XL-4020RGBC-WS2812B
Technical Data Sheet
4020幻彩 贴片式发光二极管
haracteristic
* 外观尺寸(L/W/H):3.95*1.95*1.7mm
OutlineDimensions (L / w / h): 3.95 x 1.95 x 1.7 mm
* 发光颜色及胶体: 全彩/半透明雾状胶体
Luminous color and colloid: Full color / translucent fog colloid
* 4020灯珠内部集成高质量外控单线级联恒流IC(IC内置滤波器件,增强其信号抗干扰能力),优质RGB LED芯片,体
积小巧,外围简单
The 4020 ball interior integrates high-quality external single-line cascade current IC(IC built-in filter device, enhances its
signal anti-jamming ability), high-quality RGB LED chip, compact size, and simple periphery.
* 内置N302B6恒流精度高,内部RGB芯片预先分光处理;发光高度一致,白光效果纯正
The built-in N302B7 constant current has high accuracy and the internal RGB chip is pre-spectroscopic. The luminous height
is the same, and the white light effect is pure.
* 整形转发强化技术,单线数据传输,可无限级联
Plastic forwarding enhancement technology, single-line data transmission, can be cascaded.
* 数据传输频率800Kbps/秒,可实现画面刷新速率30帧 / 秒时,不小于1024点
The data transmission frequency is 800Kbps per second, and the screen refresh rate can be achieved at 30 frames per second,
not less than 1024 points.
* 输出端口PWM控制能够实现256级灰度调节,端口扫描频率1.5KHz / s
The output port PWM control can achieve 256 levels of grayscale adjustment, and the port scan frequency is 1.5 KHz / S.
* 采用优化预置12mA/通道恒流模式,低压驱动级联数量最大化;高恒流精度,片内误差
XL-4020RGBC-WS2812B 价格&库存
很抱歉,暂时无法提供与“XL-4020RGBC-WS2812B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.41030
- 2000+0.37180
- 国内价格
- 5+0.61642
- 50+0.52836
- 150+0.44030
- 500+0.39627
- 2000+0.33243
