CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS
HXE
Surface Mount
Upgrade!
Series
・High reliability is realized by hybrid electrolyte
・Endurance with ripple current : 2,000 to 4,000 hours at 135℃
・Rated voltage range : 16 to 63Vdc, Capacitance range : 22 to 560μF
・For high temperature and high reliability applications.
(Automotive equipment, Base station equipment, etc.)
・RoHS2 Compliant
・Halogen Free
・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information.
HXE
Higher temperature
HXC
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-55 to +135℃
16 to 63Vdc
±20% (M)
I=0.01CV or 3μA, whichever is greater
Where, I : Max. leakage current (μA)
, C: Nominal capacitance(μF), V : Rated voltage(V)
Rated voltage(Vdc)
16V
25V
35V
50V
63V
tanδ
0.16
0.14
0.12
0.10
0.08
(Max.)
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
(at 20℃, 120Hz)
(at 20℃ after 2 minutes)
(at 20℃, 120Hz)
Z(-25℃)/Z(+20℃)≦1.5
Z(-55℃)/Z(+20℃)≦2.0
(at 100kHz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for 4,000 hours (F61, F80 : 2,000 hours) at 125℃ or 135℃.
Capacitance change
≦±30% of the initial value
D.F. (tanδ)
≦ 200% of the initial specified value
ESR
Leakage current
≦ The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 135℃
without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to item 4.1 of JIS
C 5101-4.
Capacitance change
D.F. (tanδ)
ESR
Leakage current
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them to the DC rated voltage
at 85℃, 85% RH for 2,000 hours.
Appearance
No significant damage
Capacitance change
≦ ±30% of the initial value
D.F.(tanδ)
ESR
Leakage current
Shelf Life
Bias Humidity Test
◆DIMENSIONS [mm]
● Terminal
● Terminal
● Size
● Size
(Except F61 to HA0)
(Except F61 to HA0)
0.3max.
L±0.3 (Note)
0.3max.
φD±0.5
P
C±0.2
B±0.2
φD±0.5
W
L±0.3 (Note)
Note : L±0.5 for HA0 to JH0
A±0.2
2
3
4
H HXE
5
6
7
8
9
10
RA
11
12
A±0.2
Size Code
F61
F80
HA0
JA0
JC5
JH0
φD
6.3
6.3
8
10
10
10
L
5.8
7.7
10.0
10.0
12.5
16.5
A
6.6
6.6
8.3
10.3
10.3
10.3
B
6.6
6.6
8.3
10.3
10.3
10.3
C
7.2
7.2
9.0
11.0
11.0
11.0
W
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
0.7 to 1.1
1.0 to 1.3
P
1.9
1.9
3.1
4.5
4.5
4.5
: Dummy terminals
◆MARKING
◆PART NUMBERING SYSTEM
1
W
P
C±0.2
Vent
Vent
Code : G(Vibration resistant structure)
code : F61 to JH0
B±0.2
Code : A
code : F61 to JH0
13
14
M
15
16
17
18
G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 47µF:470, 100µF:101)
Taping code
Terminal code (A, G)
Voltage code (ex. 35V:350, 50V:500)
Series code
Category
EX) 35V270µF
47E
270
V HE
●Rated
voltage symbol
Rated voltage (Vdc)
16
25
35
50
63
Symbol
C
E
V
H
J
Please refer to "Product code guide (conductive polymer hybrid type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001U Ver.3
Surface Mount
HXESeries
Upgrade!
◆STANDARD RATINGS
WV
(Vdc)
Cap
(μF)
Size code
82
150
270
470
560
56
100
220
330
470
560
47
68
150
270
330
470
33
47
56
68
100
120
150
220
22
33
33
47
56
82
100
150
16
25
35
50
63
ESR
(mΩmax./20℃, 100kHz)
F61
F80
HA0
JA0
JC5
F61
F80
HA0
JA0
JC5
JH0
F61
F80
HA0
JA0
JC5
JH0
HA0
HA0
JA0
HA0
JA0
JA0
JC5
JH0
HA0
HA0
JA0
HA0
JA0
JA0
JC5
JH0
45
27
15
50
30
22
14
60
35
22
14
30
30
25
30
25
25
19
16
40
40
30
40
30
30
22
16
Rated ripple current
(mArms/100kHz)
125℃
135℃
1,700
2,500
3,050
3,400
4,000
1,400
2,100
2,900
3,300
3,900
4,300
1,400
2,100
2,900
3,300
3,800
4,300
2,400
2,400
2,900
2,400
2,900
2,900
3,400
4,100
2,100
2,100
2,600
2,100
2,600
2,600
3,200
4,100
950
1,450
1,700
2,100
2,300
900
1,400
1,600
2,000
2,300
2,500
900
1,400
1,600
2,000
2,200
2,500
1,250
1,250
1,600
1,250
1,600
1,600
2,000
2,400
1,100
1,100
1,400
1,100
1,400
1,400
1,900
2,400
Part No.
HHXE160□RA820MF61G
HHXE160□RA151MF80G
HHXE160□RA271MHA0G
HHXE160□RA471MJA0G
HHXE160□RA561MJC5G
HHXE250□RA560MF61G
HHXE250□RA101MF80G
HHXE250□RA221MHA0G
HHXE250□RA331MJA0G
HHXE250□RA471MJC5G
HHXE250□RA561MJH0G
HHXE350□RA470MF61G
HHXE350□RA680MF80G
HHXE350□RA151MHA0G
HHXE350□RA271MJA0G
HHXE350□RA331MJC5G
HHXE350□RA471MJH0G
HHXE500□RA330MHA0G
HHXE500□RA470MHA0G
HHXE500□RA560MJA0G
HHXE500□RA680MHA0G
HHXE500□RA101MJA0G
HHXE500□RA121MJA0G
HHXE500□RA151MJC5G
HHXE500□RA221MJH0G
HHXE630□RA220MHA0G
HHXE630□RA330MHA0G
HHXE630□RA330MJA0G
HHXE630□RA470MHA0G
HHXE630□RA560MJA0G
HHXE630□RA820MJA0G
HHXE630□RA101MJC5G
HHXE630□RA151MJH0G
□ : Enter the appropriate terminal code.
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
Frequency(Hz)
22 to 33
47 to 150
220 to 560
120
0.07
0.10
0.13
1k
0.30
0.40
0.45
5k
0.50
0.60
0.65
10k
0.60
0.70
0.75
20k
0.70
0.80
0.85
30k
0.75
0.80
0.85
100k to 500k
1.00
1.00
1.00
