VDR-10D471K(11D)
VDR-10D471K(11D)
    VDRSAS(嵩隆)
    插件
VDR-10D471K(11D) 数据手册
VDR Varistor 10D SERIES METAL OXIDE VARISTOR – 10D SERIES FEATURES * Wide operating voltage (V1mA) range from 18V to 1100V. * Fast responding to transient over-voltage. * Large absorbing transient energy capability. * Low clamping ratio and no follow-on current. * Meets MSL level 1, per J-STD-020 * Safety number : CUL- E317616 VDE- 40028836 CQC-12001076479 ISO9001-2018 APPLICATION *Transistor, Diode, IC, Thyristor or Triac semiconductor protection. * Surge protection in consumer electronics. * Surge protection in industrial electronics. * Surge protection in electronic home appliances, gas and petroleum appliances. * Relay and electromagnetic valve surge absorption. General Characteristics Definition *Operating Temperature: (-40 ℃ ~ +85 ℃ ) o & ( -40 ℃ ~ +125 ℃) o *Storage Temperature: (-40 C ~ +125 C) *Working Surface Temperature: +115 C > 100M Ω Flame-Retardant to UL 94 V-0 o *Insulation Resistance: *Coating (Epoxy Resin): Material *Coating: Epoxy Resin *Lead Wire: The Copper Wire *Electrode: *Disk: Silver Solder Zinc Oxide PART NUMBER CODE VDR Brand Mark □□ D □□□ K Element Diameter Type: D: Disk , S: Square Varistor Voltage Tolerance : K±10%, L±15% □ □□ Sapce:Straight 85℃ H:125℃ C:Crimped , Y:Y kink I:Inner,Tor G :Plaster Lead Form : Short leg : NO : □.□ E: 4KV2KA S:6KV/3KA Y:10KV/5KA =ABCDEF Times □ J:High Surge & High Energy PH=Ultra Surge Taping : TA : Ammo, TR : Reel Page-1 VDR Varistor 10D SERIES Part No. Part No. T Max. D Max. VDR-10D180L VDR-10D220K VDR-10D270K VDR-10D330K VDR-10D390K VDR-10D470K VDR-10D560K VDR-10D680K VDR-10D820K VDR-10D101K VDR-10D121K VDR-10D151K VDR-10D181K VDR-10D201K VDR-10D221K VDR-10D241K VDR-10D271K VDR-10D301K VDR-10D331K VDR-10D361K VDR-10D391K VDR-10D431K VDR-10D471K VDR-10D511K VDR-10D561K VDR-10D621K VDR-10D681K VDR-10D751K VDR-10D781K VDR-10D821K VDR-10D911K VDR-10D102K VDR-10D112K VDR-10D180LJ VDR-10D220KJ VDR-10D270KJ VDR-10D330KJ VDR-10D390KJ VDR-10D470KJ VDR-10D560KJ VDR-10D680KJ VDR-10D820KJ VDR-10D101KJ VDR-10D121KJ VDR-10D151KJ VDR-10D181KJ VDR-10D201KJ VDR-10D221KJ VDR-10D241KJ VDR-10D271KJ VDR-10D301KJ VDR-10D331KJ VDR-10D361KJ VDR-10D391KJ VDR-10D431KJ VDR-10D471KJ VDR-10D511KJ VDR-10D561KJ VDR-10D621KJ VDR-10D681KJ VDR-10D751KJ VDR-10D781KJ VDR-10D821KJ VDR-10D911KJ VDR-10D102KJ VDR-10D112KJ 4.5 4.6 4.7 4.9 4.8 4.9 5.0 5.2 4.1 4.3 4.5 4.8 4.3 4.4 4.5 4.6 4.9 5.0 5.1 5.2 5.4 5.7 6.0 6.2 6.5 7.1 7.6 8.0 8.1 8.3 8.8 9.3 9.9 12.5 S H Max. I/C/Y 16.5 17.5 L min. 20.0 F ±0.8 d + 0.05 7.5 0.8 Page-2 VDR Varistor 10D SERIES ELECTRICAL CHARACTERISTIC Part Number Standard High Surge Maximum Varistor Withstanding Energy Allowable Voltage Maximum Clamping Voltage Voltage Surge Current 10/1000μS AC (V) DC (V) V1mA(V) IP(A) VC(V) I(A) I(A) I(A) I(A) Standard High Surge Standard High Surge Typical Rated Capacitance Powe (Reference) (W) @1KHzPF 10D180L 10D180LJ 11 14 18(15.0~21.6) 5 36 500 1000 2.1 3.0 0.05 5600 10D220K 10D220KJ 14 18 22(19.5~26.0) 5 43 500 1000 2.5 5.0 0.05 4500 10D270K 10D270KJ 17 22 27(24-31) 5 53 500 1000 3.0 6.0 0.05 3700 10D330K 10D330KJ 20 26 33(29.5~36.5) 5 65 500 1000 4.0 7.0 0.05 3000 10D390K 10D390KJ 25 31 39(35 ~43) 5 77 500 1000 4.6 9.0 0.05 2400 10D470K 10D470KJ 30 38 47(42~52) 5 93 500 1000 5.5 11.0 0.05 2100 10D560K 10D560KJ 35 45 56(50~62) 5 110 500 1000 7.0 13.0 0.05 1800 10D680K 10D680KJ 40 56 68(61~75) 5 135 500 1000 8.2 15.0 0.05 1500 10D820K 10D820KJ 50 65 82(74~90) 25 135 2500 3500 12.0 17.0 0.4 1200 10D101K 10D101KJ 60 85 100(90~110) 25 165 2500 3500 15.0 18.0 0.4 1000 10D121K 10D121KJ 75 100 120(108~132) 25 200 2500 3500 18.0 21.0 0.4 830 10D151K 10D151KJ 95 125 150(135~165) 25 250 2500 3500 22.0 25.0 0.4 670 10D181K 10D181KJ 115 150 180(162~198) 25 300 2500 3500 27.0 30.0 0.4 560 10D201K 10D201KJ 130 170 200(185~225) 25 330 2500 3500 30.0 35.0 0.4 500 10D221K 10D221KJ 140 180 220(198~242) 25 360 2500 3500 32.0 39.0 0.4 450 10D241K 10D241KJ 150 200 240(216~264) 25 395 2500 3500 35.0 42.0 0.4 420 10D271K 10D271KJ 175 225 270(243~297) 25 455 2500 3500 37.0 49.0 0.4 370 10D301K 10D301KJ 190 250 300(270~330) 25 505 2500 3500 40.0 54.0 0.4 330 10D331K 10D331KJ 210 275 330(297~363) 25 550 2500 3500 43.0 58.0 0.4 300 10D361K 10D361KJ 230 300 360(324~396) 25 595 2500 3500 47.0 65.0 0.4 280 10D391K 10D391KJ 250 320 390(351~429) 25 650 2500 3500 60.0 70.0 0.4 260 10D431K 10D431KJ 275 350 430(387~473) 25 710 2500 3500 65.0 80.0 0.4 230 10D471K 10D471KJ 300 385 470(423~517) 25 775 2500 3500 67.0 85.0 0.4 210 10D511K 10D511KJ 320 415 510(459~561) 25 845 2500 3500 69.0 90.0 0.4 200 10D561K 10D561KJ 350 460 560(504~616) 25 920 2500 3500 70.0 92.0 0.4 180 10D621K 10D621KJ 385 505 620(558~682) 25 1025 2500 3500 72.0 95.0 0.4 160 10D681K 10D681KJ 420 560 680(612~748) 25 1120 2500 3500 75.0 98.0 0.4 150 10D751K 10D751KJ 460 615 750(675~825) 25 1240 2500 3500 77.0 100.0 0.4 140 10D781K 10D781KJ 485 640 780(702~858) 25 1290 2500 3500 80.0 105.0 0.4 130 10D821K 10D821KJ 510 670 820(738~902) 25 1355 2500 3500 85.0 110.0 0.4 120 10D911K 10D911KJ 550 745 910(819~1001) 25 1500 2500 3500 93.0 130.0 0.4 110 10D102K 10D102KJ 625 825 1000(900~1100) 25 1650 2500 3500 102.0 140.0 0.4 100 10D112K 10D112KJ 680 895 1100(990~1210) 25 1815 2500 3500 115.0 150.0 0.4 90 The tolerance of varistor voltage between 18V and 68V is more than 10%. Page-3 Mechanical Ratings VDR Varistor 10D SERIES Reliability Test Performance Requirements Test Parameter Test Condition / Description Terminal Pull Strength After gradually applying the load specified below and keeping the unit fixed for ten seconds, the terminal shall be visually examined for any damage. The unit shall be secured with its terminal kept vertical and the weight specified below be applied in the axial direction. The Terminal Bending terminal shall gradually be bent by 90° in one direction, then 90° Strength in the opposite direction, and again back to the original position. The damage of the terminal shall be visually examined. Vibration Solderingsolderability SolderingResistance to Solder Heat Diameter Loading 0.6mm 1.0 Kg 0.8mm 1.0 Kg 1.0mm 2.0 Kg Diameter Loading 0.6mm 0.5 Kg 0.8mm 0.5 Kg 1.0mm 1.0 Kg The Specimen shall be vibrated by its lead wires with a total amplitude of 1.5㎜ and a varying frequency of 10~55~10HZ(each minutes) for a period of 2 hours respectively in each X,Yand Z directions. No visible damage No visible damage No visible damage △VB/VB%≦±5% After dipping the terminal to depth of approximately 3㎜ from the specimen in a soldering Terminations shall bath of 260℃ for 10±1(D5: 5±1) seconds. Thereafter the terminal shall be visually be uniformly tinned examined. After preheating the specimen, the specimen shall be completely immersed into a soldering bath having a temperature of 260±5℃ for 10±1 (D5: 5±1) seconds or iron of 400±5℃ for 3±0.5 seconds. There after the change of Vb and mechanical damage shall be examined. No visible damage △VB/VB%≦±5% ENVIRONMENTAL RATINGS The specimen shall be applied continuously the maximum allowable voltage at the specified conditions for specified period and then stored at room temperature and normal Dry Heat Loading humidity over 2 hours. Thereafter, the change of Vb and mechanical damage shall be △VB/VB%≦±10% examined. Ambient temp:125±2℃ ; Period:1000±24hours. High Temperature In a drying oven without load. Storage Ambient temp:125±2℃ ; period:1000±24hours Damp Heat Loading △VB/VB%≦±5% The specimen shall be applied continuously the maximum allowable voltage at the specified conditions for specified period and then stored at room temperature and normal humidity over 2 hours. Thereafter, the change of Vb and mechanical damage shall be △VB/VB%≦±10% examined. Ambient condition:40±2℃ , 90 to 95%R.H. ; period:1000±24 hours Step Temperature Cycle Condition the specimen to each temperature form step 1 to step 4 in this order for the period shown in the table of specifications. The change of Vb and mechanical damage shall be examined after 2 hours. o Period o Temp C 1 -40+3 C 30 min. 2 Room Temp 15 min. 3 85+2 C 30 min. 4 Room Temp 15 min. o Surge Lifetime Rating The change of Vb shall be measured after the impulse listed below is applied 10,000 times continuously with the interval of ten seconds at room temperature. Voltage Proof Voltage:2500VAC Leakage Current≦0.5mA Time:60 Seconds No visible damage △VB/VB%≦±10% No visible damage △VB/VB%≦±10% No Breakdown Page-4 VDR Varistor 10D SERIES MARKING CODE 1 DongWoSemi Logo 2 Disk Size 3 CUL Accreditation Logo 4 “Y” &“M” Product Line Code 5 Varistor Voltage 6 VDE Accreditation Logo 7 Energy and frequency of combined wave “J” is High Surge Code,not “J” is Standard Surge “H” is High temperature range ,not “H” is Standard Packaging specification / bulk packaging quantity Unit:Pcs Dimension Part No. Bag Small Carton Carton 10D 180L to 112K 500 5,000 10,000 10D (Short leg) 180L to 112K 500 7,500 15,000 Page-5
VDR-10D471K(11D) 价格&库存
很抱歉,暂时无法提供与“VDR-10D471K(11D)”相匹配的价格&库存,您可以联系我们找货
