SS10100CG
SS10100CG
    SK(時科)
    SMC(DO-214AB)
    SS10100CG
SS10100CG 数据手册
SS1045CG THRU SS10100CG Surface Mount Schottky Barrier Rectifier Reverse Voltage - 45 to 100V Forward Current - 10.0A PINNING PIN DESCRIPTION 1 Cathode 2 Anode FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications 1 2 Top View Marking Code: S1045 ~ S10100 Simplified outline SMC and symbol MECHANICAL DATA • Case: SMC • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.22g / 0.0077oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Parameter Symbols Maximum Repetitive Peak Reverse Voltage V RRM 45 Maximum RMS voltage V RMS Maximum DC Blocking Voltage V DC Maximum Average Forward Rectified Current I F(AV) 10.0 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 150 A Max Instantaneous Forward Voltage @10.0 A Maximum DC Reverse Current T j = 25°C at Rated DC Reverse Voltage T j =100°C Typical Thermal Resistance Operating Junction Temperature Range Storage Temperature Range VF SS1045CG SS10100CG Units 60 100 V 32 42 70 V 45 60 100 V 0.55 0.75 0.90 V IR 0.5 50 mA RθJA 20 °C/W Tj -55 ~ +150 °C T stg -55 ~ +150 °C (1)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. REV.08 SS1060CG 1 of 3 SS1045CG THRU SS10100CG Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( mA) Fig.1 Forward Current Derating Curve Average Forward Current (A) 12.0 10.0 8.0 6.0 4.0 2.0 0.0 25 50 75 100 125 150 1000 100 T J =25°C 1 0 0 Case Temperature (°C) Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) 20 10 1 SS1045CG SS1060CG SS10100CG 0.1 0.5 1.0 1.5 2.0 Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 180 175 150 125 100 75 50 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles at 60Hz REV.08 40 60 80 100 Fig.4- Typical Transient Thermal Impedance 100 10 1 0.01 0.1 1 10 t, Pulse Duration(sec) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 25 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic 0 T J =100°C 10 2 of 3 100 SS1045CG THRU SS10100CG PACKAGE OUTLINE SMC Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A SMC mechanical data A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil Marking The recommended mounting pad size Type number 3.8 (150) 4.1 (160) 4.3 (170) 4.1 (160) mm Unit : (mil) REV.08 3 of 3 Marking code SS1045CG S1045 SS 1060 CG S1060 SS 10100 CG S10100
SS10100CG 价格&库存
很抱歉,暂时无法提供与“SS10100CG”相匹配的价格&库存,您可以联系我们找货
