KH-1.27PH180-1X4P-L7.2 数据手册
SPECIFICATIONS
RECOMMEND P.C.B LAYOUT
PCB TOLERANCE:±0.05 (TOP VIEW)
Current Rating:
1.0 Amps
Withstanding Voltage: AC 500V
Insulation Resistance:1000M Min
Contact Resistance:
20 mΩ Max
Operation Temperature:-40 °to+105°
Insrlator Material:
Polyester(UL94V-0)
Contact Material:
Brass
Standard:
PA6T
Contact Plating:
Gold Flash
Max.Processing Temp: 240 °C for30-60seconds
(260 °C for5seconds)
(1) Pin Spacing: 127=1.27mm
(2) Product Name: PH=Pin Header
(3) No.of Rows: 1=Single Row;2=Dual Row
(4) No.of Pins Per Row: 1~50
(5) Insulator Material Height: 10=1.0mm;15=1.5mm
(6) Connector Type:S=Straight;R=Right Angle;M=SMT
(7) Contact Material Length: 72=7.2mm;105=10.5mm
(8) No.of Insulator Material: 1=1PCS;2=2PCS
(9) Contact Plating:G0=Gold Flash; AU15=Au 1.5u"
(10)Insulator Material Option:
A=BK-PA6T;B=BK-PA46;C=KB-LCP;S=Special
深圳市金航标电子有限公司
WWW.BDS666.COM
0755-83044319
UNLESS OTHEWIXE SPECIFIED TOLERANCE
X
:±0.3
X.X :±0.2
X.XX:±0.1
X°
:±5°
X.X° :±1°
X.XX°:±0.5°
CHECKED: LI BEI LIN
12/03/07
DRAWM NAME:
SIZE
REV
A4
A
CHECKED:
of DIM.A
1.27PH 1xnPin H1.0 180 °L7.2
SCALE
PROUCT NO.
UNIT
PROJECT
APPROVED:
PAGE
1/1
No. of DIM.A
DIM.B
No. of DIM.A
DIM.B
No. of DIM.A
DIM.B
No. of DIM.A
DIM.B
KH-1.27PH180-1X4P-L7.2 价格&库存
很抱歉,暂时无法提供与“KH-1.27PH180-1X4P-L7.2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.25532
- 200+0.20013
- 500+0.16643
- 2000+0.14796
- 10000+0.13209
- 20000+0.12345
- 40000+0.12194
- 80000+0.12096
