RS2118YUTQK10
RS2118YUTQK10
    RUNIC(润石)
    QFNWB10L_1.4X1.8MM
    RS2118YUTQK10
RS2118YUTQK10 数据手册
RS2118 0.8Ω, Low Ron, Dual SPDT Analog Switch with Negative Rail Capability FEATURES • Low ON-State Resistance:0.8Ω (TYP) • Supply Range: +2.5V to +5.5V • Negative Signal Swing Capability: -2V to V+ • Break-Before-Make Switching • • Fast Switching Times 1.8V Logic Control • Rail-to-Rail Input and Output Operation • Extended Industrial Temperature Range: -40°C to +85°C Available in Green QFN-1.4x1.8-10L Package • DESCRIPTION The RS2118 is a bidirectional, 2-channel single-pole double-throw (SPDT) analog switch that is designed to operate from 2.5V to 5.5V. The device features negative signal capability that allows signals below ground to pass through the switch without distortion. The break-before-make feature prevents signal distortion during the transferring of a signal from one path to another. Low ON-state resistance, excellent channel-to-channel ON-state resistance matching, and minimal total harmonic distortion (THD) performance are ideal for audio applications This device is available packaged in QFN-1.4x1.8-10L. Functional Block Diagram SPDT APPLICATIONS • • Wearable Devices Battery-Operated Equipment • Portable Instrumentation • • • Cell Phones NC1 COM1 NO1 IN 1 SPDT Automation Test Equipment Relay Replacement COM2 NC2 NO2 IN 2 Rev A.3 1 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS2118 PIN CONFIGURATIONS (TOP VIEW) NC2 GND 7 6 IN2 8 5 NC1 COM2 9 4 IN1 NO2 10 3 COM1 1 2 V+ NO1 QFN-1.4x1.8-10L PIN DESCRIPTION NAME PIN FUNCTION V+ 1 NO1, NO2 2,10 Normally-Open Terminal COM1, COM2 3,9 Common Terminal IN1, IN2 4,8 Digital Control Pin NC1, NC2 5,7 Normally-Closed Terminal GND 6 Power Supply Ground NOTE: NOX, NCX and COMX terminals may be an input or output. FUNCTION TABLE LOGIC NO NC 0 OFF ON 1 ON OFF NOTE: Switches shown for logic “0” input. 2 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS2118 ABSOLUTE MAXIMUM RATINGS (1) V+, IN to GND..................................................-0.3V to 6.0V Analog Voltage Range (2) …....................-2.0 to (V+) + 0.3V Digital Voltage Range (2) ….....................-0.3 to (V+) + 0.3V Continuous Current NO, NC, or COM……......…....±250mA Peak Current NO, NC, or COM……........….....…... ±350mA Storage Temperature ……….…………… −65°C to +150°C Operating Temperature ……….…….……. −40°C to +85°C QFN-1.4x1.8-10L………………….…………………120°C/W HBM …......................................................................2000V MM ……………………….........………………...……….200V ESD SENSITIVITY CAUTION ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. (2) Input terminals are diode-clamped to the power-supply rails. Input signals that can swing more than 0.3V beyond the supply rails should be current-limited to 10mA or less. PACKAGE/ORDERING INFORMATION PRODUCT ORDERING NUMBER RS2118 RS2118YUTQK10 TEMPERATURE PACKAGE LEAD RANGE -40°C ~+85°C QFN-1.4x1.8-10L PACKAGE MARKING 2118X PACKAGE OPTION Tape and Reel,4000 NOTE: X = Date Code MARKING INFORMATION 2118 X Date code Product name 3 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS2118 ELECTRICAL CHARACTERISTICS V+ = 5.0 V, TA= –40°C to 85°C (unless otherwise noted) PARAMETER SYMBOL CONDITIONS V+ TA MIN TYP MAX UNITS ANALOG SWITCH Analog Signal Range VNO, VNC, VCOM On-Resistance On-Resistance Match Between Channels On-Resistance Flatness RON ∆RON RFLAT(ON) 2.5V ≤V+≤3.5V FULL 3.5V ≤V+≤5.5V 0 ≤ (VNO or VNC) ≤V+, ICOM = -10mA, Switch ON, See Figure 1 0 ≤ (VNO or VNC) ≤V+, ICOM = -10mA, Switch ON, See Figure 1 0 ≤ (VNO or VNC) ≤V+, ICOM = -10mA, Switch ON, See Figure 1 NC, NO OFF Leakage Current INC(OFF), INO(OFF) VNO or VNC = 0.3V, V+/2 VCOM = V+/2, 0.3V See Figure 2 NC, NO, COM ON Leakage Current INC(ON), INO(ON), VNO or VNC = 0.3V, Open VCOM = ICOM(ON) Open, 0.3V See Figure 3 -2.0 V+ (V+)-5.5 V+ 1.1 Ω 1.3 Ω 1.8 Ω 2 Ω 0.25 Ω 0.3 Ω 0.25 Ω 0.3 Ω 0.25 Ω 0.3 Ω 0.6 Ω 0.7 Ω 2.5V to FULL 5.5V 1 μA 2.5V to FULL 5.5V 1 μA 5V 3.3V 5V 3.3V 5V 3.3V +25°C 0.8 V FULL +25°C 1.3 FULL +25°C 0.15 FULL +25°C 0.15 FULL +25°C 0.15 FULL +25°C 0.4 FULL DIGITAL CONTROL INPUTS(1) Input High Voltage VINH Input Low Voltage VINL Input Leakage Current IIN 5V FULL 1.5 V 3.3V FULL 1.3 V 5V FULL 0.5 V 3.3V FULL 0.4 V 1 μA 2.5V to FULL 5.5V VIN = VIO or 0 (1) All unused digital inputs of the device must be held at VIO or GND to ensure proper device operation. 4 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS2118 ELECTRICAL CHARACTERISTICS (continued) V+ = 5.0 V, TEMP= –40°C to 85°C (unless otherwise noted)) PARAMETER SYMBOL CONDITIONS V+ 5V TEMP MIN TYP MAX UNITS DYNAMIC CHARACTERISTICS Turn-On Time tON VCOM = V+, RL = 300Ω, CL = 35pF, See Figure 5 Turn-Off Time tOFF VCOM = V+, RL = 300Ω, CL = 35pF, See Figure 5 Break-Before-Make Time Delay tBBM VNO1 = VNC1 = VNO2 = VNC2 = V+/2, RL = 300Ω, CL = 35pF,See Figure 6 Charge Injection Q Off Isolation OISO -3dB Bandwidth Channel-to-Channel Crosstalk NC, NO OFF Capacitance NC, NO, COM ON Capacitance BW 3.3V 5V 3.3V 5V 3.3V 15 +25°C ns 25 10 +25°C ns 15 5 +25°C ns 10 5V +25°C 80 3.3V +25°C 74 RL = 50Ω, Switch OFF, f = 1MHz See Figure 8 f = 10MHz +25°C -70 dB +25°C -50 dB Switch ON, RL = 50Ω See Figure 7 +25°C 80 MHz +25°C -72 dB +25°C -52 dB +25°C 40 pF +25°C 85 pF VG=GND, RG=0Ω, CL=1.0nF, See Figure 10 Signal=0dBm, RL = f = 1MHz 50Ω, CL = 5pF, See f = 10MHz Figure 9 CNC(OFF), VNC or VNO=V+/2 or GND, Switch CNO(OFF) OFF See Figure 4 CNC(ON), CNO(ON), VNC or VNO=V+/2 or GND, Switch CCOM(ON) ON See Figure 4 XTALK pC POWER REQUIREMENTS Power Supply Range V+ Power Supply Current I+ FULL VIN = GND or V+ 5.5V 5 FULL 2.5 5.5 V 1 μA www.run-ic.com 010-67713792 sale@starttodo.com.cn RS2118 TYPICAL CHARACTERISTICS BANDWIDTH 3 0 0 Gain(dB) Gain(dB) BANDWIDTH 3 -3 -6 -3 -6 -9 -9 1 10 100 1,000 1 Frequency(MHz) V+=3.3V 10 100 1,000 Frequency(MHz) V+=5V Typical Ron as a Function of Input Voltage (VI ) for VI = 0 to V+ 2.5 2 Ron(Ω) 1.5 1 0.5 0 -2 -1 0 V+=2.5V 1 V+=3.3V 2 3 V+=4V 6 4 V+=5.5V 5 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS2118 Parameter Measurement Information Figure 1.ON-State Resistance (ron) Figure 2.OFF-State Leakage Current (ICOM(OFF), INO(OFF)) Figure 3. ON-State Leakage Current (ICOM(ON), INO(ON)) 7 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS2118 Figure 4. Capacitance (CI, CCOM(OFF), CCOM(ON), CNO(OFF), CNO(ON)) Figure 5.Turn-On (tON) and Turn-Off Time (tOFF) Figure 6.Break-Before-Make Time (tBBM) 8 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS2118 Figure 7. Bandwidth (BW) Figure 8.OFF Isolation (OISO) Figure 9. Crosstalk (XTALK) 9 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS2118 Figure 10. Charge Injection (QC) Figure11.Total Harmonic Distort 10 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS2118 TYPICAL APPLICATION Ensure that the device is powered up with a supply voltage on VCC before a voltage can be applied to the signal paths NC and NO. All unused digital inputs of the device must be held at VCC or GND to ensure proper device operation. Tie the digitally controlled inputs select pins IN1 and IN2 to VCC or GND to avoid unwanted switch states that could result if the logic control pins are left floating. OUT+ Audio Source 1 NC1 OUT– COM1 NO1 IN1 RS2118 COM2 OUT+ OUT– 8Ω-Speaker IN2 NC2 Audio Source 2 Input Select NO2 Figure 12. Typical Application Schematic 11 www.run-ic.com 010-67713792 sale@starttodo.com.cn RS2118 PACKAGE OUTLINE DIMENSIONS QFN-1.4x1.8-10L 1.800± 0.050 0.500± 0.050 0.400± 0.050 0.400 TYP PIN #1 IDEN TIFICATION CH AMFER 0.350 ×45° (×9) 0.800 REF 1.400± 0.050 PIN #1 DOT BY MARKING 0.500± 0.050 0.200± 0.050 TOP VIEW 0.100± 0.050 BOTTOM VIEW 2.100 0.563 0.550± 0.050 1.700 0.203 REF 0.000-0.050 0.663 0.225 SIDE VIEW 0.20 0.40 RECOMMENDED LAND PATTERN 12 www.run-ic.com 010-67713792 sale@starttodo.com.cn
RS2118YUTQK10 价格&库存
很抱歉,暂时无法提供与“RS2118YUTQK10”相匹配的价格&库存,您可以联系我们找货
