XL-2810UYC
XL-2810UYC
    XINGLIGHT(成兴光)
    SMD,3.5x1.4mm
    发光二极管/LED 黄色 SMD,3.5x1.4mm 585nm~595nm 1300mcd 正贴
XL-2810UYC 数据手册
XL-2810UYC Technical Data Sheet 315黄 characteristic * 外观尺寸(L/W/H):3.5*1.2*1.4mm OutlineDimensions (L / w / h): 3.5 x 1.2 x 1.4 mm * 发光颜色及胶体: 黄色/无色透明 Luminous color and colloid: Yellow / colorless transparent * 低功率消耗 Low power consumption * 背光源理想选择 Ideal lighting for backlight * 宽角度侧发光 Wide Angle side luminescence * 环保工艺符合ROHS要求 Environmental protection products Complied With RoHS Directive * EIA规范标准包装 EIA standard packaging * 适用于SMT贴片自动化生产 Suitable for SMT automatic production * 适用于回流焊制程 Suitable for reflow soldering process product application * 医用设备:内窥镜、血氧仪 Medical equipment: endoscope、oximeter * 汽车电子: 背光按键灯、指示灯 Automotive electronics: backlight key light、 indicator light * 工业产品:电子仪表盘、工业设备 Industrial products: electronic instrument panel、industrial equipment * 智能家居: 白色家电、数码管LED Smart home: white appliances, nixie tube LED * 通讯产品: 手机按键灯、路由器、电视盒 Communication products: mobile phone button lamp, router 1 Catalogue Electrical Characteristics.............................................................................................................................3 Typical Characteristic Curves......................................................................................................................5 Reliability Test Items And Conditions........................................................................................................ 6 Outline Dimensions.......................................................................................................................................7 Packaging.......................................................................................................................................................8 Guideline for Soldering..............................................................................................................................10 Precautions....................................................................................................................................................12 2 Electrical Characteristics (温度=25℃) Absoiute Maximum Ratings 参数 黄色 Parameter Yellow 单位 Unit 功率消耗 Power dissipation 102 mW 正向直流电流Forward DC current 30 mA 正向电流峰值Positive current peak 120 mA 反向电压Backward voltage 5 V -40℃ to +85℃ 操作/贮藏温度Operation / storage temperature 注:* 1/10周期,0.1ms脉宽。 Note: * 1 / 10 cycles, 0.1ms pulse width. Electro-Optical Charasteristics (Temperature=25°C): 符号 Symbol 参数 Parameter λ peak 峰值波长 Peak wavelength 主波长 Dominant wavelength 波容 Bo rong 电容 Electric capacity 正向电压 Direct voltage 反向电流 Back current 发光角度 Luminescence Angle 亮度 Luminance λD Δλ 1/2 C VF IR 2θ1/2 lm 最小值 规格值 最大值 发光颜色 单位 Least Specification Crest Light color Unit value value value 测试条件 Test condition 黄色Yellow 588 / 596 nm IF=30mA 黄色Yellow / 592 / nm IF=30mA 黄色Yellow / / / x IF=30mA 黄色Yellow / 65 / y VF=0V,f=1MHz 黄色Yellow / 2 / V IF=30mA 黄色Yellow / / 10 uA VR=5V 黄色Yellow / 90 / Deg / 黄色Yellow 300 / 1500 Mcd / 备注:2θ1/2是指当亮度减到一半时与发光特性曲线相交所对应的角度值。 Note: 2θ1/2 refers to the Angle value corresponding to the intersection of the luminescence characteristic curve, when the brightness is reduced to half. 3 : Brightness grading Code Maximum P02 Minimum value 300 P03 400 500 P04 500 600 P13 600 800 P14 800 1000 P15 1000 1200 Company Test conditions 400 mcd IF=30mA : Voltage grading Code M07 Minimum value 1.8 Maximum Company Test conditions 1.9 M08 1.9 2.0 M09 2.0 2.1 M10 2.1 2.2 M11 2.2 2.3 V IF=30mA : Wavelength grading Code Maximum HY03 Minimum value 588 HY04 590 592 HY05 592 594 HY06 594 596 Company Test conditions 590 nm IF=30mA 4 Typical Characteristics Curves IF-Forward current(mA) Ambient Temperature Ta(℃) Ambient Temperature Ta(℃) 5 可靠性实验 Reliability experiment 序号 Order number 测试项目 Test item 1 寿命实验Life experiment 测试电流:30MA 温度:25℃ 测试时间:1000小时 Test current:30mA Temperature:25℃ Test time: 1000 hours 20PCS 0/1 2 高温高湿(静态实验) High temperature and high humidity (static experiment) 温度:85℃ 湿度:95%RH 测试时间:1000小时 Temperature:85℃ Humidity: 95%RH Test time: 1000 hours 20PCS 0/1 3 冷热冲击 Hot and cold impact -35℃~+85℃ 20min 10s 20min 测试时间:50个循环 -35℃~+85℃ 20min 10s 20min Test time: 50 cycles 20PCS 0/1 4 高温储存 High-temperature storage High temperature: 100℃ 高温:100℃ 测试时间:1000小时 Test time: 1000 hours 20PCS 0/1 5 低温储存 Low temperature storage 低温:-40℃ Low temperature: -40℃ 测试时间:1000小时 Test time: 1000 hours 20PCS 0/1 -40℃~+100℃ 30min 5min 30min 测试时间:20个循环 20PCS 0/1 20PCS 0/1 6 7 温度循环Temperature cycle 回流焊Reflow soldering 测试条件 Test condition -40℃~+100℃ 30min 5min 30min Test time: 20 cycles 预热:140℃-160℃,不超过120秒钟. 高温工作区:260℃(Max.),最大不超过5秒钟 Preheat: 140℃ -160℃, no more than 120 seconds.High temperature area: 260℃ (Max.), no more than 5 seconds 允收/拒收 样品数量 Allowance / Sample size rejection 可靠度实验不合格判定标准: 1.IV:衰减超过30% 2.VF:变化超过10% 3.IR:超过上限2倍 Reliability experiment unqualified determination criteria: 1.IV: attenuation more than 30% 2.VF: change more than 10% 3.IR: more than the upper limit of 2 times 注:1.同一项实验结果的测试需在2个小时之内完成。The test results of the same experiment should be completed within 2 hours. 2.测试必须在每项实验完成后,材料恢复正常环境条件下才能进行。Testing must be performed after each experiment before the material returns to normal environmental conditions. 6 Outline Dimension 2 1 注: 1. 单位 : 毫米(mm) Unit: mm 2. 公差 :如无特别标注则为± 0.1 mm Tolerances: ± 0.1 mm if unmarked. 7 1 Packaging (1) Belt and disk dimensions 8 2 Packaging (2) 9 1 Guideline for Soldering (1) 1. Hand Soldering 只建议在修理和重工的情况下使用手工焊接;推荐使用功率低于 3 0 W 的烙铁,焊接时烙铁的温度必须保 持在 300℃以下,且每个电极只能进行一次焊接,每次焊接的持续时间不得超过 3 秒。 人手焊接过程中的不慎操作易引起 LED 产品的损坏,应当小心谨慎。 Manual welding is recommended only for repair and heavy industry situations. A soldering iron of less than 30W is recommended to be used in Hand Soldering. Please keep the temperature of the soldering iron under 300℃ while soldering. Each terminal of the LED is to go for less than 3 second and for one time only. Be careful because the damage of the product is often started at the time of the hand soldering. 2. 回流焊接温度图进行。 Reflow Soldering: Reflow welding temperature diagram is performed TH=3-5S TH=5-8S · 回流焊接最多只能进行两次。 Reflow soldering should not be done more than two times. · 在回流焊接升温过程中,请不要对 LED 施加任何压力。 Stress on the LEDs should be avoided during heating in soldering process. · 在焊接完成后,待产品温度下降到室温之后,再进行其他处理。 After soldering, do not deal with the product before its temperature drop down to room temperature. 10 2 Guideline for Soldering (2) 3. Cleaning 在焊接后推荐使用酒精进行清洗,在温度不高于 30℃的条件下持续 3 分钟, 不高于 50℃的条件下持续 30 秒。使用其他类似溶剂清洗前,请先确认使用的溶剂不会对 LED 的封装和环氧树脂部分造成损伤。 超声波清洗也是有效的方法,一般最大功率不应超过 300W ,否则可能对 LED 造成损伤。请根据具体的 情况预先测试清洗条件是否会对 LED 造成损伤。 It is recommended that alcohol be used as a solvent for cleaning after soldering. Cleaning is to go under 30℃ for 3 minutes or 50℃ for 30 seconds. When using other solvents, it should be confirmed beforehand whether the solvents will dissolve the package and the resin or not. Ultrasonic cleaning is also an effective way for cleaning. But the influence of Ultrasonic cleaning on LED depends on factors such as ultrasonic power. Generally, the ultrasonic power should not be higher than 300W. Before cleaning, a pretest should be done to confirm whether any damage to LEDs will occur. 此一般指导原则并不适用于所有 PCB 设计和焊接设备的配置。具体工艺受到诸多因素的影响, 请根据特定的PCB设计和焊接设备来确定焊接方案。 Note: This general guideline may not apply to all PCB designs and configurations of all soldering equipment. The technics in practise is influenced by many factors, it should be specialized base on the PCB designs and configurations of the soldering equipment.. 11 1 Precautions (1) 1. Storage · 本产品使用密封防潮抗静电袋包装,并附有干燥剂,未开封的产品有一年的保存时间。 Moisture proof and anti-electrostatic package with moisture absorbent material is used, to keep moisture to a minimum. · 开封前,产品须存放在温度不高于 30℃,湿度不高于 40%RH 的环境中。 Before opening the package, the product should be kept at 30℃ or less and humidity less than 4 0 % RH, and be used within a year. · 开封后,产品须存放在温度不高于 30℃,湿度不高于 10%RH 的环境中,且应该在 24小时(1天) 内使 用完;且贴片后应尽快做焊接。建议工作环境为温度不高于 30℃,湿度不高于 40%RH。 After opening the package, the product should be stored at 30℃ or less and humidity less than 10%RH, and be soldered within 2 4 hours (1 day). An d it sh o u l d be we l d e d as so o n as po s s i b l e af t e r th e pa t c h . It is recommended that the product be operated at the workshop condition of 30℃ or less and humidity less than 40%RH. · 对于尚未焊接的 LED,如果吸湿剂或包装失效,或者产品没有符合以上有效存储条件,烘焙可以起到一定 的性能恢复效果。烘焙条件: (60±5)℃,持续 24 小时。 If the moisture absorbent material has fade away or the LEDs have exceeded the storage time, baking treatment should be performed based on the following condition: (60±5)℃ for 24 hours. 2. Static Electricity 静电和电涌会导致产品特性发生改变,例如正向电压降低等,如果情况严重甚至会损毁产品。所以在使用时必须 采取有效的防静电措施。 所有相关的设备和机器都应该正确接地,同时必须采取其他防止静电和电涌的措施。使用防静电手环,防静电 垫子,防静电工作服、工作鞋、手套,防静电容器,都是有效的防止静电和电涌的措施;严禁使用普通塑料制品。建 议在作业过程中,使用离子风扇来压制静电的产生。 距离LED元件1英尺距离的环境范围内静电场电压小于100V。 Static electricity or surge voltage damages the LEDs. Damaged LEDs will show some unusual characteristic such as the forward voltage becomes lower, or the LEDs do not light at the low current. even not light. All devices, equipment and machinery must be properly grounded. At the same time, it is recommended that wrist bands or anti-electrostatic gloves, anti-electrostatic containers be used when dealing with the LEDs.Using ordinary plastic products are strictly prohibited.It is recommended to use ion fans to suppress the static electricity generation during the operation.The static field voltage is less than 100V within the ambient range of 1 foot distance from the LED element. 12 2 Precautions (2) 3. Design Consideration 设计电路时,通过 LED 的电流不能超过规定的最大值,同时,还需使用保护电阻,否则,微小的电压变 化将会引起较大的电流变化,可能导致产品损毁。 建议使用以下(A)电路,该电路能够很好的调节通过每个 LED 的电流; 不推荐使用(B)电路,该电路 在持续的电压驱动下,LED 的正向电压(VF )发生变化,电流会随之而发生变化,可能使某些 LED 承受高于 规定的电流值。 In designing a circuit, the current through each LED must not exceed the absolute maximum rating specified for each LED. In the meanwhile, resistors for protection should be applied, otherwise slight voltage shift will cause big current change, burn out may happen. It is recommended to use Circuit A which regulates the current flowing through each LED rather than Circuit B. When driving LEDs with a constant voltage in Circuit B, the current through the LEDs may vary due to the variation in Forward Voltage (VF) of the LEDs. In the worst case, some LED may be subjected to stresses in excess of the Absolute Maximum Rating. (A) (B) LED 的特性容易因为自身的发热和环境的温度的改变而发生改变。温度的升高会降低 LED 的发光效率、 影响发光颜色等,所以在设计时应充分考虑散热的问题。 Thermal Design is paramount importance because heat generation may result in the Characteristics decline, such as brightness decreased, Color changed and so on. Please consider the heat generation of the LEDs when making the system design. 13 3 Precautions (3) 4. Others 直接用手拿取产品不但会污染封装树脂表面,也可能由于静电等因素导致产品性能的改变。过度的压力也 直接影响封装内部的管芯和金线,因此请勿对产品施加过度压力,特别当产品处于高温状态下,例如在回 可能 流焊接过 程中。 When handling the product, touching the encapsulant with bare hands will not only contaminate its surface, but also affect on its optical characteristics. Excessive force to the encapsulant might result in catastrophic failure of the LEDs due to die breakage or wire deformation. For this reason, please do not put excessive stress on LEDs, especially when the LEDs are heated such as during Reflow Soldering. LED 的环氧树脂封装部分相当脆弱,请勿用坚硬、尖锐的物体刮、擦封装树脂部分。在用镊子夹取的时 候也应当小心注意。 The epoxy resin of encapsulant is fragile, so please avoid scratch or friction over the epoxy resin surface. While handling the product with tweezers, do not hold by the epoxy resin, be careful. 5. Safety Advice For Human Eyes LED 发光时,请勿直视发光光源,特别是对于一些光强较高的 LED ,强光可能伤害你的眼睛。 Viewing direct to the light emitting center of the LEDs, especially those of great Luminous Intensity, will cause great hazard to human eyes. Please be careful. 14
XL-2810UYC 价格&库存
很抱歉,暂时无法提供与“XL-2810UYC”相匹配的价格&库存,您可以联系我们找货
XL-2810UYC
  • 1+0.27000
  • 100+0.25200
  • 300+0.23400
  • 500+0.21600
  • 2000+0.20700
  • 5000+0.20160
XL-2810UYC
  • 1+0.48510
  • 200+0.31350
  • 1500+0.27170
  • 3000+0.24090
库存:6000
XL-2810UYC
  • 5+0.45680
  • 50+0.36610
  • 150+0.32066
  • 500+0.28669
  • 3000+0.25943
  • 6000+0.24584
库存:8480
