Applications Note: SY8718A1
High Efficiency,23V,2.0A Synchronous Step Down
Regulator For Dimmable LED Driver
General Description
Features
The SY8718A1 is a high efficiency synchronous stepdown LED regulator that achieves up to 2.0A output
current. It operates at 1MHz and integrates two very
low RDS(ON) power switches to minimize and reduce
the external components.
Wide Input Range: 4V-23V
Up to 2.0A Output Current Capability
Low RDS(ON) for Internal Switches
High Side/Low Side:125mΩ/75mΩ
Fixed 1MHz Switching Frequency
Cycle by Cycle 3.5A Peak Current Limit for High
Side and 2.5A Valley Current Limit for Low Side
High Accuracy for Low Dimming Scale
Output Voltage Discharging
Over Temperature Protection
Compact Package: TSOT23-6
It supports the PWM dimming duty 5%-100% to
achieve dimmable LED lighting application.
Ordering Information
SY8718 □(□□)□
Temperature Code
Package Code
Optional Spec Code
Ordering Number
SY8718A1ADC
Package type
TSOT23-6
Applications
DVR Or NVR(IP Camera) System Application
12VDC Lighting
Note
Typical Applications
L1
5V-12V
4
LX
IN
1.5V-9.0V
CBS
CIN
22µF
3
GND
BS
6
RDIM2
1MΩ
1
FB
DIM
6.8μH
5
COUT
0.1µF 22µF
CDIM1
NC
Dimming
Signal
2
RDIM1 10KΩ
R1
1KΩ
RS1
0.067Ω
Figure.1 Schematic
AN_SY8718A1 Rev.0.9
© 2018 Silergy Corp.
Silergy Corp. Confidential-Prepared for Customer Use Only
1
All Rights Reserved.
AN_SY8718A1
Pinout (Top View)
FB
1
6
BST
DIM
2
5
LX
GND
3
4
IN
(TSOT23-6)
Top Mark: Wr xyz, (Device code: Wr; x=year code, y=week code, z= lot number code)
Pin Name
Pin Number
Pin Description
FB
1
DIM
2
GND
3
Output current feedback pin. The output current: IOUT =0.1V/ RS
Dimming signal input. The PWM dimming duty range: 5%-100%
Support the dimming frequency from 20KHz to 500KHz
Ground pin
IN
4
Input supply pin. Decouple this pin to GND pin with a 1µF ceramic cap
LX
5
BST
6
Switching node pin. Connect this pin to the inductor
Boot-strap pin. Supply for top side gate driver. Decouple this pin to LX
with a 0.1µF ceramic cap
Dimming Scale
100%
5%
0%
3%
5%
100%
DDIM
Figure.2 Ideal dimming curve of SY8718A1
AN_SY8718A1 Rev.0.9
2
AN_SY8718A1
Block Diagram
IN
Bias&Ref
DIM
Regulator
BST
Dimming Curve
Conversion
Slope
Compensation
FB
Peak Current
Detectation
1MHz
Clock
Driver
LX
COMPARATOR
ERROR
AMPLIFIER
Fault
Detectation
Valley Current
Detectation
GND
OTP
Figure.3 Functional Block Diagram
Absolute Maximum Ratings (Note 1)
IN, DIM, FB----------------------------------------------------------------------------------------------- -0.3V to 25V
LX ---------------------------------------------------------------------------------------------------------------- -0.3V(*1) to 25V(*2)
BST-LX ------------------------------------------------------------------------- --------------------- -0.3V to 4V
Power Dissipation, PD @ TA = 25°C TSOT23-6 ------------------------------------------------------- 1.5W
Package Thermal Resistance (Note 2)
Ɵ JA ------------------------------------------------------------------------------------ ------------------------------- 66°C/W
Ɵ JC -------------------------------------------------------------------------------------------------------------------- 15°C/W
Junction Temperature Range ------------------------------------------------------------------------------------- -40°C to150°C
Lead Temperature (Soldering, 10 sec.) ---------------------------------------------------------------------------- 260°C
Storage Temperature Range ------------------------------------------------------------------------------------- -65°C to 150°C
(*1) LX Voltage tested down to -3V
很抱歉,暂时无法提供与“SY8718A1ADC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.40913
- 10+1.98195
- 30+1.63043
- 100+1.46794
- 300+1.33809
- 国内价格
- 1+1.55100
- 100+1.24300
- 750+1.11100
- 1500+1.04390
- 3000+0.98890
