2SA1837
Minos Silicon PNP Epitaxial Type
2SA1837
Power Amplifier Applications
Complementary to 2SC4793
High collector voltage:VCEO=-230V
(min)
Note: Using continuously under heavy loads (e.g. the application
of high temperature/current/voltage and the significant change
in temperature, etc.) may cause this product to decrease in the
reliability significantly even if the operating conditions (i.e.
operating temperature/current/voltage, etc.) are within the
absolute maximum ratings.
Absolute Maximum Ratings(Tc=25 ):
THUNDER
Characteristics
Collector-base voltage
Collector-emitter voltage
Emitter-base voltage
Collector current
Base current
Collector power dissipation (Tc=25℃)
Junction temperature
Storage temperature range
Symbol
VCBO
VCEO
VEBO
IC
IB
PC
Tj
TSTG
Rating
-230
-230
-5
-1
-0.2
50
150
-55~150
TO-220F
Unit
V
V
V
A
A
W
Thermal Characteristics
Symbol
Paramter
Typ
RθJC
Junction-to-Case
3.0
版本号: A01
修订日期: 2018/01/05
Units
℃/W
1/2
2SA1837
Electrical Characteristics
(Tc=25
Characteristics
Symbol
Collector-Base Cut-off Current
Emitter-Base Cut-off Current
Collector-Emitter Breakdown Voltage
DC current gain
Collector-emitter saturation voltage
Base-Emitter Saturation Voltage
Base-emitter voltage
Transition frequency
ICBO
IEBO
VCEO
hFE
VCEsat
VBEsat
VBE
fT
Test Condition
VCB=-230V,IE=0
VEB=-5V,IC=0
IC=-1mA
IC=-0.1A; VCE=-5V
IC=-0.5A; IB=-0.05A
IC=-0.5A,IB=-0.05A
VCE=-5V;IC=-0.5A
VCE=-10V;IC=-100mA
Min
Typ
-230
100
Max
-1.0
-1.0
300
-0.5
-1.4
-1.5
40
Unit
uA
uA
V
V
V
V
MHz
Package Information
TO-220F
PACKAGE
Notice
Minos Microelectronics Incorporated Limited reserves the right to make changes without further notice to any
products or specifications herein. When use the product, be sure to obtain the latest specification.
Minos Microelectronics Incorporated Limited does not assume any liability arising out of the application or any
product described herein. When using Minos Microelectronics Incorporated Limited products in your equipment,
you are requested to take adequate safety measures to prevent the equipment from causing a physical injury ,fire or
other problem if any of the products become faulty.
版本号: A01
修订日期: 2018/01/05
2/2
很抱歉,暂时无法提供与“2SA1837”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.47410
- 10+1.17472
- 50+1.04642
- 100+0.88636
- 500+0.81508
- 1000+0.77220
