RC100M151LO13*17H-8A1C
    BERYL(绿宝石)
    插件,D13xL17mm
    直插铝电解电容 AEC_D13X17MM_TM
RC100M151LO13*17H-8A1C 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RC Series Low impedance ,high ripple current For switching power supply RoHS2.0 Compliant ● ● ● ◆ 规格表 Specifications 项目Items 特性参数Characteristics 使用温度范围 Category Temperature Range 额定工作电压范围 Rated Voltage Range 静电容量允许偏差 -40 ~ +105℃ 6.3 ~ 450V.DC ±20%(M) Capacitance Tolerance 漏电流 Leakage Current (at 20℃,120Hz) I≤0.01CV or 3μA ,二者取大值(施加额定工作电压 2分钟后) Whichever is greater (After 2 minute application of rated voltage ) I≤0.02CV+10(μA) (施加额定工作电压2分钟后) (After 2 minute application of rated voltage ) Note: I=Max,leakage current (μA), C=Nominal capacitance(μF), V=Rated voltage(V) (at 20℃) Rated voltage(V) 6.3 损耗角正切值 tanδ tanδ(Max.) 0.22 10 16 25 Dissipation Factor 标称容量超过1000 μF,则每增加1000 μF,损耗角正切值增加0.02. 0.19 0.16 50 63 100 160 200 250 350 400 450 0.14 0.12 0.10 35 0.09 0.08 0.15 0.15 0.15 0.2 0.2 0.2 When nominal capacitance exceeds 1000μF,add 0.02 to the value above for each 1000μF increase. (at 20℃,120Hz) 低温特性 阻抗比值不得超过下表中列出的值 The impedance ratio shall not exceed the values listed in the below table. Low Temperature Rated voltage(V) 6.3 10 16 25 35 50 63 100 160 Characteristics Z(-25℃)/Z(+20℃) 4 3 3 3 3 2 2 2 3 5 6 (Max.Impedance Ratio) Z(-40℃)/Z(+20℃) 8 6 4 4 4 4 4 4 4 7 8 200 (at 120Hz) 250 350 400 450 在105℃环境中,不超过额定电压的范围内叠加最大允许纹波电流 ,连续加载右表时间,经恢复到20℃后,电容器满足以下各项要求 。 The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple Current is applied for the specified period of time at 105℃ 耐久性 Endurance Capacitance change ≦±20% of the initial value D.F.(tanδ) ≦200% of the initial specified value 6.3~100v Load life Leakage current ≦The initial specified value 160~450v Φ6.3:3000h; ≥Φ8:5000h Φ5~ Φ8 : 2000h; ≥Φ10:3000h 在105℃环境中,不施加电压条件下储存 1000小时,经恢复到20℃后,电容器满足以下各项要求 。 The following specifications shall be satisfied when the capacitors are restored at 20℃ after exposing them 高温储存特性 for 1000 hours at 105℃ without voltage applied. Shelf Life capacitance change D.F.(tanδ) Leakage current ≦±20% of the initial value ≦200% of the initial specified value ≦200% of the initial specified value ◆ 尺寸图(单位:mm)DIMENSIONS (Unit:mm) L± α. Safety Vent (Φ8up) 15min. 5min. ΦD F Φd F±0.5 Vinyl sleeve Rubber end seal Φd±0.05 Tinned copper-ply wire α D±0.5 5 2.0 0.5 6.3 2.5 0.5 (L
RC100M151LO13*17H-8A1C 价格&库存
很抱歉,暂时无法提供与“RC100M151LO13*17H-8A1C”相匹配的价格&库存,您可以联系我们找货
  • 5+1.34752
  • 50+1.08130
  • 200+0.90396
  • 400+0.76162
  • 2400+0.69822
  • 5000+0.66021
