XL-6028UWC-FB
Technical Data Sheet
6028反编白
haracteristic
* 外观尺寸(L/W/H):5.88*2.8*1.7 mm
OutlineDimensions (L / w / h): 5.88 x 2 . 8 x 1.7 mm
* 发光颜色及胶体: 白色/透明胶体
Luminous color and colloid: white /Transparent colloid
* 环保工艺符合ROHS要求
Environmental protection products Complied With RoHS Directive
* EIA规范标准包装
EIA standard packaging
* 适用于SMT贴片自动化生产
Suitable for SMT automatic production
* 适用于回流焊制程
Suitable for reflow soldering process
roduct application
* 使用表面贴装结构的电子产品中,如:机械键盘、汽车仪器等
In electronic products using surface mount structure, such as mechanical keyboard, automobile instrument, etc
* LED显示屏
LED display
* 外部和内部照明应用
Exterior and interior lighting applications
* 装饰和娱乐照明
Decorative and recreational lighting
1
Catalogue
Electrical Characteristics.............................................................................................................................3
Typical Characteristic Curves.....................................................................................................................4
Outline Dimensions.......................................................................................................................................5
Packaging.......................................................................................................................................................6
Guideline for Soldering..............................................................................................................................8
Precautions....................................................................................................................................................10
2
(温度=25℃) Absoiute Maximum Ratings
项目
Item
符号
Symbol
最大额定值
Absolute Maximum Ratig
单位
Unit
功率消耗
Pd
60
mW
IFP
30
mA
IF
mA
VR
5
V
Power Dissipation
正向峰值电流 1/10占空比,0.1ms脉冲宽
度
Pulse Forward Current 1/10 Duty Cycle,0.1ms Pulse
Width
正向电流
Forward Current
反向电压
Rcverse Voltage
工作温度
Operating Temperature
贮藏温度
Storage Temperature
焊接温度 【离车身3mm】
Soldering Temperature 【3mm From Body】
Topr
-40℃ to+100℃
Tstg
-40℃ to+110℃
Tsol
260℃ For 5 Seconds
Electro-Optical Charasteristics (Temperature=25°C):
数值 Value
Parameter
Symbol
测试条件
Condition
正向电压Forward Voltage
VF
IF=20mA
反向电流 Reverse Current
IR
VR=5V
1
μA
发光强度Luminous intensity
IV
IF=20mA
8
9
lm
色温Color temperature
CCT
IF=20mA
10000
12000
K
显色指数Color RenderingIndex
CRI
IF=20mA
80
Ra
谱线半宽Spectrum line half width
Δλ
IF=20mA
60
70
nm
观察角度Viewing Angle
2θ1/2
IF=20mA
120
140
deg
参数名称
NOTE:
符号
最小Min
典型Typ
最大Max
3.0
3.2
3.2
3.4
单位
Unit
V
1.发光强度公差:11%;Tolerance of Luminous Intensity:11%
2.主长容差:+1nm;Tolerance of Dominant Wavelength:+1nm
3.正向电压耐受值:+0.1V;Toleance of Forward Voltage:+0.1V
3
Brightness grading
Min
Max
Unit
8
9
LM
Code
Min
Max
Unit
A09
3.0
3.2
A10
3.2
3.4
Min
Max
Code
K07
Test conditions
IF=20mA
Voltage grading
V
Test conditions
IF=20mA
Wavelength division:
Code
HW4
10000
12000
Unit
K
Test conditions
IF=20mA
4
Typical Characteristics Curves
4
Outline Dimension
注(Note):
1. 单位 : 毫米(mm) Unit: mm
2. 公差 :如无特别标注则为± 0.1 mm
Tolerances: ± 0.1 mm if unmarked.
5
1
Packaging (1)
编带包装 Fabric with packaging
注:
1. 尺寸单位为毫米(mm)。
1. Size unit is mm (mm).
2. 尺寸公差是±0.1mm。
2. The dimensional tolerance is ± 0.1mm.
卷轴尺寸 Scroll size
备注NOTE:
1.所有尺寸单位均为mm,除非另有说明,否则公差为±2.0mm。
All dimensions are in mm, tolerance is±2.0mm unless otherwise noted.
2.规格如有变更,恕不另行通知。
Specifications are subject to change without notice.
6
2
Packaging (2)
7
1
Guideline for Soldering (1)
1.铅型和无铅型回流机的温度分布 Temperature profile in re-flow machine for lead type and lead free type
2.焊接条件 Soldering condition
预热
Pre-heat
预热时间
Pre-heat time
峰值温度
Peak temperature
焊接时间
Soldering time
条件
Condition
回流焊Reflow Soldering
铅焊料
Lead Solder
120~150℃
无铅焊料
Lead – free Solder
180~200℃
120sec. Max.
120sec. Max.
240℃ Max.
260℃ Max.
10sec. Max.
10sec. Max.
参见温度剖面图1
refer toTemperatureProfile 1
手工焊接Hand Soldering
温度
Temperature
最大350℃
350℃ Max.
焊接时间
Soldering time
最大值3秒
(仅一次)
3sec. Max.
(one time only)
参见温度剖面图2
refer toTemperatureProfile 2
8
2
Guideline for Soldering (2)
3.清洗 Cleaning
在焊接后推荐使用酒精进行清洗,在温度不高于 30℃的条件下持续 3 分钟, 不高于 50℃的条件下持续 30
秒。使用其他类似溶剂清洗前,请先确认使用的溶剂不会对 LED 的封装和环氧树脂部分造成损伤。
超声波清洗也是有效的方法,一般最大功率不应超过 300W ,否则可能对 LED 造成损伤。请根据具体的
情况预先测试清洗条件是否会对 LED 造成损伤。
It is recommended that alcohol be used as a solvent for cleaning after soldering. Cleaning is to go under 30℃ for
3 minutes or 50℃ for 30 seconds. When using other solvents, it should be confirmed beforehand whether the solvents
will dissolve the package and the resin or not.
Ultrasonic cleaning is also an effective way for cleaning. But the influence of Ultrasonic cleaning on LED
depends on factors such as ultrasonic power. Generally, the ultrasonic power should not be higher than 300W. Before
cleaning, a pretest should be done to confirm whether any damage to LEDs will occur.
此一般指导原则并不适用于所有 PCB 设计和焊接设备的配置。具体工艺受到诸多因素的影响,
请根据特定的PCB设计和焊接设备来确定焊接方案。
Note: This general guideline may not apply to all PCB designs and configurations of all soldering equipment.
The technics in practise is influenced by many factors, it should be specialized base on the PCB designs
and configurations of the soldering equipment..
9
1
Precautions (1)
1.
How to choose the collet
吸嘴设置不当时产生的异常: (Abnormal situation caused by improper setting of collet)
选取合适的吸嘴是提高产品品质的关健所在,因 LED 与其它电子元件不同,它所承担的不只是电性的输出
还有光学部份的输出,因此特性就决定了 LED 的命运在 SMT 过程中变的比较脆弱。若机器吸嘴下压高度
设置的不当,即当吸嘴在吸起和放下材料的时候都有可能造成对 LED 的不亮或闪烁及品质问题。
To choose the right collet is the key issue in improving the product’s quality.LED is different
from other electronic components, which is not only about electrical output but also for optical
output. This If the collet!ˉs lowering down height is not well set,it will bring damage to the
gold wire at the time of collet!ˉs picking up and loaing which will cause the LED fail to light
up, light up now and then or other quality problems.
2.
客户在 SMT 时直径尽量选择比 LED(胶体)发光面大的吸嘴防止吸嘴下压高度设置的不当造成对 LED 内
部金线的损坏。根据不同产品吸嘴选取如下图:
During SMT, please choose the collet that has larger outer diameter than the lighting area of lens, in case that
improper position of collet will damage the gold wire inside the LED. Different collets fit for different
products, please efer to the following pictures cross out.
3.
Store
为避免受潮的影响,我司建议产品在未开包装前储存条件为 5-30°C,相对湿度小于 60%;已开包装的LED
光源请在 24H 内使用安装完毕,如未用完之产品,请进行除湿并抽真空后密封保存。开封超过一周或湿度
卡发生变化时,请务必进行除湿,除湿条件:60°C±5°C,12H;产品密封保存有效使用期为一年。
To avoid moisture, we recommend storage conditions for the unopened LED +5 ~ +30 °C, relative
hu- midity
很抱歉,暂时无法提供与“XL-6028UWC-FB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.20787
- 200+0.16396
- 600+0.13954
- 2000+0.11995
- 10000+0.10723
- 20000+0.10035
- 国内价格
- 50+0.11165
- 500+0.10395
- 1500+0.09625
- 5000+0.09009
- 20000+0.08624
- 国内价格
- 1+0.23980
- 50+0.11990
- 2000+0.09086
