Aging(@25 °C 1 st year)
Storage Temp. Range
100Hz
1KHz
-95
-90
-90
-90
-125
-125
-120
-120
10KHz
-140
-140
±3
±3
-55
125
-55
125
-55
www. hd- crystal. com
2
V
pSec
dBc/Hz
-140
-140
V
±3
±3
ppm
125
-55
125
°C
Product Descipion
HCSL
Parameter
3.3V
Frequencu Range
Supply Current
25MHz
Fo
160MHz
unit
2.5V
Min
Max
Min
Max
VDD -5%
VDD +5%
VDD -5%
VDD +5%
V
25
175
25
175
MHz
mA
50
50
0.6
0.58
0.15
0.15
0.5
0.5
nSec
Start Time
10
10
mSec
0.7VDD
0.7VDD
0.3VDD
0.3VDD
0.5
0.5
±3
±3
pSec
ppm
-55
125
-55
125
°C
Output Low
Enable
Disable
RMS Phase Jitter
125MHz Fo 160MHz
Storage Temp. Range
V
V
Standard frequencise are frequencies which the crystal has been designed and does not imply a stoc k position.
+ Transition times are measured between 20% and 80% of V DD .
3
Reliability Specification
Item
Condition
Free drop from 75cm height on a hard wooden
1.
Drop characteristics
board for 3 times. (Board is thickness more than
30 mm.)
2
Mechanical shock
Device are shocked to half sine wave (1000g)
three mutually perpendicular axes each 3 times
Shake frequency 10~55Hz, cyc1~2 minutes,
3.
Shake characteristics
swing 1.5mm, direction x/y/z, all 30 minutes, test
after 1 hours.
Humidity
4.
5.
6.
characteristics
Low temperature
characteristics
High temperature
characteristics
7.
Temperature cycling
8.
Refluence
examination
9.
Others
+40±2℃ & 90%~95% R.H. 250 hours
Standard
Frequency change:≤±5ppm
Rr as specification
Rr as specification
Rr as specification
Rr as specification
-40±2℃, 250 hours, put in room temperature,
test after 1 hours.
Rr as specification
+85±2℃, 250 hours, put in room temperature,
test after 1 hours.
Rr as specification
-40±2℃/30±3 min~+85±2℃/30±3min,
5 cycles
Rr as specification
Rr as specification
www. hd- crystal.
com
4
3DFNDJH2XWOLQH'LPHQVLRQV
Units:mm
6XJJHVWHG3DG/D\RXW
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1uF as close to the part
as possible between Vdd and GND pads.
www. hd- crystal.
com
5
Packing Specification
Qty:3000Pcs
www. hd- crystal.
com
6
很抱歉,暂时无法提供与“8X0250003L1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+23.34474
- 10+19.90224
- 30+17.85510
- 100+15.78042
- 500+14.82570
- 1000+14.39424
- 国内价格
- 1+21.60000
- 10+20.80000
- 100+18.40000
- 500+17.92000
