MAC97A8
MAC97A8
    JIJINGELECTRONICS(集晶电子)
    SOT23-3L
    MAC97A8
MAC97A8 数据手册
Collective Semiconductor Technology Zhongshan Co., Ltd. SEMICONDUCTOR TECHNICAL DATA (C03A180104) CST Sensitive Gate Triacs MAC97A8 1、Description Designed for use in solid state relays, MPU interface, TTL logic and any other light industrial or consumer application. Supplied in an inexpensive TO-92 package which is readily adaptable for use in automatic insertion equipment. Sensitive Gate Triggering In Four Trigger Modes for all possible Combinations of Trigger Sources, and Especially for Circuits that Source Gate Drives 2、Features  Blocking voltage to 600V  On-state RMS current to 1.0 A  Sensitive Gate Triggering in Four Trigger Modes (Quadrants) for all possible Combinations of Trigger Sources, and especially for Circuits that Source Gate Drives  All Diffused and Glassivated Junctions for Maximum Uniformity of Parameters and Reliability  Low cost package. 3、Pinning information PIN Description 1 main terminal 1(T1) 2 Gate(G) 3 main terminal 2(T2) Simplified outline Symbol T2 T1 G TO-92 4、Quick reference data SYMBOL PARAMETER MAX UNIT VDRM&VRRM Repetitive peak off-state voltages 600 V IT(RMS) RMS on-state current 1.0 A ITSM Non-repetitive peak on-state current 10 A Value UNIT 5、Thermal characteristics SYMBOL PARAMETER Rth(j-c) junction to case(AC) TO-92 75 C/W CST TEL:+86-760-89965801 1 http://www.zsjjdz.com MAC97A8 Sensitive Gate Triacs 6、Limiting value Limiting values in accordance with the Maximum System(IEC 134). SYMBOL PARAMETER CONDITIONS VDRM&VRRM Repetitive peak off-state voltages Tj=25°C IT(RMS) RMS on-state current Full Cycle Sine Wave 50 to 60 Hz (TC = 50°C ) One Full Cycle, Sine Wave 50 Hz (TC = 110°C ) MIN TYP MAX UNIT - - 600 V - - 1.0 A - - 10 A - - 0.4 As A It Non-repetitive peak on-state current 2 I t for fusing IGM Peak gate current - - 1.0 VGM Peak gate voltage - - 5.0 V PGM Peak gate power - - 1.0 W PG(AV) Average gate power - - 0.1 W Tstg Storage temperature -40 - 150 °C Tj Operating junction temperature -40 - 125 °C MAX UNIT ITSM 2 t = 8.3 ms 2 7、Characteristics TJ = 25℃ unless otherwise stated SYMBOL PARAMETER CONDITIONS MIN TYP Static characteristics IDRM IRRM Peak Repetitive Forward Or Reverse Blocking Curent VD=Rated VDRM and VRRM,RGK=1KΩ IGT Gate trigger current (VD = 12 Vdc, RL = 33 Ohms) IL Latching current - - 5 100 μA μA T2+ G+ T2+ GT2- GT2- G+ - 1.5 2.5 2.0 5.0 5 5 5 7 mA mA mA mA T2+ G+ T2+ GT2- GT2- G+ - - 10 20 10 10 mA mA mA mA TC=25℃ TC=110℃ VD = 12 V; IGT = 0.1A IH Holding current ITM = 200 mA ; - 2.5 7.0 mA VTM Peak On–State Voltage IT = 1.1A; tp=380uS - - 1.5 V VGT Gate trigger voltage (VD = 12 Vdc, RL = 33 Ohms) - - 1.5 1.5 1.5 1.5 V V V V 0.2 - - V 1.5 - - V/µs VGD Off-state leakage Voltage T2+ G+ T2+ GT2- GT2- G+ VD = VDRM, RL = 3.3KOhms, TJ = 110℃ ;All Four Quadrants Dynamic Characteristics dv/dt(c) Critical Rate–of–Rise of Commutation Voltage VD = Rated VDRM, ITM = .84 A, Commutating di/dt = .3 A/ms, Gate Unenergized, TC dv/dt Critical Rate of Rise of Off–State Voltage VD = Rated VDRM, TC Open, Exponential Waveform 5 - - V/µs tgt Gate controlled turn-on time VD = Rated VDRM, ITM = 1.0 A pk, IG = 25 mA - 2.0 - µs CST TEL:+86-760-89965801 2 http://www.zsjjdz.com MAC97A8 Sensitive Gate Triacs 8、Electrical Characteristics Curve CST TEL:+86-760-89965801 3 http://www.zsjjdz.com MAC97A8 Sensitive Gate Triacs 9、Package outline(TO-92) Marking: MAC 97A8 CST xxx DIM Inches Milimeters Min Type Max Min Type Max A 0.175 - 0.205 4.45 - 5.20 B 0.170 - 0.210 4.32 - 5.33 C 0.125 - 0.165 3.18 - 4.19 D 0.016 - 0.021 0.407 - 0.533 E 0.016 - 0.028 0.40 - 0.70 F - 0.043 - - 1.10 - G - 0.050 - - 1.27 - H - 0.091 - - 2.30 - J 0.013 - 0.018 0.32 - 0.45 K 0.500 - 0.591 12.7 - 15.0 N 0.080 - 0.105 2.04 - 2.66 P 0.073 - 0.081 1.86 - 2.06 V - - 0.177 - - 4.50 CST TEL:+86-760-89965801 4 http://www.zsjjdz.com
MAC97A8 价格&库存
很抱歉,暂时无法提供与“MAC97A8”相匹配的价格&库存,您可以联系我们找货
