USB4520-03-0-A
USB4520-03-0-A
    GCT
    USB4520-03-0-A
USB4520-03-0-A 数据手册
11.24 6.40 4.80 3.50 2.50 1.50 H Optional shell spring 2x 1.80 2x 1.40 16x 0.20±0.05 A 0.50 8x0.30 A4B9 G B8 A5 B7 A6 A7 B6 A8 B5 B1 A12 2x 2.20 F A 8.94 As viewed from component side PCB Edge 2.10 3.16 A12 B12 B1 11.24 0.10 1.20 2.10 0.80 4.00 Pin Signal Mating Sequence Pin Signal C A1 GND First B12 GND First VBUS First B9 VBUS First A5 CC1 Second B8 SBU2 Second A6 Dp1 Second B7 Dn2 Second A7 Dn1 Second B6 Dp2 Second A8 SBU1 Second B5 CC2 Second A9 VBUS First B4 VBUS First A12 GND First B1 GND GND 4.60 4.45 B8 A5 B7 A6 A7 B6 A8 B5 2.50 3.50 4.55 5.05 6.15 6.65 A 1 0.20 0.50 1.50 Ordering Grid 03 USB4520 X Contact Plating 03 = 3µ" Gold 0.70 Part Number Product Description USB4520 USB Type C Receptacle for USB 2.0, SMT Type, Mid Mount, 2.1mm Offset By Detail 4 Revision Date 5 CC Drawing Release A 01/07/21 Tolerances (Except as Noted) Length Angle X.X ± 0.30 X.XX ± 0.20 X.XXX ± 0.10 - Units: Metric (mm) C 3rd Angle Projection 6 A Request Samples and Quotation Packing Options A = Tape & Reel Shell Spring 0 = Without 1 = With Plug and Receptacle Mating View Section A-A 1st July 2021 3 First Mechanical & Environmental Operating Temperature: -25°C to +85°C Mating Force: 5 to 20 N. Unmated Force: 6 to 20 N after test Durability: 10,000 cycles Drawing Date 2 5.00A collectively for VBUS pins 6.25A collectively for GND pins 1.25A for B5 pin 0.25A per pin for all other pins Voltage Rating: 20V DC Contact Resistance: 40mΩ max initial. 50mΩ max after test Dielectric Withstanding Voltage: 100V AC Insulation Resistance 100MΩ min GND Plug 6.5 Max. B1 A12 0.70±0.05 A1 B12 SHELL Electrical Current Rating: 2.05 Min B4A9 1.20±0.05 B Mating Sequence A4 SHELL A4B9 Plating Terminal: Contact Area: See Ordering Grid Solder Tails: Gold Flash Underplating: 50µ" Min. Nickel All Over Shell: 30µ" Min. Nickel Tolerance:±0.05mm Component Outline 0.52 Solder Area 0.85 D Material Insulator: LCP, E130i, UL 94V-0, Black Contact: Copper Alloy, C18400-H, T=0.12mm Shell: Stainless steel , SUS304-1/2H, T=0.30mm Mid Plate:Stainless Steel, SUS301-3/4H, T=0.15mm Recommended PCB Layout Thickness=0.80mm 8.34 6.69+0.045 -0.055 A1 Specifications 4x 0.60 4x1.00 9.24 +0.06 -0.02 2.56±0.04 E 2x 1.80 1.60 6.5 4.00 4.60 5.70 A1 B12 4x 0.60 B4 A9 7 (1400 pcs/reel) This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 1/2 Folder Paper Board H Unloaded Section 1400 PCS Unloaded Section (16 Pockets) Paper Board (16 Pockets) G Detail E Direction of Unreeling F Peeling Angle Vacuum Bag 165°~180° Reel and Tape E Ø330 Carton D 3 320 Ø1 Label Paper Board W+0.5 34 0 Direction of Unreeling C 0 34 4.00 2.00 Pcs / Reel 1400 1.75 24.00 B Product Description USB4520 USB Type C Receptacle for USB 2.0, SMT Type, Mid Mount, 2.1mm Offset 1st July 2021 By Detail: E 1 2 Detail 3 4 Total Quantity 14000 pcs Part Number Drawing Date 12.00 A Reels / Carton 10 Revision Date 5 CC Drawing Release A 01/07/21 Tolerances (Except as Noted) Length Angle - - Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 2/2
USB4520-03-0-A 价格&库存
很抱歉,暂时无法提供与“USB4520-03-0-A”相匹配的价格&库存,您可以联系我们找货
USB4520-03-0-A
    USB4520-03-0-A
      USB4520-03-0-A
      • 1+6.337861+0.82254
      • 10+5.3642810+0.69619
      • 25+5.0315225+0.65300
      • 50+4.7901550+0.62168
      • 100+4.56017100+0.59183
      • 250+4.27430250+0.55473
      • 500+4.07010500+0.52823
      库存:10215
