MAX706TM/TR
MAX706TM/TR
    HGSEMI(华冠)
    SOP-8
    低功耗微处理器监控电路
MAX706TM/TR 数据手册
MAX706/MAX706T/ MAX706S/MAX760R Low-Power µP Supervisor Circuits DESCRIPTION The MAX706/MAX706T/MAX706S/MAX706R CMOS supervisor circuits monitor power-supply and battery voltage level, and µP/µC operation. Compared to pin-compatible devices offered by Maxim Integrated Products, these devices feature 60 percent DIP8 lower maximu m supply current. The family offers several functional options. Each device SOP8 generates a reset signal during power-up, power-down and during brownout conditions. MSOP8 A reset is generated when the supply drops below4.4V (MAX706),3.08V (MAX706T),2.93V (MAX706S),2.63V(MAX706R).In addition,the MAX706/T/S/R feature a 2.4 second watchdog timer. A versatile power-fail circuit has a1.25V threshold, useful in ch ecking battery levels and non-5V supplies. All devices have a manual reset ( MR ) input. The watchdog timer output will trigger a reset if connected to MR . All devices are available in DIP8, SOP8 and MSOP8 packages. ORDER I NG I NFORMATI ON DEVICE Package Type MARKING Packing Packing Qty MAX607N DIP8L MAX607 TUBE 2000pcs/box MAX607TN DIP8L MAX607T TUBE 2000pcs/box MAX607SN DIP8L MAX607S TUBE 2000pcs/box MAX607RN DIP8L MAX607R TUBE 2000pcs/box MAX607M/TR SOP8L X607 REEL 2500pcs/reel MAX607TM/TR SOP8L X607T REEL 2500pcs/reel MAX607SM/TR SOP8L X607S REEL 2500pcs/reel MAX607RM/TR SOP8L X607R REEL 2500pcs/reel MAX607MM/TR MSOP8L X607 REEL 3000pcs/reel MAX607TMM/TR MSOP8L X607T REEL 3000pcs/reel MAX607SMM/TR MSOP8L X607S REEL 3000pcs/reel MAX607RMM/TR MSOP8L X607R REEL 3000pcs/reel http://www.hgsemi.com.cn 1 2022 JAN MAX706/MAX706T/ MAX706S/MAX760R FEATURES Improved replacements for the Maximu m MAX706/T/S/R – 140µA maximum supply current – 60% improvement Precision power supply monitor – 4.4V threshold (MAX706) – 3.08V threshold (MAX706T) – 2.93V threshold (MAX706S) – 2.63V threshold(MAX706R) Debounced manual reset input Voltage monitor – 1.25V threshold – Battery monitor/Auxiliary supply monitor Watchdog timer (MAX706/ MAX706T/MAX706S/MAX706R) 300ms reset pulse width MicroSO package B L OCK DIAGRAM http://www.hgsemi.com.cn 2 2022 JAN MAX706/MAX706T/ MAX706S/MAX760R APPLICATIONS ● ● ● ● Battery-operated systems ● Wireless communication systems Computers and embedded controllers Intelligent instruments PDAs and handheld equipment PIN CONFIGURATION DIP/SOP MSOP PIN DESCRIPTION Pin No. MAX706/MAX706T/MAX706S/MAX706R DIP/SOP MSOP Name Pin Function Manual RESET input. The active LOW input triggers a reset pulse. A 250µA pull-up current allows the pin to be driven by TTL / CMOS logic or shorted to ground with a switch. +5V power supply input. 1 3 MR 2 4 Vcc 3 5 GND Ground reference for all signals. Power-fail voltage monitor input. 4 6 PFI 5 7 PFO 6 8 WDI With PFI less than 1.25V, PFO goes low. Connect PFI to ground or V C C when not used. Power-fail output. The output is active LOW and sinks current when PFI is less than1.25V. Watchdog input. WDI controls the internal watchdog timer. A HIGH or LOW signal for2.4sec at WDI allows the internal timer to http://www.hgsemi.com.cn 3 run-out, setting WDO LOW. The watchdog function is disabled by floating WDI or by connecting WDI to a high-impedance 2022 JAN MAX706/MAX706T/ MAX706S/MAX760R 6 7 8 WDI 1 RESET three-state buffer. The internal watchdog timer clears when: RESET is asserted; WDI is three-stated; or WDI sees a rising or falling edge. Active-LOW reset output. Pulses LOW for 300ms when triggered, and stays low whenever Vcc is below the reset threshold (MAX706: 4.4V, MAX706T: 3.08V, MAX706S: 1.93V,MAX706R:2.63). RESET remains LOW for 300ms after Vcc rises above the RESET threshold or MR goes from LOW to HIGH. A watchdog timeout will not trigger RESET unless WDO is connected to MR . 8 Watchdog output. WDO pulls LOW when the 2.4 sec internal watchdog timer times-out and does not go HIGH until the watchdog is cleared. In addition, when Vcc is below the reset 2 WDO threshold, WDO remains low. Unlike RESET , WDO does not have a minimum pulse width and as soon as Vcc exceeds the reset threshold, WDO goes HIGH with no delay. ABSOLUTE MAXIMUM RATING (Ta=25 ℃ ) Characteristics Supply voltage All other inputs *1 Input current at Vcc and GND Output current :All outputs Rate of Rise at Vcc Plastic DIP power dissipation (Derate 9mW/℃ above 70 ℃ ) SOP power dissipation (Derate 5.9mW/℃ above 70 ℃ ) MSOP power dissipation (Derate 4.1mW/℃ above 70 ℃ ) Operating temp erature range Storage temperature range Lead temperature (soldering,10 sec.) Value -0.3~ +6.0 -0.3~ Vcc+0.3 20 20 100 700 470 330 0~ 70 -65 ~ +150 300 Unit V V mA mA V/µs mW mW mW ℃ ℃ ℃ * 1 . T h e i n p u t v o l t a g e l i m i t s o n P F I a n d MR c a n b e e x c e e d e d i f t h e i n p u t c u r r e n t i s l e s s t h a n 10mA. http://www.hgsemi.com.cn 4 2022 JAN MAX706/MAX706T/ MAX706S/MAX760R ELECTRICAL CHARACTERISTICS ( Unless otherwise noted, V C C = 4.5V to 5.5V for the MAX706/MAX706T/MAX706S/MAX706R) Characteristics Symbol Conditions Min. Typ . Max Unit Operating voltage range Vcc MAX706/T/S/R 1.2 5.5 V Supply current Icc MAX706/T/S/R 75 140 µA MAX 706 4.25 4.4 4.5 MAX 706T 2.98 3.08 3.15 V V RT RESET threshold MAX 706S 2.83 2.93 3 MAX 706R 2.54 2.63 2.69 40 mV RESET threshold hysteresis RESET pulse width MR pulse width MR to o ut RESET delay MR input threshold t RS 1 40 t MR 0.15 0.25 WDI input threshold WDI input current WDO output voltage PFI input threshold PFI input current PFO output voltage t WD t WP V IH V IL ms µs 2.0 V IH V IL RESET output voltage 420 µs t MD MR =0V 100 I S O U R C E =800µA I S I N K =3.2mA MAX706/T/S/R,Vcc=1.2 V, I S I N K =100µA MAX 706/T/S/R V IL =0.4V,V IH =0.8Vcc Vcc-1.5 MR pull-up current Watchdog timeout period WDI pulse width 300 MAX706/T/S/R,Vcc=5V 250 V 0.8 600 µA 0.4 V 0.3 2.00 50 3.5 MAX706/T/S/R,WDI=Vcc MAX706/T/S/R,WDI=0V -150 MAX706/T/S/R, Vcc-1.5 I S O U R C E =800µA MAX706/T/S/R, I S I N K =1.2mA Vcc=5V 1.20 -25 Vcc-1.5 I S O U R C E =800µA I S I N K =3.2mA 2.4 50 -50 3.00 0.8 150 s ns V µA V 0.4 1.25 0.01 1.30 25 V nA 0.4 V FEATURE SUMMARY Power-fail detector Brownout detection Manual RESET input Power-up/down RESET Watchdog timer Active-HIGH RESET output Active-LOW RESET output RESET threshold http://www.hgsemi.com.cn MAX706 ● ● ● ● ● MAX706T ● ● ● ● ● MAX706S ● ● ● ● ● MAX706R ● ● ● ● ● ● 4.4V ● 3.08V ● 2.93V ● 2.63V 5 2022 JAN MAX706/MAX706T/ MAX706S/MAX760R DETAIL DESCRIPTIONS RESET Operation The RESET signals are designed to start a µP/µC in a known state or return the system to a known state. RESET is guaranteed to be LOW with Vcc above 1.2V. During a power-up sequence, RESET remains low until the supply rises above the threshold level, either 4.4V, 3.08V, 2.93V or 2.63V. RESET goes high approximately 300ms after crossing the threshold. During power-down, RESET goes LOW as Vcc falls below the threshold level and is guaranteed to be under 0.4V with Vcc above 1.2V. In a brownout situation where Vcc falls below the threshold level, RESET pulses low. If a brownout occurs during an already initiated reset, the pulse will continue for a minimum of 140ms. Auxiliary Comparator All devices have an auxiliary comparator with 1.25V trip point and uncommitted output ( PFO ) and noninverting input (PFI). This comp arator can be used as a supply voltage monitor with an external resistor voltage divider. The attenuated voltage at PFI should be set just below the 1.25 threshold. As the supply level falls, PFI is reduced causing the PFO output to transit LOW. Normally PFO interrupts the processor so the system can be shut down in a controlled manner. Manual Reset ( MR ) The active-LOW manual reset input is pulled high by a 250µA pull-up current and can be driven low by CMOS/TTL logic or a mechan ical switch to ground. An external debounce circuit is unnecessary since the 140ms minimu m reset time will debounce mechanical pushbutton switches. By connecting the watchdog output ( WDO ) and MR , a watchdog timeout forces RESET to be generated. Watchdog Timer The watchdog timer available on the MAX 706/MAX706T/MAX706S/MAX706R monitors µP/µC activity. If activity is not detected within 2.4 seconds, the internal timer puts the http://www.hgsemi.com.cn 6 2022 JAN MAX706/MAX706T/ MAX706S/MAX760R watchdog output, WDO ,into a LOW state. WDO will remain LOW until activity is detected at WDI. The watchdog function is disabled, meaning it is cleared and not counting, if WDI is floated or connected to a three-stated circuit. The watchdog timer is also disabled if RESET is asserted. When RESET becomes inactive and the WDI input sees a high or low transition as short as 50ns, the watchdog timer will begin a 2.4 second countdown. Additional transitions at WDI will reset the watchdog timer and initiate a new countdown sequence. WDO will also become LOW and remain so, whenever the supply voltage, Vcc , falls below the device threshold level. WDO goes HIGH as soon as Vcc transitions above the threshold. There is no minimum pulse width for WDO as there is for the RESET outputs. If WDI is floated, WDO essentially acts as a low-power output indicator. APPLICATION INFORMATION Ensuring That RESET is Valid Down to Vcc = 0V When Vcc falls below 1.1V, the MAX706/MAX706T/MAX706S/MAX706R RESET output no longer pulls down; it becomes indeterminate. To avoid the possibility that stray charges build up and force RESET to the wrong state, a pull-down resistor should be connected to the RESET pin,thus draining such charges to ground and holding RESET low. The resistor value is not critical. A 100k Ω resistor will pull RESET to ground without loading it. Bi-directional Reset Pin Interfacing The MAX706/MAX706T/MAX706S/MAX706R can interface with µP/µC bi-directional reset pins by connecting a 4.7kΩ resistor in series with the RESET output and the µP/µC bi-directional RESET pin. http://www.hgsemi.com.cn 7 2022 JAN MAX706/MAX706T/ MAX706S/MAX760R MAX706x MAX706x Monitoring Voltages Other Than Vcc The MAX706/MAX706T/MAX706S/MAX706R can monitor voltages other than Vcc using the Power Fail circuitry. If a resistive divider is connected from the voltage to be monitored to the Power Fail input, PFI, the PFO (output) will go LOW if the divider voltage goes below its 1.25V reference. Should hysteresis be desired, connect a resistor (equal to approximately 10 times the sum of the two resistors in the divider) between the PFI and PFO pins. A capacitor between PFI and GND will reduce circuit sensitivity to input high-frequency noise. If it is desired to assert a RESET in addition to the PFO flag, this may be achieved by connecting the PFO output to MR . Monitoring a Negative Voltage The Power-Fail circuitry can also monitor a negative supply rail. When the negative rail is OK, PFO will be LOW, and when the negative rail is failing (not negative enough), PFO goes HIGH(the opposite of when positive voltages are monitored). To trigger a reset, these outputs need to be inverted: adding the resistors and transistor as shown achieves this. The RESET output will then have the sa me sense as for positive voltages: good = HIGH, bad = LOW. It should be noted that this circuit’s accuracy depends on the Vcc line, the PFI threshold tolerance, and the resistors. http://www.hgsemi.com.cn 8 2022 JAN MAX706/MAX706T/ MAX706S/MAX760R MAX706x MAX706x http://www.hgsemi.com.cn 9 2022 JAN MAX706/MAX706T/ MAX706S/MAX760R PACKAGE SOP8       Dimensions In Millimeters Symbol Min Max Symbol Min Max A 1.225 1.570 D   A1   Q  B    a  C    b  C1    DIP8                 http://www.hgsemi.com.cn  10                                         2022 JAN MAX706/MAX706T/ MAX706S/MAX760R PACKAGE A A2 MSOP8 D E E1 A1 e b © L       0.25    http://www.hgsemi.com.cn 11                                          2022 JAN MAX706/MAX706T/ MAX706S/MAX760R Important statement: Huaguan Semiconductor Co,Ltd. reserves the right to change the products and services provided without notice. Customers should obtain the latest relevant information before ordering, and verify the timeliness and accuracy of this information. Customers are responsible for complying with safety standards and taking safety measures when using our products for system design and machine manufacturing to avoid potential risks that may result in personal injury or property damage. Our products are not licensed for applications in life support, military, aerospace, etc., so we do not bear the consequences of the application of these products in these fields. Our documentation is only permitted to be copied without any tampering with the content, so we do not accept any responsibility or liability for the altered documents. http://www.hgsemi.com.cn 12 2022 JAN
MAX706TM/TR 价格&库存
很抱歉,暂时无法提供与“MAX706TM/TR”相匹配的价格&库存,您可以联系我们找货
