SMBJ6.5CA
SMBJ6.5CA
    SINO-IC(光宇睿芯)
    SMB(DO-214AA)
    SMBJ6.5CA
SMBJ6.5CA 数据手册
SHANGHAI MARCH 2008 MICROELECTRONICS CO., LTD. SMBJ Seires 600 W Surface Mount Transient Voltage Suppressors FGeneral Description Features SMBJ Seires from SINO-IC is designed z Peak pulse power: 600 W (10/1000μs) to protect voltage sensitive components from z Breakdown Voltage :5.0V~120V high voltage, high energy transients. It has z Bidirectional Type excellent clamping capability, high surge z Low Clamping Factor capability, z Fast Response Time < 1 ns fast Revision:B response time and cost-effectiveness. z Glass Passivated Junction Applications Mechanical Data z Communication Systems Case: JESEC DO214AA. Molded plastic over glass z Power Supplies passivated junction z Medical Equipment Polarity: Color band denoted positive end z Business Machines (cathode) except Bidirectional Absolute Maximum Ratings @ 25°C Unless Otherwise Specified Parameter Symbol Value Uni ts Peak Power Dissipation (Note 1.) @TL = 25°C, Pulse Width = 1 ms PPK 600 W Peak pulse current of on 10/1000μs waveform IPPM SEE TABLE 1 A Peak forward surge Current IPSM 100 A Storage Temperature Range TSTG -55 to 150 °C TJ, TSTG -55 to 150 °C Operating Junction and Storage Temperature Range Notes: 1. 10 X 1000 us, non–repetitive 2. 1/2 sine wave (or equivalent square wave), PW = 8.3 ms, duty cycle = 4 pulses per minute maximum. 3. Mounted on 5.0mm2(0.03mm thick) Copper Rads to each terminal 4. A transient suppressor is normally selected according to the working peak reverse voltage (VRWM), which should be equal to or greater than the DC or continuous peak operating voltage level. 5. VBR measured at pulse test current IT at an ambient temperature of 25°C. 6. Surge current waveform per Figure 1 and derate per Figure 3. Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM Working Peak Reverse Voltage IR Maximum Reverse Leakage Current @ VRWM IT Test Current VBR Breakdown Voltage @ IT ShangHai Sino-IC Microelectronics Co., Ltd. 1. Electrical Characteristics Per Line @ 25°C Unless Otherwise Specified PART NUMBER V(BR)@IT VRWM (V) min max (V) (V) IT VC@ IPP IPP (mA) (V) (A) IR@ VRWM ( μ A) UNI-POLAR BI-POLAR SMBJ5.0A SMBJ5.0CA 5.0 6.40 7.25 10 9.2 65.2 800 SMBJ6.0A SMBJ6.0CA 6.0 6.67 7.67 10 10.3 58.3 800 SMBJ6.5A SMBJ6.5CA 6.5 7.22 7.98 10 11.2 53.6 500 SMBJ7.0A SMBJ7.0CA 7.0 7.78 8.95 10 12.0 50.0 200 SMBJ7.5A SMBJ7.5CA 7.5 8.33 9.58 1 12.9 46.5 100 SMBJ8.0A SMBJ8.0CA 8.0 8.89 10.23 1 13.6 44.1 50 SMBJ8.5A SMBJ8.5CA 8.5 9.44 10.82 1 14.4 41.7 20 SMBJ9.0A SMBJ9.0CA 9.0 10.00 11.50 1 15.4 39.0 10 SMBJ10A SMBJ10CA 10 11.10 12.80 1 17.0 35.3 5 SMBJ11A SMBJ11CA 11 12.20 14.00 1 18.2 33.0 5 SMBJ12A SMBJ12CA 12 13.30 15.30 1 19.9 30.2 5 SMBJ13A SMBJ13CA 13 14.40 16.50 1 21.5 27.9 5 SMBJ14A SMBJ14CA 14 15.60 17.90 1 23.2 25.8 5 SMBJ15A SMBJ15CA 15 16.70 18.50 1.0 24.4 24.6 5 SMBJ16A SMBJ16CA 16 17.80 19.70 1.0 26.0 23.1 5 SMBJ17A SMBJ17CA 17 18.90 20.90 1.0 27.6 21.7 5 SMBJ18A SMBJ18CA 18 20.00 22.10 1.0 29.2 20.5 5 SMBJ20A SMBJ20CA 20 22.20 24.50 1.0 32.4 18.5 5 SMBJ22A SMBJ22CA 22 24.40 26.90 1.0 35.5 16.9 5 SMBJ24A SMBJ24CA 24 26.70 29.50 1.0 38.9 15.4 5 SMBJ26A SMBJ26CA 26 28.90 31.90 1.0 42.1 14.3 5 SMBJ28A SMBJ28CA 28 31.10 34.40 1.0 45.4 13.2 5 SMBJ30A SMBJ30CA 30 33.30 36.80 1.0 48.4 12.4 5 SMBJ33A SMBJ33CA 33 36.70 40.60 1.0 53.3 11.3 5 SMBJ36A SMBJ36CA 36 40.00 44.20 1.0 58.1 10.3 5 SMBJ40A SMBJ40CA 40 44.40 49.10 1.0 64.5 9.3 5 SMBJ43A SMBJ43CA 43 47.80 52.80 1.0 69.4 8.6 5 SMBJ45A SMBJ45CA 45 50.00 55.30 1.0 72.7 8.3 5 SMBJ48A SMBJ48CA 48 53.30 58.90 1.0 77.4 7.8 5 SMBJ51A SMBJ51CA 51 56.70 62.70 1.0 82.4 7.3 5 SMBJ54A SMBJ54CA 54 60.00 66.30 1.0 87.1 6.9 5 SMBJ58A SMBJ58CA 58 64.40 71.20 1.0 93.6 6.4 5 SMBJ60A SMBJ60CA 60 66.70 73.70 1.0 96.8 6.2 5 SMBJ64A SMBJ64CA 64 71.10 78.60 1.0 103 5.8 5 SMBJ70A SMBJ70CA 70 77.80 86.00 1.0 113 5.3 5 SMBJ75A SMBJ75CA 75 83.30 92.10 1.0 121 5.0 5 SMBJ78A SMBJ78CA 78 86.70 95.80 1.0 126 4.7 5 SMBJ85A SMBJ85CA 85 94 104 1.0 137 4.4 5 SMBJ90A SMBJ90CA 90 100 111 1.0 146 4.1 5 SMBJ100A SMBJ100CA 100 111 123 1.0 162 3.7 5 SMBJ110A SMBJ110CA 110 122 135 1.0 177 3.4 5 SMBJ120A SMBJ120CA 120 133 147 1.0 193 3.1 5 ShangHai Sino-IC Microelectronics Co., Ltd. 2. Rating And Characteristic Curves@ 25°C Unless Otherwise Specified Fig1. Peak Pulse Power Rating Fig3. Pulse Waveform Fig5.- Typ. Transient Thermal Impedance ShangHai Sino-IC Microelectronics Co., Ltd. Fig2. Pulse Derating Curve Fig4. Typical Junction Fig6.- Maxmum Non-Repetitive Peak Forward Surge Current 3. PACKAGE DIMENSIONS (DO-214AA) The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics Co., Ltd. © 2005 SINO-IC – Printed in China – All rights reserved. SHANGHAI SINO-IC MICROELECTRONICS CO., LTD Add: Building 3, Room 3401-03, No.200 Zhangheng Road, ZhangJiang Hi-Tech Park, Pudong, Shanghai 201203, China Phone: +86-21-33932402 33932403 33932405 33933508 33933608 Fax: +86-21-33932401 Email:szrxw002@126.com Website: http://www.sino-ic.net ShangHai Sino-IC Microelectronics Co., Ltd. 4.
SMBJ6.5CA 价格&库存
很抱歉,暂时无法提供与“SMBJ6.5CA”相匹配的价格&库存,您可以联系我们找货
