XL-2012UBC-DS
Technical Data Sheet
0805单闪蓝
haracteristic
* 外观尺寸(L/W/H):2.0*1.2*0.8mm
OutlineDimensions (L / w / h): 2.0 x 1 . 2 x 0.8mm
* 发光颜色及胶体: 高亮度蓝色/透明胶体
Luminous color and colloid: high brightness Blue / transparent colloid
* 环保工艺符合ROHS要求
Environmental protection products Complied With RoHS Directive
* EIA规范标准包装
EIA standard packaging
* 适用于SMT贴片自动化生产
Suitable for SMT automatic production
* 适用于回流焊制程
Suitable for reflow soldering process
* 闪烁频率1.5Hz,频率容许误差:±30%
Flicker frequency: 1.5Hz, allowable frequency error: ± 30%
* 正输出,上电长闪
Positive output, power on long flash
roduct application
* 医用设备:内窥镜、血氧仪
Medical equipment: endoscope、oximeter
* 汽车电子: 背光按键灯、指示灯
Automotive electronics: backlight key light、 indicator light
* 工业产品:电子仪表盘、工业设备
Industrial products: electronic instrument panel、industrial equipment
* 智能家居: 白色家电、数码管LED
Smart home: white appliances, nixie tube LED
* 通讯产品: 手机按键灯、路由器、电视盒
Communication products: mobile phone button lamp, router
1
Catalogue
Electrical Characteristics.............................................................................................................................3
Reliability Test Items And Conditions....................................................................................................... 4
Outline Dimensions.......................................................................................................................................5
Packaging...................................................................................................................................................... 6
Guideline for Soldering.............................................................................................................................. 8
Precautions....................................................................................................................................................10
2
Electro-Optical Charasteristics (Temperature=25°C):
参数
Parameter
测试条件
Test
Condition
符号
Symbol
最小值
minimum
value
代表值
Representa
tive value
最大值
Maximum
单位
Unit
光强
light intensity
IF =20mA
IV
180
mcd
半光强视角
Half light angle
IF =20mA
2θ1/2
120
deg
主波长
Main wavelength
IF =20mA
λD
467
nm
半波宽
Half wave width
IF =20mA
Δλ
30
nm
Electrical specifications ( VDD=3V , TA=25℃ Unless otherwise defined)
特性
Characteristic
符号
Symbol
最小
Min
典型Typ
最大
Max
单位
Unit
备注
Note
工作电压
Operating Voltage
VDD
2.0
3.0
4.5
V
工作电流
Operating Current
IDD
0.1
0.2
mA
No load
驱动电流
Driving Current
IOL
25
mA
@VDS=1.0V
工作温度
Operating Temperature
Temp.
60
3
Brightness grading
Code
Min
Max
Unit
J37
150
300
mcd
IF=20mA
Code
Min
Max
Unit
Test conditions
A31
2.0
4.5
V
Test conditions
Voltage grading
IF=20mA
Wavelength division:
Code
Min
Max
Unit
Test conditions
TB37
460
470
nm
IF=20mA
4
Operation
Sequence
Environmental
Sequence
类
别
Typ
e
*1
备注
Note
数量
Quantity
不良数量
Number of
Damaged
100 cycle
22
50 cycle
22
10 cycle
22
Ta=80°C
1000hrs
22
JIS C 7021 (1977)B11
Ta=60°C
RH=90%
1000hrs
JIS C 7021 (1977)B12
Ta=-30°C
1000hrs
JIS C 7035 (1985)
Ta=25°C
IF=20mA
1000hrs
22
60°C RH=90%
IF=20mA
500hrs
22
Ta=-25°C
IF=20mA
1000hrs
22
测试项目
Test item
源科参照标准
YK. Standard
高低温循环
Temperature Cycle
JIS C 7021
(1977)A-4
热冲击
Thermal Shock
MIL-SLD-107D
高温度热循环
High Humidity Heat Cycle
JIS C 7021 (1977)A5
高温存储
High Temperature
Storage
高温高湿存储
Humidity Heat Storage
低温存储
Low Temperature Storage
JIS C 7021 (1977)B10
常温寿命测试 Life Test
高温高湿寿命测试
High Humidity Heat Life
Test
低温寿命测试
Low Temperature Life
Test
测试条件
Test Conditions
-25°C 30min
↑↓5min
80°C 30min
-25°C 15min
↑↓5min
80°C 15min
30°C〈=〉65°C
90%RH
24hrs/1cycle
22
22
Criteria For Judging Damage
测试项目
符号
测试条件
正向电压
Forward Voltage
VF
IF=IFT
反向电流
Reverse Current
IR
VR=5V
光强
Luminous Intensity
IV
IF=IFT
耐焊接热
Resistance to Soldering Heat
判定标准
初始值±10℅
Initial Data±10℅
IR≦10μA
平均IV衰减≦30℅,单个平均IV衰减≦50℅
Average IV degradation≦30℅
Single LED IV degradation≦50℅
材料无内部裂痕、无材料间爆裂、剥离、无死灯
Meterial without internal cracks, no material
between stripped, no deaded light.
*数据工作表中所示的技术信息仅限于典型特征和电路实例引用的产品.它既不构成工业特性的保证,也不构成任何许可的授权
The technical information shown in the data sheets are limited to the typical characteristics and circuit examples of the referenced products. It does
not constitute the warranting of industrial property nor the granting of any license.
5
外形
Outline Dimensions
备注:
Remarks:
1.单位:毫米(mm)
1. Unit: mm
2.公差: 如无特别标注则为±0.10mm
2. Tolerance: ± 0.10mm unless otherwise specified
6
包装(1)
Packaging
φ60
Belt and disk dimensions
φ13.0
A
U ser F eed D irection
备注:
Remarks:
A
A-A剖面图
1.单位:毫米(mm)
1. Unit: mm
7
包装(2)
Packaging (2)
8
1
Guideline for Soldering (1)
1.
Hand Soldering
推荐使用功率低于 20W 的烙铁,焊接时烙铁的温度必须保持在 300℃以下,且每个电极只能进行一次焊
接,每次焊接的持续时间不得超过 3 秒。
人手焊接过程中的不慎操作易引起 LED 产品的损坏,应当小心谨慎。
A soldering iron of less than 20W is recommended to be used in Hand Soldering. Please keep the temperature of
the soldering iron under 300℃ while soldering. Each terminal of the LED is to go for less than 3 second and for one
time only.
Be careful because the damage of the product is often started at the time of the hand soldering.
2.
推荐使用以下无铅回流焊接温度图进行。
Reflow Soldering: Use the conditions shown in the under Figure ofPb-Free Reflow Soldering.
有铅制程Lead process
无铅制程Lead free
· 回流焊接最多只能进行一次。
Reflow soldering should not be done more than once .
· 在回流焊接升温过程中,请不要对 LED 施加任何压力。
Stress on the LEDs should be avoided during heating in soldering process.
· 在焊接完成后,待产品温度下降到室温之后,再进行其他处理。
After soldering, do not deal with the product before its temperature drop down to room temperature.
9
2
Guideline for Soldering (2)
3.
Cleaning
在焊接后推荐使用酒精进行清洗,在温度不高于 30℃的条件下持续 3 分钟, 不高于 50℃的条件下持续 30
秒。使用其他类似溶剂清洗前,请先确认使用的溶剂不会对 LED 的封装和环氧树脂部分造成损伤。
超声波清洗也是有效的方法,一般最大功率不应超过 300W ,否则可能对 LED 造成损伤。请根据具体的
情况预先测试清洗条件是否会对 LED 造成损伤。
It is recommended that alcohol be used as a solvent for cleaning after soldering. Cleaning is to go under 30℃ for
3 minutes or 50℃ for 30 seconds. When using other solvents, it should be confirmed beforehand whether the solvents
will dissolve the package and the resin or not.
Ultrasonic cleaning is also an effective way for cleaning. But the influence of Ultrasonic cleaning on LED
depends on factors such as ultrasonic power. Generally, the ultrasonic power should not be higher than 300W. Before
cleaning, a pretest should be done to confirm whether any damage to LEDs will occur.
此一般指导原则并不适用于所有 PCB 设计和焊接设备的配置。具体工艺受到诸多因素的影响,
请根据特定的PCB设计和焊接设备来确定焊接方案。
Note: This general guideline may not apply to all PCB designs and configurations of all soldering equipment.
The technics in practise is influenced by many factors, it should be specialized base on the PCB designs
and configurations of the soldering equipment..
10
1
Precautions (1)
1.
Storage
· 本产品使用密封防潮抗静电袋包装,并附有干燥剂,未开封的产品有一年的保存时间。
Moisture proof and anti-electrostatic package with moisture absorbent material is used, to keep moisture to a
minimum.
· 开封前,产品须存放在温度不高于 30℃,湿度不高于 60%RH 的环境中。
Before opening the package, the product should be kept at 30℃ or less and humidity less than 60% RH, and be
used within a year.
· 开封后,产品须存放在温度不高于 30℃,湿度不高于 10%RH 的环境中,且应该在 168 小时(7 天) 内使
用完。建议工作环境为温度不高于 30℃,湿度不高于 60%RH。
After opening the package, the product should be stored at 30℃ or less and humidity less than 10%RH, and be
soldered within 168 hours (7 days). It is recommended that the product be operated at the workshop condition of
30℃ or less and humidity less than 60%RH.
· 对于尚未焊接的 LED,如果吸湿剂或包装失效,或者产品没有符合以上有效存储条件,烘焙可以起到一定
的性能恢复效果。烘焙条件: (60±5)℃,持续 24 小时。
If the moisture absorbent material has fade away or the LEDs have exceeded the storage time, baking treatment
should be performed based on the following condition: (60±5)℃ for 24 hours.
2.
Static Electricity
静电和电涌会导致产品特性发生改变,例如正向电压降低等,如果情况严重甚至会损毁产品。所以在使用时必须采
取有效的防静电措施。
所有相关的设备和机器都应该正确接地,同时必须采取其他防止静电和电涌的措施。
使用防静电手环,防静电垫子,防静电工作服、工作鞋、手套,防静电容器,都是有效的防止静电和电涌的措施。
Static electricity or surge voltage damages the LEDs. Damaged LEDs will show some unusual characteristic such
as the forward voltage becomes lower, or the LEDs do not light at the low current. even not light.
All devices, equipment and machinery must be properly grounded. At the same time, it is recommended that wrist
bands or anti-electrostatic gloves, anti-electrostatic containers be used when dealing with the LEDs.
11
2
Precautions (2)
3.
Design Consideration
设计电路时,通过 LED 的电流不能超过规定的最大值,同时,还需使用保护电阻,否则,微小的电压变
化将会引起较大的电流变化,可能导致产品损毁。
建议使用以下(A)电路,该电路能够很好的调节通过每个 LED 的电流; 不推荐使用(B)电路,该电路
在持续的电压驱动下,LED 的正向电压(VF )发生变化,电流会随之而发生变化,可能使某些 LED 承受高于
规定的电流值。
In designing a circuit, the current through each LED must not exceed the absolute maximum rating specified for
each LED. In the meanwhile, resistors for protection should be applied, otherwise slight voltage shift will cause big
current change, burn out may happen.
It is recommended to use Circuit A which regulates the current flowing through each LED rather than Circuit B.
When driving LEDs with a constant voltage in Circuit B, the current through the LEDs may vary due to the variation
in Forward Voltage (VF) of the LEDs. In the worst case, some LED may be subjected to stresses in excess of the
Absolute Maximum Rating.
(A)
(B)
LED 的特性容易因为自身的发热和环境的温度的改变而发生改变。温度的升高会降低 LED 的发光效率、
影响发光颜色等,所以在设计时应充分考虑散热的问题。
Thermal Design is paramount importance because heat generation may result in the Characteristics decline,
such as brightness decreased, Color changed and so on. Please consider the heat generation of the LEDs when
making the system design.
12
3
Precautions (3)
4.
Others
直接用手拿取产品不但会污染封装树脂表面,也可能由于静电等因素导致产品性能的改变。过度的压力也可能直接
影响封装内部的管芯和金线,因此请勿对产品施加过度压力,特别当产品处于高温状态下,例如在回流焊接过程中。
When handling the product, touching the encapsulant with bare hands will not only contaminate its surface, but
also affect on its optical characteristics. Excessive force to the encapsulant might result in catastrophic failure of the
LEDs due to die breakage or wire deformation. For this reason, please do not put excessive stress on LEDs, especially
when the LEDs are heated such as during Reflow Soldering.
LED 的环氧树脂封装部分相当脆弱,请勿用坚硬、尖锐的物体刮、擦封装树脂部分。在用镊子夹取的时
候也应当小心注意。
The epoxy resin of encapsulant is fragile, so please avoid scratch or friction over the epoxy resin surface. While
handling the product with tweezers, do not hold by the epoxy resin, be careful.
不可用在PH
很抱歉,暂时无法提供与“XL-2012UBC-DS”相匹配的价格&库存,您可以联系我们找货
