Effective August 2019
Supersedes June 2017
Technical Data 2052
S500
5 mm x 20 mm Fast-acting glass tube fuses
Agency information
• cURus: File E19180, Guide JDYX2, JDYX8
• CSA Component Acceptance: File
1803366
• SEMKO Approval: File 414552
• VDE Approval: File 40014109
• BSI Approval: File KM55676
• IMQ Approval: File CA03.00097
• CCC Approval: File 2005010207155694
Product features
Ordering information
Fast-acting, low breaking capacity
Optional axial leads available
5 mm x 20 mm physical size
Glass tube with silver-plated (32-125 mA) and nickelplated (160 mA-10 A) endcaps
• Designed to IEC 60127-2 (160 mA-10 A)
Electrical Characteristics
1.5 I n 2.1 I n
2.75 I n
4 In
10 I n
In
min
max
min
max
min
max
max
32mA-125mA 60 min 30 min
160mA-6.3A 60 min 30 min 50 ms 2 sec 10 ms 300 ms 20 ms
8A-10A
30 min 30 min 50 ms 2 sec 10 ms 400 ms 40 ms
Voltage Interrupting Rating
Part Number Rating
(amps) at Rated
Voltage (50Hz) Vac
Vac
S500-32-R
250
35
S500-40-R
250
35
S500-50-R
250
35
S500-63-R
250
35
S500-80-R
250
35
S500-100-R
250
35
S500-125-R
250
35
S500-160-R
250
35
S500-200-R
250
35
S500-250-R
250
35
S500-315-R
250
35
S500-400-R
250
35
S500-500-R
250
35
S500-630-R
250
35
S500-800-R
250
35
S500-1-R
250
35
S500-1.25-R
250
35
S500-1.6-R
250
35
S500-2-R
250
35
S500-2.5-R
250
35
S500-3.15-R
250
35
S500-4-R
250
40
S500-5-R
250
50
S500-6.3-R
250
63
S500-8-R
250
80
S500-10-R
250
100
Specify product code
Insert packaging code prefix before part number. E.g.
BK/S500-32-R
Ratings above 6.3 A have a 0.8 mm diameter lead (axial lead)
Specify option code if desired
For axial leads, insert “V” between catalog series and
amp rating. E.g. S500-V-100-R
Specifications
Typical DC
Cold Resistance
(Ω)*
40
25
17
125
5.0
3.8
2.8
9.1
6.8
4.3
3.1
2.0
0.26
0.20
0.14
0.125
0.096
0.066
0.043
0.034
0.025
0.021
0.014
0.010
0.010
0.008
Typical
Maximum
Agency Approvals
Melting I 2t Voltage
AC†
Drop (mV)‡ cURus CSA CCC BSI VDE SEMKO IMQ
0.000047
3200
0.00011
2500
0.00020
2400
0.00057
2000
0.0012
1200
0.003
1100
0.005
1000
0.008
2000
X
X
X
X
X
X
X
0.016
1700
X
X
X
X
X
X
X
0.28
1400
X
X
X
X
X
X
X
0.58
1300
X
X
X
X
X
X
X
0.18
1100
X
X
X
X
X
X
X
0.18
220
X
X
X
X
X
X
X
0.35
220
X
X
X
X
X
X
X
0.67
190
X
X
X
X
X
X
X
0.60
200
X
X
X
X
X
X
X
0.84
200
X
X
X
X
X
X
X
1.6
190
X
X
X
X
X
X
X
4.2
150
X
X
X
X
X
X
X
6.1
150
X
X
X
X
X
X
X
13
130
X
X
X
X
X
X
X
22
130
X
X
X
X
X
X
X
42
120
X
X
X
X
X
X
X
69
120
X
X
X
X
X
X
X
N/A
120
X
X
X
X
X
N/A
120
X
X
X
X
X
* DC Cold Resistance (Measured at
很抱歉,暂时无法提供与“S500-100-R”相匹配的价格&库存,您可以联系我们找货
