PESD24VS1UL-N
ESD Protection Diode
»Features
225Watts peak pulse power (tp = 8/20μs)
Unidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±30kV contact ±30kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 5A (8/20μs)
»Applications
»Mechanical Data
Microprocessor based equipment
DFN1006 package
Personal Digital Assistants (PDA’s)
Molding compound flammability rating: UL 94V-0
Notebooks, Desktops, and Servers
Packaging: Tape and Reel
Portable Instrumentation
RoHS/WEEE Compliant
Pagers Peripherals
»Schematic & PIN Configuration
DFN1006
Revision 2018
www.born-tw.com
1/4
PESD24VS1UL-N
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
225
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
5
A
VESD
30
30
kV
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 150
Storage Temperature
Tstg
-55 to + 150
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
Max
Units
24.0
V
VBR
IT=1mA
26.7
V
Reverse Leakage Current
IR
VRWM=24.0V,T=25℃
Clamping Voltage
VC
IPP=5A,tp=8/20μs
45
V
Junction Capacitance
Cj
VR = 0V, f = 1MHz
30
pF
0.5
uA
»Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
V RW M
IR
V BR
IT
I
IF
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RW M
VC VBR VRWM
IR VF
IT
Breakdown Voltage @ IT
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
PESD24VS1UL-N
»Typical Characteristics
Figure 1: Peak Pulse Power vs. Pulse Time
Figure 2: Power Derating Curve
110
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
10
225w 8/20µs waveform
1
0.1
0.01
0.1
1
10
100
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
90
Percent
Ipp
80
e-1
50
40
td=Ipp/2
Revision 2018
10
15
125
150
35
30
25
Test
Waveform
Para m
ters
tr=8μ s
td=20μ s
10
5
10
40
Clamping Voltage–VC (V)
100
45
Waveform
Paramters
tr=8µs
td=20µs
30
50
Figure 4: Clamping Voltage vs.Ipp
110
60
25
Ambient Temperature - TA (℃)
Figure3: Pulse Waveform
70
Time (µs)
30
www.born-tw.com
4
6
8
10
12
14
16
Peak Pulse Current–IPP (A)
3/4
PESD24VS1UL-N
»Outline Drawing – DFN1006
»Marking
24F
»Ordering information
Order code
PESD24VS1UL-N
Revision 2018
Package
DFN1006
Base qty
10k
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“PESD24VS1UL-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.26070
- 500+0.17380
- 5000+0.15180
- 10000+0.13750
- 国内价格
- 10+0.28066
- 100+0.22839
- 2000+0.18265
- 4000+0.14058
- 10000+0.13266
- 国内价格
- 10+0.30618
- 100+0.24916
- 300+0.22065
- 1000+0.19926
- 5000+0.15336
- 10000+0.14472
