PSIP-06V-LE
PSIP-06V-LE
    JST
    P=4mm
    2X3P 4MM
PSIP-06V-LE 数据手册
PSI CONNECTOR 4.0mm pitch/Disconnectable Crimp style connectors Wire-to-wire type Side entry type • Secure locking structure • Mis-mating prevention mechanism by keying (2 to 4 circuits/3 kinds of keying) • Finger-friendly design • Large electric current was realized. Specifications ––––––––––––––––––– Single type Double type • Current rating: 12 A AC, DC (Refer to the following table.) • Voltage rating: 300 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #26 to #16 * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Note: The current rating differs depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and the wire size. Current unit: A Top entry type Circuits 2 3 4, 5, 6, 8 10, 12 14 This PSI connector is designed for wire-toboard and wire-to-wire 4.0 mm pitch connector. Low insertion force type contact is adopted and it provides excellent operability. This connector has the secure locking device that has the mechanism for preventing the inverse insertion. By adopting key shape and multi colors of housing, prevention function of mis-mating is considered. 1 # 16 # 18 12 11 10 9 9 10 9 8 7 7 Wire size (AWG) # 20 # 22 8 7 6 6 6 5 5 5 5 4.5 # 24 # 26 4 4 4 4 4 3 3 3 3 3 Note: Do not branch in parallel current which exceeds the rated current (e.g. more than 12 A in the case of 2 circuits with AWG #12). If branched in parallel, current imbalance or other problems may develop. If it is absolutely necessary to branch such a large current in parallel, design the circuits without causing any imbalance and provide an extra margin for each circuit. Standards –––––––––––––––––––––– 0 Recognized E 60389 1 Certified LR 20812 2 R50259465 PSI CONNECTOR PC board layout and Assembly layout Top entry type ● Single type ● Double type 10 1.65 4.5 ±0.05 +0.1 0 φ1.3 17.8 4 +0.1 0 17.8 φ1.3 ±0.05 ±0.05 ±0.05 ±0.05 +0.1 0 4.5 φ1.65 15.95 +0.1 0 5.95 φ1.65 1.65 ±0.05 A ±0.05 4 ±0.05 A ±0.05 Side entry type Wire-to-wire type 22.1 9.35 10.25 10 F ±0.05 4 ±0.05 +0.1 0 30.9 +0.1 0 ±0.05 H 8.7 +0.1 0 9 3 3 ±0.05 9 ±0.05 φ1.7 φ1.65 0.8 4 ±0.05 ±0.05 +0.1 0 ±0.05 A±0.05 A ±0.05 φ1.65 +0.1 0 ±0.05 G 7.2 19.6 +0.1 0 φ1.7 +0.1 0 φ1.7 +0.1 0 Keying: A, B types φ1.7 +0.1 0 F Circuits Keying: C type 0.8 t 1.2 1.2 t 2.0 2 3 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 13 17 13.3 17.3 G H Applicable panel thickness (mm) 9 13 6.8 8.4 0.8∼2.0 Socket contact Applicable wire mm2 AWG# Model No. SPSI-001T-M1.1 SPSI-41T-M1.1 0.13∼0.33 26∼22 1.3∼2.4 2,600 0.5 ∼1.25 20∼16 1.7∼3.2 2,600 11.3 6.5 2.2 Insulation O.D. (mm) Q'ty/reel Material and Finish 4 2.8 Copper alloy, tin-plated RoHS compliance Contact Crimping machine Crimp applicator MKS-L SPSI-001T-M1.1 AP-K2N SPSI-41T-M1.1   ―   MKS-L   ―   Applicator Dies Crimp applicator with dies MK/SPSI/M-001-11 APLMK SPSI/M001-11 ― ― MK/SPSI/M-41-11 APLMK SPSI/M41-11 ― ― 2 PSI CONNECTOR Socket housing Top entry type B A B 10 15.95 14.9 14.9 A RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PSIP-02V-LE-A LE...light blue Y...yellow R...red Header Top entry type 9.1 12.35 B φ1.1 4 1.65 3.7 □1.14 4.5 A 15.05 12.35 B RoHS compliance This product displays (LF)(SN) on a label. Note: Other kinds of post-omitted products are available. Contact JST for details. φ1.1 4 1.65 A 3.7 □1.14 4.5 5.95 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 3 B02B-PSILE-A1 LE...light blue Y...yellow R...red PSI CONNECTOR Header Side entry type S02B-PSILE-A1 S02B-PSIY-B1 S02B-PSIR-C2 S03B-PSILE-A1 S03B-PSIY-B1 S03B-PSIR-C2 S04B-PSILE-A1 S04B-PSIY-B1 S04B-PSIR-C2 16.65 3.7 9.35 B 3 □1.14 9 4 RoHS compliance This product displays (LF)(SN) on a label. Note: Other kinds of post-omitted products are available. Contact JST for details. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. A ex. S02B-PSILE-A1 LE...light blue Y...yellow R...red Pin contact Applicable wire mm2 AWG# Model No. SPSM-001T-M1.1 SPSM-41T-M1.1 26∼22 1.3∼2.4 2,600 0.5 ∼1.25 20∼16 1.7∼3.2 2,600 Material and Finish 18 2.2 Insulation O.D. (mm) Q'ty/reel 0.13∼0.33 6.6 4 Copper alloy, tin-plated 2.8 RoHS compliance Contact Crimping machine Crimp applicator MKS-L SPSM-001T-M1.1 AP-K2N SPSM-41T-M1.1 Applicator Dies   ―   MKS-L Crimp applicator with dies MK/SPSI/M-001-11 APLMK SPSI/M001-11 ― ― MK/SPSI/M-41-11 APLMK SPSI/M41-11   ―   ― ― Receptacle housing Circuits Keying A 2 3 C A B A B Model No. PSIR-02V-LE-A PSIR-02V-Y-B PSIR-03V-LE-A PSIR-03V-Y-B Dimensions (mm) A B C Q’ty/ bag 4.0 16.1 12.5 200 4.0 16.1 12.5 200 8.0 20.1 16.5 150 8.0 20.1 16.5 150 Material 9.1 Glass-filled PBT, UL94V-0 15.85 RoHS compliance 25.45 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B PSIR-03V-LE-A LE...light blue Y...yellow 8.45 4 PSI CONNECTOR Contact position location numbers Socket housing 5 4 3 2 14 13 12 11 10 9 8 7 2 1 Header Header ● Top entry ● Side entry 14 13 12 11 10 1 6 5 4 3 5 4 3 2 9 8 2 1 1 1 7 6 5 4 3 2 Receptacle housing 3 3 4 2 1 Single Double Single Double Single Single Pin-omitted Header 1) When setting two times of pitch in single type header with omitting every other one pin However, pins shall be inserted in No.1-circuit and No. N-circuit. B *1 (8.0)B-PSI ; With circuit (pin) e.g.) *1; No. of circuits (No. of pins) Circuit No. 3 ; Without circuit (pin) 2 1 Circuit (pin) Model No. 5 Circuit No. 4 e.g.) Circuit No. Model No. B3(8.0)B-PSILE-1 6 5 4 3 2 1 Circuit (pin) *1; No. of circuits (No. of pins) *2; Circuit No. of used original header *3; Circuit number without pin (Circuit number in which pin was removed) Circuit No. Circuit (pin) Model No. B4(6-2, 5)B-PSILE-1 3) When setting three times of pitch in double type header with omitting every other two pins However, pins shall be inserted in the both ends of circuit. B *1 (*2-*3)B-PSI e.g.) Circuit No. 14 13 12 11 10 9 8 7 6 5 4 3 2 1 Circuit (pin) Circuit No. Circuit (pin) Model No. B6(14-2, 3, 5, 6, 9, 10, 12, 13)B-PSILE-1 4) When omitting a pin of No.3 circuit in single type herder However, pins shall be inserted in the both ends of circuit. B *1 (*2-*3)B-PSI e.g.) Circuit No. 5 4 3 2 Circuit (post) Model No. B4(5-3)B-PSILE-1 Note) As for pin-omitted product, there is a setting that cannot be used. Contact JST for details. 5 2 Circuit (pin) B2(8.0)B-PSILE-A1 2) When setting two times of pitch in double type header with omitting every other one pin However, pins shall be inserted in the both ends of circuit. B *1 (*2-*3)B-PSI 3 1 1 PSI CONNECTOR Keying Socket housing Shape A type B type C type A type B type C type A type B type C type 2 circuits 3 circuits 4 circuits Header Top entry type Shape 2 circuits 3 circuits 4 circuits Side entry type Shape 2 circuits 3 circuits 4 circuits Receptacle housing Shape A type B type 2 circuits 3 circuits 6
PSIP-06V-LE
1. 物料型号:文档中提到了多种型号的PSI CONNECTOR,包括用于线对板和线对线的4.0毫米间距连接器,有单排和双排类型。
2. 器件简介:PSI CONNECTOR设计用于4.0毫米间距的连接器,采用低插入力接触,具有优秀的操作性。它具有防止反向插入的锁定机制,并通过键形和多种颜色的外壳实现防错配功能。
3. 引脚分配:文档中提供了详细的PCB布局和组装布局图,展示了不同类型连接器的引脚分配
4. 参数特性: - 电流额定值:12 A AC, DC(具体值取决于电路数量和使用的线规)。 - 电压额定值:300 V AC, DC。 - 温度范围:-25°C 至 +85°C。 - 接触电阻:初始值/最大10 mΩ,环境测试后/最大20 mΩ。 - 绝缘电阻:最小1,000 MΩ。 - 耐电压:1,500 VAC/分钟。 - 适用电线:AWG #26至#16。
5. 功能详解:文档中解释了连接器的锁定结构、防错配机制、手指友好设计,并指出实现了大电流。
6. 应用信息:连接器符合RoHS标准,并且文档中提到了在使用端子和连接器时的一般指导和注意事项。
7. 封装信息:文档提供了插座接触件、插座外壳、插头外壳的型号、适用电线、绝缘外径、每卷数量等信息,以及材料和表面处理的详细描述,如铜合金、锡镀层等。
PSIP-06V-LE 价格&库存
很抱歉,暂时无法提供与“PSIP-06V-LE”相匹配的价格&库存,您可以联系我们找货
PSIP-06V-LE
    库存:510
    PSIP-06V-LE
      库存:3800
      PSIP-06V-LE
        • 1+2.198331+0.28476
        • 10+2.1198210+0.27459
        • 50+1.5876850+0.20566
        • 100+1.23002100+0.15933
        • 500+1.15151500+0.14916
        • 1000+1.099171000+0.14238
        • 2000+1.073002000+0.13899
        库存:37
