XL-3216RGBC
XL-3216RGBC
    XINGLIGHT(成兴光)
    LED指示灯 三色 红色,翠绿色 蓝色(RGB) 1206 共阳极 正贴
XL-3216RGBC 数据手册
XL-3216RGBC Technical Data Sheet 1206七彩 Characteristic * 外观尺寸(L/W/H):3.2*1.6*0.8mm Outline Dimensions (L / w / h): 3.2x1.6x 0.8mm * 发光颜色及胶体: 高亮度RGB/透明胶体 Luminous color and colloid: high brightness RGB / transparent colloid * 环保工艺符合ROHS标准 Environmental protection meets ROHS standard * EIA规范标准包装 EIA standard packaging * 适用于SMT贴片自动化生产 And is suitable for automatic production of SMT patches * 适用于回流焊制程 Suitable for reflow soldering process Product application * 医用设备:内窥镜、血氧仪 Medical equipment: endoscope、oximeter * 汽车电子: 背光按键灯、指示灯 Automotive electronics: backlight key light、 indicator light * 工业产品:电子仪表盘、工业设备 Industrial products: electronic instrument panel、industrial equipment * 智能家居: 白色家电、数码管LED Smart home: white appliances, nixie tube LED * 通讯产品: 手机按键灯、路由器、电视盒 Communication products: mobile phone button lamp, router 1 Catalogue Electrical Characteristics.............................................................................................................................3 Reliability Test Items And Conditions........................................................................................................5 Typical photoelectric characteristic curve.................................................................................................. 6 Outline Dimensions......................................................................................................................................7 Packaging.......................................................................................................................................................8 Guideline for Soldering.............................................................................................................................. 10 Precautions....................................................................................................................................................12 2 Electrical Characteristics 极限参数 Limit parameters (Ta=25℃): 参数 parameter 消耗功率 Power consumption 最大脉冲电流(1/10占空比,0.1ms脉宽) Maximum pulse current (1 / 10 duty cycle, 0.1ms pulse width) 正向直流工作电流 Forward DC working current 反向电压 Reverse voltage 工作环境温度 Working ambient temperature 存储环境温度 Storage ambient temperature 焊接条件 Welding conditions 抗静电能力 Antistatic ability 符号 Symbol Pd IFP IF VR 最大额定值 Maximum rating R 55 G 80 B 80 R 100 G 100 B 100 R 25 G 25 B 25 R 5 G 5 B 5 Topr -30°C ~ + 85°C Tstg -40°C ~ + 90°C Tsol ESD 单位 unit mW mA mA V 回流焊Reflow soldering : 260°C ,10s 手动焊Manual welding : 300°C ,3s 2000 V 3 Electro-Optical Charasteristics 参数 parameter 符号 Symbol 光强 Lightintensity IV 半光强视角 Half light angle 峰值波长 Peak wavelength 主波长 Main wavelength 半波宽 Half wave width 正向电压 Forward voltage 反向电流 Reverse current 备注: Remarks: 2θ1/2 λP λD Δλ VF IR (Temperature=25°C) 颜色 colour 最小值 minimum value 代表值 Representat ive value 最大值 Maximum 红Red / 150 / 绿Green / 550 / 蓝Blue / 180 / / / 120 / 红Red / 630 / 绿Green / 530 / 蓝Blue / 470 / 红Red 620 / 630 绿Green 520 / 530 蓝Blue 465 / 475 红Red / 20 / 绿Green / 35 / 蓝Blue / 30 / 红Red 1.8 / 2.6 绿Green 2.8 / 3.5 蓝Blue 2.8 / 3.5 红Red / / 1 绿Green / / 1 蓝Blue / / 1 单位 Unit 测试条件 Test conditions mcd IF = 20mA deg IF = 20mA nm IF = 20mA nm IF = 20mA nm IF=20mA V IF=20mA uA VR=5V 1. 发光强度是由光纤和过滤器的组合测定的,因此接近视觉感应曲线 1. The luminous intensity is measured by the combination of optical fiber and filter, so it is close to the visual induction curve 2.半光强视角是轴向发光强度一半时的离轴角. 2. The angle of half light intensity is the off-axis angle when the axial luminous intensity is half 3. 主波长λd源自CIE色度图,代表单一的波长,它定义了器件的颜色 3. Main wavelength λ D is derived from CIE chromaticity diagram, representing a single wavelength, which defines the color of the device 4 : Brightness grading 颜色 Colour 代码 Code 最小值 Minimum value 最大值 Maximum 红Red I12 42 59 绿Green R58 220 280 蓝Blue I23 52 68 单位 Unit 测试条件 Test conditions mcd IF=20mA : Voltage grading 颜色 Colour 代码 Code 最小值 Minimum value 最大值 Maximum 红Red F4 1.9 2.1 绿Green A07 2.6 2.8 蓝Blue A07 2.6 2.8 颜色 Colour 代码 Code 最小值 Minimum value 最大值 Maximum 红Red HR21 619 624 绿Green HG07 525 528 蓝Blue HB05 466 469 单位 Unit 测试条件 Test conditions V IF=20mA 单位 Unit 测试条件 Test conditions nm IF=20mA : Wavelength grading 5 Reliability Test Items And Conditions 测试项目 Test items 测试条件 Test conditions 测试次数 Number of tests 参考标准 Reference standard 失效判 定 标准 Failure determi nation standar d --- JEITA ED4701 300.301 ﹟1 0/22 - JEITA ED4701 303 303A ﹟2 0/22 300 个循环 300 cycles JESD22A104 ﹟1 0/22 300 个循环 300 cycles JESD22A106 ﹟1 0/22 失效LED数 量(PCS) Number of failed LEDs (PCS) 1. 回流焊最高温度=260℃ ,10秒,2次回流焊; 1. Maximum temperature of reflow soldering =260 ℃, 10 防潮等级 Moisture proof grade seconds, 2 reflow soldering; 2.回流焊之前存储条件:30 ℃,相对湿度=70%,168H; 2. Storage conditions before reflow soldering: 30 ℃, relative humidity =70%, 168h; 回流焊最高温度=245±5℃, 焊接信赖性 (无铅回流焊) Welding reliability (lead free reflow soldering) 冷热循环 thermal cycling 冷热冲击 Thermal Shock 5秒(无铅回流焊) Maximum temperature of reflow soldering =245 ± 5 ℃, 5 seconds (lead-free reflow soldering) -40℃ 30分钟~25℃ 5分钟~ 100℃ 30分钟~25℃ 5分钟 -40 ℃ for 30 minutes ~ 25 ℃ for 5 minutes~ 100 ℃ for 30 minutes ~ 25 ℃ for 5 minutes -35℃ 15分钟 转换时间3分钟 85℃ 15分钟 -35 ℃ for 15 minutes Conversion time 3 minutes 85 ℃ for 15 minutes 6 高温存储 High temperature storage Ta=100℃ 1000 小时 1000 hours JESD22A103 ﹟1 0/22 低温存储 Low temperature storage Ta=-40℃ 1000 小时 1000 hours JESD22A119 ﹟1 0/22 常温老化 Normal temperature aging Ta=25℃ IF=20mA 1000小时 1000 hours JESD22A108 ﹟1 0/22 失效标准: Failure criteria 标准﹟ standard ﹟1 ﹟2 项目 project 测试条件 Test conditions 失效标准 Failure criteria 正向电压(VF) Forward voltage IF=20mA >U.S.L*1.1 光强(IV) light intensity IF=20mA <L.S.L*0.7 反向电流(IR) Reverse current VR=5V >U.S.L*2.0 焊接可靠性 Welding reliability / 锡膏覆盖焊盘比例小于95% The proportion of solder paste covering pad is less than 95% 7 典型光电特性曲线 Typical optical characteristics curves 8 外形 Outline Dimensions 备注: 1. 单位 : 毫米(mm) Remarks: 1. Unit: mm 2.公差 :如无特别标注则为± 0.10 mm 2. Tolerance: ± 0.10 mm unless otherwise specified 9 包装(1) Packaging (1) φ60 载带与圆盘尺寸 Belt and disc dimensions φ13.0 A U ser F eed D irection 备注: Remarks: A A-A剖面图 1. 尺寸单位为毫米(mm); 1. Dimensions are in millimeters (mm); 2.尺寸公差如无标注,为±0.15mm; 2. The dimensional tolerance is ± 0.15mm if not marked; 10 包装(2) Packaging (2) 11 1 Guideline for Soldering (1) 1. Hand Soldering 推荐使用功率低于 20W 的烙铁,焊接时烙铁的温度必须保持在 300℃以下,且每个电极只能进行一次焊 接,每次焊接的持续时间不得超过 3 秒。 人手焊接过程中的不慎操作易引起 LED 产品的损坏,应当小心谨慎。 A soldering iron of less than 20W is recommended to be used in Hand Soldering. Please keep the temperature of the soldering iron under 300℃ while soldering. Each terminal of the LED is to go for less than 3 second and for one time only. Be careful because the damage of the product is often started at the time of the hand soldering. 2. 推荐使用以下无铅回流焊接温度图进行。 Reflow Soldering: Use the conditions shown in the under Figure ofPb-Free Reflow Soldering · 回流焊接最多只能进行一次。 Reflow soldering should not be done more than once . · 在回流焊接升温过程中,请不要对 LED 施加任何压力。 Stress on the LEDs should be avoided during heating in soldering process. · 在焊接完成后,待产品温度下降到室温之后,再进行其他处理。 After soldering, do not deal with the product before its temperature drop down to room temperature. 建议焊接温度曲线: Recommended welding curve temperature 有铅制程 Lead process 无铅制程 Lead-free Process 12 2 Guideline for Soldering (2) 3. Cleaning 在焊接后推荐使用酒精进行清洗,在温度不高于 30℃的条件下持续 3 分钟, 不高于 50℃的条件下持续 30 秒。使用其他类似溶剂清洗前,请先确认使用的溶剂不会对 LED 的封装和环氧树脂部分造成损伤。 超声波清洗也是有效的方法,一般最大功率不应超过 300W ,否则可能对 LED 造成损伤。请根据具体的 情况预先测试清洗条件是否会对 LED 造成损伤。 It is recommended that alcohol be used as a solvent for cleaning after soldering. Cleaning is to go under 30℃ for 3 minutes or 50℃ for 30 seconds. When using other solvents, it should be confirmed beforehand whether the solvents will dissolve the package and the resin or not. Ultrasonic cleaning is also an effective way for cleaning. But the influence of Ultrasonic cleaning on LED depends on factors such as ultrasonic power. Generally, the ultrasonic power should not be higher than 300W. Before cleaning, a pretest should be done to confirm whether any damage to LEDs will occur. 此一般指导原则并不适用于所有 PCB 设计和焊接设备的配置。具体工艺受到诸多因素的影响, 请根据特定的PCB设计和焊接设备来确定焊接方案。 Note: This general guideline may not apply to all PCB designs and configurations of all soldering equipment. The technics in practise is influenced by many factors, it should be specialized base on the PCB designs and configurations of the soldering equipment.. 13 1 Precautions (1) 1. Storage · 本产品使用密封防潮抗静电袋包装,并附有干燥剂,未开封的产品有一年的保存时间。 Moisture proof and anti-electrostatic package with moisture absorbent material is used, to keep moisture to a minimum. · 开封前,产品须存放在温度不高于 30℃,湿度不高于 60%RH 的环境中。 Before opening the package, the product should be kept at 30℃ or less and humidity less than 60% RH, and be used within a year. · 开封后,产品须存放在温度不高于 30℃,湿度不高于 10%RH 的环境中,且应该在 168 小时(7 天) 内使 用完。建议工作环境为温度不高于 30℃,湿度不高于 60%RH。 After opening the package, the product should be stored at 30℃ or less and humidity less than 10%RH, and be soldered within 168 hours (7 days). It is recommended that the product be operated at the workshop condition of 30℃ or less and humidity less than 60%RH. · 对于尚未焊接的 LED,如果吸湿剂或包装失效,或者产品没有符合以上有效存储条件,烘焙可以起到一定 的性能恢复效果。烘焙条件: (60±5)℃,持续 24 小时。 If the moisture absorbent material has fade away or the LEDs have exceeded the storage time, baking treatment should be performed based on the following condition: (60±5)℃ for 24 hours. 2. Static Electricity 静电和电涌会导致产品特性发生改变,例如正向电压降低等,如果情况严重甚至会损毁产品。所以在使用时必须采 取有效的防静电措施。 所有相关的设备和机器都应该正确接地,同时必须采取其他防止静电和电涌的措施。 使用防静电手环,防静电垫子,防静电工作服、工作鞋、手套,防静电容器,都是有效的防止静电和电涌的措施。 Static electricity or surge voltage damages the LEDs. Damaged LEDs will show some unusual characteristic such as the forward voltage becomes lower, or the LEDs do not light at the low current. even not light. All devices, equipment and machinery must be properly grounded. At the same time, it is recommended that wrist bands or anti-electrostatic gloves, anti-electrostatic containers be used when dealing with the LEDs. 14 2 Precautions (2) 3. Design Consideration 设计电路时,通过 LED 的电流不能超过规定的最大值,同时,还需使用保护电阻,否则,微小的电压变 化将会引起较大的电流变化,可能导致产品损毁。 建议使用以下(A)电路,该电路能够很好的调节通过每个 LED 的电流; 不推荐使用(B)电路,该电路 在持续的电压驱动下,LED 的正向电压(VF )发生变化,电流会随之而发生变化,可能使某些 LED 承 受高于规定的电流值。 In designing a circuit, the current through each LED must not exceed the absolute maximum rating specified for each LED. In the meanwhile, resistors for protection should be applied, otherwise slight voltage shift will cause big current change, burn out may happen. It is recommended to use Circuit A which regulates the current flowing through each LED rather than Circuit B. When driving LEDs with a constant voltage in Circuit B, the current through the LEDs may vary due to the variation in Forward Voltage (VF) of the LEDs. In the worst case, some LED may be subjected to stresses in excess of the Absolute Maximum Rating. (A) (B) LED 的特性容易因为自身的发热和环境的温度的改变而发生改变。温度的升高会降低 LED 的发光效率、 影响发光颜色等,所以在设计时应充分考虑散热的问题。 Thermal Design is paramount importance because heat generation may result in the Characteristics decline, such as brightness decreased, Color changed and so on. Please consider the heat generation of the LEDs when making the system design. 15 3 Precautions (3) 4. Others 直接用手拿取产品不但会污染封装树脂表面,也可能由于静电等因素导致产品性能的改变。过度的压力也可能直接 影响封装内部的管芯和金线,因此请勿对产品施加过度压力,特别当产品处于高温状态下,例如在回流焊接过程中。 When handling the product, touching the encapsulant with bare hands will not only contaminate its surface, but also affect on its optical characteristics. Excessive force to the encapsulant might result in catastrophic failure of the LEDs due to die breakage or wire deformation. For this reason, please do not put excessive stress on LEDs, especially when the LEDs are heated such as during Reflow Soldering. LED 的环氧树脂封装部分相当脆弱,请勿用坚硬、尖锐的物体刮、擦封装树脂部分。在用镊子夹取的时 候也应当小心注意。 The epoxy resin of encapsulant is fragile, so please avoid scratch or friction over the epoxy resin surface. While handling the product with tweezers, do not hold by the epoxy resin, be careful. 不可用在PH
XL-3216RGBC 价格&库存
很抱歉,暂时无法提供与“XL-3216RGBC”相匹配的价格&库存,您可以联系我们找货
XL-3216RGBC
  • 1+0.39380
  • 200+0.25410
  • 1500+0.22110
  • 3000+0.19470
库存:4740
XL-3216RGBC
  • 20+0.77230
  • 100+0.47450
  • 800+0.33210
  • 3000+0.23720
  • 6000+0.22540
  • 30000+0.20870
库存:245347
XL-3216RGBC
  • 1+0.21000
  • 30+0.20250
  • 100+0.19500
  • 500+0.18000
  • 1000+0.17250
  • 2000+0.16800
