XL-6028UGC-FB
XL-6028UGC-FB
    XINGLIGHT(成兴光)
    SMD,6x2.8mm
    发光二极管/LED 翠绿色 SMD,6x2.8mm 510nm~530nm 1600mcd
XL-6028UGC-FB 数据手册
XL-6028UGC-FB Technical Data Sheet 6028反编翠绿 haracteristic * 外观尺寸(L/W/H):6.0*2.8mm OutlineDimensions (L / w / h): 6.0*2.8mm * 发光颜色及胶体: 翠绿/透明胶体 Luminous color and colloid: green/Transparent colloid * 环保工艺符合ROHS要求 Environmental protection products Complied With RoHS Directive * EIA规范标准包装 EIA standard packaging * 适用于SMT贴片自动化生产 Suitable for SMT automatic production * 适用于回流焊制程 Suitable for reflow soldering process roduct application * 使用表面贴装结构的电子产品中,如:机械键盘、汽车仪器等 In electronic products using surface mount structure, such as mechanical keyboard, automobile instrument, etc * LED显示屏 LED display * 外部和内部照明应用 Exterior and interior lighting applications * 装饰和娱乐照明 Decorative and recreational lighting 1 Catalogue Electrical Characteristics.............................................................................................................................3 Typical Characteristic Curves.....................................................................................................................4 Outline Dimensions.......................................................................................................................................5 Packaging.......................................................................................................................................................6 Guideline for Soldering..............................................................................................................................8 Precautions....................................................................................................................................................10 2 Electrical Characteristics (温度=25℃) Absoiute Maximum Ratings(Temperature=25°C): 项目 符号 Item Symbol 功率消耗 Power Dissipation 正向峰值电流 1/10占空比,0.1ms脉冲宽度 Pulse Forward Current 1/10 Duty Cycle,0.1ms Pulse Width 正向电流 Forward Current 反向电压 Rcverse Voltage Pd 100 mW IFP 80 mA IF 20 mA VR 5 V 工作温度 Operating Temperature 贮藏温度 Storage Temperature 焊接温度 【离车身3mm】 Soldering Temperature 【3mm From Body】 最大额定值 单位 Absolute Maximum Ratig Unit Topr -40℃ to+100℃ Tstg -40℃ to+110℃ Tsol 260℃ For 5 Seconds Electro-Optical Charasteristics (Temperature=25°C): 符号 测试条件 Parameter Symbol Condition 正向电压 Forward Voltage VF IF=20mA IF=2mA IF=5mA 2.8 2.4 2.5 -2 .6 2 .7 3 .1 2 .8 2 .9 反向电流 Reverse Current IR VR=5V -- -- 5 IF=20mA 1 2 -- IF=2mA 0.1 0. 5 1.0 IF=5mA 0.2 0 .7 1.2 最小Min 典型Typ 最大Max 单位 Unit V μA 发光强度 Luminous intensity IV 观察角度 Viewing Angle 主波长 2θ1/2 IF=20mA -- 120 -- deg λd IF=5mA 520 -- 525 nm Dominant Wavelength NOTE: 数值 Value 参数名称 lm 1.发光强度公差:11%;Tolerance of Luminous Intensity:11% 2.主波长容差:+1nm;Tolerance of Dominant Wavelength:+1nm 3.正向电压耐受值:+0.1V;Toleance of Forward Voltage:+0.1V 3 : Brightness grading Code Min Max Unit Z03 1400 1700 mcd Test conditions IF=5mA : Voltage grading Code Min Max Unit A10 3.2 3.4 V Min Max Unit 519 522 nm Test conditions IF=5mA : Wavelength division: Code HG05 Test conditions IF=5mA 5 Typical Characteristics Curves 5 Outline Dimension 注(Note): 1. 单位 : 毫米(mm) Unit: mm 2. 公差 :如无特别标注则为± 0.1 mm Tolerances: ± 0.1 mm if unmarked. 6 1 Packaging (1) 编带包装 Fabric with packaging 注: 1. 尺寸单位为毫米(mm)。 1. Size unit is mm (mm). 2. 尺寸公差是±0.1mm。 2. The dimensional tolerance is ± 0.1mm. 卷轴尺寸 Scroll size 备注NOTE: 1.所有尺寸单位均为mm,除非另有说明,否则公差为±2.0mm。 All dimensions are in mm, tolerance is±2.0mm unless otherwise noted. 2.规格如有变更,恕不另行通知。 Specifications are subject to change without notice. 7 2 Packaging (2) 8 1 Guideline for Soldering (1) 1.铅型和无铅型回流机的温度分布 Temperature profile in re-flow machine for lead type and lead free type 2.焊接条件 Soldering condition 回流焊Reflow Soldering 预热 Pre-heat 预热时间 Pre-heat time 峰值温度 Peak temperature 焊接时间 Soldering time 条件 Condition 手工焊接Hand Soldering 铅焊料 Lead Solder 120~150℃ 无铅焊料 Lead – free Solder 180~200℃ 120sec. Max. 120sec. Max. 240℃ Max. 260℃ Max. 10sec. Max. 10sec. Max. 参见温度剖面图1 refer toTemperatureProfile 1 温度 Temperature 最大350℃ 350℃ Max. 焊接时间 Soldering time 最大值3秒 (仅一次) 3sec. Max. (one time only) 参见温度剖面图2 refer toTemperatureProfile 2 9 2 Guideline for Soldering (2) 3.清洗 Cleaning 在焊接后推荐使用酒精进行清洗,在温度不高于 30℃的条件下持续 3 分钟, 不高于 50℃的条件下持续 30 秒。使用其他类似溶剂清洗前,请先确认使用的溶剂不会对 LED 的封装和环氧树脂部分造成损伤。 超声波清洗也是有效的方法,一般最大功率不应超过 300W ,否则可能对 LED 造成损伤。请根据具体的 情况预先测试清洗条件是否会对 LED 造成损伤。 It is recommended that alcohol be used as a solvent for cleaning after soldering. Cleaning is to go under 30℃ for 3 minutes or 50℃ for 30 seconds. When using other solvents, it should be confirmed beforehand whether the solvents will dissolve the package and the resin or not. Ultrasonic cleaning is also an effective way for cleaning. But the influence of Ultrasonic cleaning on LED depends on factors such as ultrasonic power. Generally, the ultrasonic power should not be higher than 300W. Before cleaning, a pretest should be done to confirm whether any damage to LEDs will occur. 此一般指导原则并不适用于所有 PCB 设计和焊接设备的配置。具体工艺受到诸多因素的影响, 请根据特定的PCB设计和焊接设备来确定焊接方案。 Note: This general guideline may not apply to all PCB designs and configurations of all soldering equipment. The technics in practise is influenced by many factors, it should be specialized base on the PCB designs and configurations of the soldering equipment.. 10 1 Precautions (1) 1. How to choose the collet 吸嘴设置不当时产生的异常: (Abnormal situation caused by improper setting of collet) 选取合适的吸嘴是提高产品品质的关健所在,因 LED 与其它电子元件不同,它所承担的不只是电性的输出 还有光学部份的输出,因此特性就决定了 LED 的命运在 SMT 过程中变的比较脆弱。若机器吸嘴下压高度 设置的不当,即当吸嘴在吸起和放下材料的时候都有可能造成对 LED 的不亮或闪烁及品质问题。 To choose the right collet is the key issue in improving the product’s quality.LED is different from other electronic components, which is not only about electrical output but also for optical output. This If the collet!ˉs lowering down height is not well set,it will bring damage to the gold wire at the time of collet!ˉs picking up and loaing which will cause the LED fail to light up, light up now and then or other quality problems. 2. How to choose the collet 客户在 SMT 时直径尽量选择比 LED(胶体)发光面大的吸嘴防止吸嘴下压高度设置的不当造成对 LED 内 部金线的损坏。根据不同产品吸嘴选取如下图: During SMT, please choose the collet that has larger outer diameter than the lighting area of lens, in case that improper position of collet will damage the gold wire inside the LED. Different collets fit for different products, please efer to the following pictures cross out. 3. Store 为避免受潮的影响,我司建议产品在未开包装前储存条件为 5-30°C,相对湿度小于 60%;已开包装的LED 光源请在 24H 内使用安装完毕,如未用完之产品,请进行除湿并抽真空后密封保存。开封超过一周或湿度 卡发生变化时,请务必进行除湿,除湿条件:60°C±5°C,12H;产品密封保存有效使用期为一年。 To avoid moisture, we recommend storage conditions for the unopened LED +5 ~ +30 °C, relative hu- midity
XL-6028UGC-FB 价格&库存
很抱歉,暂时无法提供与“XL-6028UGC-FB”相匹配的价格&库存,您可以联系我们找货
XL-6028UGC-FB
  • 50+0.07250
  • 500+0.06750
  • 1500+0.06250
  • 5000+0.05850
  • 20000+0.05600
XL-6028UGC-FB
  • 20+0.14883
  • 200+0.11546
  • 600+0.09688
  • 2000+0.08025
  • 10000+0.07064
  • 20000+0.06545
库存:2382
